POST /api/v2/conversations/calls returns 409 Conflict with 'Already in conversation' despite idle state
Trying to automate outbound calls from using the REST Proxy. The flow is supposed to grab the next lead and kick off a call on behalf of the current agent.
I’m using GetRESTProxy to hit POST /api/v2/conversations/calls. The JSON payload looks like this:
 "to": [{"phoneNumber": "{lead.phone}"}],
 "from": {"phoneNumber": "{agent.phone}"},
 "type": "outbound",
 "providerId": "{provider.id}"
The call works fine if the agent has been idle for a while. The problem happens when the agent just hung up. If I trigger the within 2-3 seconds of the previous call ending, I get a 409 Conflict. The error message says User is already in a conversation.
I’ve checked the agent state in the UI. It clearly shows Available. The previous call object shows state: terminated. I even added a WAIT for 5 seconds in the script, but the 409 still hits.
Is there a delay in the platform clearing the conversation lock? Or am I missing a step to explicitly release the agent before initiating the new call? Here is the block I’m using:
Set RESTProxy to GetRESTProxy(
 method: POST,
 path: /api/v2/conversations/calls,
 body: {
 "type": "outbound",
The response status code is 409. Body contains "message": "User is already in a conversation".
Not sure if I need to query the conversations API first to confirm the previous one is truly gone. Or if there’s a specific header I should be sending. Tried adding If-None-Match: * but that didn’t change anything.
Any ideas on how to handle this race condition?
