Problems with SIPDialog between Genesys SIP Server and Avaya SES
Hi, there is a problem with the blind transfer between GVP and Avaya SES. Sometimes the SIP Dialog isn’t established. Here is the log for a wrong call and a correct call. Can I determine if the caller hang-up?
Wrong call:
@13:16:53.6200 [ISCC] Translate: ‘968641407’ → ‘’; result 1 ()
@13:16:53.6200 [ISCC] Party object is removed: p:0000000000000000,00000000 n::
@13:16:53.6200 [ISCC] Error: No call is associated with the event, skipped
13:16:53.620 Int 04544 Interaction message “EventReleased” generated
13:16:53.620 Trc 04542 EventReleased sent to [596] (0000000e LDServer 10.4.213.50:1547)
13:16:53.620 Trc 04542 EventReleased sent to [584] (0000000d LDServer 10.4.213.50:1546)
13:16:53.620 Trc 04542 EventReleased sent to [572] (0000000c StatServer_CCP_bck 10.4.213.32:2090)
13:16:53.620 Trc 04542 EventReleased sent to [560] (0000000b StatServer_URS_bck 10.4.213.37:1758)
13:16:53.620 Trc 04542 EventReleased sent to [548] (0000000a LDServer_bck 10.4.213.28:2053)
13:16:53.620 Trc 04542 EventReleased sent to [508] (00000007 StatServer_URS 10.4.213.55:4454)
13:16:53.620 Trc 04542 EventReleased sent to [496] (00000006 StatServer_CCP 10.4.213.53:2510)
@13:16:53.6200 [ISCC] Call destroyed:
- c:00be021781d8bd25,01c90ff0 @ m:0000000000000000,00000000 p:0 i:0018c1a6 nw:0000000000000000 t:2
@13:16:53.6200 [ISCC] Call object is removed: c:00be021781d8bd25,00000000
13:16:53.620 – call_info::committed destroyed
13:16:53.620 – deleted call_info_tspp 00be021781d8bd25@01C90FF0
@13:16:53.6200 {tscp.call {destructed} {uuid 6TTMUFO9HP2S7AQVKHQ20US23O04DU5O} {connection-id 00be021781d8bd25} {call-id 1622438}}
13:16:53.620 SipDialog: event DESTROY, t=0, s=10, r=4, m=00000000
13:16:53.620 SipDialog[3594010]:<< Abort ALL <<
@13:16:53.6200 [BSYNC] Trace: Send to backup (SIP_Server_bck) [452]:
Correct call:
@14:01:05.0410 [ISCC] Translate: ‘915127199’ → ‘’; result 1 ()
@14:01:05.0410 [ISCC] Party object is removed: p:0000000000000000,00000000 n::
@14:01:05.0410 [ISCC] Error: No call is associated with the event, skipped
14:01:05.041 Int 04544 Interaction message “EventReleased” generated
14:01:05.041 Trc 04542 EventReleased sent to [596] (0000000e LDServer 10.4.213.50:1547)
14:01:05.041 Trc 04542 EventReleased sent to [584] (0000000d LDServer 10.4.213.50:1546)
14:01:05.041 Trc 04542 EventReleased sent to [572] (0000000c StatServer_CCP_bck 10.4.213.32:2090)
14:01:05.041 Trc 04542 EventReleased sent to [560] (0000000b StatServer_URS_bck 10.4.213.37:1758)
14:01:05.041 Trc 04542 EventReleased sent to [548] (0000000a LDServer_bck 10.4.213.28:2053)
14:01:05.041 Trc 04542 EventReleased sent to [508] (00000007 StatServer_URS 10.4.213.55:4454)
14:01:05.041 Trc 04542 EventReleased sent to [496] (00000006 StatServer_CCP 10.4.213.53:2510)
@14:01:05.0410 [ISCC] Call destroyed:
- c:00be021781d8bfc9,02976780 @ m:0000000000000000,00000000 p:0 i:0018c44a nw:0000000000000000 t:2
@14:01:05.0410 [ISCC] Call object is removed: c:00be021781d8bfc9,00000000
14:01:05.041 – call_info::committed destroyed
14:01:05.041 – deleted call_info_tspp 00be021781d8bfc9@02976780
@14:01:05.0410 {tscp.call {destructed} {uuid 6TTMUFO9HP2S7AQVKHQ20US23O04ECJ4} {connection-id 00be021781d8bfc9} {call-id 1623114}}
14:01:05.041 -----------------------------------------------------------
14:01:05.041 C[1623114]:CF[D[[0]]:SC[2991293]
14:01:05.041 HA: BEGIN SYNC: CALL[1623114] SYNCTYPE[4]: SECOND CALL[0] SYNCTYPE[-1]
14:01:05.041 HA: END SYNC: CALL[1623114] SYNCTYPE[4]: SECOND CALL[0] SYNCTYPE[-1]
@14:01:05.0410 [BSYNC] Trace: Send to backup (SIP_Server_bck) [452]:
You have published a few lines after the very last event (EventReleased). That’s not going to tell us anything about your potential issue.
Fra
To determine if customer hangup please enable proper option in TServer section of SIP Server and look at Extension data attached to Released event
