Bonjour à vous,
jai un problème avec IWS à chaque connexion
j’ai ce message d’erreur qui s’affiche “Impossible d’enregistre le DN”
Merci d’avance
- Post in English even if as French you hate it… ;D Seriously, at least take that job
- Post logs
Hello to you
I have a problem with IWS EVERY connection
I HAVE THIS Who Error message appears “Can not Save the DN”
Thank you in advance
Provide Full permissions to agents folder to the IWS user group.
Follow the IWS Deployment step by step, mostly the permissions setup.
I copy the file to a host computer that does not issue DN and paste into other computers it works then did declare extension
thank you for your help
