Port NICE CXone Phone Numbers Using the Telephony API with Go
- A Go module that constructs, validates, and submits bulk phone number porting requests to NICE CXone with full lifecycle tracking.
- The solution uses the NICE CXone Telephony API v2 and standard
net/httpwith typed request and response structures. - The implementation covers OAuth authentication, regulatory validation, LOA document handling, atomic POST submission, status polling, webhook synchronization, and audit logging.
- OAuth 2.0 Client Credentials grant with
telephony:ports:writeandtelephony:ports:readscopes - NICE CXone Platform API v2 (
https://platform.nicecxone.com/api/v2/) - Go 1.21 or later
- Standard library dependencies only (
net/http,encoding/json,time,sync,regexp,crypto/sha256,log,fmt,os)
NICE CXone uses the OAuth 2.0 Client Credentials flow. The token endpoint returns a short-lived access token that must be cached and refreshed before expiration. The following implementation stores the token in memory with a mutex guard and tracks expiry to prevent unauthorized requests.
package main
import (
"context"
"crypto/sha256"
"encoding/json"
"fmt"
"io"
"log"
"net/http"
"os"
"sync"
"time"
const (
cxoneBaseURL = "https://platform.nicecxone.com"
oauthURL = cxoneBaseURL + "/oauth/token"
portsURL = cxoneBaseURL + "/api/v2/telephony/ports"
type TokenResponse struct {
Scope string `json:"scope"`
type AuthManager struct {
mu sync.Mutex
token string
expiresAt time.Time
clientID string
clientSecret string
func NewAuthManager(clientID, clientSecret string) *AuthManager {
return &AuthManager{
clientID: clientID,
clientSecret: clientSecret,
func (a *AuthManager) GetToken(ctx context.Context) (string, error) {
a.mu.Lock()
defer a.mu.Unlock()
if a.token != "" && time.Now().Before(a.expiresAt.Add(-5*time.Minute)) {
return a.token, nil
return a.fetchToken(ctx)
func (a *AuthManager) fetchToken(ctx context.Context) (string, error) {
payload := fmt.Sprintf("grant_type=client_credentials&client_id=%s&client_secret=%s&scope=telephony:ports:write+telephony:ports:read",
a.clientID, a.clientSecret)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, oauthURL, strings.NewReader(payload))
if err != nil {
return "", fmt.Errorf("failed to create oauth request: %w", err)
resp, err := http.DefaultClient.Do(req)
if err != nil {
return "", fmt.Errorf("oauth request failed: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("oauth authentication failed with status %d: %s", resp.StatusCode, string(body))
var tokenResp TokenResponse
return "", fmt.Errorf("failed to decode oauth response: %w", err)
a.token = tokenResp.AccessToken
a.expiresAt = time.Now().Add(time.Duration(tokenResp.ExpiresIn) * time.Second)
return a.token, nil
The GetToken method checks expiration with a five-minute safety buffer. This prevents race conditions during concurrent porting submissions. The scope telephony:ports:write is required for port creation, while telephony:ports:read enables status polling and audit retrieval.
Step 1: Validate Number Eligibility and Batch Constraints
NICE CXone enforces strict regulatory and operational limits on porting requests. The API rejects batches exceeding fifty numbers, and it validates E.164 formatting, NPA-NXX routing, and reserved number ranges. The following validator checks batch size, format, regulatory exclusions, and LOA document integrity before payload construction.
import (
"regexp"
"strings"
const maxBatchSize = 50
var e164Regex = regexp.MustCompile(`^\+[1-9]\d{1,14}$`)
var reservedNPANXX = map[string]bool{
"111": true, "211": true, "311": true, "411": true, "511": true,
"611": true, "711": true, "811": true, "911": true, "555": true,
type PortValidationResult struct {
Valid bool
Errors []string
Warnings []string
func ValidatePortRequest(numbers []string, loaBase64 string) PortValidationResult {
var errs, warns []string
if len(numbers) == 0 {
errs = append(errs, "number list cannot be empty")
return PortValidationResult{Valid: false, Errors: errs}
if len(numbers) > maxBatchSize {
errs = append(errs, fmt.Sprintf("batch size %d exceeds maximum limit of %d", len(numbers), maxBatchSize))
for _, num := range numbers {
if !e164Regex.MatchString(num) {
errs = append(errs, fmt.Sprintf("invalid E.164 format: %s", num))
npa := num[1:4]
if reservedNPANXX[npa] {
errs = append(errs, fmt.Sprintf("reserved NPA detected: %s", npa))
if loaBase64 != "" {
if len(loaBase64) < 100 || len(loaBase64)%4 != 0 {
warns = append(warns, "LOA document size or padding appears invalid")
Valid: len(errs) == 0,
Errors: errs,
Warnings: warns,
The validator rejects reserved area codes and enforces the fifty-number batch limit. It also performs a quick structural check on the LOA base64 string. NICE CXone requires the LOA to be a valid PDF encoded in base64. Production systems should decode the string and verify the %PDF- magic bytes before submission.
Step 2: Construct Porting Payload with Carrier Matrix and Transfer Directive
The porting payload must include number references, carrier routing information, and a transfer directive that specifies whether the port is full or partial. The carrier matrix supplies the current carrier account details required for the LOA handoff. NICE CXone expects a flat JSON structure with explicit field names.
type CarrierMatrix struct {
CurrentCarrier string `json:"currentCarrier"`
AccountNumber string `json:"accountNumber"`
PINCode string `json:"pinCode,omitempty"`
LATA string `json:"lata,omitempty"`
type PortingPayload struct {
PortingRequestID string `json:"portingRequestId"`
Numbers []string `json:"numbers"`
CarrierMatrix CarrierMatrix `json:"carrierMatrix"`
TransferDirective string `json:"transferDirective"`
LOADocument string `json:"loaDocument,omitempty"`
Metadata map[string]any `json:"metadata,omitempty"`
func BuildPortingPayload(requestID string, numbers []string, carrier CarrierMatrix, directive, loa string) PortingPayload {
return PortingPayload{
PortingRequestID: requestID,
Numbers: numbers,
CarrierMatrix: carrier,
TransferDirective: directive,
LOADocument: loa,
Metadata: map[string]any{
"sourceSystem": "go-porter",
"batchTimestamp": time.Now().UTC().Format(time.RFC3339),
The transferDirective field accepts full or partial. A full directive moves all lines associated with the account, while partial requires explicit line selection. The metadata block is optional but recommended for downstream reconciliation. NICE CXone ignores unknown metadata keys, so you can safely attach internal tracking identifiers.
Step 3: Submit Atomic POST Operation with LOA Handoff
Porting submission is an atomic operation. The API returns HTTP 201 on success with a portingRequestId and initial status. The following function handles request construction, retry logic for 429 rate limits, and structured error parsing.
import (
"bytes"
"math"
"math/rand"
type PortResponse struct {
Status string `json:"status"`
CreatedAt string `json:"createdAt"`
func SubmitPortRequest(ctx context.Context, auth *AuthManager, payload PortingPayload) (*PortResponse, error) {
jsonBody, err := json.Marshal(payload)
if err != nil {
return nil, fmt.Errorf("failed to marshal payload: %w", err)
token, err := auth.GetToken(ctx)
if err != nil {
return nil, fmt.Errorf("authentication failed: %w", err)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, portsURL, bytes.NewBuffer(jsonBody))
if err != nil {
return nil, fmt.Errorf("failed to create port request: %w", err)
var resp *http.Response
maxRetries := 3
for attempt := 0; attempt <= maxRetries; attempt++ {
resp, err = http.DefaultClient.Do(req)
if err != nil {
return nil, fmt.Errorf("port submission request failed: %w", err)
backoff := time.Duration(math.Pow(2, float64(attempt))) * time.Second
jitter := time.Duration(rand.Intn(int(backoff/2))) * time.Millisecond
log.Printf("Rate limited (429). Retrying in %v", backoff+jitter)
time.Sleep(backoff + jitter)
break
if resp.StatusCode != http.StatusCreated {
return nil, fmt.Errorf("port submission failed with status %d: %s", resp.StatusCode, string(body))
var portResp PortResponse
if err := json.NewDecoder(resp.Body).Decode(&portResp); err != nil {
return nil, fmt.Errorf("failed to decode port response: %w", err)
return &portResp, nil
The retry loop implements exponential backoff with jitter to avoid thundering herd scenarios during carrier handoff windows. NICE CXone enforces rate limits per OAuth client, so backing off on 429 prevents cascading failures across your integration fleet.
Step 4: Status Tracking, Webhook Synchronization, and Audit Logging
Porting is asynchronous. NICE CXone updates the port status through polling endpoints and webhook notifications. The following implementation polls for status changes, synchronizes with external portability databases via webhook parsing, calculates latency, and writes structured audit logs.
type PortStatus struct {
UpdatedAt string `json:"updatedAt"`
type AuditEntry struct {
RequestID string `json:"requestId"`
Action string `json:"action"`
LatencyMs int64 `json:"latencyMs"`
SuccessCount int `json:"successCount"`
TotalCount int `json:"totalCount"`
func PollPortStatus(ctx context.Context, auth *AuthManager, requestID string, interval time.Duration) (*PortStatus, error) {
for {
select {
case <-ctx.Done():
return nil, ctx.Err()
case <-time.After(interval):
if err != nil {
return nil, err
url := fmt.Sprintf("%s/%s", portsURL, requestID)
req, _ := http.NewRequestWithContext(ctx, http.MethodGet, url, nil)
if err != nil {
return nil, err
if resp.StatusCode == http.StatusNotFound {
return nil, fmt.Errorf("port request %s not found", requestID)
return nil, fmt.Errorf("status poll failed: %s", string(body))
var status PortStatus
if err := json.NewDecoder(resp.Body).Decode(&status); err != nil {
return nil, err
if status.Status == "COMPLETED" || status.Status == "FAILED" {
return &status, nil
func HandlePortWebhook(req *http.Request) (PortStatus, error) {
var payload struct {
Event string `json:"event"`
if err := json.NewDecoder(req.Body).Decode(&payload); err != nil {
return PortStatus{}, err
if payload.Event != "port.status.changed" {
return PortStatus{}, fmt.Errorf("unsupported webhook event: %s", payload.Event)
return PortStatus{
PortingRequestID: payload.PortingRequestID,
Status: payload.Status,
UpdatedAt: payload.UpdatedAt,
}, nil
func WriteAuditLog(entry AuditEntry) {
jsonLine, _ := json.Marshal(entry)
log.Printf("AUDIT:%s", string(jsonLine))
The polling loop terminates only on terminal states (COMPLETED or FAILED). The webhook handler validates the event type and extracts status updates for real-time synchronization with external number portability databases. Audit logs capture latency, success rates, and governance metadata for compliance reporting.
The following script combines authentication, validation, submission, tracking, and webhook handling into a single runnable module. Replace the placeholder credentials with your NICE CXone OAuth values before execution.
package main
import (
"context"
"encoding/json"
"fmt"
"log"
"net/http"
"os"
"strings"
"time"
func main() {
ctx, cancel := context.WithTimeout(context.Background(), 300*time.Second)
defer cancel()
clientID := os.Getenv("CXONE_CLIENT_ID")
clientSecret := os.Getenv("CXONE_CLIENT_SECRET")
if clientID == "" || clientSecret == "" {
log.Fatal("CXONE_CLIENT_ID and CXONE_CLIENT_SECRET environment variables are required")
auth := NewAuthManager(clientID, clientSecret)
numbers := []string{"+12125551001", "+12125551002", "+12125551003"}
loaDoc := os.Getenv("CXONE_LOA_BASE64")
result := ValidatePortRequest(numbers, loaDoc)
if !result.Valid {
log.Fatalf("Validation failed: %v", result.Errors)
if len(result.Warnings) > 0 {
log.Printf("Validation warnings: %v", result.Warnings)
carrier := CarrierMatrix{
CurrentCarrier: "Verizon",
AccountNumber: "987654321",
PINCode: "5678",
LATA: "345",
payload := BuildPortingPayload(
fmt.Sprintf("PORT-%d", time.Now().Unix()),
numbers,
carrier,
"full",
loaDoc,
start := time.Now()
portResp, err := SubmitPortRequest(ctx, auth, payload)
if err != nil {
log.Fatalf("Submission failed: %v", err)
latency := time.Since(start).Milliseconds()
WriteAuditLog(AuditEntry{
Timestamp: time.Now(),
RequestID: portResp.PortingRequestID,
Action: "PORT_SUBMIT",
Status: portResp.Status,
LatencyMs: latency,
SuccessCount: 1,
TotalCount: 1,
log.Printf("Port request created: %s (%s)", portResp.PortingRequestID, portResp.Status)
status, err := PollPortStatus(ctx, auth, portResp.PortingRequestID, 15*time.Second)
if err != nil {
log.Fatalf("Tracking failed: %v", err)
RequestID: status.PortingRequestID,
Action: "PORT_COMPLETED",
Status: status.Status,
LatencyMs: time.Since(start).Milliseconds(),
SuccessCount: 1,
TotalCount: 1,
log.Printf("Final status: %s", status.Status)
http.HandleFunc("/webhooks/cxone", func(w http.ResponseWriter, r *http.Request) {
status, err := HandlePortWebhook(r)
if err != nil {
http.Error(w, err.Error(), http.StatusBadRequest)
return
Action: "WEBHOOK_SYNC",
w.WriteHeader(http.StatusOK)
log.Printf("Webhook listener started on :8080")
log.Fatal(http.ListenAndServe(":8080", nil))
Run the module with go run main.go. The script submits the port, tracks it to completion, writes audit entries, and exposes a webhook endpoint for asynchronous status synchronization.
Error: HTTP 400 Bad Request
- Cause: Invalid E.164 format, missing carrier matrix fields, or malformed LOA base64.
- Fix: Run
ValidatePortRequestbefore submission. Decode the LOA string and verify the%PDF-header. Ensure the carrier matrix containscurrentCarrierandaccountNumber. - Code: Add
log.Printf("Payload: %s", string(jsonBody))before the POST request to inspect the exact JSON sent to the API.
Error: HTTP 401 Unauthorized
- Cause: Expired OAuth token or missing
telephony:ports:writescope. - Fix: Verify the client credentials have the correct scopes assigned in the NICE CXone admin console. The
AuthManagerautomatically refreshes tokens, but manual token revocation in the console will invalidate cached tokens. - Code: Force a token refresh by calling
auth.mu.Lock(); auth.token = ""; auth.mu.Unlock();before the next request.
Error: HTTP 403 Forbidden
- Cause: The OAuth client lacks telephony permissions or the account has regional telephony restrictions.
- Fix: Contact your NICE CXone account manager to enable telephony porting for your organization. Verify that the numbers belong to a region supported by your CXone instance.
- Code: Check the response body for the
error_descriptionfield, which specifies the exact policy violation.
- Cause: Exceeded rate limits for port creation or status polling.
- Fix: The implementation includes exponential backoff with jitter. If failures persist, reduce polling frequency to thirty seconds and stagger batch submissions across multiple OAuth clients.
- Code: Adjust
maxRetriesand backoff multipliers inSubmitPortRequestto match your account tier limits.
Error: HTTP 404 Not Found
- Cause: Polling a
portingRequestIdthat was never created or belongs to a different CXone environment. - Fix: Verify the environment URL matches your OAuth token. Use the
portingRequestIdreturned directly from the 201 response. - Code: Log the full URL in the polling function to confirm environment alignment.
