We are trying to have the switch simulator generate calls that we can monitor via the Tlib.
Configuration of the switch simulator with the DNs, Queues, routepoints is completed.
Connection with the TServer is up ( CTI link is up)
We are able to run the CCA sim with a type 2 scenario (ringingwait-answer-talk-release-aftercallwork-ready) scenario set up and working. ( when the scenario is run, the test simulator interface shows the devices under the appropriate queues)
To generate calls to these agents, understand that there are two ways,
a. Create a Type1 Scenario in the test simulator and run it
b. From the Test simulator interface, in the pbx summary tab, use the interface to generate a specific number of calls.
When we execute option a) above, the test simulator starts Dialing and remains so (no calls are generated)
When we execute option b) nothing happens (ofcourse the Go is displayed in the window )
I do not have experience with a) however, when b) is not working for me it is usually because I forgot to define an entry point in the annex of the switch
ex: Annex → section ‘Simulator’
option name:
entry-point5557000
option value:
5557000, 18883695555, 1.0
‘1888…’ should come through as DNIS and 1.0 is the rate of calls / sec.
5557000 is defined as a RP on which I have my main strategy.
There may be some sparse bits on this is the 6.5 Simulator Test Toolkit document as well.
Thanks!! but this does not seem to solve the problem. is there something else that i should look out for.
I have tried making calls through the Test Simulator Interface and am able to make individual calls, however, i am unable to make the CCAsim work though!!!.
I do have the simulator user guide. Is there anyother manual that i should be referring to inorder to configure the same?
Can you please let me know what a strategy is ? and how does it help inbound call generation. I tried your post verbatim but did not understand what this ‘strategy’ is ?
It’s been a long time since you posted your question, so probably you got this working. I struggled with it today and saw your post while I was looking for a solution.
To enable automatically launching calls, I configured Switch Annex Simulator q1 and r1 like this:
The first line sets up an ACD queue with a range of extensions. After the extension range, two additional parameters can be set: autoanswer (or noautoanswer) and postready (or nopostready). You can omit the parameters and the noautoanswer and nopostready states will be the default.
The second line associates the queue with a routing point, puts in a 0 as a DNIS placeholder, and sets the speed at which calls are launched.
