Hi
This are logs at the moment that problem occurs.
GIS Log
17:57:39.308 Dbg 20013 call to login method for default → SessionService:1180133859308H2
17:57:39.495 Dbg 20012 Checking out feature GIS_STATSERVICE in 7260@CTI01: OK
17:57:39.495 Dbg 20012 SessionService:1180133859308H2 → license GIS_STATSERVICE checked
17:59:48.823 Std 04504 Connection to Stat server ‘ReportingStatServer’ at host ‘CTI02’, port 3420 lost
17:59:57.573 Std 04503 Connected to Stat Server ‘ReportingStatServer’ at host ‘CTI02’, port 3420
17:59:57.573 Dbg 20012 SOpenServerEx: ReportingStatServer@CTI02:3420
18:00:18.323 Dbg 20012 retrieveStatistic java.lang.Exception: PeekStat Timout
18:00:18.355 Dbg 20012 retrieveStatistic java.lang.Exception: PeekStat Timout
18:00:18.370 Dbg 20012 retrieveStatistic java.lang.Exception: PeekStat Timout
18:02:20.558 Std 04504 Connection to Stat server ‘ReportingStatServer’ at host ‘CTI02’, port 3420 lost
18:02:26.370 Dbg 20012 retrieveStatistic java.lang.Exception: PeekStat Timout
18:02:26.495 Dbg 20012 retrieveStatistic java.lang.Exception: StatServer out of service
18:02:26.542 Dbg 20012 retrieveStatistic java.lang.Exception: StatServer out of service
StatServer LOG
18:01:22.258 Trc 04541 Message NewAPIGetStat received from 308 ( ‘GIS’)
18:01:22.289 Trc 04541 Message NewAPIGetStat received from 308 ( ‘GIS’)
18:01:24.133 Trc 04541 Message NewAPIGetStat received from 308 ( ‘GIS’)
18:01:24.164 Trc 04541 Message NewAPIGetStat received from 308 ( ‘GIS’)
18:01:46.930 Int 04543 Interaction message “EventReleased” received from 65200 (“TServerAlcatel”)
18:01:53.820 Int 04543 Interaction message “EventOffHook” received from 65200 (“TServerAlcatel”)
18:01:54.289 Trc 04541 Message NewAPIGetStat received from 308 ( ‘GIS’)
18:01:54.305 Trc 04541 Message NewAPIGetStat received from 308 ( ‘GIS’)
18:01:54.320 Trc 04541 Message NewAPIGetStat received from 308 ( ‘GIS’)
18:01:54.508 Int 04543 Interaction message “EventOnHook” received from 65200 (“TServerAlcatel”)
18:01:54.711 Int 04543 Interaction message “EventAgentReady” received from 65200 (“TServerAlcatel”)
18:01:56.164 Trc 04541 Message NewAPIGetStat received from 308 ( ‘GIS’)
Signal 0xC0000005 received
…exception in block [NCO_exec]
----FAULT----05/25/07@18:01:56.1640----
Exception: 5 (0xc0000005) ACCESS_VIOLATION
AddrPC: 005d5c35
AddrFrame: 014632c8
AddrStack: 014632ac
005d5c35 statserv:___sbh_free_block+371(17e4554,22fa9bc,17eda90,22fa710..)
005d22f8 statserv:_free+89(22fab00,1463328,49ce0c,670cc0..)
004a34f8 statserv:_tmemory_pool_free+108(670cc0,22fab00,146333c,49cdaa..)
0049ce0c statserv:_msg_delete+143(22fab00,22fab00,22fab20,1463348..)
0049cdaa statserv:_msg_delete+45(22fa710,1463398,404132,22fa710..)
005bfe7c statserv:_MessageDelete+12(22fa710,22f9070,22f9070,212acb0..)
00404132 statserv:CLIENT::NewAPIStatsHandle+1522(17eda90,22f9070,212acb0,22f8c60..)
.. file N:\statserver\main\client.cpp, line 1867 (disp=0)
00401985 statserv:CLIENT::Message+725(22f9070,146f588,1940cf0,0..)
.. file N:\statserver\main\client.cpp, line 850 (disp=0)
00401611 statserv:CLIENT::Request+193(997e00,146f4d8,4a0e27,212c930..)
.. file N:\statserver\main\client.cpp, line 370 (disp=0)
004a1034 statserv:?conn_do_multi_scan@@YAHHHPAUfd_set@@H@Z+3345(212c930,146f588,1940cf0,1463434..)
004a0e27 statserv:?conn_do_multi_scan@@YAHHHPAUfd_set@@H@Z+2820(790,ffffffff,0,ffffffff..)
004a16c3 statserv:_conn_main_loop+75(118ade8,118d8f8,74617473,76726573..)
00574d30 statserv:_NCO_exec+1177(146f5b8,1,7,146f82c..)
00574a3e statserv:_NCO_exec+423(146f82c,118ade8,118d8f8,74617473..)
00405ab4 statserv:ServerMainLoop+116(145b78,146f8d0,118ade8,1162d90..)
.. file N:\statserver\main\main_m.cpp, line 131 (disp=41)
00405957 statserv:sserver_main+775(9,118ade8,0,9..)
.. file N:\statserver\main\main_m.cpp, line 629 (disp=11)
00574ca8 statserv:_NCO_exec+1041(146f900,0,0,146faac..)
00574a3e statserv:_NCO_exec+423(146faac,9,118ade8,0..)
00573afd statserv:_NCO_main+989(9,118ade8,0,405650..)
00405610 statserv:g_run_app_my+80(9,118ade8,0,146ff84..)
.. file N:\statserver\main\main_m.cpp, line 682 (disp=16)
004055b9 statserv:g_run_app+41(9,118ade8,146fb64,1162d90..)
.. file N:\statserver\main\main_m.cpp, line 690 (disp=15)
00590537 statserv:?main_thread@@YAXPAX@Z+648(0,0,0,1162d90..)
005d8845 statserv:__beginthread+206(1162d90,0,0,1162d90..)
77e6608b kernel32:GetModuleFileNameA+235(5d87ee,1162d90,0,c8..)
-----------END-OF-FAULT-INFO-----------
I think that StatServer goes down when the access violation occurs because I found many small log files around the time of this problem.
Thanks for your help
