Passing Custom Participant Attributes Securely in Web Messaging Initiation
This guide details the architectural pattern for injecting custom participant attributes into Genesys Cloud CX Web Messaging sessions using server-side token generation and programmatic initiation. When implemented correctly, your web application will pass validated business context (order IDs, session tokens, risk scores, or segmentation tags) directly into the Genesys participant record, making those attributes immediately available to Architect routing expressions, WEM scoring logic, and post-call analytics without exposing sensitive data to the client browser.
  • Licensing Tier: CX 3 or CX 4 (Web Messaging requires CX 3 baseline). WEM Add-on required if routing to agents based on custom attribute values.
  • Administrative Permissions: Custom Attributes > Manage, Web Messaging > Widget > Edit, Architect > Flow > Edit
  • OAuth Scopes: webmessaging:widget:read, webmessaging:widget:write, webmessaging:conversation:write, routing:conversation:read, integration:integrations:read
  • External Dependencies: A secure backend service capable of RS256/ES256 JWT signing, an identity provider or session management system, and a registered Web Messaging Widget in Genesys Cloud.
1. Defining the Participant Attribute Schema
Custom attributes in Genesys Cloud are strictly typed and scoped to an entity type. For Web Messaging, you must scope attributes to Participant rather than Contact or User. Participant attributes bind to the ephemeral messaging session and persist only for the duration of the conversation or until explicitly merged into a contact record via a downstream integration. Contact attributes require a verified email or phone match, which defeats the purpose of secure, stateless web initiation.
Navigate to Admin > Custom Attributes and create a new definition. Set the Entity Type to Participant. Define the key as routing_context with a Data Type of String. Set the Visibility to Hidden if the attribute contains internal routing logic or PII that should not appear in standard agent UI fields. Enable Allow in Routing Expressions. This final flag is critical. Without it, the attribute will populate the participant record but will return null when referenced in Architect flow conditions, causing silent routing failures.
The Trap: Defining the attribute as Contact scoped. Web Messaging initiations do not automatically resolve to a contact record unless a known identifier is passed and matched against the Genesys CRM. When you scope to Contact, the platform attempts a synchronous lookup during initiation. If the lookup fails or times out, the attribute is silently dropped, and the participant enters the queue with an empty context. The architectural reasoning for Participant scoping is that it guarantees immediate availability at the Conversation Started event, decoupling routing logic from CRM latency.
2. Server-Side Token Generation and Initiation Payload Construction
Client-side attribute injection via genesyscloud.widgets.setAttributes() is fundamentally insecure. Browser console manipulation, developer tools, and malicious script injection allow end users to alter routing contexts, bypass segmentation, or inject PII into audit logs. The secure pattern requires your backend to generate a signed initiation payload or token that the client widget consumes.
Genesys Cloud supports secure initiation through the POST /api/v2/webmessaging/widgets/{widgetId}/conversations endpoint. This endpoint accepts a JSON body containing the participant attributes, which the platform validates and attaches to the session before the client establishes the WebSocket connection.
Your backend service must construct the initiation request using the exact schema below. The customAttributes object must map directly to the keys defined in Step 1.
POST https://api.mypurecloud.com/api/v2/webmessaging/widgets/{widgetId}/conversations
  "widgetId": "your-registered-widget-id",
  "customAttributes": {
    "routing_context": "priority_tier_2|order_id:88472|session_hash:a3f9c21",
    "client_ip": "192.168.10.45",
    "geo_segment": "na-east"
  "initialMessage": "I need assistance with order 88472.",
  "routing": {
    "queueId": "your-default-queue-id",
    "routingConfig": {
      "skillRequirements": [
          "skillId": "your-skill-id",
          "level": 1
Upon successful execution, the API returns a 201 Created response containing a conversationId and a token. This token is a base64-encoded, platform-signed reference that your frontend passes to the widget initialization function. The client-side implementation then calls genesyscloud.widgets.startConversation({ conversationId: response.conversationId, token: response.token }). The widget uses this token to establish the WebSocket channel. The attributes are already bound to the participant record server-side, so no client-side state synchronization is required.
The Trap: Passing attributes through the widget configuration JSON (genesyscloud.widgets.init({ config: { customAttributes: {...} } })). The widget configuration is cached in the browser and exposed in network requests. Competitors, scrapers, or compromised third-party scripts can read the configuration object. Furthermore, the configuration object does not support dynamic per-session values. The architectural reasoning for API-driven initiation is that it enforces a single source of truth for context injection, separates authentication from presentation, and allows your backend to apply business logic (rate limiting, fraud scoring, or session validation) before Genesys allocates a conversation resource.
3. Architect Flow Consumption and Routing Validation
Once the participant enters the Genesys routing layer, the custom attributes are accessible through the standard expression syntax. In Architect, navigate to your Web Messaging flow and locate the Conversation Started trigger. The attributes are immediately available in the participant.custom_attributes object.
To route based on the injected context, use a Decision block or a Split block with the following expression syntax:
{{participant.custom_attributes.routing_context}}
For structured parsing, avoid string manipulation in routing expressions. Genesys Cloud routing engine evaluates expressions synchronously, and complex string parsing introduces evaluation latency that can increase initial queue wait times. Instead, split your context into discrete attributes during Step 2. Define priority_tier, order_id, and session_hash as separate participant attributes. Route using direct equality or range checks:
{{participant.custom_attributes.priority_tier}} == "2"
If your routing logic requires external validation (for example, verifying the session_hash against your fraud prevention system), use the Fetch External Data block. Configure the block to call your validation endpoint, set a timeout of 3000 milliseconds, and map the response to a flow variable. Route based on the flow variable, not the raw participant attribute. This prevents routing stalls when the external service experiences degradation.
The Trap: Assuming custom attributes are available at the Agent Connected event without verifying their presence at Conversation Started. Web Messaging flows often include pre-chat surveys or IVR-like menu steps. If your flow modifies the participant attributes during these steps (using the Set Participant Attributes block), you must understand the mutation scope. The Set Participant Attributes block overwrites the entire customAttributes object if not configured correctly. Always use the Append or Update operation mode to preserve server-injected attributes. The architectural reasoning for discrete attribute separation and explicit update operations is that it guarantees routing determinism and prevents silent context loss during flow execution.
Edge Case 1: Type Coercion Failures in Routing Expressions
  • The failure condition: The conversation enters a default queue instead of the targeted skill-based queue. The Architect trace shows the decision block evaluating to false despite the attribute containing the expected value.
  • The root cause: Genesys Cloud routing expressions perform strict type matching. If you define priority_tier as String in Admin but pass an integer 2 in the JSON payload, the platform stores it as "2" (string) but your routing expression might evaluate {{participant.custom_attributes.priority_tier}} == 2. The type mismatch causes the evaluation to fail. Alternatively, if you pass a JSON object as a string value ({"tier":2}), the routing engine cannot parse it without an explicit json() function call, which is not supported in standard routing expressions.
  • The solution: Standardize on string types for all routing-critical attributes. Enforce type validation in your backend serialization layer before calling the Genesys API. Use explicit string comparison in Architect. If numeric comparison is required, cast the value using {{to_number(participant.custom_attributes.priority_tier) == 2}}. Document the exact serialization contract between your backend and the Genesys ingestion endpoint.
Edge Case 2: Token Expiration and Cold-Start Latency
  • The failure condition: The client widget displays a connection error or the conversation fails to initialize after the user clicks the start button. The browser console shows a 401 Unauthorized or Token Expired response from the Web Messaging gateway.
  • The root cause: The initiation token returned by the API has a default lifetime of 300 seconds. If your frontend application experiences a cold start, lazy loads the widget script, or requires additional user interaction before calling startConversation(), the token expires before consumption. Additionally, network latency between your backend and the Genesys edge can cause the token to be generated, but the client receives it after the platform’s internal validation window closes.
  • The solution: Implement a token refresh pattern in your frontend state manager. When the user interacts with the messaging UI, trigger a lightweight backend call to validate session state. If the session is active, request a fresh initiation payload. Cache the token only in memory, never in localStorage or sessionStorage, to prevent replay attacks. Configure your backend to generate tokens with a 60-second validity window and enforce strict UI timeout handling. The architectural reasoning for short-lived tokens is that it minimizes the attack surface for token theft while aligning with the ephemeral nature of web sessions.
Edge Case 3: Asynchronous Attribute Population and WEM Snapshot Misalignment
  • The failure condition: WEM (Workforce Engagement Management) reports show agents receiving conversations with incomplete context. The WEM snapshot captures the conversation state at the moment of agent assignment, but the custom attributes appear empty in the historical transcript.
  • The root cause: WEM snapshots are taken at the Agent Connected event. If your flow uses a Fetch External Data block or a Wait block to enrich attributes after the initial routing decision, the WEM snapshot captures the pre-enrichment state. Additionally, if you use a Set Participant Attributes block triggered by a downstream webhook, the update occurs after the WEM snapshot is finalized.
  • The solution: Ensure all routing-critical and WEM-tracked attributes are populated before the Queue or Select Agent block executes. If external enrichment is mandatory, use the Enrich block pattern within a pre-routing subflow. Configure the subflow to complete before the conversation enters the main routing queue. Validate the WEM snapshot configuration in Admin > WEM > Data Collection to ensure Participant Attributes are included in the capture schema. The architectural reasoning for pre-routing enrichment is that it aligns the routing engine state with the WEM telemetry state, ensuring accurate productivity and quality measurement.
