POST /api/v2/conversations/calls returning 403 despite valid OAuth scopes
Quick question, has anyone seen this weird error? with the Genesys Cloud Conversations API when trying to initiate an outbound call on behalf of an agent via our custom React desktop.
I am using the GC Client App SDK to manage the session. The user is authenticated via OAuth implicit grant with PKCE. I have verified the access token is valid and contains the calls:view and calls:modify scopes.
Here is the request payload:
 "to": [{"phoneNumber": "+15550199", "name": "Test Contact"}],
 "from": {"phoneNumber": "+18005551234"},
 "routing": {"type": "user", "userId": "agent-id-123"}
The API returns a 403 Forbidden error:
“The user does not have permission to perform this action.”
I have checked the documentation:
“To initiate a call on behalf of another user, the authenticated user must have the calls:modify scope AND the target user must be available or in a state that allows outbound calls.”
The agent is Available. I am not using the SDK’s ClientApp wrapper for this specific call; I am making a raw fetch request with the bearer token. Is there a hidden permission check on the routing.userId field that requires additional admin rights? Or is the PKCE flow stripping necessary context?
This looks like a scope mismatch; the Conversations API requires callcenter:outboundcalls:modify rather than calls:modify. Verify the token payload directly in your notebook before assuming the SDK handled the grant correctly.
If I remember correctly, scope alignment is only half the battle. The 403 often stems from the target user’s role configuration, not just the token scopes. Even with callcenter:outboundcalls:modify, the acting agent must have the Agent role and the specific Outbound Call permission enabled in their profile.
I debug this by checking the user’s effective permissions via the API before attempting the call creation. This isolates whether the issue is authentication or authorization.
curl -X GET "https://api.mypurecloud.com/api/v2/users/me" \
 -H "Authorization: Bearer <ACCESS_TOKEN>" \
 -H "Content-Type: application/json"
Verify the outboundCall permission is true in the response. If it is false, update the user’s role or grant the permission directly. Also ensure the from number in the payload belongs to a configured outbound route.
Check API Endpoint Expected Status
User Permissions /api/v2/users/me outboundCall: true
Outbound Route Check via UI or config Active and Valid
This prevents wasted cycles on token introspection when the real blocker is role-based access control.
