Hi all, i never used a Genesys solution before, so i’ll try to be as more specific as i can.
Here’s my issue:
The call center i’m workin’ with made an aggresive upgrade from Genesys 5.1 to 8.1, so i have to develop a toolbar/softphone solution migration (almost from scratch) and integrate it with a Web Based CRM system.
In 5.1 the integration was made this way (in VB6):
- A toolbar with the basic voice instructions (dial, answer, login, ready, not ready, transfer) make calls to generic functions that are present in a dll and communicate with the CRM through a WebBrowser embedded.
- The [i]generic[/i] functions makes the genesys calls and interacts with Genesys CTI.
My questions are:
Before I develop, i would like to know if this is really a good practice, or should i just make use of the platform SDK directly?
For now, this should be a voice solution only, but in the future, there should be a Live Chat and Video Support. Can this be done with .Net and Platform SDK?
Can I make the toolbar/softphone stuff independent of the CTI i use? I mean by example, the toolbar development having a Generic DIAL buttons that triggers a DIAL_GENESYS event. Is this kind of programming recommended?
CTI is Genesys in this case. If you have another CTI like Avaya you need their SDK…Cisco with Cisco SDK…etc.
Maybe there is a lower interphase (CSTA) but is harder and complicated to do so
Maybe this image will help you: It’s the current implementation of Genesys 5.1. According on what i’ve been told, the whole point of Generic and Abstract is to make the softphone desktop App CTI-independent (i could use any CTI just changing the Abstract source).
Use PSDK(Platform SDK) developer guide for your preferred code language (.Net,Java,C++). R5.1 and R8.1 are incomparable in this way. I recommend to you visit any Genesys training or at least more familiar with the Genesys product as a solution. It is very difficult to develop “good” app without notion about system.
Both abstract and Generic are VB6 dll’s that have the special calls to Genesys functionalities (the names are defined long before i arrived).
By example, the button “DIAL” in the softphone calls a generic DIAL instruction passed to dll.
It’s a 10 years old development, and i think the original programmer made it this way so if the company changed the CTI he didn’t have to change the Client application, only point it to another dll.
Yes,you can use it. BUT it is possible that the any function(name,parameters,..) can be changed during the releasing new Genesys(5.1,6.1,6.5,7.x,..),so your dll’s in version 8.1 do not cover all functions,may be. You have to try it and test all possible scenario. For me,my opinion,the whole work is unnecessary and is a waste of time I guess.Being on your site so you program all over again,it saves issue in the future and the entire solution will be clean.Take note that version 5.1 is completely different from the version 8.1 and between these release is very big different.
I disagree with Kubig’s comments, one thing to note is that the difference between 5.1 and 8.1 is NOT that much.
We still have a 5.1 client working on a new 8.1 deployment. The functionality works correctly but it is very slow due to the version of VB used
Genesys have added events over the years but not removed any. The Event model is applicable across all versions.
Yes,you are right,therefore I wrote “maybe”. But I still think that it is usually better rewrite very “old” solution to new solution,which is proposed for these purposes from vendor. As you wrote above,multimedia layer contains a lot of changes during the releasing. It is possible that your existing solution will work on R8.1,but question is “how well?”. The final decision is up to you as well
