Problem with Composer - eclipse juno
Hello good afternoon, I have a problem and I would appreciate it if you could help me solve it:
I have a simple strategy that routes agent made in Composer but at the moment of validating the development I get the following error:
cvc-complex-type.3.2.2: Attribute ‘resolveid’ is not allowed to appear in element ‘xi: include’. IPD_default_defaultWorkflow.scxml / Agent / src-gen line 103 Validation Message[/b]
Refers to: IPD_default_defaultWorkflow.scxml
Description:
cvc-complex-type.3.2.2: Attribute ‘resolveid’ is not allowed to appear in element ‘xi:include’. IPD_default_defaultWorkflow.scxml /Agente/src-gen line 103 Validation Message
Error Code: (highlighted in yellow)
<?xml version="1.0" encoding="utf-8"?>
<script><xi:include href="../include/common.js" parse="text"/></script>
<script><xi:include href="../include/DataAccess.js" parse="text"/></script>
<script><xi:include href="../include/RouteFeature.js" parse="text"/></script>
<script><xi:include href="../include/IrdEnumMapper.js" parse="text"/></script>
<script><xi:include href="../include/StringManipulation.js" parse="text"/></script>
<script><xi:include href="../include/DateTime.js" parse="text"/></script>
<script><xi:include href="../include/ListManipulation.js" parse="text"/></script>
<script><xi:include href="../include/MiscIRDFunctions.js" parse="text"/></script>
<!-- SCXML code generated by Composer 8.1.400.21 -->
<!-- Diagram created/upgraded by Composer: Composer 8.1.400.21 -->
<!-- Project version: 8.1.400.21 -->
<!-- Diagram version: 1.0 CreatedOn:  -->
<!-- Application Author:  -->
<state id="_composer_globalstate" initial="_composer_parallel">
	<datamodel>
		<data id="system" expr="new Object()"/>
		<data id="context_management_services_url"/>
		<data id="context_management_services_username"/>
		<data id="context_management_services_password"/>
		<data id="ors_url"/>
		<data id="grat_server" />
		<data id="grat_username" />
		<data id="grat_password" />
		<data id="grat_tenant" />
	</datamodel>
	<parallel id="_composer_parallel">
		<onentry>
			<script>
				<!-- Global Variables declarations -->
				var system = new Object();
				system.SessionID = undefined;
				system.uncaughtApplicationEvents = [];
				_data.system.context = system;
				<!-- Deprecated variables START -->
				<!-- Do not use them in your diagrams -->
				var App_Name = 'defaultWorkflow';
				var App_BaseURL = getBaseURL();
				var App_RelativePathURL = getRelativePathURL();
				var InteractionID;
				var CallID;
				var DNIS;
				var ThisDN;
				var ANI;
				var TenantID;
				var Tenant_Name;
				var App_Last_Error_Event;
				var App_Last_Error_Event_Name;
				var App_Last_Error_Description;
				var App_StartEvent;
				<!-- Deprecated variables END -->
			</script>
			<log expr="'RelativePathURL = ' + getRelativePathURL()" />
		</onentry>
		<!-- User application leg -->
		<state id="_composer_application" initial="_composer_init">
			<!-- Initial state of the application leg, just wait for the application.start event -->
			<state id="_composer_init">
				<onentry>
					<log expr="'Application initialized'"/>
				</onentry>
				<transition event="application.start" target="_composer_start"/>
			</state>
			<!-- Start state of the application leg, the application.start event is caught,
				the workflow SCXML can now be run-->
			<state id="_composer_start" initial="defaultWorkflow">
				<onentry>
					<script>
						setSystemVarsForEffectiveIxnId(system);
						TenantID = system.TenantID;
						Tenant_Name = system.TenantName;
						CallID = system.CallID;
						DNIS = system.DNIS;
						ANI = system.ANI;
					</script>
					<if cond="typeof system.InteractionID != 'undefined'">
						<log expr="system.Type + ' Interaction ' + system.InteractionID + ' processing'"/>
					<else/>
						<log expr="'Interaction less processing'"/>
					</if>
				</onentry>
				<state id="defaultWorkflow" initial="defaultWorkflow._composer_entry">
					<!-- include workflow scxml -->
					<xi:include href="default.scxml" parse="xml" resolveid="defaultWorkflow" xpointer="_composer_entry" />
					<transition event="done.state.defaultWorkflow._composer_entry" target="_composer_global_exit" />
				</state>
			</state>
			<!-- application.exit is caught, that means it was not caught by the underlying workflow SCXML,
			so we fall back on default behavior which is to stop the application (and the session) -->
			<transition event="application.exit" target="_composer_global_exit"/>
			<!-- store uncaught application events. those events might be processed by the system handler. -->
			<transition event="*">
				<log expr="_event.name + ' event received in user application thread ' + _event.toSource()"/>
				<script>storeUnhandledEvent();</script>
			</transition>
		</state>
		<!-- Event Handler leg -->
		<state id="_composer_event_handler">
			<onentry>
				<log expr="'Waiting for events'"/>
			</onentry>
			<!-- The Event Handler leg catches and processes 'system' events (by default) & any user defined event.
			When an event is received, it never transitions out to a target state.
			So this state remains active until the user application leg is finished. -->
			<transition event="error.notallowed" cond="_data.keepGVPSessionAlive==true">
				<log expr="'*** Received error.notallowed event in IPD. Ignoring the error.notallowed event ***'"></log>
			</transition>
			<transition event="interaction.added" cond="typeof system.SessionID == 'undefined'">
<!-- Global Exit state -->
<final id="_composer_global_exit">
	<onentry>
		<log expr="'Reached Final global exit state for application. Session will terminate now.'" />
	</onentry>
</final>
Thank you very much for your help and / or suggestions
Which version of Composer are you using?
Does your eclipse has any other plug-ins?
Any other jar loaded at your project?
Enviado de meu E6633 usando o Tapatalk
Hello Cavagnaro
Thank you for your response and time to read my case, here I answer:
Eclipse Version Juno Service Release 2
Build id: 20130225-0426
Genesys Composer: 8.1.450.20
I only have a single project, it’s a strategy that routes the operator, it’s simple, I’ve also noticed that the same error comes out when I validate other projects.
Thank you
Your Composer version is 8.1.450.20 but SCXML shows it was generated using older release. Have you upgraded your project to 8.1.450.20? I’m not saying it will fix the issue but it is a first step you should do.
Hello Rene
You were right, the problem was the composer version in relation to the eclipse, as I have a server with windows server 2012 I had to install an eclipse compatible with this OS version, I installed the LUNA eclipse, then I installed the Composer for this version and so I could homologate the versions.
I made a test strategy that always routes the operator and did not give me the error.
Thank you very much for your kind support.
