Just noticed that the performance dashboard aggregation is failing to reflect real-time queue activity for our EU-FR data residency environment. The specific issue manifests when agents complete interactions via the ‘Complex Claims Resolution’ flow, where the conversation detail views show a completed status within seconds, yet the Agent Performance metrics do not update for approximately 15-20 minutes. This latency creates a significant discrepancy in our operational reporting, particularly during peak hours when accurate staffing levels are critical. The environment is configured with strict data residency settings, which we suspect may be impacting the telemetry ingestion pipeline, although no explicit error codes are returned in the standard logs. The platform version is currently 2024-06-01, and we have verified that the OAuth tokens are valid and not expiring prematurely. The problem is not isolated to a single queue but affects all queues utilizing the legacy script framework, which suggests a potential incompatibility between the script execution engine and the new performance metric aggregation service. We have attempted to clear the browser cache and refresh the dashboard tokens, but the delay persists across different devices and users. The conversation detail views correctly log the start and end times, but the duration metrics used for service level calculations appear to be queued or processed asynchronously in a manner that introduces this unacceptable lag. We require a definitive explanation of how the data residency configuration impacts the performance dashboard’s ability to aggregate queue activity data correctly, as the current behavior undermines our ability to monitor agent performance in real-time. Is there a known workaround or a specific configuration parameter that can force immediate metric synchronization without compromising the security constraints of the EU-FR environment? We have reviewed the developer documentation for the performance API endpoints, but the information regarding data latency in restricted residency zones is sparse, leaving us without a clear path to resolution. The business impact is substantial, as our management team relies on these metrics for immediate operational adjustments, and the current 15-minute delay renders the dashboard ineffective for tactical decision-making. We need to understand if this is a platform limitation or a configuration error on our end, and what steps can be taken to mitigate the aggregation delay while maintaining compliance with our data residency requirements. Any insights into the underlying data flow between the interaction recording service and the performance analytics engine would be greatly appreciated, as we are currently unable to pinpoint the exact stage where the telemetry data is being held or processed incorrectly.
This looks like a synchronization gap between the real-time WebRTC stream and the asynchronous batch processing required for legal-compliant metadata in the EU-FR region. The 15-20 minute delay often aligns with the default chunk size for bulk export jobs when digital channel transcripts are involved.
"filter": {
"type": "conversation",
"dateFrom": "2023-10-01T00:00:00Z",
"dateTo": "2023-10-01T23:59:59Z"
"include": ["transcript", "media", "metadata"],
"metadata": {
"redaction": true,
"chainOfCustody": true
Verify if the metadata inclusion flag is triggering a secondary validation pass for PII redaction, which can throttle the aggregation pipeline during peak loads.
It varies, but usually the lag stems from the ServiceNow Data Action blocking the main thread while waiting for the EU-FR REST API response. Try implementing an asynchronous webhook pattern to decouple the ticket creation from the conversation close event.
- Configure the Data Action to return
202 Acceptedimmediately. - Use a background job in ServiceNow to process the payload.
- Update the Genesys Cloud ticket status via a separate callback.
You might want to check at the WebSocket connection pooling strategy in your load test script. The 15-20 minute lag often isn’t a backend processing issue but rather the client-side dropping the persistent connection due to idle timeouts or memory leaks during high-concurrency simulations.
In my recent JMeter tests (v5.6.2) with 500 concurrent threads, I saw similar delays when the WebSocket heartbeat interval wasn’t aligned with the GC platform_api defaults. The dashboard relies on these active streams for real-time aggregation. If the stream drops, the client waits for a full page refresh or a new handshake, which introduces that exact latency window you are seeing.
Try adjusting your JMeter WebSocket sampler to include a keep-alive ping every 15 seconds. Also, ensure you are reusing the same WebSocket instance for the duration of the test run rather than creating a new connection per iteration. Here is a quick snippet for the WebSocket Open Sampler configuration:
"endpoint": "wss://streaming.mypurecloud.com/v2/analytics/events",
"headers": {
"Authorization": "Bearer {{access_token}}"
"pingInterval": 15000,
"reconnect": true
This usually resolves the synchronization gap. The EU-FR region has stricter firewall rules that might kill idle connections faster than other regions. By forcing the keep-alive, you maintain the session state, allowing the performance metrics to update as expected. Check your server logs for WebSocket close frame received errors around the time the delay starts. That will confirm if it is a connectivity issue rather than a data pipeline bottleneck.
