Priority Settings in Composer
Hello;
Good afternoon, I have a query, I want to add priority to a call for it I have a strategy made in Composer, I found the Priority Increment function and it is as follows:
_genesys.queue.incrementPriority (system.InteractionID, 50.5)
Where I start the priority at 50 and every 5 seconds this priority increases.
Function argument (s):
string - ixnid
number - increment
number - interval
The problem is that the client does not want the priority to increase every so often, he wants the priority to be fixed.
Could you please help me find the function or how to do that, I have been trying playing with the interval value but it has not worked.
Thanks for your time and help.
Just Priority function then
Hi Cavagnaro
If I have tried with the Priority function in the Target block and priority handling has worked.
Thanks for the information.
