How does the PII redaction engine actually handle overlapping phrase boundaries when compliance tagging is forced on? The stack’s running NICE CXone v23.11 alongside Genesys Cloud Speech Analytics SDK 2.4.1, and the redaction job creation process keeps throwing a 422 Unprocessable Entity. Payload validation doesn’t pass the compliance_scope field, claiming the regex patterns clash with the built-in keyword spotting rules. It’s like tuning sentiment calibration while the noise floor keeps shifting. Precision drops to sixty percent whenever the auto-tagging pipeline tries to resolve SSN and credit card overlaps. Checked that redaction timeout thread from last month, but that focused on batch exports, not real-time transcription streams. The architect flow logs show the compliance guardrail kicking in before the phrase detection module even parses the utterance. Retrying with a broader recall threshold won’t help since it floods the audit queue with false positives. Logs are doing jack all to clarify the boundary logic. The mic stays hot during the retry window. Console output points to a strict MIME type mismatch on the JSON payload. The schema validator passes locally anyway.
The compliance_scope regex usually fails validation because the hybrid setup is trying to apply CXone boundary rules directly to the Genesys redaction queue.
Skip the overlapping pattern match and route the compliance tags through a separate transcription queue before the redaction step runs. That’ll cut down on audit delays during your cutover window. What’s the exact date you’re targeting for the final data sync anyway, since the timeline risk needs to be mapped out.
This 422 error comes from payload mismatch. In CIC we used to handle PII masking inside flow script before recording hit the server. That way regex never touch boundary logic like this. The suggestion above is good, but direct fix exists.
Strip lookahead assertion from compliance_scope pattern. GC engine gets confused by (?!...) when phrase boundary is active. Saw workaround on community post last week where simple character class used instead.
Setting exclude_overlaps to true stops engine from trying to merge tags. It’s not perfect, but it stops the 422. Boundary overlap happens because compliance tag tries to wrap PII block. In PureConnect, attendant logic just ignored overlap. Here API rejects it. You’ll need to adjust payload structure as well. Don’t send full object if scope is partial. Just send pattern change. Validation is too strict here.
CXone’s PII masking just bundles overlapping phrases into one blob, whereas GC Speech Analytics needs strict boundary offsets. You’ll need to map your compliance_scope regex directly to phrase_boundary_mode: strict and drop the lookahead assertion, since the redaction engine chokes on nested matches. What exact pattern are you feeding it right now, since the lookahead is probably still in there.
PureCloudPlatformClientV2 actually enforces strict boundary resolution when the CX-as-Code provider pushes the redaction topic configuration through the deployment pipeline. The runtime engine treats any overlapping regex pattern in compliance_scope as a conflicting directive against the native phrase boundary logic. First, the validation layer checks the phrase_boundary_mode against the regex structure when you submit the payload to the speech and text analytics topics endpoint. Second, if you keep the lookahead assertion like (?!compliance), the parser throws that 422 because it cannot resolve the overlapping match offsets. The suggestion above about stripping the lookahead is correct, but you also need to explicitly set phrase_boundary_mode to strict in the request body. Otherwise the state backup will drift every time the analytics engine recalculates the transcription queue.
You’ll notice the character class replacement handles the boundary without triggering the nested match error. The Go struct inside the platform client maps this directly to the underlying REST call, so you don’t have to construct the query parameters manually. Just make sure your Terraform state file captures the updated compliance_scope object after the initial apply, otherwise drift detection will flag it on the next sync. The OAuth scope speechanalytics:topics:write is required for the token, but the provider usually handles that automatically. Run the update through the SDK once the payload matches the strict schema. The state file will pick it up anyway.
It’s pretty straightforward once you drop the lookahead. The parser just chokes on nested assertions, and you can’t really force the engine to resolve overlapping boundaries without breaking the state sync. You can verify the boundary offsets by running a test transcription through the staging environment first. The API response will show the corrected phrase_boundary_mode value in the metadata. Keep the regex simple and let the engine handle the overlap resolution. The Terraform plan will reflect the change immediately after you push the config. State drift settles on its own.
