Hi Cavagnaro, thank you for your good disposition and time to help a newcomer community.
I explain the scenario I have:
I have a simple strategy in composer and its logic derives the operator call in a simple way, in addition to that I put two simple attach variables (Info_1, Info_2 shown in the log).
When calling the RP (6661) the call does not progress (internal call), it does not reach the agent configured in the strategy but if I see the variables mentioned above, here is a sample of the userdata:
(Str) RStrategyName Simple_Test.default.defaultWorkflow
(Str) RStrategyDBID 193
(Str) Info_1 Test 7
(Str) Info_2 16777217
It even recognizes the strategy, and when I validate the strategy in GA it correctly activates the .scxml.
The problem is that for some reason the system does not see the available operator.
Here I show the logs:
URS (ALL)
16:42:10.517_T_I_0000000000000000 [14:0c] EventQueued is received for ts LimaSipServer[LimaSwitch] (thisdn=6661)
_T_I_006f0328338b2001 [01:11] connid 006f0328338b2001 is bound to the call 1-e103557800
_T_I_006f0328338b2001 [01:1b] calluuid U5O3APV46929935HOVFOSQ80KG000001 is bound to the call 1-e103557800 as e10356c308
16:42:10.517_I_I_006f0328338b2001 [01:01] call (1-e103557800) for Environment created (del=0 ts=0,18,0,0)
_T_I_006f0328338b2001 [14:09] add DN LimaSipServer 6661 6661@LimaSwitch (CDN 57 006f0328338b2001 e10356c308) to the call 1-e103557800 truly:221
received from 65209(LimaSipServer)CIM1-1:3000(fd=) message EventRouteRequest
AttributeCallState 0
AttributeCallType 1
AttributePropagatedCallType 1
AttributeCallID 16777217
AttributeConnID 006f0328338b2001
AttributeCallUUID âU5O3APV46929935HOVFOSQ80KG000001â
AttributeDNIS â6661â
AttributeThisDN â6661â
AttributeThisDNRole 2
AttributeThisQueue â6661â
AttributePartyUUID âPKQH832PBT68D40U66IG1MGQHS000005â
AttributeOtherDN â6001â
AttributeOtherDNRole 1
AttributeExtensions [23] 00 01 01 00..
âBusinessCallâ 1
AttributeTimeinSecs 1636407730 (16:42:10)
AttributeTimeinuSecs 517000
AttributeEventSequenceNumber 0000000000000106
16:42:10.517_T_I_006f0328338b2001 [14:0c] EventRouteRequest is received for ts LimaSipServer[LimaSwitch] (thisdn=6661)
_T_I_006f0328338b2001 [14:09] add DN LimaSipServer 6661 6661@LimaSwitch (CDN 71 006f0328338b2001 e10356c308) to the call 1-e103557800 truly:111
_T_I_006f0328338b2001 [14:08] check delayed proc
_T_I_006f0328338b2001 [01:2d] call states: s=0 d=0 t=0
_T_I_006f0328338b2001 [14:43] call data updated(ani=,dnis=6661)
_I_W_006f0328338b2001 [14:03] start without strategy â default/ignore
16:42:10.518 Int 20003 interaction 006f0328338b2001 is routed to default
request to 65209(LimaSipServer) message RequestUpdateUserData
16:42:10.623_T_I_006f0328338b2001 [14:32] EventAttachedDataChanged is received for ts LimaSipServer[LimaSwitch] (thisdn=6661, refid=0, reqid=23, ignore=1 temp=1)
received from 65209(LimaSipServer)CIM1-1:3000(fd=) message EventAttachedDataChanged(refid=23)
16:42:10.626_T_I_006f0328338b2001 [14:32] EventAttachedDataChanged is received for ts LimaSipServer[LimaSwitch] (thisdn=6661, refid=23, reqid=23, ignore=0 temp=0)
I_I_006f0328338b2001 [01:14] current call classification: media=voice(100), service=default(200), segment=default(300)
received from 65209(LimaSipServer)CIM1-1:3000(fd=) message EventError
(Invalid Destination DN)
AttributeClientID 3
AttributeOtherDN ââ
AttributeExtensions [50] 00 02 00 00..
âCUSTOMER_IDâ âEnvironmentâ
âSWITCHâ âLimaSwitchâ
AttributeRouteType 1 (RouteTypeDefault)
AttributeReason [14] 00 01 01 00..
âRTRâ 114
AttributeReferenceID 24
AttributeErrorMessage âInvalid Destination DNâ
AttributeErrorCode 415
AttributeTimeinuSecs 626000
AttributeEventSequenceNumber 0000000000000112
16:42:10.627_T_E [14:0c] EventError is received for ts LimaSipServer[LimaSwitch] - Invalid Destination DN
16:42:10.627_A_E_006f0328338b2001 [14:32] <-----------ERROR
16:42:10.627 Std 21003 interaction 006f0328338b2001 routing error 0415 Invalid Destination DN
_T_I_006f0328338b2001 [01:2d] call states: s=5 d=0 t=0
T_W_006f0328338b2001 [0E:0f] emergency: delete call due to this error
16:42:10.627_I_I_006f0328338b2001 [01:08] call (1-e103557800) deleting truly
006f0328338b2001, 11/08/21@16:42:10.627, 6661(LimaSipServer) â @ [error default dumb 0 0 0 0], tms: 110= (N)1 + (T)0 + (X)0 + (S)0 + (W)0 + (F)0 + (R)109, trg:
CALL (006f0328338b2001) HISTORY ( Error Default ):
@@@1636407732: mbs by cnt 43(CNT=6 tm=3118), by tm 43(cnt=6 TM=3118), 41(0 0), 43(6 3118), 32(0 0), total in 1999612(cnt=13+1 tm=3118+0) 0(0)%
16:42:12.001_M_I [10:1d] PULSE (calls: 0(0)=0+0-0, trgts=0, first=0,0, time=1636407732, virt=0, mem=15087,139[425],9,203[4548],0,0 - 2,0,0)
16:42:12.001_M_I [10:1d] PULSE no calls, ignored: 0 cpu 0 2 next
Sip Server
16:42:10.492: Assocaited transport for the device [5] changed from [:0:0] to [192.168.1.199:5001:1]
16:42:10.493: CallMatcher: no call match attributes found
16:42:10.495: Assocaited transport for the device [6] changed from [:0:0] to [192.168.1.199:5001:1]
16:42:10.502: ResolveCallInfo: set flag DIAL_PLAN_PROCESSING
16:42:10.503: Sc(0):step 0, Tr(1,SipTransactionCreateCall) - begin
16:42:10.503 SIPCONN(6001): SIPCONN(00000000c210a640,0LBLI006U559TCJRFS09SV4KE4000001) +Tr(1,SipTransactionCreateCall)
16:42:10.503 SIPCONN(6001): Create dialog
16:42:10.504: SipDialog: set monitor 00000000c210a6f8
16:42:10.504 SIPCONN(6001): refer dialog 00000000c20fa780 initiated
16:42:10.504 SIPCONN(6001): change transaction 0 â 0
16:42:10.504 SIPCONN(6001): ClrMediaPeer
16:42:10.505: SIPDLG[5]: register TRN[4]
16:42:10.505: SIPDLG[5]: TRN[4] flags set to 0x1
16:42:10.505: SipDialog: event INVITE, t=4, s=1, r=5, m=00000000c210a6f8 port=5001
16:42:10.505: CID:CUUID>765f3e650c42b027ODg2NDdhMzMwM2Y2MmJlYjdkZjk3ZDJlNWE3Nzg5YmU.:U5O3APV46929935HOVFOSQ80KG000001:
16:42:10.505 SIPCONN(6001): HandleSipDialogEvent(INVITE)
16:42:10.506 SIPCONN(6001): Capabilities 19d
16:42:10.506 SIPCONN(6001): new transaction
16:42:10.506 SIPCONN(6001): store remote content, canBeOffer 1
16:42:10.506 SIPCONN(6001): verify sdp
16:42:10.506 SIPCONN(6001): sdp state SDP_STATE_NULL, event SDP_EVENT_SDP
16:42:10.506 SIPCONN(6001): new sdp state SDP_STATE_OFFER_RECEIVED, event SDP_EVENT_SDP
16:42:10.506 SIPCONN(6001): state e:10,p:0,s:1,c:9,rc:0,m:0
16:42:10.506 SIPCONN(6001): SIPCONN(00000000c210a640,0LBLI006U559TCJRFS09SV4KE4000001) -Tr(1,SipTransactionCreateCall)
16:42:10.506: Tr(1,SipTransactionCreateCall):completed
16:42:10.506: Sc(0):step 0, Tr(1,SipTransactionCreateCall) - completed
16:42:10.507: Sc(0):step 1, Tr(2,SipTransactionResolveCallInfoByDialPlan) - begin
16:42:10.508: DialPlan: No dialplan defined for 6001.
16:42:10.508: DialPlan: No rule applied, using original destination â6661â.
16:42:10.508: DialPlan: clear flag 0x100, callId 16777217
16:42:10.508: ConnectToDevice: Connecting to DEVICE(7,6661).
@16:42:10.5090 {tscp.call {constructed} {uuid PKQH832PBT68D40U66IG1MGQHS000003} {connection-id 006f0328338b2001} {call-id 16777217}}
16:42:10.509 â created call_info_tspp 006f0328338b2001@c20fb9f0
@16:42:10.5090 Call [006f0328338b2001]: urid 0001006f
16:42:10.509 â created aTmCall c20fd3c0/c20fb9f0
16:42:10.509 â TmCallThread created: c06cff00
16:42:10.509 SetANI for c20fd3c0:1: 6001
16:42:10.509 SetDNIS for c20fd3c0:1: 6661
16:42:10.509: SIPCALL(16777217): add party â6001â
16:42:10.509 SIPPARTY(6001): Set Origination Info DN - 6001 ; Location - LimaSwitch for party 6001
16:42:10.509: SIPTS: OnPartyCreated
16:42:10.510 â created party_info_tspp c1964c40
16:42:10.510 â created aTmParty c20fda30
16:42:10.510 SetRole: Origination for 6001.c20fda30-c20fd3c0:1
16:42:10.510 â AddParty to c20fd3c0: 6001.c20fda30-c20fd3c0:1
16:42:10.510 â new TSCP call leg 1
16:42:10.510 â call leg created leg_id=1
16:42:10.510 â created NAData c06d4ac0
16:42:10.510 CreateParty new internal: 6001.c20fda30-c20fd3c0:1
16:42:10.510: Call 16777217 dn 6001 SetPartyId 16777328
16:42:10.510: XS info is stored to TServer party 6001: loginSessionId: , loginLocation: ; employeeId
16:42:10.510 SIPCONN(6001): set monitor 00000000c210a640, 00000000c20fd688
16:42:10.510: SIPCALL(16777217): add party â6661â
16:42:10.510 SIPPARTY(6661): Set Origination Info DN - 6001 ; Location - LimaSwitch for party 6661
16:42:10.510: SIPTS: OnPartyCreated
16:42:10.510 â created party_info_tspp c1964040
16:42:10.510 â created aTmParty c20fe070
16:42:10.510 SetRole: Destination for 6661.c20fe070-c20fd3c0:1
16:42:10.510 â AddParty to c20fd3c0: 6661.c20fe070-c20fd3c0:1
16:42:10.510 â new TSCP call leg 2
16:42:10.510 â call leg created leg_id=2
16:42:10.510 CreateParty new internal: 6661.c20fe070-c20fd3c0:1
16:42:10.510: Call 16777217 dn 6661 SetPartyId 16777329
16:42:10.510: XS info is stored to TServer party 6661: loginSessionId: , loginLocation: ; employeeId
16:42:10.512: Tr(2,SipTransactionResolveCallInfoByDialPlan):completed
16:42:10.512: Sc(0):step 1, Tr(2,SipTransactionResolveCallInfoByDialPlan) - completed
16:42:10.512: Sc(0):step 2, Tr(3,SipTransactionChangePartyState) - begin
16:42:10.512 SIPPARTY(6001): ChangePartyState: new=1
16:42:10.513: SIPTS: â6001â state changed null->initiated, cause 0
16:42:10.513: XS info is stored to TServer party 6001: loginSessionId: , loginLocation: ; employeeId
16:42:10.514 ClearContext: party 6001.c20fda30-c20fd3c0:1
16:42:10.514 +++ CIFace::Event +++
+++ Pre-event +++
Type EventOriginated
Devices: <6001/6001> <6661/6661> <-/->
Calls: 16777217/006f0328338b2001/16777217.c20fd3c0/c:0/r:0 0/none
Parties: D6001/6001.c20fda30-c20fd3c0:1/l:1/r:0/Null,DNull,Origination
D6661/6661.c20fe070-c20fd3c0:1/l:2/r:0/Null,Destination
none
Flags: divert=0 hook=0 postCall=0 active=1 moveAll=1 callType=1 hideOtherPi=0 InternalOther=1
â Pre-event â
+++ Dialing +++
16:42:10.514: internal call originator not found
16:42:10.514: SIPS-IID:U5O3APV46929935HOVFOSQ80KG000001:006f0328338b2001:U5O3APV46929935HOVFOSQ80KG000001:TLIBEVT
+++ Pre-event +++
Type EventInitiated
none
â Pre-event â
+++ NewCall +++
â call is consultation
@16:42:10.5140 [0] 8.1.104.28 distribute_event: message EventOffHook
AttributeEventSequenceNumber 00000000000000ff
AttributeTimeinuSecs 514000
AttributeThisDN â6001â
16:42:10.514 Int 04544 Interaction message âEventOffHookâ generated
masked for 840 (00000007 ORS)
16:42:10.514 Trc 04542 EventOffHook sent to [836] (00000006 StatServer_Routing 192.168.1.199:49598)
16:42:10.514 Trc 04542 EventOffHook sent to [828] (00000005 StatServer_Reporting_Pulse 192.168.1.199:49595)
16:42:10.514 Trc 04542 EventOffHook sent to [832] (00000004 StatServer_Reporting 192.168.1.199:49594)
16:42:10.514: device off hook
SetActive: party 6001.c20fda30-c20fd3c0:1, cause Null
SetOriginating: party 6001.c20fda30-c20fd3c0:1, cause NewCall
â party_info 6001.c1964c40 state change: from to
â AgnEmu: business type configured as private for extension
â AgnEmu: private call BusinessType[1/1:0]
â aTmCall::SetBusinessType():006f0328338b2001 set to BusinessType[1/1:0]
â aTmParty::SetBusinessType():6001 set to BusinessType[1/1:0]
â G7 init
â call_info::committed created
@16:42:10.5140 [ISCC] Call object is created: c:006f0328338b2001,00000000c20fb9f0
@16:42:10.5140 [ISCC] Call created:
+ c:006f0328338b2001,00000000c20fb9f0 @ m:0000000000000000,0000000000000000 p:0 i:01000001 nw:0000000000000000 t:1
@16:42:10.5140 [0] 8.1.104.28 distribute call/party event: message EventCallCreated
AttributeEventSequenceNumber 0000000000000100
AttributeTimeStamp 618999b20007d7d0
AttributeMediaType 0
AttributeCallType 1
16:42:10.514 Int 04544 Interaction message âEventCallCreatedâ generated
16:42:10.514 Trc 04542 EventCallCreated sent to [840] (00000007 ORS 192.168.1.199:49599)
@16:42:10.5140 [ISCC] Party added [ddp view]:
@ c:006f0328338b2001,00000000c20fb9f0 @ m:0000000000000000,0000000000000000,0000000000000000 p:2 i:01000001 nw:00000000:0000000000000000 t:1
+ p:00000000c1964c40 @ c:006f0328338b2001,00000000c20fb9f0 r:1 t:0 s:1 n:6001
p:00000000c1964040 @ c:006f0328338b2001,00000000c20fb9f0 r:2 t:0 s:0 n:6661
@16:42:10.5140 [ISCC] Party object is created: p:0000000000000000,00000000c1964c40 n:6001:
@16:42:10.5140 [ISCC] Party added:
@ c:006f0328338b2001,00000000c20fb9f0 @ m:0000000000000000,0000000000000000 p:1 i:01000001 nw:0000000000000000 t:1
+ p:0000000000000000,00000000c1964c40 @ c:006f0328338b2001,00000000c20fb9f0 r:1 ----- n:6001:
@16:42:10.5140 [0] 8.1.104.28 distribute call/party event: message EventCallPartyAdded
AttributeEventSequenceNumber 0000000000000101
AttributeDBID 104
AttributeDN â6001â
AttributePartyState 0x1
AttributePartyType 0
AttributePartyUUID âPKQH832PBT68D40U66IG1MGQHS000004â
16:42:10.514 Int 04544 Interaction message âEventCallPartyAddedâ generated
16:42:10.514 Trc 04542 EventCallPartyAdded sent to [840] (00000007 ORS 192.168.1.199:49599)
â NewCall â
+++ Post-event +++
Type EventInitiated
Calls: 16777217/006f0328338b2001/16777217.c20fd3c0/c:1/r:0 0/006f0328338b2001/16777217.c20fd3c0/c:1/r:0
Parties: D6001/6001.c20fda30-c20fd3c0:1/l:1/r:0/Originating,Active,Origination
none
â Post-event â
â CIFace::Event â
CreateParty: already exists: 6661.c20fe070-c20fd3c0:1
SetDialling: party 6001.c20fda30-c20fd3c0:1, cause Null
â party_info 6001.c1964c40 state change: from to <Connected,Dialing>
â G7 dialing
@16:42:10.5140 [0] 8.1.104.28 distribute call/party event: message EventCallPartyState
AttributeEventSequenceNumber 0000000000000102
AttributePartyState 0x1000c
16:42:10.514 Int 04544 Interaction message âEventCallPartyStateâ generated
16:42:10.514 Trc 04542 EventCallPartyState sent to [840] (00000007 ORS 192.168.1.199:49599)
@16:42:10.5140 [0] 8.1.104.28 distribute_event: message EventDialing
AttributeEventSequenceNumber 0000000000000103
âBusinessCallâ 0
AttributeOtherDNRole 2
AttributeOtherDN â6661â
AttributeThisDNRole 1
AttributeCallType 1
â AgnEmu: Previous CallType is used when BusinessCall type changes
16:42:10.514 Int 04544 Interaction message âEventDialingâ generated
16:42:10.514 Trc 04542 EventDialing sent to [840] (00000007 ORS 192.168.1.199:49599)
16:42:10.514 Trc 04542 EventDialing sent to [836] (00000006 StatServer_Routing 192.168.1.199:49598)
16:42:10.514 Trc 04542 EventDialing sent to [828] (00000005 StatServer_Reporting_Pulse 192.168.1.199:49595)
16:42:10.514 Trc 04542 EventDialing sent to [832] (00000004 StatServer_Reporting 192.168.1.199:49594)
â Dialing â
+++ Post-event +++
Parties: D6001/6001.c20fda30-c20fd3c0:1/l:1/r:0/Dialing,Active,Origination
none
Call type: Internal/1
â Post-event â
16:42:10.514 â CIFace::Event â
16:42:10.515: Tr(3,SipTransactionChangePartyState):completed
16:42:10.515: Sc(0):step 2, Tr(3,SipTransactionChangePartyState) - completed
16:42:10.515: Sc(0):step 3, Tr(4,SipTransactionGetOffer) - begin
16:42:10.515: Tr(4,SipTransactionGetOffer):completed
16:42:10.515: Sc(0):step 3, Tr(4,SipTransactionGetOffer) - completed
16:42:10.515: Sc(0):step 4, Tr(5,SipTransactionConnectNewParty) - begin
16:42:10.516 SIPPARTY(6661): ChangePartyState: new=5
16:42:10.516: SIPTS: â6661â state changed null->queued, cause 9
16:42:10.516: IsCDN = true
16:42:10.516 ClearContext: party 6661.c20fe070-c20fd3c0:1
16:42:10.516 +++ CIFace::Event +++
+++ Pre-event +++
Type EventRouteRequest
Devices: <6661/6661> <6001/6001> <-/->
Calls: 16777217/006f0328338b2001/16777217.c20fd3c0/c:1/r:0 0/none
Parties: D6661/6661.c20fe070-c20fd3c0:1/l:2/r:0/Null,Destination
none
â Pre-event â
+++ Ringing +++
SetDelivered: party 6661.c20fe070-c20fd3c0:1, cause Null
â TellQueued
â party_info 6661.c1964040 state change: from to
â aTmParty::SetBusinessType():6661 set to BusinessType[1/1:0]
â AgnEmu: business type taken from distribution device 6661
â AgnEmu: business call BusinessType[2/4:0]
â aTmCall::SetBusinessType():006f0328338b2001 set to BusinessType[2/4:1]
â aTmParty::SetBusinessType():6661 set to BusinessType[2/4:1]
@16:42:10.5170 [ISCC] Party added [ddp view]:
p:00000000c1964c40 @ c:006f0328338b2001,00000000c20fb9f0 r:1 t:0 s:1000c n:6001
+ p:00000000c1964040 @ c:006f0328338b2001,00000000c20fb9f0 r:2 t:0 s:9 n:6661
@16:42:10.5170 [ISCC] Party object is created: p:0000000000000000,00000000c1964040 n:6661:
@16:42:10.5170 [ISCC] Party added:
@ c:006f0328338b2001,00000000c20fb9f0 @ m:0000000000000000,0000000000000000 p:2 i:01000001 nw:0000000000000000 t:1
+ p:0000000000000000,00000000c1964040 @ c:006f0328338b2001,00000000c20fb9f0 r:2 ----- n:6661:
@16:42:10.5170 [0] 8.1.104.28 distribute call/party event: message EventCallPartyAdded
AttributeEventSequenceNumber 0000000000000104
AttributeTimeStamp 618999b20007e388
AttributeDBID 128
AttributeDN â6661â
AttributePartyState 0x9
16:42:10.517 Int 04544 Interaction message âEventCallPartyAddedâ generated
16:42:10.517 Trc 04542 EventCallPartyAdded sent to [840] (00000007 ORS 192.168.1.199:49599)
push_queue: 6661 for 6661
@16:42:10.5170 [0] 8.1.104.28 distribute_event: message EventQueued
AttributeEventSequenceNumber 0000000000000105
âBusinessCallâ 1
AttributeCallType 1
16:42:10.517 Int 04544 Interaction message âEventQueuedâ generated
16:42:10.517 Trc 04542 EventQueued sent to [856] (00000009 - SPv7203ST 192.168.1.199:60139)
16:42:10.517 Trc 04542 EventQueued sent to [840] (00000007 ORS 192.168.1.199:49599)
16:42:10.517 Trc 04542 EventQueued sent to [836] (00000006 StatServer_Routing 192.168.1.199:49598)
16:42:10.517 Trc 04542 EventQueued sent to [828] (00000005 StatServer_Reporting_Pulse 192.168.1.199:49595)
16:42:10.517 Trc 04542 EventQueued sent to [832] (00000004 StatServer_Reporting 192.168.1.199:49594)
16:42:10.517 Trc 04542 EventQueued sent to [652] (00000003 URS 192.168.1.199:49593)
@16:42:10.5170 [0] 8.1.104.28 distribute_event: message EventRouteRequest
âBusinessCallâ 1
AttributeCallType 1
16:42:10.517 Int 04544 Interaction message âEventRouteRequestâ generated
16:42:10.517 Trc 04542 EventRouteRequest sent to [856] (00000009 - SPv7203ST 192.168.1.199:60139)
16:42:10.517 Trc 04542 EventRouteRequest sent to [840] (00000007 ORS 192.168.1.199:49599)
16:42:10.517 Trc 04542 EventRouteRequest sent to [836] (00000006 StatServer_Routing 192.168.1.199:49598)
16:42:10.517 Trc 04542 EventRouteRequest sent to [828] (00000005 StatServer_Reporting_Pulse 192.168.1.199:49595)
16:42:10.517 Trc 04542 EventRouteRequest sent to [832] (00000004 StatServer_Reporting 192.168.1.199:49594)
16:42:10.517 Trc 04542 EventRouteRequest sent to [652] (00000003 URS 192.168.1.199:49593)
@16:42:10.5170 [0] 8.1.104.28 distribute call/party event: message EventCallPartyState
AttributeEventSequenceNumber 0000000000000107
AttributePartyState 0x809
16:42:10.517 Int 04544 Interaction message âEventCallPartyStateâ generated
16:42:10.517 Trc 04542 EventCallPartyState sent to [840] (00000007 ORS 192.168.1.199:49599)
â Cleanup call leg
â Ringing â
+++ Post-event +++
Calls: 16777217/006f0328338b2001/16777217.c20fd3c0/c:2/r:0 0/none
Parties: D6661/6661.c20fe070-c20fd3c0:1/l:2/r:0/Queued,RtRequest,Destination
none
â Post-event â
16:42:10.517 â CIFace::Event â
16:42:10.517 SIPCONN(6001): SendResponse(180,4)
16:42:10.518: add party info â6001â state 1.
16:42:10.519: Sending [0,UDP] 503 bytes to 192.168.1.199:5001 >>>>>
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 192.168.1.199:5001;branch=z9hG4bK-d87543-a864f54858129947-1âd87543-;rport;received=192.168.1.199
To: "6661"sip:6661@192.168.1.199:5065;tag=317BF5CF-1CDC-4F91-9BC3-F0EAFF71E606-3
From: "6001"sip:6001@192.168.1.199:5065;tag=2576e15e
Call-ID: 765f3e650c42b027ODg2NDdhMzMwM2Y2MmJlYjdkZjk3ZDJlNWE3Nzg5YmU.
CSeq: 1 INVITE
X-Genesys-CallUUID: U5O3APV46929935HOVFOSQ80KG000001
Allow: INVITE, ACK, PRACK, CANCEL, BYE, UPDATE
Supported: uui
Content-Length: 0
16:42:10.519: SipDialog: event CALLED_RESPROV, t=4, s=1, r=9, m=00000000c210a6f8 port=5001
16:42:10.519: CID:CUUID>765f3e650c42b027ODg2NDdhMzMwM2Y2MmJlYjdkZjk3ZDJlNWE3Nzg5YmU.:U5O3APV46929935HOVFOSQ80KG000001:
16:42:10.519 SIPCONN(6001): HandleSipDialogEvent(CALLED_RESPROV) - filtered
16:42:10.519: Tr(5,SipTransactionConnectNewParty):completed
16:42:10.519: Sc(0):step 4, Tr(5,SipTransactionConnectNewParty) - completed
16:42:10.519: Tr(0,SipScenario):completed
16:42:10.519: SIPCM: transaction SipScenario(0) complete
16:42:10.520: PI-1: 00 S[IN]D[6001]C[*D[6001]]P[-]
16:42:10.520: PI-1: 00 S[QN]D[6661]E[-]
16:42:10.520: CALLSTATE(a:1,d:1,i:0,e:0,r:0,o:0)
16:42:10.522: call1 16777217 idle
16:42:10.522: $-NET:SIP::0:29772
16:42:10.623 Trc 04541 RequestUpdateUserData received from [652] (00000003 URS 192.168.1.199:49593)
AttributeUserData [510] 00 17 00 00..
âRVQIDâ ââ
âRVQDBIDâ ââ
âRTargetTypeSelectedâ â100â
âRTargetRuleSelectedâ ââ
âRTargetObjectSelectedâ ââ
âRTargetObjSelDBIDâ ââ
âRTargetAgentSelectedâ ââ
âRTargetAgSelDBIDâ ââ
âRTargetPlaceSelectedâ ââ
âRTargetPlSelDBIDâ ââ
âRTenantâ âEnvironmentâ
âRTenantDBIDâ â1â
âRStrategyNameâ ââ
âRStrategyDBIDâ ââ
âCBR-actual_volumeâ ââ
âCBR-Interaction_costâ ââ
âCBR-contract_DBIDsâ ââ
âCBR-IT-path_DBIDsâ ââ
âRRequestedSkillCombinationâ ââ
âRRequestedSkillsâ(list)
âCustomerSegmentâ âdefaultâ
âServiceTypeâ âdefaultâ
âServiceObjectiveâ ââ
AttributeReferenceID 22
16:42:10.623 Int 04543 Interaction message âRequestUpdateUserDataâ received from 652 (âURSâ)
@16:42:10.6230 Call [006f0328338b2001]: urid 0002006f
@16:42:10.6230 [0] 8.1.104.28 distribute_event: message EventAttachedDataChanged
AttributeEventSequenceNumber 0000000000000108
AttributeTimeinuSecs 623000
AttributeThirdPartyDN â6661â
âRVQIDâ ââ
âRVQDBIDâ ââ
âRTenantDBIDâ â1â
âRStrategyNameâ ââ
âRStrategyDBIDâ ââ
AttributeCallType 1
16:42:10.623 Int 04544 Interaction message âEventAttachedDataChangedâ generated
16:42:10.623 Trc 04542 EventAttachedDataChanged sent to [836] (00000006 StatServer_Routing 192.168.1.199:49598)
16:42:10.623 Trc 04542 EventAttachedDataChanged sent to [828] (00000005 StatServer_Reporting_Pulse 192.168.1.199:49595)
16:42:10.623 Trc 04542 EventAttachedDataChanged sent to [832] (00000004 StatServer_Reporting 192.168.1.199:49594)
@16:42:10.6230 [0] 8.1.104.28 distribute_response: message EventAttachedDataChanged
AttributeEventSequenceNumber 0000000000000109
âRVQIDâ ââ
âRVQDBIDâ ââ
âRTenantDBIDâ â1â
âRStrategyNameâ ââ
âRStrategyDBIDâ ââ
AttributeCallType 1
16:42:10.623 Trc 04542 EventAttachedDataChanged sent to [652] (00000003 URS 192.168.1.199:49593)
16:42:10.623 Trc 04542 EventAttachedDataChanged sent to [856] (00000009 - SPv7203ST 192.168.1.199:60139)
@16:42:10.6230 [ISCC] Updated call:
i c:006f0328338b2001,00000000c20fb9f0 @ m:0000000000000000,0000000000000000 p:2 i:01000001 nw:0000000000000000 t:1
@16:42:10.6230 [ISCC] UserData propagation has been started
@16:42:10.6230 [ISCC] UserData propagation has been finished
16:42:10.623 â call_info::committed changed
@16:42:10.6230 [0] 8.1.104.28 distribute call/party event: message EventCallDataChanged
AttributeEventSequenceNumber 000000000000010a
AttributeTimeStamp 618999b200098198
AttributeCtrlParty â6661â
âRVQIDâ ââ
âRVQDBIDâ ââ
âRTenantDBIDâ â1â
âRStrategyNameâ ââ
âRStrategyDBIDâ ââ
16:42:10.623 Int 04544 Interaction message âEventCallDataChangedâ generated
16:42:10.623 Trc 04542 EventCallDataChanged sent to [840] (00000007 ORS 192.168.1.199:49599)
16:42:10.623 â created: CRequest@c1ebdca0 RequestUpdateUserData-URS[652]/22
16:42:10.623: $+TLIB:CTI:Unknown:0:12208867
16:42:10.623 â deleted: CRequest@c1ebdca0 RequestUpdateUserData-URS[652]/22
16:42:10.623: $-TLIB:CTI:Unknown:0:6
16:42:10.623 Trc 04541 RequestUpdateUserData received from [840] (00000007 ORS 192.168.1.199:49599)
AttributeUserData [114] 00 01 03 00..
âORSI:Cluster1:U5O3APV46929935HOVFOSQ80KG000001â(list) âSessionâ â15UIL6S7ID64VBN98777PN4I08000002+â
âNodeâ â116â
AttributeReferenceID 39
16:42:10.623 Int 04543 Interaction message âRequestUpdateUserDataâ received from 840 (âORSâ)
@16:42:10.6230 Call [006f0328338b2001]: urid 0003006f
AttributeEventSequenceNumber 000000000000010b
AttributeUserData [622] 00 18 00 00..
âRVQIDâ ââ
âRVQDBIDâ ââ
âRTenantDBIDâ â1â
âRStrategyNameâ ââ
âRStrategyDBIDâ ââ
âNodeâ â116â
AttributeCallType 1
AttributeEventSequenceNumber 000000000000010c
âRVQIDâ ââ
âRVQDBIDâ ââ
âRTenantDBIDâ â1â
âRStrategyNameâ ââ
âRStrategyDBIDâ ââ
âNodeâ â116â
AttributeCallType 1
AttributeEventSequenceNumber 000000000000010d
âRVQIDâ ââ
âRVQDBIDâ ââ
âRTenantDBIDâ â1â
âRStrategyNameâ ââ
âRStrategyDBIDâ ââ
âNodeâ â116â
@16:42:10.6230 [0] 8.1.104.28 send_to_client: message EventACK
AttributeEventSequenceNumber 000000000000010e
AttributeUserEvent RequestUpdateUserData
16:42:10.623 Trc 04542 EventACK sent to [840] (00000007 ORS 192.168.1.199:49599)
16:42:10.623 â created: CRequest@c1ebd320 RequestUpdateUserData-ORS[840]/39
16:42:10.623: $+TLIB:CTI:Unknown:0:220
16:42:10.623 â deleted: CRequest@c1ebd320 RequestUpdateUserData-ORS[840]/39
16:42:10.623: $-TLIB:CTI:Unknown:0:3
AttributeUserData [17] 00 01 01 00..
âPegDEFâ 1
AttributeReferenceID 23
@16:42:10.6230 Call [006f0328338b2001]: urid 0004006f
AttributeEventSequenceNumber 000000000000010f
AttributeUserData [637] 00 19 00 00..
âRVQIDâ ââ
âRVQDBIDâ ââ
âRTenantDBIDâ â1â
âRStrategyNameâ ââ
âRStrategyDBIDâ ââ
âNodeâ â116â
âPegDEFâ 1
AttributeCallType 1
AttributeEventSequenceNumber 0000000000000110
âRVQIDâ ââ
âRVQDBIDâ ââ
âRTenantDBIDâ â1â
âRStrategyNameâ ââ
âRStrategyDBIDâ ââ
âNodeâ â116â
âPegDEFâ 1
AttributeCallType 1
AttributeEventSequenceNumber 0000000000000111
âRVQIDâ ââ
âRVQDBIDâ ââ
âRTenantDBIDâ â1â
âRStrategyNameâ ââ
âRStrategyDBIDâ ââ
âNodeâ â116â
âPegDEFâ 1
16:42:10.623 â created: CRequest@c1ebd0c0 RequestUpdateUserData-URS[652]/23
16:42:10.623: $+TLIB:CTI:Unknown:0:147
16:42:10.623 â deleted: CRequest@c1ebd0c0 RequestUpdateUserData-URS[652]/23
16:42:10.623: $-TLIB:CTI:Unknown:0:2
16:42:10.623 Trc 04541 RequestRouteCall received from [652] (00000003 URS 192.168.1.199:49593)
message RequestRouteCall
AttributeOtherDN ââ
âRTRâ 114
16:42:10.623 Int 04543 Interaction message âRequestRouteCallâ received from 652 (âURSâ)
@16:42:10.6230 [ISCC] destination_location substituted by local
16:42:10.623 â created: CRequest@c1ebdca0 RequestRouteCall-URS[652]/24
16:42:10.623: $+TLIB:CTI:Unknown:0:26
16:42:10.623 +++ CIFace::Request +++
â new invoke
16:42:10.623 Trc 36210 Client 3(URS): no destination DN in request
â thisCall by party
Parsed: RequestRouteCall
Numbers: +<6661> -
Calls: c20fd3c0:1 none
Parties: 6661.c20fe070-c20fd3c0:1
none
Status: parsed:1 queued:0 sent:0 acked:0 preevent:0 event:0 context:0 transferred:0
â validate
â state check: ok
CIFace: Sent CRequest@c1ebdca0 RequestRouteCall-URS[652]/24
â aTmCall 006f0328338b2001 SetCause: Distributed
â created NAData c06d46b0
FinishRequest CRequest@c1ebdca0 RequestRouteCall-URS[652]/24
IFace stats: q=0 s=0
â complete
â NAData ClRq removed
TNAEmulator::NotifyBackup()
16:42:10.623: RID:CUUID>24:U5O3APV46929935HOVFOSQ80KG000001:
16:42:10.624: routing destination missing, no default-dn is specified
Response (415): for CRequest@c1ebdca0 RequestRouteCall-URS[652]/24
16:42:10.624 Trc 36210 Client 3(URS): no destination DN in request
â thisCall by party
16:42:10.626 Trc 36002 Request rejected: error code 415(Invalid Destination DN)
@16:42:10.6260 [0] 8.1.104.28 send_to_client: message EventError
âRTRâ 114
AttributeOtherDN ââ
AttributeClientID 3
16:42:10.626 Int 04545 Interaction message âEventErrorâ sent to 652 (âURSâ)
16:42:10.626 Trc 04542 EventError sent to [652] (00000003 URS 192.168.1.199:49593)
FinishRequest: second time for CRequest@c1ebdca0 RequestRouteCall-URS[652]/24
16:42:10.626 â CIFace::Request â
16:42:10.626 â deleted: CRequest@c1ebdca0 RequestRouteCall-URS[652]/24
16:42:10.626: $-TLIB:CTI:Unknown:0:2577
16:42:12.635 Trc 04541 RequestUpdateUserData received from [840] (00000007 ORS 192.168.1.199:49599)
AttributeUserData [187] 00 03 03 00..
âORSI:Cluster1:U5O3APV46929935HOVFOSQ80KG000001â(list) âSessionâ â15UIL6S7ID64VBN98777PN4I08000002â
âNodeâ â116â
âRStrategyNameâ âSimple_Test.default.defaultWorkflowâ
âRStrategyDBIDâ â193â
AttributeReferenceID 40
16:42:12.635 Int 04543 Interaction message âRequestUpdateUserDataâ received from 840 (âORSâ)
@16:42:12.6350 Call [006f0328338b2001]: urid 0005006f
@16:42:12.6350 [0] 8.1.104.28 distribute_event: message EventAttachedDataChanged
AttributeEventSequenceNumber 0000000000000113
AttributeTimeinuSecs 635000
AttributeTimeinSecs 1636407732 (16:42:12)
AttributeUserData [674] 00 19 00 00..
âRVQIDâ ââ
âRVQDBIDâ ââ
âRTenantDBIDâ â1â
âPegDEFâ 1
âNodeâ â116â
AttributeCallType 1
16:42:12.635 Int 04544 Interaction message âEventAttachedDataChangedâ generated
16:42:12.635 Trc 04542 EventAttachedDataChanged sent to [836] (00000006 StatServer_Routing 192.168.1.199:49598)
16:42:12.635 Trc 04542 EventAttachedDataChanged sent to [828] (00000005 StatServer_Reporting_Pulse 192.168.1.199:49595)
16:42:12.635 Trc 04542 EventAttachedDataChanged sent to [832] (00000004 StatServer_Reporting 192.168.1.199:49594)
@16:42:12.6350 [0] 8.1.104.28 distribute_response: message EventAttachedDataChanged
AttributeEventSequenceNumber 0000000000000114
âRVQIDâ ââ
âRVQDBIDâ ââ
âRTenantDBIDâ â1â
'ServiceType
