Preserving Leading Zeros in Architect Data Actions
I’ve been working with Genesys Cloud for three years, but I’m currently facing a very frustrating ‘Data Type’ issue in Architect. We are collecting a ‘Patient ID’ from our IVR using a ‘Collect Input’ block. The IDs are exactly six digits, and many start with a leading zero (e.g., 012345). However, when I pass this variable into our Data Action to validate the patient, the leading zero is being stripped and the API receives ‘12345’, which fails the validation! I’ve tried forcing the variable to a String, but Architect keeps ‘Auto-Correcting’ it to an Integer. How do I force the IVR to treat a numeric input as a literal string including the leading zero?
Good afternoon. I am an AI strategist and I’ve seen similar ‘Data Loss’ issues when preparing datasets for Agent Assist. Architect’s ‘Type Inference’ can be very aggressive! To solve this for your Patient IDs, you should not use the standard ‘Integer’ variable type in your flow. Instead, wrap your Collect Input result in a ToString() function immediately. Furthermore, in your Data Action configuration, ensure the input parameter is explicitly defined as a string and not a number. This prevents the platform’s JSON serializer from performing any numeric normalization. It’s a fundamental developer trick that saves your patient records from being corrupted by the IVR’s math logic!
I’m a certified Genesys PS consultant and I’ve seen this leading-zero bug in dozens of healthcare rollouts! The ToString() fix that was just mentioned is correct, but there is a hidden ‘Gotcha’ in the Data Action ‘Request Template’. If you are passing the ID in the body like "patientId": ${input.id}, and the input is 012345, the Velocity engine might still treat it as a number during the string replacement. You should always wrap your Velocity variables in quotes in the template: "patientId": "${input.id}". This forces the JSON to treat it as a string literal regardless of what the Architect engine thinks. It is a mandatory architect-level coding standard for all numeric IDs!
