Processing Genesys Cloud EventBridge Dead Letter Queue Events with Java
A Java Spring Boot DLQ processor that retrieves failed EventBridge events, validates retry constraints, executes atomic HTTP POST retries with exponential backoff, synchronizes with external error trackers, and generates governance audit logs. It uses the Genesys Cloud Java SDK and modern HTTP clients. It covers Java 17+ and Spring Boot 3.x.
- OAuth 2.0 Client Credentials flow with scopes
eventbridge:readandeventbridge:write - Genesys Cloud Java SDK v14.0+
- Java 17+ runtime
- Spring Boot 3.2+
- Dependencies:
com.genesyscloud:genesyscloud-java-sdk:14.0.0,com.fasterxml.jackson.core:jackson-databind:2.15.2,org.springframework.boot:spring-boot-starter-web
The Genesys Cloud Java SDK manages token caching and automatic refresh when configured with client credentials. You must initialize PureCloudPlatformClientV2 before invoking any EventBridge API.
import com.genesyscloud.platform.client.Configuration;
import com.genesyscloud.platform.client.PureCloudPlatformClientV2;
import com.genesyscloud.auth.oauth2.api.OAuth2Api;
import com.genesyscloud.auth.oauth2.model.TokenResponse;
import java.util.Map;
public class GenesysAuthConfig {
private static final String REGION = "my.genesys.cloud";
private static final String CLIENT_ID = System.getenv("GENESYS_CLIENT_ID");
private static final String CLIENT_SECRET = System.getenv("GENESYS_CLIENT_SECRET");
public static PureCloudPlatformClientV2 getPlatformClient() {
Configuration config = new Configuration.Builder()
.setRegion(REGION)
.setClientId(CLIENT_ID)
.setClientSecret(CLIENT_SECRET)
.build();
return new PureCloudPlatformClientV2(config);
public static TokenResponse fetchToken(PureCloudPlatformClientV2 client) throws Exception {
OAuth2Api oAuth2Api = new OAuth2Api(client);
Map<String, String> body = Map.of(
"grant_type", "client_credentials",
"scope", "eventbridge:read eventbridge:write"
return oAuth2Api.postOauthToken(body);
The SDK caches the access token and refreshes it automatically before expiration. You do not need to implement manual token rotation unless you are bypassing the SDK.
Step 1: Initialize EventBridge Client and Fetch DLQ Events
You retrieve dead letter queue events using the EventBridgeApi. The endpoint /api/v2/events/eventbridge/dlq/events supports pagination via pageSize and nextPageToken. You must handle 429 rate limits and 401/403 authentication errors.
import com.genesyscloud.events.eventbridge.api.EventBridgeApi;
import com.genesyscloud.events.eventbridge.model.EventBridgeDlqEvent;
import com.genesyscloud.events.eventbridge.model.GetEventsEventbridgeDlqEventsResponse;
import java.util.ArrayList;
import java.util.List;
public class DlgEventFetcher {
private final EventBridgeApi eventBridgeApi;
private static final int PAGE_SIZE = 50;
public DlgEventFetcher(PureCloudPlatformClientV2 client) {
this.eventBridgeApi = new EventBridgeApi(client);
public List<EventBridgeDlqEvent> fetchDlqEvents() throws Exception {
List<EventBridgeDlqEvent> allEvents = new ArrayList<>();
String nextPageToken = null;
do {
GetEventsEventbridgeDlqEventsResponse response = eventBridgeApi.getEventsEventbridgeDlqEvents(
null, null, PAGE_SIZE, nextPageToken, null, null
if (response == null || response.getEntities() == null) {
break;
allEvents.addAll(response.getEntities());
nextPageToken = response.getNextPageToken();
} while (nextPageToken != null);
return allEvents;
Required OAuth Scope: eventbridge:read
Expected Response: A list of EventBridgeDlqEvent objects containing id, eventType, body, retryCount, and dlqRef.
Step 2: Construct Processing Payloads and Validate Schemas
You must parse the event body to extract the dlqRef, errorMatrix, and retryDirective. You then validate the payload against queue constraints and maximum retry limits to prevent processing failure.
public class DlqPayloadValidator {
private static final int MAX_RETRY_COUNT = 5;
private final ObjectMapper mapper = new ObjectMapper();
public ProcessingPayload constructPayload(EventBridgeDlqEvent event) throws Exception {
JsonNode bodyNode = mapper.readTree(event.getBody());
String dlqRef = bodyNode.path("dlqRef").asText();
JsonNode errorMatrix = bodyNode.path("errorMatrix");
JsonNode retryDirective = bodyNode.path("retryDirective");
if (dlqRef.isEmpty()) {
throw new IllegalArgumentException("Missing dlqRef in event payload");
int currentRetries = event.getRetryCount() != null ? event.getRetryCount() : 0;
boolean exceedsLimit = currentRetries >= MAX_RETRY_COUNT;
return new ProcessingPayload(
event.getId(),
dlqRef,
errorMatrix,
retryDirective,
currentRetries,
exceedsLimit
public record ProcessingPayload(
String eventId,
String dlqRef,
JsonNode errorMatrix,
JsonNode retryDirective,
int retryCount,
Schema Validation Rule: The errorMatrix must contain a classification field. The retryDirective must contain a targetEndpoint and method. If either is missing, you reject the payload and log a schema violation.
Step 3: Classify Errors and Evaluate Backoff Strategy
You calculate error classification and exponential backoff based on the errorMatrix. Transient errors (5xx, timeout) trigger retries with backoff. Permanent errors (4xx, malformed payload) trigger immediate poison pill classification.
public class BackoffStrategyEvaluator {
private static final long BASE_DELAY_MS = 1000;
private static final long MAX_DELAY_MS = 60000;
public BackoffResult evaluate(JsonNode errorMatrix, int retryCount) {
String classification = errorMatrix.path("classification").asText("unknown");
int statusCode = errorMatrix.path("statusCode").asInt(500);
boolean isTransient = statusCode >= 500 || classification.equalsIgnoreCase("timeout");
long delayMs = isTransient ? calculateExponentialBackoff(retryCount) : 0;
return new BackoffResult(isTransient, delayMs, classification);
private long calculateExponentialBackoff(int retryCount) {
long delay = BASE_DELAY_MS * (1L << retryCount);
return Math.min(delay, MAX_DELAY_MS);
public record BackoffResult(boolean isTransient, long delayMs, String classification) {}
You enforce the maximum retry count limit by checking ProcessingPayload.exceedsLimit before invoking the backoff evaluator. If the limit is exceeded, you classify the event as a poison pill and skip retry execution.
Step 4: Execute Atomic HTTP POST and Verify Handler Compatibility
You perform an atomic HTTP POST operation to retry the event. You verify handler compatibility by checking the target endpoint response headers. You trigger an automatic purge on success to prevent queue buildup.
import java.net.URI;
import java.nio.charset.StandardCharsets;
import java.time.Duration;
public class AtomicRetryExecutor {
private final HttpClient httpClient = HttpClient.newBuilder()
.connectTimeout(Duration.ofSeconds(10))
.build();
public RetryResult execute(String eventId, String targetEndpoint, JsonNode retryDirective, String bearerToken) throws Exception {
String body = retryDirective.toString();
.uri(URI.create(targetEndpoint))
.header("Authorization", "Bearer " + bearerToken)
.header("X-Genesys-DLQ-Ref", eventId)
.POST(HttpRequest.BodyPublishers.ofString(body, StandardCharsets.UTF_8))
.timeout(Duration.ofSeconds(30))
.build();
boolean handlerCompatible = response.headers()
.firstValue("X-Handler-Compatible")
.map("true"::equalsIgnoreCase)
.orElse(false);
boolean success = response.statusCode() == 200 || response.statusCode() == 202;
return new RetryResult(success, handlerCompatible, response.statusCode(), response.body());
public record RetryResult(boolean success, boolean handlerCompatible, int statusCode, String responseBody) {}
Required OAuth Scope: eventbridge:write
Format Verification: The target endpoint must return a 2xx status code. If the response body contains a purgeTrigger flag, you mark the event for automatic DLQ removal.
Step 5: Synchronize External Trackers and Generate Audit Logs
You synchronize processing events with external error trackers via webhooks. You track processing latency and retry success rates. You generate audit logs for event governance.
import java.time.Instant;
public class DlqAuditSyncService {
private final HttpClient httpClient = HttpClient.newHttpClient();
private final Map<String, Long> latencyTracker = new ConcurrentHashMap<>();
private final Map<String, Integer> retrySuccessTracker = new ConcurrentHashMap<>();
private static final String WEBHOOK_URL = System.getenv("EXTERNAL_TRACKER_WEBHOOK");
public void syncAndAudit(String eventId, long startNano, RetryResult result) throws Exception {
long latencyMs = (System.nanoTime() - startNano) / 1_000_000;
latencyTracker.put(eventId, latencyMs);
retrySuccessTracker.merge(eventId, result.success() ? 1 : 0, Integer::sum);
Map<String, Object> auditPayload = Map.of(
"eventId", eventId,
"timestamp", Instant.now().toString(),
"latencyMs", latencyMs,
"retrySuccess", result.success(),
"handlerCompatible", result.handlerCompatible(),
"statusCode", result.statusCode(),
"auditAction", result.success() ? "RETRY_COMPLETED" : "RETRY_FAILED"
String jsonBody = mapper.writeValueAsString(auditPayload);
HttpRequest webhookRequest = HttpRequest.newBuilder()
.uri(URI.create(WEBHOOK_URL))
.POST(HttpRequest.BodyPublishers.ofString(jsonBody))
.build();
httpClient.send(webhookRequest, HttpResponse.BodyHandlers.ofString());
You expose the DLQ processor as a Spring Boot endpoint to enable automated Genesys Cloud management. The endpoint orchestrates fetching, validation, retry execution, and audit synchronization.
import org.springframework.web.bind.annotation.PostMapping;
import org.springframework.web.bind.annotation.RequestMapping;
import org.springframework.web.bind.annotation.RestController;
@RestController
@RequestMapping("/api/dlq")
public class DlqProcessorController {
private final PureCloudPlatformClientV2 client;
private final DlgEventFetcher eventFetcher;
private final DlqPayloadValidator payloadValidator;
private final BackoffStrategyEvaluator backoffEvaluator;
private final AtomicRetryExecutor retryExecutor;
private final DlqAuditSyncService auditSync;
public DlqProcessorController(PureCloudPlatformClientV2 client) {
this.client = client;
this.eventFetcher = new DlgEventFetcher(client);
this.payloadValidator = new DlqPayloadValidator();
this.backoffEvaluator = new BackoffStrategyEvaluator();
this.retryExecutor = new AtomicRetryExecutor();
this.auditSync = new DlqAuditSyncService();
@PostMapping("/process")
public Map<String, Object> processDlqEvents() throws Exception {
long processStart = System.nanoTime();
List<EventBridgeDlqEvent> events = eventFetcher.fetchDlqEvents();
int processed = 0;
int poisonPills = 0;
int failures = 0;
for (EventBridgeDlqEvent event : events) {
long eventStart = System.nanoTime();
DlqPayloadValidator.ProcessingPayload payload = payloadValidator.constructPayload(event);
if (payload.exceedsLimit()) {
poisonPills++;
auditSync.syncAndAudit(event.getId(), eventStart, new AtomicRetryExecutor.RetryResult(false, false, 410, "Max retries exceeded"));
continue;
BackoffStrategyEvaluator.BackoffResult backoff = backoffEvaluator.evaluate(payload.errorMatrix(), payload.retryCount());
if (!backoff.isTransient() && payload.retryCount() > 0) {
poisonPills++;
continue;
if (backoff.delayMs() > 0) {
Thread.sleep(backoff.delayMs());
String targetUrl = payload.retryDirective().path("targetEndpoint").asText();
String token = GenesysAuthConfig.fetchToken(client).getAccessToken();
AtomicRetryExecutor.RetryResult retryResult = retryExecutor.execute(event.getId(), targetUrl, payload.retryDirective(), token);
auditSync.syncAndAudit(event.getId(), eventStart, retryResult);
if (retryResult.success()) {
processed++;
} else {
failures++;
} catch (Exception e) {
failures++;
auditSync.syncAndAudit(event.getId(), eventStart, new AtomicRetryExecutor.RetryResult(false, false, 500, e.getMessage()));
long totalLatency = (System.nanoTime() - processStart) / 1_000_000;
return Map.of(
"processed", processed,
"poisonPills", poisonPills,
"failures", failures,
"totalLatencyMs", totalLatency
You run this module by deploying it as a Spring Boot application. You configure the environment variables GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET, and EXTERNAL_TRACKER_WEBHOOK. You trigger processing via POST /api/dlq/process.
Error: HTTP 401 Unauthorized
- Cause: OAuth token expired or missing
eventbridge:readscope. - Fix: Verify client credentials. Ensure the token request includes
eventbridge:read eventbridge:write. The SDK refreshes tokens automatically, but manual token fetch calls must re-execute if cached tokens expire. - Code Fix: Catch
ApiExceptionwith status 401 and re-initialize the OAuth flow before retrying.
Error: HTTP 403 Forbidden
- Cause: OAuth application lacks required permissions or the user account associated with the client credentials does not have EventBridge admin rights.
- Fix: Grant the OAuth application the
eventbridge:readandeventbridge:writescopes. Assign the associated user theEventBridge Adminrole in Genesys Cloud.
- Cause: Exceeding the Genesys Cloud API rate limit. DLQ queries return paginated results that can trigger throttling if polled aggressively.
- Fix: Implement exponential backoff on 429 responses. Parse the
Retry-Afterheader from the response. - Code Fix: Wrap
eventFetcher.fetchDlqEvents()in a retry loop that readsRetry-Afterand sleeps before the next request.
Error: Schema Validation Failure (Missing dlqRef)
- Cause: EventBridge payload does not contain the expected
dlqReffield. - Fix: Validate the event schema before processing. Route malformed events to a separate quarantine queue instead of throwing an unhandled exception.
- Code Fix: Add a fallback schema validator that checks for required keys before invoking
constructPayload.
Error: Handler Incompatible Response
- Cause: Target endpoint rejects the retry directive due to version mismatch or unsupported payload format.
- Fix: Verify the
X-Handler-Compatibleheader. If false, log the event and skip retry. Update the retry directive structure to match the target system contract.
