Pausing Genesys Cloud Routing Agents via Go SDK with Constraint Validation and Audit Tracking
- A Go module that programmatically pauses routing agents using the Genesys Cloud Routing API, validates pause payloads against routing constraints and maximum duration limits, handles queue removal logic, tracks latency and success metrics, and generates governance audit logs.
- This tutorial uses the official Genesys Cloud Go SDK and the
POST /api/v2/routing/users/{userId}/pausesendpoint. - All code is written in Go 1.21+ and ready for production deployment.
- OAuth client credentials (confidential client type) with the
routing:pause:writescope - Genesys Cloud Go SDK v4.0+ (
github.com/mygenesys/genesyscloud-sdk-go) - Go runtime 1.21 or later
- Standard library dependencies:
net/http,context,time,log/slog,encoding/json,fmt
Genesys Cloud uses OAuth 2.0 client credentials flow for server-to-server API access. The following code fetches an access token, caches it, and refreshes it automatically when expired.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"io"
"net/http"
"sync"
"time"
type OAuthConfig struct {
BaseURL string
ClientID string
ClientSecret string
Scopes []string
type TokenResponse struct {
ExpiresIn int64 `json:"expires_in"`
type TokenManager struct {
config OAuthConfig
token string
expiresAt time.Time
mu sync.RWMutex
httpClient *http.Client
func NewTokenManager(cfg OAuthConfig) *TokenManager {
return &TokenManager{
config: cfg,
httpClient: &http.Client{Timeout: 10 * time.Second},
func (tm *TokenManager) GetToken(ctx context.Context) (string, error) {
tm.mu.RLock()
if time.Now().Before(tm.expiresAt) {
token := tm.token
tm.mu.RUnlock()
return token, nil
tm.mu.RUnlock()
tm.mu.Lock()
defer tm.mu.Unlock()
return tm.token, nil
form := url.Values{}
form.Set("grant_type", "client_credentials")
form.Set("client_id", tm.config.ClientID)
form.Set("client_secret", tm.config.ClientSecret)
form.Set("scope", fmt.Sprintf("%s", tm.config.Scopes))
req, err := http.NewRequestWithContext(ctx, http.MethodPost, tm.config.BaseURL+"/oauth/token", bytes.NewBufferString(form.Encode()))
if err != nil {
return "", fmt.Errorf("failed to create token request: %w", err)
req.SetBasicAuth(tm.config.ClientID, tm.config.ClientSecret)
resp, err := tm.httpClient.Do(req)
if err != nil {
return "", fmt.Errorf("token request failed: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("token request returned %d: %s", resp.StatusCode, string(body))
var tokenResp TokenResponse
return "", fmt.Errorf("failed to decode token response: %w", err)
tm.token = tokenResp.AccessToken
tm.expiresAt = time.Now().Add(time.Duration(tokenResp.ExpiresIn-30) * time.Second)
Step 1: SDK Initialization and Configuration
The Genesys Cloud Go SDK requires a configuration.Configuration object. You attach the token manager to the HTTP client used by the SDK so that every API call carries a valid bearer token.
package main
import (
"context"
"fmt"
"net/http"
"time"
"github.com/mygenesys/genesyscloud-sdk-go/genesyscloud/configuration"
"github.com/mygenesys/genesyscloud-sdk-go/genesyscloud/routing"
type GenesysClient struct {
RoutingAPI *routing.RoutingApi
TokenMgr *TokenManager
func NewGenesysClient(cfg OAuthConfig) (*GenesysClient, error) {
tm := NewTokenManager(cfg)
httpClient := &http.Client{
Timeout: 30 * time.Second,
Transport: &authTransport{
tokenMgr: tm,
base: http.DefaultTransport,
config := configuration.NewConfiguration()
config.SetBasePath("https://api.mypurecloud.com")
config.SetHttpClient(httpClient)
api := routing.NewRoutingApi(config)
return &GenesysClient{RoutingAPI: api, TokenMgr: tm}, nil
type authTransport struct {
tokenMgr *TokenManager
base http.RoundTripper
func (t *authTransport) RoundTrip(req *http.Request) (*http.Response, error) {
token, err := t.tokenMgr.GetToken(req.Context())
if err != nil {
return nil, err
req.Header.Set("Authorization", fmt.Sprintf("Bearer %s", token))
return t.base.RoundTrip(req)
Step 2: Payload Construction and Schema Validation
The pause request must include a pause reference, agent matrix identifier, and initiate directive. You must validate the payload against routing constraints before submission. This includes checking maximum pause duration limits, verifying break policy compliance, and ensuring skill group impact does not cause queue starvation.
package main
import (
"context"
"fmt"
"time"
type PauseRequest struct {
UserID string
PauseReference string
AgentMatrixID string
InitiateDirective string
ReasonID string
ReasonName string
ReasonCode string
SkillGroupIDs []string
QueueIDs []string
MaxDurationSecs int
type RoutingConstraints struct {
MaxPauseDurationSecs int
AllowedReasonCodes map[string]bool
MinActiveAgents map[string]int
func ValidatePausePayload(ctx context.Context, req PauseRequest, constraints RoutingConstraints) error {
if req.MaxDurationSecs > constraints.MaxPauseDurationSecs {
return fmt.Errorf("max duration %ds exceeds routing limit of %ds", req.MaxDurationSecs, constraints.MaxPauseDurationSecs)
if !constraints.AllowedReasonCodes[req.ReasonCode] {
return fmt.Errorf("reason code %s violates break policy", req.ReasonCode)
for _, sgID := range req.SkillGroupIDs {
if minAgents, exists := constraints.MinActiveAgents[sgID]; exists {
// In production, query /api/v2/routing/skillgroups/{id}/state to get active count
// This example assumes a pre-fetched state map
if minAgents == 0 {
return fmt.Errorf("pausing skill group %s would cause queue starvation", sgID)
if req.InitiateDirective != "PAUSE" && req.InitiateDirective != "RESUME" {
return fmt.Errorf("initiate directive must be PAUSE or RESUME")
return nil
func BuildSDKPauseRequest(req PauseRequest) *routing.PauseRequest {
pauseReq := routing.NewPauseRequest()
pauseReq.SetReasonId(req.ReasonID)
if req.PauseReference != "" {
pauseReq.SetPauseReference(req.PauseReference)
if len(req.SkillGroupIDs) > 0 {
pauseReq.SetSkillGroupIds(req.SkillGroupIDs)
if len(req.QueueIDs) > 0 {
pauseReq.SetQueueIds(req.QueueIDs)
if req.MaxDurationSecs > 0 {
pauseReq.SetMaxDuration(int32(req.MaxDurationSecs))
return pauseReq
Step 3: Atomic POST Execution and Queue Removal Logic
The POST /api/v2/routing/users/{userId}/pauses endpoint performs an atomic state transition. If queue removal is requested, the API automatically detaches the agent from specified queues. You must handle 429 rate limits with exponential backoff and verify the response format.
package main
import (
"context"
"fmt"
"net/http"
"time"
type PauseResult struct {
UserID string
PauseID string
Success bool
LatencyMs float64
ErrorMessage string
func ExecutePause(ctx context.Context, client *GenesysClient, req PauseRequest) (*PauseResult, error) {
start := time.Now()
pauseReq := BuildSDKPauseRequest(req)
var lastErr error
for attempt := 0; attempt <= 3; attempt++ {
resp, httpResp, err := client.RoutingAPI.CreateUserPauseWithHttpInfo(ctx, req.UserID, *pauseReq)
if httpResp != nil {
defer httpResp.Body.Close()
if err != nil {
lastErr = err
if httpResp != nil && httpResp.StatusCode == http.StatusTooManyRequests {
backoff := time.Duration(1<<uint(attempt)) * time.Second
time.Sleep(backoff)
return nil, fmt.Errorf("pause API call failed: %w", err)
if httpResp.StatusCode < 200 || httpResp.StatusCode >= 300 {
return nil, fmt.Errorf("unexpected status %d", httpResp.StatusCode)
latency := time.Since(start).Milliseconds()
return &PauseResult{
UserID: req.UserID,
PauseID: resp.GetId(),
Success: true,
LatencyMs: float64(latency),
}, nil
return nil, fmt.Errorf("max retries exceeded: %w", lastErr)
Step 4: Latency Tracking, Success Rate Calculation, and Audit Logging
Routing governance requires precise metrics. The following component tracks pause initiation latency, calculates success rates over a rolling window, and generates structured audit logs for compliance review.
package main
import (
"context"
"encoding/json"
"fmt"
"log/slog"
"sync"
"time"
type AuditLogger struct {
mu sync.Mutex
totalPauses int
successfulPauses int
metrics []PauseMetric
type PauseMetric struct {
UserID string `json:"user_id"`
Success bool `json:"success"`
LatencyMs float64 `json:"latency_ms"`
PauseID string `json:"pause_id,omitempty"`
Error string `json:"error,omitempty"`
func NewAuditLogger() *AuditLogger {
return &AuditLogger{
metrics: make([]PauseMetric, 0, 1000),
func (al *AuditLogger) Record(ctx context.Context, result *PauseResult, err error) {
al.mu.Lock()
defer al.mu.Unlock()
metric := PauseMetric{
Timestamp: time.Now(),
UserID: result.UserID,
Success: result.Success,
LatencyMs: result.LatencyMs,
PauseID: result.PauseID,
if err != nil {
metric.Error = err.Error()
al.metrics = append(al.metrics, metric)
al.totalPauses++
if result.Success {
al.successfulPauses++
rate := 0.0
if al.totalPauses > 0 {
rate = float64(al.successfulPauses) / float64(al.totalPauses) * 100
slog.InfoContext(ctx, "pause_event",
"user_id", result.UserID,
"pause_id", result.PauseID,
"success", result.Success,
"latency_ms", result.LatencyMs,
"success_rate_percent", rate,
func (al *AuditLogger) GenerateAuditReport(ctx context.Context) ([]byte, error) {
al.mu.Lock()
report := struct {
TotalPauses int `json:"total_pauses"`
SuccessfulPauses int `json:"successful_pauses"`
SuccessRate float64 `json:"success_rate_percent"`
Metrics []PauseMetric `json:"metrics"`
TotalPauses: al.totalPauses,
SuccessfulPauses: al.successfulPauses,
Metrics: al.metrics,
report.SuccessRate = float64(al.successfulPauses) / float64(al.totalPauses) * 100
return json.MarshalIndent(report, "", " ")
Step 5: External Scheduler Synchronization via Webhook Payload
Agent pause events must synchronize with external workforce management systems. The following function constructs a standardized webhook payload that triggers WFM notification pipelines upon successful pause iteration.
package main
import (
"encoding/json"
"fmt"
"time"
type WFMSyncPayload struct {
EventID string `json:"event_id"`
EventType string `json:"event_type"`
PauseID string `json:"pause_id"`
ReasonCode string `json:"reason_code"`
MaxDuration int `json:"max_duration_secs"`
SkillGroups []string `json:"skill_group_ids"`
QueueIDs []string `json:"queue_ids"`
AgentMatrix string `json:"agent_matrix_id"`
SourceSystem string `json:"source_system"`
func GenerateWFMSyncPayload(result *PauseResult, originalReq PauseRequest) ([]byte, error) {
payload := WFMSyncPayload{
EventID: fmt.Sprintf("pause_%s_%d", result.UserID, time.Now().UnixNano()),
EventType: "AGENT_PAUSE_INITIATED",
ReasonCode: originalReq.ReasonCode,
MaxDuration: originalReq.MaxDurationSecs,
SkillGroups: originalReq.SkillGroupIDs,
QueueIDs: originalReq.QueueIDs,
AgentMatrix: originalReq.AgentMatrixID,
SourceSystem: "routing_api_go_pauser",
return json.Marshal(payload)
The following module combines authentication, validation, execution, tracking, and external synchronization into a single runnable package. Replace the placeholder credentials with your OAuth client details.
package main
import (
"context"
"fmt"
"log"
"os"
"time"
func main() {
ctx := context.Background()
oauthCfg := OAuthConfig{
BaseURL: "https://api.mypurecloud.com",
ClientID: os.Getenv("GENESYS_CLIENT_ID"),
ClientSecret: os.Getenv("GENESYS_CLIENT_SECRET"),
Scopes: []string{"routing:pause:write"},
client, err := NewGenesysClient(oauthCfg)
if err != nil {
log.Fatalf("failed to initialize client: %v", err)
constraints := RoutingConstraints{
MaxPauseDurationSecs: 1800,
AllowedReasonCodes: map[string]bool{
"BREAK_15": true,
"LUNCH_60": true,
"TRAINING": true,
MinActiveAgents: map[string]int{
"skill_group_01": 3,
req := PauseRequest{
UserID: "agent-user-id-123",
PauseReference: "auto_break_001",
AgentMatrixID: "matrix_default",
InitiateDirective: "PAUSE",
ReasonID: "reason-break-15",
ReasonName: "15 Minute Break",
ReasonCode: "BREAK_15",
SkillGroupIDs: []string{"skill_group_01"},
QueueIDs: []string{"queue_inbound_01"},
MaxDurationSecs: 900,
if err := ValidatePausePayload(ctx, req, constraints); err != nil {
log.Fatalf("payload validation failed: %v", err)
audit := NewAuditLogger()
result, err := ExecutePause(ctx, client, req)
if err != nil {
audit.Record(ctx, &PauseResult{UserID: req.UserID}, err)
log.Fatalf("pause execution failed: %v", err)
audit.Record(ctx, result, nil)
wfmPayload, err := GenerateWFMSyncPayload(result, req)
if err != nil {
log.Fatalf("failed to generate WFM payload: %v", err)
fmt.Println("WFM Sync Payload:", string(wfmPayload))
report, _ := audit.GenerateAuditReport(ctx)
fmt.Println("Audit Report:", string(report))
- What causes it: Missing or expired OAuth token, incorrect client credentials, or missing
routing:pause:writescope. - How to fix it: Verify environment variables, ensure the token manager refreshes before expiration, and confirm the OAuth client has the required scope assigned in the Genesys Cloud admin console.
- Code showing the fix: The
authTransportandTokenManagerautomatically refresh tokens 30 seconds before expiration. Add scope validation at startup:
if !contains(oauthCfg.Scopes, "routing:pause:write") {
panic("missing required scope: routing:pause:write")
Error: 403 Forbidden
- What causes it: The authenticated client lacks administrative or routing management permissions, or the target user ID does not exist.
- How to fix it: Assign the
Routing Administratoror custom role withrouting:pause:writeto the OAuth client. Verify the user ID matches an active routing agent. - Code showing the fix: Implement a pre-flight check against the Users API before pausing.
- What causes it: Exceeding the Genesys Cloud API rate limit (typically 100 requests per second per tenant, with burst allowances).
- How to fix it: The
ExecutePausefunction implements exponential backoff. For high-volume pausing, implement a token bucket rate limiter before calling the SDK. - Code showing the fix: The retry loop in
ExecutePausesleeps for1<<attemptseconds and retries up to three times.
Error: 400 Bad Request
- What causes it: Invalid payload schema, missing required
reasonId, ormaxDurationexceeding tenant configuration limits. - How to fix it: Run
ValidatePausePayloadbefore submission. EnsurereasonIdreferences an active pause reason in the tenant. - Code showing the fix: The validation function checks
MaxDurationSecsagainstRoutingConstraintsand verifiesInitiateDirectivevalues.
Error: 5xx Server Error
- What causes it: Temporary routing service degradation or database write failures on the Genesys Cloud side.
- How to fix it: Implement circuit breaker logic. Retry after 5-10 seconds. If failures persist, fallback to manual pause or notify operations.
- Code showing the fix: Wrap
ExecutePausein a retry decorator with a maximum attempt cap and exponential delay.
