Problem with CPD server
I am trying to place a test callover the CPD server from a Outbound campaign and I am seeing this error:
“state disconnected, dtiB1T8: 0x547 - ‘Congestion on the line’ ( GC_DM3CC_LIB: 0x22a - ‘Network congestion’ )”
Below is the excerpt from the CPD log
Appreciate your guidance.
     04:29:11.0530 ThID:  3420 ReqID:        113: making a call to '7047591205'
     04:29:11.0530 ThID:  3420 ReqID:        113: license consumed, 2 in use
     04:29:11.0530 ThID:  3420 ReqID:        113: reusing DM3 data channel: dtiB1T8
     04:29:14.0210 ThID:  3420 ReqID:        113: getting DM3 voice channel handle for dtiB1T8
     04:29:14.0210 ThID:  3420 ReqID:        113: DM3 voice channel handle for dtiB1T8 is dxxxB6C1
     04:29:14.0210 ThID:  3420 ReqID:        113: primary server info: ("host"="s-prd-irv-sm-1","port"=3000,"protocol"="addp","addp-timeout"=60,"addp-remote-timeout"=90,"addp-trace"="both")
     04:29:14.0210 ThID:  3420 ReqID:        113: queue is NULL
     04:29:14.0210 ThID:  3420 ReqID:        113: Queue type unknown
     04:29:14.1440 ThID:  3420 ReqID:        113: invoking gc_MakeCall: dtiB1T8
     04:29:18.1470 ThID:  3420 ReqID:        113: event 0x826 received: dtiB1T8
     04:29:18.1470 ThID:  3420 ReqID:        113: event 0x826, call state disconnected: dtiB1T8
     04:29:18.1470 ThID:  3420 ReqID:        113: state disconnected, dtiB1T8: 0x547 - 'Congestion on the line' ( GC_DM3CC_LIB: 0x22a - 'Network congestion' )
     04:29:18.2240 ThID:  3420 ReqID:        113: out of service counter set to 1: dtiB1T8
     04:29:18.2710 ThID:  3420 ReqID:        113: event 0x805 received: dtiB1T8
     04:29:18.2710 ThID:  3420 ReqID:        113: gc_DropCall successful completion: dtiB1T8
     04:29:18.2710 ThID:  3420 ReqID:        113: event 0x859 received: dtiB1T8
     04:29:18.2710 ThID:  3420 ReqID:        113: gc_ReleaseCall successful completion: dtiB1T8
     04:29:18.2710 ThID:  3420 ReqID:        113: license released, 1 in use
     04:29:18.2710 ThID:  4944 ReqID:        113: data channel released: dtiB1T8
     04:29:18.2710 ThID:  4944 ReqID:        113: release channel notification sent: dtiB1T8, client id 81476, request id 113
04:29:18.348 Trc 04542 Message Rsp_CallProgress sent to 81476 ( ‘ocs-irv-p’)
04:29:18.348 Trc 11005 CPDServerMessage: Rsp_CallProgress
BAttr_Extensions
‘GSW_RECORDING_REFERENCE’ ‘0000000000’
‘GSW_DIALING’ ‘04:29:14.144’
‘GSW_RINGING’ ‘04:29:14.144’
‘GSW_ANSWERED’ ‘’
‘GSW_CPD_COMPLETED’ ‘’
‘GSW_BEEP_COMPLETED’ ‘’
‘GSW_TRANSFER_INITIATED’ ‘’
‘GSW_QUEUED’ ‘’
‘GSW_AGENT_ANSWERED’ ‘’
‘GSW_TRANSFER_COMPLETED’ ‘’
‘GSW_RELEASED’ ‘04:29:18.224’
‘GSW_CPDFILE’ ‘cpd_’
‘GSW_CONVFILE’ ‘conv_’
‘GSW_CURRENT_TIME’ ‘04:29:18.224’
IAttr_ErrorCode No error
IAttr_CallStatus Error during making a call
IAttr_CallProgress General Error
IATRCFG_REQUESTID 113
SDServer::sendChReleasedMessage: Message has been sent to client ocs-irv-p 81476.
04:29:18.348 Trc 11005 CPDServerMessage: Rsp_ChannelsReleased
BAttr_Extensions
‘GSW_DialingChannels’ 1
IAttr_CallStatus No status
-AP[7]->-684 @04:29:23.5410
-Ap[7]-<-684 @04:29:23.5410
-AP[10]->-80500 @04:29:44.9930
-Ap[10]-<-80500 @04:29:44.9930
-AP[7]-<-684 @04:29:52.5660
-Ap[7]->-684
I used PSTNDemo utility to place a call and also get similar error, I am suspecting Dialogic card issue. I am novice at this :frowning:
04:58:57.251 APP Channel 1 Calling 17047591205
04:58:57.251 APP dtiB1T1 gc_MakeCall( 17047591205 ) OK
04:59:01.282 EVT dtiB1T1 GCEV_DISCONNECTED due to Network congestion
04:59:01.282 APP dtiB1T1 gc_DropCall()
04:59:01.313 EVT dtiB1T1 GCEV_DROPCALL
04:59:01.313 APP dtiB1T1 gc_ReleaseCall()
04:59:01.313 EVT dtiB1T1 GCEV_RELEASECALL
04:59:01.313 APP dxxxB1C1 dx_listen(95)=0
04:59:01.313 APP dtiB1T1 dt_listen(96)=0
Does it sync? Can you dial with the Dialogic tools?
Thanks cavagnaro for your reply
I used the PSTNDemo utility that I had got from Genesys support some time back that could not dial out
Got the error GCEV_DISCONNECTED due to Network congestion
I will look around on the server for other utiliy on the server, Appreciate if you can suggest any utility. I am a novice as far as Dialogic goes.
Hum..well that indicates that it is not a Genesys issue but a Dialogic configuration, you must be sure that your T1/E1 is correctly configured and synchronized.
The phone line guy is away will check with him Monday, Asking some one to get in Server room to check if the T1 is still plugged in :slight_smile:
there is a Dialogic utility (lineadmin, as far as I recall) that you can use to check for the line status
Thanks @fnunezsa for your reply!!
I ran the line admin as
lineadmin -board 0
The lineadmin window came up with “Line In/OutService” 01 02 03 04 all four green with a check mark in the box
Transmit Alarms are all unchecked
Does this mean lines are ok?
What about the “alarm status”?
I am attaching the image of lineadmin
Thank you very much!!!
Based on the provided screenshot I believe there is something wrong with your first 2 E1 lines as the DChannel is only green for the last 2 E1 line.
In order to prove this, I’d disable the first 2 folders in CME (dt1B1 and dt1B2), restart CPD Server and re-test.
