Is the correct approach to use the conversationsApi.createCallConversation method for initiating an outbound call on behalf of an agent, or should I be hitting the REST endpoint directly? I’m building a Kotlin utility in Android to trigger outbound calls from our internal app, but I keep getting a 403 Forbidden response when trying to post to /api/v2/conversations/calls. The code looks like this:
val callRequest = CallConversationRequest(
to = listOf("+15551234567"),
from = "+15559876543",
routing = CallRoutingObject(
type = "queue",
queueId = "abc-123-xyz"
val response = conversationsApi.createCallConversation(callRequest)
I’ve verified the OAuth token has the conversation:call:create scope. The endpoint works fine in Postman with the same token. The error payload says Access to resource is forbidden. I’m using the genesys-cloud-kotlin-client SDK version 2.4.0. The agent is online and available in the queue. I’ve tried swapping the token for a long-lived service account token with full admin rights, but it still fails. The stack trace doesn’t show much detail beyond the 403. Is there a specific permission missing on the service account or a weird quirk with the Kotlin SDK client builder?
