Problem with Genesys Studio
When I open any block and edit the JSP code in it, close it and try to edit again - my changes are lost. Studio Version 7.5.0.31.
Can some one help. System is Windows XP with Service Pack 3. I found a solution in the genesys support site
http://solutionsearch.genesyslab.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=1176262011&sliceId=1&docTypeID=DT_SOLUTION_1_1&dialogID=3220567&stateId=0%200%203218792
which is to uninstall windows security patch KB918118, but I can’t find that particular patch may be 'coz my system’s got SP 3..
Thanks in Advance..
Okay.. I downloaded an older version of riched20.dll into the directory where my Studio.exe is and it works now.
Attached is the zipped dll file.
Thanks.
