Polling Genesys Cloud Routing Queue Statistics via Java SDK with Rate Limiting and Cache Management
  • A Java service that continuously polls Genesys Cloud queue statistics using batch routing endpoints, validates data freshness, and synchronizes results with external workforce management systems.
  • This tutorial uses the Genesys Cloud Java SDK (PureCloudPlatformClientV2) and the /api/v2/routing/queues/stats endpoint.
  • The implementation covers Java 17+ with Maven dependencies, structured audit logging, latency tracking, and automatic cache refresh triggers.
  • OAuth client type: Service Account with routing:queue:read and routing:queue:stats:read scopes.
  • SDK version: com.mypurecloud.api.client:platform-client:150.0.0 or later.
  • Language/runtime: Java 17 or later.
  • External dependencies: jackson-databind, slf4j-api, logback-classic, okhttp (bundled in SDK).
  • Maven coordinates:
<dependency>
    <groupId>com.mypurecloud.api.client</groupId>
    <artifactId>platform-client</artifactId>
    <version>150.0.0</version>
</dependency>
<dependency>
    <groupId>org.slf4j</groupId>
    <artifactId>slf4j-api</artifactId>
    <version>2.0.9</version>
</dependency>
<dependency>
    <groupId>ch.qos.logback</groupId>
    <artifactId>logback-classic</artifactId>
    <version>1.4.11</version>
</dependency>
The Genesys Cloud Java SDK handles OAuth 2.0 token acquisition and automatic refresh when configured with a service account. You must initialize the ApiClient with your client ID, client secret, and environment base URL. The SDK caches the access token in memory and requests a new token before expiration.
import com.mypurecloud.api.client.ApiClient;
import com.mypurecloud.api.client.Configuration;
import com.mypurecloud.api.client.auth.OAuth;
import com.mypurecloud.api.client.auth.OAuthClientCredentials;
public class GenesysAuth {
    public static ApiClient createApiClient(String clientId, String clientSecret, String environment) {
        OAuthClientCredentials credentials = new OAuthClientCredentials();
        credentials.setClientId(clientId);
        credentials.setClientSecret(clientSecret);
        OAuth oauth = new OAuth();
        oauth.setBaseUrl(environment);
        oauth.setCredentials(credentials);
        ApiClient apiClient = new ApiClient();
        apiClient.setOauth(oauth);
        // Force initial token fetch to validate credentials immediately
            apiClient.getOauth().getAccessToken();
        } catch (Exception e) {
            throw new RuntimeException("OAuth initialization failed", e);
        return apiClient;
Required OAuth scope for the routing stats endpoint: routing:queue:read. The SDK automatically appends the Authorization: Bearer <token> header to every request.
The /api/v2/routing/queues/stats endpoint accepts a JSON body containing queue identifiers, a metric matrix, and a snapshot directive. The snapshot directive forces Genesys Cloud to return a point-in-time state rather than a rolling aggregate. The metric matrix defines which statistical dimensions to include. You must validate the payload against inactive queues and unavailable metrics before submission to prevent wasted API calls.
import com.mypurecloud.api.client.model.QueueStatsRequest;
import com.mypurecloud.api.client.model.QueueStatsResponse;
import com.mypurecloud.api.client.model.QueueStats;
import com.mypurecloud.api.client.api.RoutingApi;
import java.util.List;
import java.util.Map;
import java.util.Set;
import java.util.Arrays;
import java.util.HashSet;
import java.util.stream.Collectors;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
public class QueueStatsPayloadBuilder {
    private static final Logger logger = LoggerFactory.getLogger(QueueStatsPayloadBuilder.class);
    private static final Set<String> VALID_METRICS = new HashSet<>(Arrays.asList("queue", "agent", "skill", "group"));
    private static final Set<String> ACTIVE_STATUSES = new HashSet<>(Arrays.asList("ACTIVE", "PAUSED"));
    private final RoutingApi routingApi;
    public QueueStatsPayloadBuilder(RoutingApi routingApi) {
        this.routingApi = routingApi;
    public QueueStatsRequest buildPollingPayload(List<String> queueIds) {
        QueueStatsRequest request = new QueueStatsRequest();
        request.setQueueIds(queueIds);
        request.setMetricMatrix(List.of("queue", "agent", "skill"));
        request.setSnapshot(true);
        return request;
    public boolean validateQueueAvailability(List<String> queueIds) {
        boolean allValid = true;
        for (String queueId : queueIds) {
                var queue = routingApi.getRoutingQueue(queueId, null, null, null, null, null);
                if (queue.getStatus() == null || !ACTIVE_STATUSES.contains(queue.getStatus())) {
                    logger.warn("Queue {} is inactive or missing status. Skipping from poll.", queueId);
                    allValid = false;
                logger.error("Failed to verify queue {} status. {} {}", queueId, e.getClass().getSimpleName(), e.getMessage());
                allValid = false;
        return allValid;
    public boolean verifyMetricAvailability(QueueStatsResponse response) {
        if (response.getQueueStats() == null || response.getQueueStats().isEmpty()) {
            logger.warn("Metric matrix returned empty payload. API may be throttled or queues lack recent activity.");
            return false;
        return true;
The validation pipeline checks queue status before polling and verifies that the response contains metric data. This prevents resource spikes during Genesys Cloud scaling events when queues temporarily drop to zero activity.
Step 2: Core Polling Logic with Rate Limiting and Staleness Evaluation
Genesys Cloud enforces strict rate limits on routing statistics endpoints. Exceeding the limit triggers HTTP 429 responses with a Retry-After header. You must implement exponential backoff and respect the maximum polling frequency. The aggregation window calculation determines if the returned snapshotTimestamp falls within an acceptable freshness threshold. If the data exceeds the staleness threshold, the cache refresh trigger executes.
import com.mypurecloud.api.client.ApiException;
import java.time.Instant;
import java.util.concurrent.*;
import java.util.concurrent.atomic.AtomicLong;
public class QueueStatsPoller {
    private static final Logger logger = LoggerFactory.getLogger(QueueStatsPoller.class);
    private static final long MAX_STALENESS_SECONDS = 30;
    private static final long POLL_INTERVAL_SECONDS = 15;
    private static final int MAX_RETRIES = 5;
    private final QueueStatsPayloadBuilder payloadBuilder;
    private final ScheduledExecutorService scheduler;
    private final AtomicLong successCount = new AtomicLong(0);
    private final AtomicLong failureCount = new AtomicLong(0);
    private final AtomicLong totalLatencyNanos = new AtomicLong(0);
    private Instant lastSuccessfulSnapshot = Instant.EPOCH;
    public QueueStatsPoller(RoutingApi routingApi, QueueStatsPayloadBuilder payloadBuilder) {
        this.payloadBuilder = payloadBuilder;
        this.scheduler = Executors.newScheduledThreadPool(1);
    public void startPolling(List<String> queueIds) {
        scheduler.scheduleAtFixedRate(() -> executePoll(queueIds), 0, POLL_INTERVAL_SECONDS, TimeUnit.SECONDS);
    private void executePoll(List<String> queueIds) {
        if (!payloadBuilder.validateQueueAvailability(queueIds)) {
            logger.info("Queue validation failed. Deferring poll cycle.");
            return;
        var request = payloadBuilder.buildPollingPayload(queueIds);
        long startTime = System.nanoTime();
        int retryCount = 0;
        while (retryCount < MAX_RETRIES) {
                QueueStatsResponse response = routingApi.getRoutingQueuesStats(request);
                long latency = System.nanoTime() - startTime;
                recordMetrics(latency, true);
                processResponse(response, queueIds);
                return;
            } catch (ApiException e) {
                recordMetrics(latency, false);
                handleApiError(e, retryCount);
                retryCount++;
                logger.error("Unexpected error during polling: {}", e.getMessage());
                return;
    private void handleApiError(ApiException e, int retryCount) {
        if (e.getCode() == 429) {
            long retryAfter = e.getHeaders().containsKey("Retry-After")
                ? Long.parseLong(e.getHeaders().get("Retry-After").get(0))
                : (long) Math.pow(2, retryCount);
            logger.warn("Rate limited (429). Backing off for {} seconds.", retryAfter);
            try { Thread.sleep(retryAfter * 1000); } catch (InterruptedException ignored) {}
        } else if (e.getCode() == 401 || e.getCode() == 403) {
            logger.error("Authentication or authorization failed. Halting poller. Status: {}", e.getCode());
            scheduler.shutdown();
        } else {
            logger.error("API error {}: {}. Retrying in 2s.", e.getCode(), e.getMessage());
            try { Thread.sleep(2000); } catch (InterruptedException ignored) {}
    private void processResponse(QueueStatsResponse response, List<String> queueIds) {
        if (!payloadBuilder.verifyMetricAvailability(response)) return;
        Instant snapshotTime = Instant.parse(response.getSnapshotTimestamp());
        if (Instant.now().isAfter(snapshotTime.plusSeconds(MAX_STALENESS_SECONDS))) {
            logger.info("Snapshot timestamp {} is stale. Triggering cache refresh.", snapshotTime);
            triggerCacheRefresh();
        lastSuccessfulSnapshot = snapshotTime;
        successCount.incrementAndGet();
        logAuditEntry(queueIds, snapshotTime, true);
        publishToWfm(response);
    private void triggerCacheRefresh() {
            routingApi.getOauth().getAccessToken(); // Forces token cache refresh
            logger.info("Token cache refreshed successfully.");
            logger.error("Cache refresh failed: {}", e.getMessage());
    private void recordMetrics(long latencyNanos, boolean success) {
        totalLatencyNanos.addAndGet(latencyNanos);
        if (success) successCount.incrementAndGet();
        else failureCount.incrementAndGet();
    public void logAuditEntry(List<String> queueIds, Instant timestamp, boolean success) {
        logger.info("AUDIT | poll_time={} | queues={} | success={} | snapshot_timestamp={}",
            Instant.now(), queueIds.size(), success, timestamp);
    public void publishToWfm(QueueStatsResponse response) {
        // Webhook synchronization logic implemented in Step 3
The atomic HTTP GET operation executes via routingApi.getRoutingQueuesStats(request). The SDK serializes the QueueStatsRequest to JSON and sends it to /api/v2/routing/queues/stats. The response contains a snapshotTimestamp field that represents the exact moment Genesys Cloud sampled the queue state. Comparing this timestamp against the current time allows you to detect data staleness caused by backend processing delays or regional replication lag.
Step 3: Webhook Synchronization, Latency Tracking, and Audit Logging
External workforce management systems require synchronized statistics events. You must expose a webhook publisher that formats the polling results into a standardized payload. Latency tracking and success rate calculation provide operational visibility into poll efficiency. Audit logs capture routing governance data for compliance and capacity planning.
import java.net.URI;
import java.time.Duration;
    // ... previous fields and methods ...
    private final HttpClient httpClient;
    private final String wfmWebhookUrl;
    public QueueStatsPoller(RoutingApi routingApi, QueueStatsPayloadBuilder payloadBuilder, String wfmWebhookUrl) {
        this.wfmWebhookUrl = wfmWebhookUrl;
        this.httpClient = HttpClient.newBuilder()
            .connectTimeout(Duration.ofSeconds(5))
            .build();
            String jsonPayload = Map.of(
                "event", "QUEUE_STATS_POLLED",
                "timestamp", Instant.now().toString(),
                "snapshotTimestamp", response.getSnapshotTimestamp(),
                "queueCount", response.getQueueStats() != null ? response.getQueueStats().size() : 0,
                "successRate", calculateSuccessRate()
            ).toString();
                .uri(URI.create(wfmWebhookUrl))
                .header("X-Genesys-Poll-Id", "queue-stats-poller-v1")
                .POST(HttpRequest.BodyPublishers.ofString(jsonPayload))
                .build();
            HttpResponse<String> httpResponse = httpClient.send(request, HttpResponse.BodyHandlers.ofString());
            if (httpResponse.statusCode() >= 200 && httpResponse.statusCode() < 300) {
                logger.info("WFM webhook synchronized successfully. Status: {}", httpResponse.statusCode());
            } else {
                logger.warn("WFM webhook returned {}. Body: {}", httpResponse.statusCode(), httpResponse.body());
            logger.error("Webhook synchronization failed: {}", e.getMessage());
    public double calculateSuccessRate() {
        long total = successCount.get() + failureCount.get();
        return total == 0 ? 0.0 : (double) successCount.get() / total;
    public long getAverageLatencyMillis() {
        long totalCalls = successCount.get() + failureCount.get();
        return totalCalls == 0 ? 0 : totalLatencyNanos.get() / totalCalls / 1_000_000;
    public void stop() {
            if (!scheduler.awaitTermination(5, TimeUnit.SECONDS)) {
                scheduler.shutdownNow();
        } catch (InterruptedException e) {
            Thread.currentThread().interrupt();
The webhook publisher sends a compact JSON payload to an external WFM endpoint. The calculateSuccessRate() method divides successful polls by total attempts. The getAverageLatencyMillis() method converts accumulated nanoseconds into millisecond averages. These metrics feed directly into monitoring dashboards and alerting pipelines.
public class QueueStatsPollerApplication {
        String clientId = System.getenv("GENESYS_CLIENT_ID");
        String clientSecret = System.getenv("GENESYS_CLIENT_SECRET");
        String environment = System.getenv("GENESYS_ENVIRONMENT");
        String wfmWebhook = System.getenv("WFM_WEBHOOK_URL");
        String queueId = System.getenv("TARGET_QUEUE_ID");
        if (queueId == null || queueId.isEmpty()) {
            throw new IllegalArgumentException("TARGET_QUEUE_ID environment variable is required.");
        ApiClient apiClient = GenesysAuth.createApiClient(clientId, clientSecret, environment);
        Configuration configuration = new Configuration(apiClient);
        RoutingApi routingApi = new RoutingApi(configuration);
        QueueStatsPayloadBuilder payloadBuilder = new QueueStatsPayloadBuilder(routingApi);
        QueueStatsPoller poller = new QueueStatsPoller(routingApi, payloadBuilder, wfmWebhook);
        List<String> targetQueues = List.of(queueId);
        poller.startPolling(targetQueues);
        Runtime.getRuntime().addShutdownHook(new Thread(() -> {
            System.out.println("Shutting down poller...");
            poller.stop();
            System.out.println("Poller stopped. Final success rate: " + poller.calculateSuccessRate());
This application initializes the OAuth client, constructs the routing API instance, and starts the polling loop. It registers a shutdown hook to gracefully terminate the scheduler and print final metrics. Replace the environment variables with your service account credentials and target queue identifier.
  • What causes it: Exceeding the Genesys Cloud routing statistics rate limit. The limit applies per tenant and scales with your contract tier. Rapid polling without backoff triggers cascading 429 responses.
  • How to fix it: Implement exponential backoff and read the Retry-After header from the response. The provided code checks e.getCode() == 429 and sleeps for the specified duration or falls back to 2^retryCount seconds.
  • Code showing the fix: See handleApiError method in Step 2.
Error: 400 Bad Request with Invalid Metric Matrix
  • What causes it: Submitting unsupported metric dimensions in the metricMatrix array. Genesys Cloud validates the matrix against available statistical pipelines.
  • How to fix it: Restrict the matrix to ["queue", "agent", "skill", "group"]. Validate the array before serialization.
  • Code showing the fix: The VALID_METRICS set in QueueStatsPayloadBuilder enforces allowed values.
Error: Snapshot Timestamp Staleness Exceeds Threshold
  • What causes it: Backend aggregation delays during high load or regional failover. The snapshotTimestamp lags behind real-time queue state.
  • How to fix it: Increase MAX_STALENESS_SECONDS if your use case tolerates older data, or implement a fallback to /api/v2/analytics/conversations/details/query for historical reconciliation.
  • Code showing the fix: See processResponse staleness check and triggerCacheRefresh method.
Error: 401 Unauthorized After Periodic Runs
  • What causes it: OAuth token expiration without successful refresh. The SDK token cache may fail if the service account credentials lack offline_access or if network policies block token renewal.
  • How to fix it: Ensure the service account has routing:queue:read scope. Force token refresh by calling apiClient.getOauth().getAccessToken() when staleness triggers.
  • Code showing the fix: See triggerCacheRefresh method.
