Persisting NICE Cognigy Conversation State Across Channels with Java Spring and Redis
  • A Java Spring Boot microservice that intercepts inbound Cognigy bot sessions, serializes dialog context to a Redis cluster, and restores AI flow position when a user switches communication channels.
  • This implementation uses the Cognigy REST API v1 endpoints for session creation and message routing, combined with Spring Data Redis for distributed state management.
  • The tutorial covers Java 17, Spring Boot 3.2, Lettuce Redis client, and OkHttp for synchronous REST calls.
  • Cognigy API credentials (username and password or API key)
  • Required permissions: bot:read, bot:write, session:manage (Cognigy uses role-based JWT claims rather than OAuth scopes; these roles must be assigned to the API user)
  • Redis cluster endpoint with TLS and password authentication
  • Java 17+, Maven or Gradle
  • Dependencies: spring-boot-starter-web, spring-boot-starter-data-redis, com.fasterxml.jackson.core:jackson-databind, com.squareup.okhttp3:okhttp
Cognigy authenticates programmatic clients via a JWT obtained from /v1/auth/login. The token is valid for one hour and must be cached in your service. You do not refresh tokens via a standard OAuth 2.0 flow; you request a new JWT when the current one expires. The following code demonstrates token acquisition, caching, and automatic expiration handling.
import okhttp3.*;
import org.springframework.stereotype.Component;
import org.springframework.beans.factory.annotation.Value;
import java.io.IOException;
import java.time.Instant;
@Component
public class CognigyAuthManager {
    private final OkHttpClient httpClient;
    private final ObjectMapper objectMapper;
    private final String cognigyBaseUrl;
    private final String cognigyUsername;
    private final String cognigyPassword;
    private final ConcurrentHashMap<String, CachedToken> tokenCache = new ConcurrentHashMap<>();
    public CognigyAuthManager(
            @Value("${cognigy.base-url}") String cognigyBaseUrl,
            @Value("${cognigy.username}") String cognigyUsername,
            @Value("${cognigy.password}") String cognigyPassword) {
        this.cognigyBaseUrl = cognigyBaseUrl;
        this.cognigyUsername = cognigyUsername;
        this.cognigyPassword = cognigyPassword;
        this.httpClient = new OkHttpClient.Builder()
                .connectTimeout(10, TimeUnit.SECONDS)
                .readTimeout(15, TimeUnit.SECONDS)
                .build();
        this.objectMapper = new ObjectMapper();
    public String getValidToken() throws IOException, InterruptedException {
        CachedToken cached = tokenCache.get("default");
        if (cached != null && !cached.isExpired()) {
            return cached.token;
        String body = String.format("{\"username\":\"%s\",\"password\":\"%s\"}", cognigyUsername, cognigyPassword);
        Request request = new Request.Builder()
                .url(cognigyBaseUrl + "/v1/auth/login")
                .post(RequestBody.create(body, MediaType.parse("application/json")))
                .build();
        try (Response response = httpClient.newCall(request).execute()) {
            if (!response.isSuccessful()) {
                throw new IOException("Cognigy auth failed: " + response.code() + " " + response.message());
            JsonNode json = objectMapper.readTree(response.body().string());
            String newToken = json.get("token").asText();
            long expiresAt = json.has("expiresIn") ? Instant.now().getEpochSecond() + json.get("expiresIn").asLong() : Instant.now().getEpochSecond() + 3600;
            tokenCache.put("default", new CachedToken(newToken, expiresAt));
            return newToken;
    private record CachedToken(String token, long expiresAt) {
        public boolean isExpired() {
            return Instant.now().getEpochSecond() > expiresAt - 30; // Refresh 30s before expiry
Step 1: Redis Cluster Configuration and Context Serialization
You must serialize dialog context in a format that survives JVM restarts and scales across Redis cluster shards. Cognigy sessions carry custom variables, flow state, and platform metadata. You will define a structured payload and use Spring Data Redis with Jackson2JsonRedisSerializer to handle type preservation. The Redis key strategy uses a composite pattern: cognigy:session:{guestId}:{platform} to guarantee uniqueness during channel switches.
import com.fasterxml.jackson.annotation.JsonInclude;
import org.springframework.context.annotation.Bean;
import org.springframework.context.annotation.Configuration;
import org.springframework.data.redis.connection.RedisClusterConfiguration;
import org.springframework.data.redis.connection.RedisConnectionFactory;
import org.springframework.data.redis.connection.lettuce.LettuceConnectionFactory;
import org.springframework.data.redis.core.RedisTemplate;
import org.springframework.data.redis.serializer.GenericJackson2JsonRedisSerializer;
import org.springframework.data.redis.serializer.StringRedisSerializer;
import java.time.Duration;
import java.util.List;
import java.util.Map;
@Configuration
public class RedisConfig {
    @Bean
    public RedisConnectionFactory redisConnectionFactory() {
        RedisClusterConfiguration clusterConfig = new RedisClusterConfiguration();
        clusterConfig.setClusterNodes(List.of(
                org.springframework.data.redis.connection.RedisNode.builder("redis-node-1").withPort(6379).build(),
                org.springframework.data.redis.connection.RedisNode.builder("redis-node-2").withPort(6380).build(),
                org.springframework.data.redis.connection.RedisNode.builder("redis-node-3").withPort(6381).build()
        clusterConfig.setPassword("cluster-password");
        clusterConfig.useSsl();
        return new LettuceConnectionFactory(clusterConfig);
    @Bean
    public RedisTemplate<String, SessionContext> redisTemplate(RedisConnectionFactory factory) {
        RedisTemplate<String, SessionContext> template = new RedisTemplate<>();
        template.setConnectionFactory(factory);
        template.setKeySerializer(new StringRedisSerializer());
        template.setValueSerializer(new GenericJackson2JsonRedisSerializer());
        template.setHashKeySerializer(new StringRedisSerializer());
        template.setHashValueSerializer(new GenericJackson2JsonRedisSerializer());
        template.afterPropertiesSet();
        return template;
@JsonInclude(JsonInclude.Include.NON_NULL)
public record SessionContext(
        String guestId,
        String platform,
        String cognigySessionId,
        String currentFlowId,
        Map<String, Object> customVariables,
        long lastActiveTimestamp
The GenericJackson2JsonRedisSerializer preserves Java types during deserialization, which prevents class cast exceptions when you retrieve complex maps from Redis. You must set a time-to-live on every write to prevent stale session accumulation. Cognigy recommends a session timeout of 15 to 30 minutes. You will enforce this at the Redis layer using EXPIRE or setEx.
Step 2: Cognigy REST API Client and Session Initialization
You will create a dedicated service that handles all Cognigy REST interactions. The service must implement retry logic for 429 Too Many Requests responses, which occur when you exceed Cognigy’s rate limit of 100 requests per minute per bot. You will use exponential backoff with jitter to avoid thundering herd scenarios during peak traffic.
import okhttp3.*;
import org.springframework.stereotype.Service;
import org.springframework.beans.factory.annotation.Autowired;
import java.util.concurrent.ThreadLocalRandom;
@Service
public class CognigyApiClient {
    private final CognigyAuthManager authManager;
    private final String botId;
    @Autowired
    public CognigyApiClient(
            CognigyAuthManager authManager,
            @Value("${cognigy.bot-id}") String botId) {
        this.authManager = authManager;
        this.botId = botId;
                .readTimeout(20, TimeUnit.SECONDS)
                .build();
    public String createSession(String guestId, String platform) throws IOException, InterruptedException {
        String token = authManager.getValidToken();
        String payload = objectMapper.writeValueAsString(Map.of(
                "externalSessionId", guestId,
                "platform", platform,
                "guestId", guestId
                .url(cognigyBaseUrl + String.format("/v1/bots/%s/sessions", botId))
                .post(RequestBody.create(payload, MediaType.parse("application/json")))
                .addHeader("Authorization", "Bearer " + token)
                .build();
        return executeWithRetry(request, "createSession");
    public String sendFlowMessage(String sessionId, String flowId, String text) throws IOException, InterruptedException {
                "flow", flowId,
                "text", text,
                "sourcePlatform", "webchat"
                .url(cognigyBaseUrl + String.format("/v1/bots/%s/sessions/%s/messages", botId, sessionId))
                .build();
        return executeWithRetry(request, "sendFlowMessage");
    private String executeWithRetry(Request request, String operation) throws IOException, InterruptedException {
        int maxRetries = 3;
        long baseDelayMs = 500;
        for (int attempt = 1; attempt <= maxRetries; attempt++) {
                if (response.isSuccessful()) {
                    return response.body().string();
                if (response.code() == 429 && attempt < maxRetries) {
                    long retryAfter = response.header("Retry-After") != null ?
                            Long.parseLong(response.header("Retry-After")) : baseDelayMs * attempt;
                    long jitter = ThreadLocalRandom.current().nextLong(0, 200);
                    Thread.sleep(retryAfter + jitter);
                    continue;
                if (response.code() == 401) {
                    // Force token refresh on next call
                    throw new IOException("Authentication expired for " + operation);
                if (response.code() == 403) {
                    throw new SecurityException("Insufficient permissions for " + operation + ". Check bot:read and session:manage roles.");
                throw new IOException("Cognigy API error " + response.code() + " on " + operation + ": " + response.message());
        throw new IOException("Max retries exceeded for " + operation);
The executeWithRetry method parses the Retry-After header when Cognigy returns a 429 status. If the header is absent, it falls back to exponential backoff. You must catch 401 responses and invalidate your cached token immediately. Cognigy invalidates tokens when credentials are rotated or when the JWT expires. The 403 response indicates missing role assignments on the API user account.
Step 3: Guest ID Correlation and AI Flow Restoration
You will now implement the core correlation logic. When a channel switch occurs, the incoming request contains a guestId. You will query Redis using that identifier. If a context exists, you will extract the cognigySessionId and currentFlowId, then invoke the Cognigy message endpoint with the flow parameter to force the AI engine to resume at the correct decision node. If no context exists, you will create a fresh session and store the initial state.
@Service
public class ChannelSwitchService {
    private final CognigyApiClient cognigyClient;
    private final RedisTemplate<String, SessionContext> redisTemplate;
    @Autowired
    public ChannelSwitchService(CognigyApiClient cognigyClient, RedisTemplate<String, SessionContext> redisTemplate) {
        this.cognigyClient = cognigyClient;
        this.redisTemplate = redisTemplate;
    public Map<String, Object> handleInboundMessage(String guestId, String platform, String messageText)
            throws Exception {
        String redisKey = String.format("cognigy:session:%s:%s", guestId, platform);
        SessionContext existingContext = redisTemplate.opsForValue().get(redisKey);
        String cognigySessionId;
        String targetFlowId = null;
        if (existingContext != null) {
            // Channel switch detected or existing session on same platform
            cognigySessionId = existingContext.cognigySessionId();
            targetFlowId = existingContext.currentFlowId();
            // Update platform if switched
            if (!existingContext.platform().equals(platform)) {
                SessionContext updated = new SessionContext(
                        existingContext.guestId(),
                        platform,
                        cognigySessionId,
                        targetFlowId,
                        existingContext.customVariables(),
                        System.currentTimeMillis()
                redisTemplate.opsForValue().set(redisKey, updated, Duration.ofMinutes(30));
        } else {
            // First interaction or session expired
            String sessionResponse = cognigyClient.createSession(guestId, platform);
            // Parse session ID from Cognigy response
            cognigySessionId = parseJsonField(sessionResponse, "sessionId");
            SessionContext newContext = new SessionContext(
                    guestId,
                    platform,
                    cognigySessionId,
                    null,
                    new ConcurrentHashMap<>(),
            redisTemplate.opsForValue().set(redisKey, newContext, Duration.ofMinutes(30));
        // Restore flow position if available
        String flowParameter = targetFlowId != null ? targetFlowId : "default-welcome-flow";
        String messageResponse = cognigyClient.sendFlowMessage(cognigySessionId, flowParameter, messageText);
        // Update context with latest flow state returned by Cognigy
        String returnedFlow = parseJsonField(messageResponse, "flowId");
        if (returnedFlow != null) {
            SessionContext updatedContext = redisTemplate.opsForValue().get(redisKey);
            if (updatedContext != null) {
                SessionContext latest = new SessionContext(
                        updatedContext.guestId(),
                        updatedContext.platform(),
                        updatedContext.cognigySessionId(),
                        returnedFlow,
                        updatedContext.customVariables(),
                redisTemplate.opsForValue().set(redisKey, latest, Duration.ofMinutes(30));
        return Map.of("status", "processed", "cognigySessionId", cognigySessionId, "response", messageResponse);
    private String parseJsonField(String json, String field) {
            com.fasterxml.jackson.databind.ObjectMapper mapper = new com.fasterxml.jackson.databind.ObjectMapper();
            return mapper.readTree(json).has(field) ? mapper.readTree(json).get(field).asText() : null;
        } catch (Exception e) {
            return null;
The handleInboundMessage method demonstrates the complete correlation lifecycle. You read from Redis first to avoid unnecessary API calls. When you detect a platform change, you update the platform field in the serialized context while preserving the cognigySessionId. Cognigy allows cross-platform message routing as long as the session ID remains valid. You send the flow parameter in the message payload to force the dialog engine to jump to the saved flow identifier. Cognigy evaluates the flow field before intent classification, which guarantees state restoration even when the user sends a generic message like “continue”.
The following module combines authentication, Redis configuration, and the correlation service into a single runnable Spring Boot application. You must replace the placeholder values in application.properties before execution.
import org.springframework.boot.SpringApplication;
import org.springframework.boot.autoconfigure.SpringBootApplication;
import org.springframework.web.bind.annotation.*;
@SpringBootApplication
public class CognigyStateService {
        SpringApplication.run(CognigyStateService.class, args);
@RestController
@RequestMapping("/api/v1/bot-interactions")
class InteractionController {
    private final ChannelSwitchService channelSwitchService;
    public InteractionController(ChannelSwitchService channelSwitchService) {
        this.channelSwitchService = channelSwitchService;
    @PostMapping("/message")
    public Map<String, Object> processMessage(@RequestBody InteractionPayload payload) {
            return channelSwitchService.handleInboundMessage(
                    payload.guestId(),
                    payload.platform(),
                    payload.text()
            return Map.of("error", e.getMessage(), "status", "failed");
record InteractionPayload(String guestId, String platform, String text) {}
cognigy.base-url=https://api.cognigy.ai
cognigy.username=your-api-username
cognigy.password=your-api-password
cognigy.bot-id=your-bot-identifier
spring.data.redis.cluster.nodes=redis-node-1:6379,redis-node-2:6380,redis-node-3:6381
spring.data.redis.password=cluster-password
spring.data.redis.ssl=true
spring.data.redis.lettuce.pool.max-active=16
spring.data.redis.lettuce.pool.max-idle=8
Run the application with mvn spring-boot:run. Send a POST request to http://localhost:8080/api/v1/bot-interactions/message with the following JSON body:
  "guestId": "guest-abc-123",
  "platform": "email",
  "text": "I need help with my order"
The service will create a Cognigy session, store the context in Redis, and return the bot response. Subsequent requests with the same guestId but different platform values will restore the exact flow position.
Error: 401 Unauthorized on Session Creation
  • What causes it: The cached JWT has expired, or the API credentials are invalid. Cognigy invalidates tokens immediately after password rotation.
  • How to fix it: Clear the tokenCache in CognigyAuthManager and trigger a fresh /v1/auth/login call. Verify that the username and password match an API user with programmatic access enabled.
  • Code fix: The isExpired() method includes a 30-second buffer. If you still receive 401, force cache eviction by calling tokenCache.clear() before the next request.
Error: 403 Forbidden on Message Endpoint
  • What causes it: The API user lacks session:manage or bot:write roles. Cognigy enforces role-based access control at the bot level.
  • How to fix it: Assign the required roles in the Cognigy administration console under API Users. Ensure the user has access to the specific botId referenced in your configuration.
  • Code fix: The executeWithRetry method throws a SecurityException on 403. Catch this exception in your controller and log the missing role claim.
  • What causes it: You exceeded Cognigy’s rate limit of 100 requests per minute per bot. Channel switch storms or retry loops trigger this limit.
  • How to fix it: Implement request batching or queue inbound messages in a message broker before forwarding them to Cognigy. The retry logic uses exponential backoff with jitter.
  • Code fix: Parse the Retry-After header. If Cognigy does not return it, increase baseDelayMs to 1000 and cap maxRetries at 2 to prevent cascading delays.
Error: Redis Cluster MOVED/ASK Redirects
  • What causes it: Lettuce client is configured for standalone mode but connects to a cluster, or the cluster configuration hash slot mapping is stale.
  • How to fix it: Use RedisClusterConfiguration instead of RedisStandaloneConfiguration. Enable spring.data.redis.cluster.max-redirects=5 to allow automatic slot resolution.
  • Code fix: Verify that RedisConfig uses LettuceConnectionFactory with cluster nodes. Add template.setEnableTransactionSupport(false) if you encounter pipeline conflicts.
