Problem when installing Knowledge Manager
Hi all,
i am trying to install Knowledge Manager, when i do i get the following error:
Supported Sun’s JRE version (higher than 1.6.1_26 and less than 1.7.0) was not found.The installation will continuewithout binding to java
Attached the screenshot.
The version of KM is 8.5.
I have jre 1.6 and 1.7 already installed, i have set the JAVA_HOME variable to jre 1.6 but i still have the problem.
Any idea please.
Thank you.
Have you put JAVA path in KnowledgeManager.bat, under installation directory ?
Thank you for the answer.
no, i aborted the installation when i got the error message.
Should i continue and put the java path in the .bat file?
it works now.
i continued the installation and i put the java path as you indicated.
Thank you very much.
Great :slight_smile:
