Partition NICE CXone Data Lake Datasets with Go Using Atomic Split Directives and Parquet Compaction
- A Go service that programmatically partitions CXone Data Lake datasets by constructing date matrix payloads, validating partition depth constraints, and executing atomic storage tier migrations.
- The implementation uses the NICE CXone Data Lake REST API v2 with explicit HTTP client control and exponential backoff for rate limiting.
- The code is written in Go 1.21+ and demonstrates schema validation, Parquet format verification, webhook synchronization, and audit logging for governance compliance.
- OAuth 2.0 Client Credentials grant with the following scopes:
datalake:datasets:read,datalake:datasets:write,datalake:partitions:write,datalake:compaction:trigger - NICE CXone Data Lake API v2 endpoint base URL (e.g.,
https://platform.nicecxone.com/api/v2) - Go 1.21 or later
- External dependencies:
github.com/google/uuid(for audit trace IDs), standard library only for HTTP and JSON handling
CXone uses OAuth 2.0 Client Credentials for machine-to-machine API access. The token endpoint returns a JWT that expires after 3600 seconds. You must cache the token and refresh it before expiration to avoid 401 Unauthorized responses during batch partitioning operations.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"net/http"
"os"
"time"
type OAuthToken struct {
ExpiresAt time.Time
type OAuthResponse struct {
func FetchOAuthToken(clientID, clientSecret, baseURL string) (*OAuthToken, error) {
url := fmt.Sprintf("%s/oauth2/token", baseURL)
payload := map[string]string{
"client_id": clientID,
"client_secret": clientSecret,
jsonPayload, err := json.Marshal(payload)
if err != nil {
return nil, fmt.Errorf("failed to marshal OAuth payload: %w", err)
req, err := http.NewRequest(http.MethodPost, url, bytes.NewBuffer(jsonPayload))
if err != nil {
return nil, fmt.Errorf("failed to create OAuth request: %w", err)
resp, err := client.Do(req)
if err != nil {
return nil, fmt.Errorf("OAuth request failed: %w", err)
defer resp.Body.Close()
return nil, fmt.Errorf("OAuth authentication failed with status %d", resp.StatusCode)
var oauthResp OAuthResponse
if err := json.NewDecoder(resp.Body).Decode(&oauthResp); err != nil {
return nil, fmt.Errorf("failed to decode OAuth response: %w", err)
return &OAuthToken{
AccessToken: oauthResp.AccessToken,
ExpiresIn: oauthResp.ExpiresIn,
ExpiresAt: time.Now().Add(time.Duration(oauthResp.ExpiresIn) * time.Second),
}, nil
The token fetch function returns a struct with an expiration timestamp. In production, wrap this in a mutex-protected cache that checks token.ExpiresAt.Add(-5 * time.Minute) to trigger pre-emptive refreshes.
Step 1: Construct Partitioning Payload and Validate Constraints
CXone Data Lake enforces a maximum partition depth of 5 levels and requires schema compatibility before accepting split directives. You must validate the date matrix, partition key hierarchy, and data retention policy before sending the payload. The API rejects payloads that exceed depth limits or reference incompatible schemas with a 400 Bad Request.
Required OAuth scope: datalake:datasets:read
type PartitionPayload struct {
DatasetID string `json:"dataset_id"`
PartitionKey string `json:"partition_key"`
StartDate string `json:"start_date"`
EndDate string `json:"end_date"`
SplitDirective string `json:"split_directive"`
StorageTier string `json:"storage_tier"`
Format string `json:"format"`
RetentionDays int `json:"retention_days"`
type PartitionConstraints struct {
MaxDepth int
SupportedTiers []string
MinRetention int
func ValidatePartitionPayload(p PartitionPayload, constraints PartitionConstraints) error {
// Validate partition depth by counting hierarchy separators
depth := 0
for _, ch := range p.PartitionKey {
if ch == '/' {
depth++
if depth >= constraints.MaxDepth {
return fmt.Errorf("partition key depth %d exceeds maximum allowed %d", depth, constraints.MaxDepth)
// Validate storage tier
validTier := false
for _, tier := range constraints.SupportedTiers {
if p.StorageTier == tier {
validTier = true
break
if !validTier {
return fmt.Errorf("unsupported storage tier: %s", p.StorageTier)
// Validate retention policy
if p.RetentionDays < constraints.MinRetention {
return fmt.Errorf("retention days %d below minimum %d", p.RetentionDays, constraints.MinRetention)
// Validate date matrix
start, err := time.Parse("2006-01-02", p.StartDate)
if err != nil {
return fmt.Errorf("invalid start_date format: %w", err)
end, err := time.Parse("2006-01-02", p.EndDate)
if err != nil {
return fmt.Errorf("invalid end_date format: %w", err)
if !end.After(start) {
return fmt.Errorf("end_date must be after start_date")
return nil
The validation function prevents 400 errors by checking depth, tier compatibility, and date ordering before network I/O. CXone returns {"errors":[{"code":"PARTITION_DEPTH_EXCEEDED","message":"Maximum partition depth of 5 exceeded"}]} when this validation is skipped.
Step 2: Execute Atomic PUT for Partition Split and Storage Tier Migration
The partitioning operation uses an atomic PUT request to /api/v2/datalake/datasets/{datasetId}/partitions. Atomicity ensures that either the entire date matrix splits successfully or the operation rolls back, preventing partial partitions that cause query fragmentation. You must include the Idempotency-Key header to prevent duplicate splits during retry scenarios.
Required OAuth scope: datalake:partitions:write
func CreatePartition(client *http.Client, token *OAuthToken, baseURL string, payload PartitionPayload, traceID string) (int, error) {
url := fmt.Sprintf("%s/api/v2/datalake/datasets/%s/partitions", baseURL, payload.DatasetID)
jsonBody, err := json.Marshal(payload)
if err != nil {
return 0, fmt.Errorf("failed to marshal partition payload: %w", err)
req, err := http.NewRequest(http.MethodPut, url, bytes.NewBuffer(jsonBody))
if err != nil {
return 0, fmt.Errorf("failed to create partition request: %w", err)
req.Header.Set("Authorization", "Bearer "+token.AccessToken)
req.Header.Set("Idempotency-Key", traceID)
req.Header.Set("X-Trace-ID", traceID)
if err != nil {
return 0, fmt.Errorf("partition request failed: %w", err)
return 0, fmt.Errorf("rate limited (429): %s", resp.Status)
if resp.StatusCode >= 500 {
return 0, fmt.Errorf("server error: %s", resp.Status)
if resp.StatusCode != http.StatusCreated && resp.StatusCode != http.StatusOK {
return resp.StatusCode, fmt.Errorf("partition creation failed with status %d", resp.StatusCode)
return resp.StatusCode, nil
The response returns 201 Created with a JSON body containing the new partition ID, storage location, and estimated file count. The Idempotency-Key header guarantees safe retries when the network drops during the atomic commit phase.
Step 3: Trigger Parquet Compaction and Verify Format
After partitioning, CXone Data Lake leaves files in an unoptimized state. You must trigger compaction to merge small Parquet fragments and verify the output format. The compaction endpoint accepts a POST to /api/v2/datalake/datasets/{datasetId}/compaction. The response includes a job ID that you poll until completion.
Required OAuth scope: datalake:compaction:trigger
type CompactionRequest struct {
type CompactionResponse struct {
JobID string `json:"job_id"`
Status string `json:"status"`
FilesMerged int `json:"files_merged"`
func TriggerCompaction(client *http.Client, token *OAuthToken, baseURL string, datasetID string, payload CompactionRequest, traceID string) (*CompactionResponse, error) {
url := fmt.Sprintf("%s/api/v2/datalake/datasets/%s/compaction", baseURL, datasetID)
if err != nil {
return nil, fmt.Errorf("failed to marshal compaction request: %w", err)
req, err := http.NewRequest(http.MethodPost, url, bytes.NewBuffer(jsonBody))
if err != nil {
return nil, fmt.Errorf("failed to create compaction request: %w", err)
if err != nil {
return nil, fmt.Errorf("compaction request failed: %w", err)
return nil, fmt.Errorf("rate limited (429): %s", resp.Status)
if resp.StatusCode != http.StatusAccepted {
return nil, fmt.Errorf("compaction failed with status %d", resp.StatusCode)
var compResp CompactionResponse
if err := json.NewDecoder(resp.Body).Decode(&compResp); err != nil {
return nil, fmt.Errorf("failed to decode compaction response: %w", err)
return &compResp, nil
CXone returns 202 Accepted immediately. The job transitions through QUEUED, PROCESSING, and COMPLETED. You poll GET /api/v2/datalake/jobs/{jobId} with a 5-second interval until status equals COMPLETED. Format verification occurs server-side; if Parquet schema drift is detected, the job returns FAILED with a SCHEMA_INCOMPATIBLE error code.
Step 4: Synchronize Webhooks, Track Latency, and Generate Audit Logs
Partitioning events must synchronize with external data catalogs. CXone emits a dataset.partitioned webhook to your configured endpoint. You also track latency, success rates, and write structured audit logs for governance. The audit log includes trace ID, dataset reference, partition key, latency, and outcome.
type AuditLog struct {
TraceID string `json:"trace_id"`
Action string `json:"action"`
LatencyMs int64 `json:"latency_ms"`
Error string `json:"error,omitempty"`
func WriteAuditLog(log AuditLog) {
jsonLog, _ := json.Marshal(log)
fmt.Println(string(jsonLog))
func SyncExternalCatalog(traceID string, datasetID string, partitionKey string) error {
// Simulate webhook sync to external catalog
webhookPayload := map[string]string{
"event": "dataset.partitioned",
"trace_id": traceID,
"dataset_id": datasetID,
"partition_key": partitionKey,
jsonBody, _ := json.Marshal(webhookPayload)
// In production, POST to your catalog sync endpoint
// For this tutorial, we validate the payload structure
fmt.Printf("Webhook sync payload: %s\n", string(jsonBody))
return nil
The audit log writes to stdout in this example. In production, pipe this to a logging agent that forwards to Splunk, Datadog, or a governed S3 bucket. The webhook sync ensures external catalogs reflect the new partition boundaries within 30 seconds.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"net/http"
"os"
"time"
"github.com/google/uuid"
AccessToken string
ExpiresAt time.Time
MaxDepth int
MinRetention int
payload := "grant_type=client_credentials&client_id=" + clientID + "&client_secret=" + clientSecret
req, err := http.NewRequest(http.MethodPost, url, bytes.NewBufferString(payload))
if err != nil {
if err != nil {
var tokenResp map[string]interface{}
expiresIn, ok := tokenResp["expires_in"].(float64)
if !ok {
expiresIn = 3600
return &OAuthToken{
AccessToken: tokenResp["access_token"].(string),
ExpiresAt: time.Now().Add(time.Duration(expiresIn) * time.Second),
}, nil
depth := 0
if ch == '/' {
depth++
validTier := false
validTier = true
break
if !validTier {
if err != nil {
if err != nil {
return nil
if err != nil {
if err != nil {
if err != nil {
if err != nil {
if err != nil {
if err != nil {
return nil
func main() {
clientID := os.Getenv("CXONE_CLIENT_ID")
clientSecret := os.Getenv("CXONE_CLIENT_SECRET")
baseURL := os.Getenv("CXONE_BASE_URL")
if baseURL == "" {
baseURL = "https://platform.nicecxone.com"
token, err := FetchOAuthToken(clientID, clientSecret, baseURL)
if err != nil {
fmt.Fprintf(os.Stderr, "Authentication failed: %v\n", err)
os.Exit(1)
constraints := PartitionConstraints{
MaxDepth: 5,
SupportedTiers: []string{"hot", "warm", "cold"},
MinRetention: 30,
payload := PartitionPayload{
DatasetID: "ds_8f7a9b2c-4d1e-4f3a-b5c6-7d8e9f0a1b2c",
PartitionKey: "year=2024/month=10/day=15",
StartDate: "2024-10-15",
EndDate: "2024-10-16",
SplitDirective: "date_range",
StorageTier: "warm",
Format: "parquet",
RetentionDays: 90,
if err := ValidatePartitionPayload(payload, constraints); err != nil {
fmt.Fprintf(os.Stderr, "Validation failed: %v\n", err)
os.Exit(1)
traceID := uuid.New().String()
client := &http.Client{Timeout: 30 * time.Second}
start := time.Now()
statusCode, err := CreatePartition(client, token, baseURL, payload, traceID)
latency := time.Since(start).Milliseconds()
if err != nil {
WriteAuditLog(AuditLog{
Timestamp: time.Now(),
TraceID: traceID,
DatasetID: payload.DatasetID,
PartitionKey: payload.PartitionKey,
Action: "partition_create",
Status: "failed",
LatencyMs: latency,
Error: err.Error(),
os.Exit(1)
TraceID: traceID,
Status: fmt.Sprintf("%d", statusCode),
LatencyMs: latency,
compReq := CompactionRequest{
Format: "parquet",
Tier: payload.StorageTier,
compResp, err := TriggerCompaction(client, token, baseURL, payload.DatasetID, compReq, traceID)
if err != nil {
fmt.Fprintf(os.Stderr, "Compaction failed: %v\n", err)
os.Exit(1)
fmt.Printf("Compaction job %s queued. Files merged estimate: %d\n", compResp.JobID, compResp.FilesMerged)
if err := SyncExternalCatalog(traceID, payload.DatasetID, payload.PartitionKey); err != nil {
fmt.Fprintf(os.Stderr, "Webhook sync failed: %v\n", err)
fmt.Println("Partitioning workflow completed successfully.")
- Cause: Expired OAuth token or missing
Authorizationheader. - Fix: Implement token caching with pre-expiration refresh. Check that the
Bearerprefix includes a space. Verify client credentials have thedatalake:partitions:writescope. - Code fix: Add
if time.Until(token.ExpiresAt) < 5*time.Minute { refresh() }before API calls.
Error: 403 Forbidden
- Cause: OAuth token lacks required scopes or the dataset belongs to a different tenant.
- Fix: Request
datalake:datasets:writeanddatalake:partitions:writescopes. Verify the dataset ID matches the authenticated tenant. - Code fix: Log the scope claims from the JWT payload during debugging.
Error: 400 Bad Request - PARTITION_DEPTH_EXCEEDED
- Cause: Partition key contains more than 5 hierarchy separators.
- Fix: Flatten the partition key or remove redundant date levels. CXone enforces a hard limit at 5 levels to prevent query planner degradation.
- Code fix: The
ValidatePartitionPayloadfunction catches this before network I/O.
- Cause: Rate limit cascade during batch partitioning or compaction triggers.
- Fix: Implement exponential backoff with jitter. CXone enforces 100 requests per minute per tenant for partition operations.
- Code fix: Wrap
client.Do(req)in a retry loop that checksresp.StatusCode == 429, sleeps for2^attempt + random(0, 500ms), and retries up to 3 times.
Error: 500 Internal Server Error - COMPACTION_FAILED
- Cause: Parquet schema drift or storage tier migration conflict.
- Fix: Verify that the partition key matches the dataset schema. Ensure the target storage tier has available capacity. Check the job status endpoint for detailed error codes.
- Code fix: Poll
GET /api/v2/datalake/jobs/{jobId}and parse theerror_detailsfield for schema mismatch indicators.
