POST /api/v2/conversations/calls failing with 400 on agentId validation
Getting a 400 Bad Request when trying to initiate an outbound call on behalf of an agent. The payload looks standard, but the error message is vague: Validation failed for object 'conversation'. List of failures: 'agentId' must be a valid agent ID.
Here’s the JSON body I’m sending:
 "to": [{"phoneNumber": "+61298765432"}],
 "from": {"phoneNumber": "+61212345678"},
 "agentId": "5f9c8b7a-1234-5678-9abc-def012345678",
 "type": "voice"
I’ve double-checked the agentId against /api/v2/users/me and it matches exactly. The agent is currently online and set to ‘Available’. I’m using a service account token with conversation:read and conversation:write scopes.
Tried swapping the token for a user token with the same result. The endpoint is definitely POST /api/v2/conversations/calls. Is there a specific permission on the user profile or routing profile that blocks API-initiated calls? Or is the agentId format different for this endpoint than the user ID?
Checked the debug logs on the Genesys side. Nothing jumps out. Just the validation failure.
The docs state: “The agentId must be a valid UUID of an active user in the organization.” Your ID looks truncated in the snippet. Verify the full UUID in the payload and ensure the user has the callCenter:all permission.
