Problems when original call i disconnected during consult calls (meridian)
Hi !
We have a problem scenario that I want help with.
Environment:
  • Genesys 6.5.303 Tserver for succession with mls-link.
  • Meridian 1, option 81 rel 25.40
Scenario:
  • Agent A recives an inbound call
  • Agent A starts consult call to external number(not sure if this applies to internal calls.
  • Customer on hold hangsup.
Genesys recives disconnect, and agent i in ready state to router which sends a new call to the agent.
Does anyone recognize this problem, and have a solution perhaps?
Regards
Mikael
Does the problem refer to
→ receive another new incoming while
last customer on hold (via router) hangs up during consult call?
(i.e., the second call leg is in progress)
Does the router refer to Nortel ACD or Genesys URS?
In both cases, agent mode is ready after releasing the first ACD call.
Phone/line state Agent mode Remark
Idle Ready Agent ready to receive ACD call
Ringing Ready incomign call arrives
In-used Ready in conversation
By default, agent mode is kept as Ready; the line/phone state is in-used or busy when in conversation.
When the ACD call is released, line / agent modes are changed to Idle/Ready status that will receive next ACD incoming call!
Possible solution is to change agent mode to Not-Ready after establishing conversion.
NB: operation impact is that agent may require to change agent mode to from NotReady to Ready manually.
Be sure that T-server option “no-call-disconnect” is set to no-call-disconnect (3 or 5, T-server / M-link dependent; check T-server manual!); otherwise, call in conversion will be disconnected!
e.g. for Genesys 7.1 T-server for NCS1000
no-call-disconnect
Default Value: 0 (All current calls are disconnected)
Valid Values:
0 All current calls are disconnected.
1 Current ACD calls are not disconnected.
2 Current DN calls are not disconnected.
3 Neither ACD nor DN calls are disconnected.
refer to http://www.sggu.com/smf/index.php/topic,3132.msg12793.html#msg12793 for “no-call-disconnect”
for wrap-up / not ready issue in Nortel environment, please refer to http://www.sggu.com/smf/index.php/topic,2802.msg11270.html#msg11270
Many thanks !
I now see waht I can do to solv it,
but i think that the switch / link / genesys should realize that there still i a call ongoing. :wink:
/ Micke
