Probleme connection T-server on Switch
Hi guys,
Im trying to connect my T-server on a switch and I am getting the error <> in the interface console.
When I run my Switch, Everything looks fine ((look at the command console)):
Message Beginning***********************************************
C:\Program Files\GCTI\Test Simulator Server Mlink>n_simlink.exe -sw MontrealSwit
ch -ts MontrealTServer -host LABCCSO-VM03 -port 2020 -pass password
MLINK Switch Simulator, Version: 6.5.000.04 (Total DNs<= 4000)
Compiled: Mar 29 2002
Genesys Telecommunications Laboratories, Inc., Copyright 2000 - 2001
Creating equipment from ConfigServer…
(conn_adjust_rlimit) set_sbh_threshold(1016):1
(conn_adjust_rlimit) get_sbh_threshold=1016
Mlink switch simulator Waits for connection to port 9010
…Simulators settings…
port = 9010
console-port = 9011
start-trunk-num = 1210
trunk-num-range = 100
queue-tout = 30
call-duration =
ani-file =
data-file =
…Predictive dialing settings…
probability-answer = 0.100000
probability-no-answer = 0.100000
probability-busy = 0.100000
probability-ans-mach = 0.100000
probability-invalid-num = 0.100000
probability-vacant = 0.100000
probability-num-changed = 0.100000
probability-unknown = 0.100000
probability-no-circuit = 0.100000
probability-fax = 0.100000
tout-answer = 5
tout-no-answer = 5
tout-busy = 5
tout-ans-mach = 5
tout-invalid-num = 5
tout-vacant = 5
tout-num-changed = 5
tout-unknown = 5
tout-no-circuit = 5
tout-fax = 5
MLINK PBX Simulator waits for connection to port 9010 …
END OF MESSAGE********************************
BUT! if you thake a look at this T-Server LOG, I am getting disconnected from the switch. Can someone can see something wrong in this?? Thx
Beginning of the T-SERVER Log********************************
Application name: MontrealTServer
Application type: TServer (1)
Command line: succession_server.exe -host LABCCSO-VM03 -port 2020 -app MontrealTServer -l C:\FLEXlm\license.dat
Host name: LABCCSO-VM03
DST: TZ = 1, timeb = 1
Time zone: 18000, Eastern Standard Time, Eastern Daylight Time
UTC time: 2010-05-07T18:16:41.969
Local time: 2010-05-07T14:16:41.969
Start time (UTC): 2010-05-07T18:16:41
Running time: 0:00:00:00
Host info: Windows 5.2.3790, 2, Service Pack 2, 2.0, 0110, 3
File: (1) C:\Documents and Settings\Administrator\Desktop\Logs\Tserver\Log.20100507_141641_970.log
14:16:41.969 Trc 04112 The Log Output of type ‘C:\Documents and Settings\Administrator\Desktop\Logs\Tserver\Log’ has been created and opened
14:16:41.969 Std 04503 Connected to ConfigServer at LABCCSO-VM03:2020 (appName=MontrealTServer)
@14:16:41.9690 [TCONF] Redundancy Type : ColdStandby
@14:16:41.9690 [TCONF] Main Tenant received: DBID [101], name [Resources]
@14:16:41.9690 [TCONF] Main Switch received: DBID [102], type [AvayaDefinityECS(MV)], name [MontrealSwitch]
@14:16:41.9690 [TCONF] Requesting DNs for the main Switch [MontrealSwitch] …
@14:16:41.9690 [TCONF] Main Switch’s DNs are read. Number: 28
@14:16:41.9690 [ISCC] ISCC initialization started
@14:16:41.9690 [ISCC] Location localLocation/0 is created
@14:16:41.9690 [ISCC] {server localServer {role primary} {created}}
@14:16:41.9690 [ISCC] [connection 011bcfb0] Connection [0]0 is created
@14:16:41.9690 [ISCC] {server localServer {role backup} {role changed}}
@14:16:41.9690 [ISCC] Client location ISCC:00000001@ added
@14:16:41.9690 [ISCC] ISCC initialization finished
@14:16:41.9690 [tsgctm] Creating GctmSwitch Object.
@14:16:41.9690 [tsgctm] GCTM ver 7.6.005.03 started
Tserver for Nortel Communication Server 1000 with SCCS/MLS, Version: 7.6.007.00 Compiled: Jan 17 2008 13:49:01
Genesys Telecommunications Laboratories, Inc., Copyright 1991 - 2008
Build with Framework (GCTM) 7.6.005.03
Build with TServerCommonPart 7.6.008.04
High Availability feature: ON
ISCC feature support: ON
CTI link type(s): TCP/IP
Genesys Common Library SE: 7.5.000.36 C2
TServer Library (TLib): 7.6.000.02 HA
gmessage library: 7.5.000.01
gservice library: 7.5.000.04
gthread library: 7.6.000.00
Config Server support: CfgLib 7.6.000.05
LCA support: LCALib 7.5.000.06
License support: GLMLib 7.5.000.00 MT (FLEXLm 8.3c)
Message Server support: LogLib 7.6.000.00
Nonstop Operation: NSOLib 7.6.000.00 __try/except
SNMP support: MngmLib 7.5.000.01
14:16:41.985 Std 05060 Application started
@14:16:41.9850 [tsgctm] Link [1,s0] created.
@14:16:41.9850 [TCONF] Registering CfgSwitch tenant=101
@14:16:41.9850 [TCONF] Registering CfgDN tenant=101
@14:16:41.9850 [TCONF] Registering CfgApplication tenant=101
@14:16:41.9850 [TCONF] Registering CfgHost tenant=0
@14:16:41.9850 [TCONF] Registering CfgTenant tenant=0
@14:16:41.9850 [TCONF] Registering CfgAgentLogin tenant=101
@14:16:41.9850 [gctm] Address [6660,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6661,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6662,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6650,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6001,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6002,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6003,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6004,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6005,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6006,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6007,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6008,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6601,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6602,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6009,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6010,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6011,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6012,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6013,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6014,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6015,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [6016,tUNK,sUNK] created.
@14:16:41.9850 [tsgctm] Ignoring config for Access Resource 6
@14:16:41.9850 [gctm] Address [6,tUNK,sUNK] created.
@14:16:41.9850 [gctm] AgentLogin [6,id,sUNK] created.
@14:16:41.9850 [gctm] Address [7,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [8,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [9,tUNK,sUNK] created.
@14:16:41.9850 [gctm] Address [10,tUNK,sUNK] created.
TServer list
list <+>
compatibility-port = 0
management-port = 0
license list <+>
num-of-licenses = 500 <+>
num-sdn-licenses = 200 <+>
tenant-profile list <+>
check-tenant-profile = false
@tenant-name = ‘Resources’ <+>
@tenant-password = NULL
server-id = 110 <D+>
customer-id = NULL
@location = ‘MontrealSwitch’ <+>
background-processing = false
background-timeout = ‘60 msec’
extrouter list <+>
reconnect-tout = ‘5 sec’
request-tout = ‘20 sec’
timeout = ‘1 min’ <+>
report-connid-changes = false
match-call-once = true
network-request-timeout = ‘20 sec’
use-data-from = active
tcs-use = never
tcs-queue = NULL
cast-type = ‘route direct-callid reroute direct-uui direct-ani direct-notoken dnis-pool direct-digits pullback route-uui direct-network-callid’
register-tout = ‘2 sec’
register-attempts = 5
default-dn = NULL
route-dn = NULL
dn-for-unexpected-calls = NULL
use-implicit-access-numbers = false
direct-digits-key = ‘CDT_Track_Num’
cdt-udata-key – alias for direct-digits-key
resource-load-maximum = 0
resource-allocation-mode = circular
cof-feature = false
cof-ci-req-tout = ‘500 msec’
cof-rci-tout = ‘10 sec’
cof-ci-wait-all = false
cof-ci-defer-delete = ‘0’
cof-ci-defer-create = ‘0’
event-propagation = list
inbound-translator-%d array
backup-sync list
sync-reconnect-tout = ‘20 sec’
protocol = ‘default’
addp-timeout = 0
addp-remote-timeout = 0
addp-trace = ‘off’
@server-name = ‘MontrealTServer’ <+>
consult-user-data = inherited <+>
user-data-limit = 16000
merged-user-data = main-only
merge-consult-data – alias for merged-user-data
ani-distribution = inbound-calls-only
call-cleanup list
notify-idle-tout = ‘0’
cleanup-idle-tout = ‘0’
periodic-check-tout = ‘10 min’
agent-reservation list <+>
request-collection-time = ‘100 msec’
reservation-time = ‘10 sec’ <+>
reject-subsequent-request = true
link-timeout = 2000
response-timeout = 15000
link-type = symposium
max-attempts-to-register = 10
no-call-disconnect = 0
acw-by-request-only = false
mute-xfer-method = 2step
make-call-manner = semi-polite
set-dnis-from-dest = false
rls-consult-rtv = immediately
nrdy-after-login = true
cdn-cabq-timeout = 5000
out-of-service-retry-interval = 900000
update-login-on-err = true
delete-external-call-timeout = 30000
routing-state-timeout = 600000
scu-emerg-type = 0xc
uudata-attach-type = none
callpilot-dn-range = NULL
enable-consult-swap = false
default-agent-id-is-position = false
soft-tacw-support = false
soft-wrap-up-time = ‘0’
set-discovery = false
link-%d-name array <+>
link-tcp [1] list {aux} <+>
protocol (uf:-1) = tcp <+>
hostname (uf:2) = ‘LABCCSO-VM03’ <+>
port (uf:2) = 6000 <+>
link$id -c (uf:-2) = 1
host-id = ‘Lanlink’
customer-number = 0
mail-name = NULL
application-id = NULL
poll-interval = 0
log-trace-flags = 0x6C00000 = +iscc +cfg$dn -cfgserv +passwd +udata -devlink -sw -req -callops -conn -client
backup-server-%d array
remote-server-%d array
AgentLogin array
client-appl-%d array
DN array
[144] dn = ‘6660’ type = EXT xtype = RouteDN cfgtype = 4 reg-mode = 0x1 = +force
[145] dn = ‘6661’ type = EXT xtype = RouteDN cfgtype = 4 reg-mode = 0x1 = +force
[146] dn = ‘6662’ type = EXT xtype = RouteDN cfgtype = 4 reg-mode = 0x1 = +force
[148] dn = ‘6001’ type = EXT xtype = DN cfgtype = 1 reg-mode = 0x21 = +force
[149] dn = ‘6002’ type = EXT xtype = DN cfgtype = 1 reg-mode = 0x21 = +force
[150] dn = ‘6003’ type = EXT xtype = DN cfgtype = 1 reg-mode = 0x21 = +force
[151] dn = ‘6004’ type = EXT xtype = DN cfgtype = 1 reg-mode = 0x21 = +force
[152] dn = ‘6005’ type = EXT xtype = DN cfgtype = 1 reg-mode = 0x21 = +force
[153] dn = ‘6006’ type = EXT xtype = DN cfgtype = 1 reg-mode = 0x21 = +force
[154] dn = ‘6007’ type = EXT xtype = DN cfgtype = 1 reg-mode = 0x21 = +force
[155] dn = ‘6008’ type = EXT xtype = DN cfgtype = 1 reg-mode = 0x21 = +force
[156] dn = ‘6601’ type = EXT xtype = Queue cfgtype = 3 reg-mode = 0x1 = +force
[157] dn = ‘6602’ type = EXT xtype = Queue cfgtype = 3 reg-mode = 0x1 = +force
[158] dn = ‘6009’ type = EXT xtype = DN cfgtype = 1 reg-mode = 0x21 = +force
[159] dn = ‘6010’ type = EXT xtype = DN cfgtype = 1 reg-mode = 0x21 = +force
[160] dn = ‘6011’ type = EXT xtype = DN cfgtype = 1 reg-mode = 0x21 = +force
[161] dn = ‘6012’ type = EXT xtype = DN cfgtype = 1 reg-mode = 0x21 = +force
[162] dn = ‘6013’ type = EXT xtype = DN cfgtype = 1 reg-mode = 0x21 = +force
[163] dn = ‘6014’ type = EXT xtype = DN cfgtype = 1 reg-mode = 0x21 = +force
[164] dn = ‘6015’ type = EXT xtype = DN cfgtype = 1 reg-mode = 0x21 = +force
[165] dn = ‘6016’ type = EXT xtype = DN cfgtype = 1 reg-mode = 0x21 = +force
[167] dn = ‘6’ type = IVR/Pos xtype = Position cfgtype = 2 reg-mode = 0x21 = +force
[168] dn = ‘7’ type = N/A xtype = Other cfgtype = 10 reg-mode = 0x1 = +force
[169] dn = ‘8’ type = N/A xtype = EMail cfgtype = 24 reg-mode = 0x1 = +force
[170] dn = ‘9’ type = N/A xtype = Other cfgtype = 25 reg-mode = 0x1 = +force
[171] dn = ‘10’ type = EXT xtype = DN cfgtype = 7 reg-mode = 0x1 = +force
DN/EXR array
[-1] cdn = ‘direct’ type = N/A reg-mode = 0x0 =
access-list array
linked-resources array
[147] *cdn = ‘6650’ type = EXT xtype = RouteDN cfgtype = 19 reg-mode = 0x1 = +force
access-list array
[166] *cdn = ‘6’ type = N/A xtype = AcResource cfgtype = 31 reg-mode = 0x1 = +force
access-list array
@14:16:42.0000 [TCONF] Connecting to LCA at port 4999…
Open LCALayer on port=4999
LCA Library version 7.5.000.06
GLM_CO(tserver_sdn:switch_102,200,1)=0 count=200
14:16:42.016 Std 07101 Feature ‘tserver_sdn’: 200 licenses checked out
LICENSE: seat=200
GLM_CO(tserver_iscc:switch_102,1,1)=0 count=1
14:16:42.016 Std 07101 Feature ‘tserver_iscc’: 1 licenses checked out
14:16:42.016 {listener-set.0087ce00 {initialize}}
14:16:42.016 {listener-set.0087ce00 {on-port-created {port-id default}}}
14:16:42.016 {listener.01219bb8 {created} {port-id default}}
14:16:42.016 {listener.01219bb8 {open}}
@14:16:42.0160 [TSCP] Debug: Port parameters: (“protocol”=“addp”,“addp-timeout”=“0”,“addp-remote-timeout”=“0”,“addp-trace”=“off”,“name”=“MontrealTServer”,“server-type”=“1”,“backlog”=“5”,“port”=“3000”,“id”=“default”,“name”="TLib:7.6.000.02 HA
14:16:42.016 Std 04525 Port 3000 opened for listening
14:16:42.016 {listener.01219bb8 {open complete} {socket 1724}}
14:16:42.016 {listener-set.0087ce00 {on-port-created complete}}
14:16:42.016 {listener-set.0087ce00 {initialize complete}}
@14:16:42.0160 [ISCC] ISCC configuration started
@14:16:42.0160 [ISCC] {server localServer {role primary} {role changed}}
@14:16:42.0160 [ISCC] Broadcast to all connected servers: message ISCCEventServerRoleChanged
ISCCAttributeServerRole Primary
@14:16:42.0160 [ISCC] Server node location MontrealTServer@MontrealSwitch added
@14:16:42.0160 [ISCC] Resource (xrp) direct created
@14:16:42.0160 [ISCC] Resource (xrp) 6650 created
@14:16:42.0160 [ISCC] Resource 6650: created
@14:16:42.0160 [ISCC] Resource 6650: added
@14:16:42.0160 [ISCC] Resource 6650: enabled
@14:16:42.0160 [ISCC] Resource (access resource) 6 created
@14:16:42.0160 [ISCC] Resource 6: created
@14:16:42.0160 [ISCC] Resource 6: added
@14:16:42.0160 [ISCC] Resource 6: enabled
@14:16:42.0160 [ISCC] ISCC configuration finished
@14:16:42.0160 [ISCC] ISCC enable started
@14:16:42.0160 [ISCC] ISCC enable finished
@14:16:42.0160 [tsgctm] Switch [sUNK] STARTING ALL LINKS
@14:16:42.0310 [tsgctm] Link [1,s0] start
(link_start) link [1] ‘link-tcp’ start
(tcp_start) connecting to LABCCSO-VM03:6000… contacted on socket [1716]
@14:16:42.0310 [tsgctm] Link [1,s0] Changing state to 1
14:16:42.031 Std 05061 Initialization completed
LCA_set_AppLiveStatus(APP_STATUS_SERVICE_UNAVAILABLE)
14:16:42.031 Trc 04541 Registered received from 1856 (CfgServer)
LCALayer: REventRegistered on LCA…
AgentLogin array <+>
[117] login-id = ‘1601’ <+>
[118] login-id = ‘1602’ <+>
[119] login-id = ‘1603’ <+>
[120] login-id = ‘1604’ <+>
[121] login-id = ‘1605’ <+>
[122] login-id = ‘1606’ <+>
[123] login-id = ‘1607’ <+>
[124] login-id = ‘1608’ <+>
[125] login-id = ‘1609’ <+>
[126] login-id = ‘1610’ <+>
[127] login-id = ‘1611’ <+>
[128] login-id = ‘1612’ <+>
[129] login-id = ‘1613’ <+>
[130] login-id = ‘1614’ <+>
[131] login-id = ‘1615’ <+>
[132] login-id = ‘1616’ <+>
@14:16:42.0310 [TCONF] Main Switch’s Agent Logins are read. Number: 16
@14:16:42.0310 [TCONF] Configuration is fully initialized
(tcp_except_handler) disconnected on socket [1716]
@14:16:42.9690 [tsgctm] Link [1,s1] Changing state to 0
@14:16:42.9690 [tsgctm] Link [1,s0] Rx DOWN_PACKET
@14:16:42.9690 [tsgctm] Link [1,s0] stop
@14:16:42.9690 [tsgctm] LinkReg [1, act=0] clearAll
@14:16:42.9690 [tsgctm] Link [1,s0] Changing state to 0
(link_stop) link [1] ‘link-tcp’ stop
(tcp_stop) closed on [1716]
@14:16:42.9690 [tsgctm] Link [1,s0] Rx STOPPED_PACKET
(tcp_stop) nothing to close
@14:16:44.9690 [tsgctm] Link [1,s0] restart timer expired. Opening link.
@14:16:44.9690 [tsgctm] Link [1,s0] start
@14:16:44.9690 [tsgctm] Link [1,s0] Changing state to 1
@14:16:45.8750 [tsgctm] Link [1,s1] Changing state to 0
@14:16:45.8750 [tsgctm] Link [1,s0] Rx DOWN_PACKET
@14:16:45.8750 [tsgctm] Link [1,s0] stop
@14:16:45.8750 [tsgctm] LinkReg [1, act=0] clearAll
@14:16:45.8750 [tsgctm] Link [1,s0] Changing state to 0
@14:16:45.8750 [tsgctm] Link [1,s0] Rx STOPPED_PACKET
@14:16:47.8750 [tsgctm] Link [1,s0] restart timer expired. Opening link.
@14:16:47.8750 [tsgctm] Link [1,s0] start
@14:16:47.8750 [tsgctm] Link [1,s0] Changing state to 1
@14:16:48.7970 [tsgctm] Link [1,s1] Changing state to 0
@14:16:48.7970 [tsgctm] Link [1,s0] Rx DOWN_PACKET
@14:16:48.7970 [tsgctm] Link [1,s0] stop
@14:16:48.7970 [tsgctm] LinkReg [1, act=0] clearAll
@14:16:48.7970 [tsgctm] Link [1,s0] Changing state to 0
@14:16:48.7970 [tsgctm] Link [1,s0] Rx STOPPED_PACKET
@14:16:50.7970 [tsgctm] Link [1,s0] restart timer expired. Opening link.
@14:16:50.7970 [tsgctm] Link [1,s0] start
@14:16:50.7970 [tsgctm] Link [1,s0] Changing state to 1
@14:16:51.7190 [tsgctm] Link [1,s1] Changing state to 0
@14:16:51.7190 [tsgctm] Link [1,s0] Rx DOWN_PACKET
@14:16:51.7190 [tsgctm] Link [1,s0] stop
@14:16:51.7190 [tsgctm] LinkReg [1, act=0] clearAll
@14:16:51.7190 [tsgctm] Link [1,s0] Changing state to 0
@14:16:51.7190 [tsgctm] Link [1,s0] Rx STOPPED_PACKET
@14:16:53.7190 [tsgctm] Link [1,s0] restart timer expired. Opening link.
@14:16:53.7190 [tsgctm] Link [1,s0] start
@14:16:53.7190 [tsgctm] Link [1,s0] Changing state to 1
@14:16:53.7350 — Shutdown triggered by SIGBREAK signal
@14:16:53.7350 [tsgctm] Link [1,s1] stop
@14:16:53.7350 [tsgctm] LinkReg [1, act=0] clearAll
@14:16:53.7350 [tsgctm] Link [1,s1] Changing state to 0
14:16:54.250 {listener-set.0087ce00 {close}}
14:16:54.250 {listener.01219bb8 {close}}
14:16:54.250 {listener.01219bb8 {close complete}}
14:16:54.250 {listener-set.0087ce00 {close complete}}
@14:16:54.2500 [ISCC] ISCC disable started
@14:16:54.2500 [ISCC] ISCC disable finished
@14:16:54.2500 [BSYNC] Trace: Shutdown
@14:16:54.2500 [tsgctm] Link [1,s0] stop
@14:16:54.2500 [tsgctm] LinkReg [1, act=0] clearAll
@14:16:54.2500 [tsgctm] Link [1,s0] Changing state to 0
@14:16:54.2500 [tsgctm] Link [1,s0] deleting.
@14:16:54.2500 [gctm] Address [10,tDN,sUNK] deleting.
@14:16:54.2500 [gctm] AgentLogin [6,id,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6,tDN,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6001,tDN,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6002,tDN,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6003,tDN,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6004,tDN,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6005,tDN,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6006,tDN,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6007,tDN,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6008,tDN,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6009,tDN,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6010,tDN,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6011,tDN,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6012,tDN,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6013,tDN,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6014,tDN,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6015,tDN,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6016,tDN,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6601,tQ,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6602,tQ,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6650,tRP,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6660,tRP,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6661,tRP,sUNK] deleting.
@14:16:54.2500 [gctm] Address [6662,tRP,sUNK] deleting.
@14:16:54.2500 [gctm] Address [7,tVIR,sUNK] deleting.
@14:16:54.2500 [gctm] Address [8,tVIR,sUNK] deleting.
@14:16:54.2500 [gctm] Address [9,tVIR,sUNK] deleting.
@14:16:54.2500 [gctm] GCTM shutdown complete.
@14:16:54.2500 [ISCC] ISCC termination started
@14:16:54.2500 [ISCC] Resource 6: removed
@14:16:54.2500 [ISCC] Resource 6: deleted
@14:16:54.2500 [ISCC] Resource 6650: removed
@14:16:54.2500 [ISCC] Resource 6650: deleted
@14:16:54.2500 [ISCC] Location MontrealTServer@MontrealSwitch/0 is removed
@14:16:54.2500 [ISCC] {server MontrealTServer@MontrealSwitch {role backup} {role changed}}
@14:16:54.2500 [ISCC] [connection 011bcfb0] Connection [0]0 is removed
@14:16:54.2500 [ISCC] [connection 011bcfb0] disconnected [0]0
@14:16:54.2500 [ISCC] {server MontrealTServer@MontrealSwitch {role backup} {removed}}
@14:16:54.2500 [ISCC] Location object MontrealTServer@MontrealSwitch/0/0 is removed
@14:16:54.2500 [ISCC] Location MontrealSwitch/0 is removed
@14:16:54.2500 [ISCC] Location object MontrealSwitch/0/0 is removed
@14:16:54.2500 [ISCC] Location ISCC:00000001@/0 is removed
@14:16:54.2500 [ISCC] Location object ISCC:00000001@/0/0 is removed
@14:16:54.2500 [ISCC] ISCC termination finished
14:16:54.250 Std 05063 Normal termination
14:16:54.281 Trc 04109 Logging service stopped
Your issue is caused by wrong configuration of switch port. Based on the log, TServer is trying to connect to port 6000 on LABCCSO-VM03 host
@14:16:42.0310 [tsgctm] Link [1,s0] start (link_start) link [1] 'link-tcp' start (tcp_start) connecting to LABCCSO-VM03:[b]6000[/b]... contacted on socket [1716] @14:16:42.0310 [tsgctm] Link [1,s0] Changing state to 1
but switch simulator uses port 9010
>> MLINK PBX Simulator waits for connection to port [b]9010[/b] ...
I found another configuration issue - incorrect switch type in CME. You use TServer for Meridian but configured switch type (switching office) is Avaya.
@14:16:41.9690 [TCONF] Main Switch received: DBID [102], [b]type [AvayaDefinityECS(MV)][/b], name [MontrealSwitch]
Very nice for the hints!
Ive reinstalled everything to match with a nortel system. But now, when i am starting the switch, i am getting a very Random port… Look at this.
LOG START****
port = 4488264
console-port = 4801
queue-tout = 30
call-duration =
ani-file =
data-file =
tout-answer = 5
tout-no-answer = 5
tout-busy = 5
tout-ans-mach = 5
tout-vacant = 5
tout-unknown = 5
tout-no-circuit = 5
tout-fax = 5
MLINK PBX Simulator waits for connection to port 4488264 …
LOG ENDS****
Is there a way to overide this port number to the port i’ve configured in my T-server?
Allright!
I’ve found the problem. I’ve change the port number via the annex tab in the MontrealSwitch and now the T-server is connecting fine on the Switch.
