Parsing NICE CXone Email Header Chains with Go for Provenance and Spoof Detection
A Go module that retrieves raw email headers from the NICE CXone Email API, reconstructs the routing path, validates hop counts, checks DKIM alignment, detects missing relays, and triggers security webhooks. This tutorial uses the CXone REST API with standard Go net/http client patterns. The programming language covered is Go 1.21+.
- NICE CXone OAuth 2.0 client credentials (Client ID and Client Secret)
- Required OAuth scopes:
email.read,email.headers.read - CXone API version:
v2 - Go runtime:
1.21or higher - Standard library dependencies only:
net/http,context,time,encoding/json,log/slog,strings,net/netip,fmt,errors
NICE CXone uses standard OAuth 2.0 client credentials flow. The token endpoint follows the pattern https://{region}.cxone.com/oauth/token. You must cache the token and refresh it before expiry to avoid 401 errors during batch parsing.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"net/http"
"time"
type CXoneAuthConfig struct {
Region string
ClientID string
ClientSecret string
type OAuthTokenResponse struct {
type CXoneClient struct {
AuthConfig CXoneAuthConfig
HTTPClient *http.Client
Token string
TokenExpiry time.Time
func NewCXoneClient(cfg CXoneAuthConfig) *CXoneClient {
return &CXoneClient{
AuthConfig: cfg,
HTTPClient: &http.Client{Timeout: 15 * time.Second},
func (c *CXoneClient) EnsureToken(ctx context.Context) error {
if c.Token != "" && time.Until(c.TokenExpiry) > 30*time.Second {
return nil
payload := fmt.Sprintf(
"grant_type=client_credentials&client_id=%s&client_secret=%s",
c.AuthConfig.ClientID, c.AuthConfig.ClientSecret,
req, err := http.NewRequestWithContext(ctx, http.MethodPost,
fmt.Sprintf("https://%s.cxone.com/oauth/token", c.AuthConfig.Region),
bytes.NewBufferString(payload))
if err != nil {
return fmt.Errorf("failed to create token request: %w", err)
resp, err := c.HTTPClient.Do(req)
if err != nil {
return fmt.Errorf("token request failed: %w", err)
defer resp.Body.Close()
return fmt.Errorf("token request returned %d", resp.StatusCode)
var tokenResp OAuthTokenResponse
return fmt.Errorf("failed to decode token response: %w", err)
c.Token = tokenResp.AccessToken
c.TokenExpiry = time.Now().Add(time.Duration(tokenResp.ExpiresIn) * time.Second)
return nil
The EnsureToken method checks cache validity, constructs the client credentials payload, and handles HTTP errors. It returns immediately if a valid token exists within a 30-second safety window.
Step 1: Fetch Email Headers with Atomic HTTP GET and Retry Logic
The CXone Email API v2 exposes header data at GET /api/v2/emails/{emailId}. The response contains a headers array. You must handle 429 rate limits with exponential backoff and validate the response schema before parsing.
type CXoneEmailResponse struct {
ID string `json:"id"`
Headers []CXoneHeader `json:"headers"`
Raw string `json:"raw,omitempty"`
type CXoneHeader struct {
Name string `json:"name"`
Value string `json:"value"`
func (c *CXoneClient) GetEmailHeaders(ctx context.Context, emailID string) ([]CXoneHeader, error) {
if err := c.EnsureToken(ctx); err != nil {
return nil, fmt.Errorf("authentication failed: %w", err)
url := fmt.Sprintf("https://%s.cxone.com/api/v2/emails/%s", c.AuthConfig.Region, emailID)
var headers []CXoneHeader
// Retry logic for 429
maxRetries := 3
for attempt := 0; attempt <= maxRetries; attempt++ {
req, err := http.NewRequestWithContext(ctx, http.MethodGet, url, nil)
if err != nil {
return nil, fmt.Errorf("request creation failed: %w", err)
req.Header.Set("Authorization", "Bearer "+c.Token)
if err != nil {
return nil, fmt.Errorf("request failed: %w", err)
wait := time.Duration(1<<uint(attempt)) * time.Second
time.Sleep(wait)
if resp.StatusCode == http.StatusUnauthorized {
c.Token = "" // Force refresh
return nil, fmt.Errorf("unexpected status %d", resp.StatusCode)
var emailResp CXoneEmailResponse
if err := json.NewDecoder(resp.Body).Decode(&emailResp); err != nil {
return nil, fmt.Errorf("JSON decode failed: %w", err)
headers = emailResp.Headers
break
return headers, nil
The retry loop handles 429 responses with exponential backoff. It clears the cached token on 401 to trigger a refresh. The endpoint returns headers as key-value pairs, which eliminates the need for raw RFC 822 parsing.
Step 2: Construct Route-Matrix and Validate SMTP Hop Constraints
Email routing chains reside in Received: headers. You must parse them bottom-to-top to reconstruct the path. RFC 5321 recommends limiting hop counts to prevent infinite loops and parsing failures. This step builds the route-matrix and enforces a maximum hop count of 50.
type RouteHop struct {
Sequence int
FromIP string
ViaDomain string
Timestamp string
Raw string
type ParseResult struct {
RouteMatrix []RouteHop
HopCount int
Valid bool
Flags []string
func BuildRouteMatrix(headers []CXoneHeader) (*ParseResult, error) {
const maxHops = 50
var receivedHeaders []string
for _, h := range headers {
if strings.EqualFold(h.Name, "Received") {
receivedHeaders = append(receivedHeaders, h.Value)
if len(receivedHeaders) == 0 {
return &ParseResult{Valid: false, Flags: []string{"MISSING_RECEIVED_HEADERS"}}, nil
if len(receivedHeaders) > maxHops {
return &ParseResult{Valid: false, Flags: []string{"EXCEEDS_MAX_HOP_COUNT"}}, nil
var matrix []RouteHop
// Process bottom-to-top (last Received is the first hop)
for i := len(receivedHeaders) - 1; i >= 0; i-- {
hop := parseSingleHop(i+1, receivedHeaders[i])
matrix = append(matrix, hop)
RouteMatrix: matrix,
HopCount: len(matrix),
Valid: true,
Flags: []string{},
}, nil
func parseSingleHop(seq int, raw string) RouteHop {
hop := RouteHop{Sequence: seq, Raw: raw}
// Extract IP from "from [IP]" pattern
if idx := strings.Index(raw, "from ["); idx != -1 {
end := strings.Index(raw[idx:], "]")
if end != -1 {
hop.FromIP = raw[idx+6 : idx+end]
// Extract domain from "via domain.com" pattern
if idx := strings.Index(raw, "via "); idx != -1 {
end := strings.Index(raw[idx:], " ")
if end == -1 {
end = len(raw) - idx
hop.ViaDomain = raw[idx+4 : idx+end]
return hop
The BuildRouteMatrix function isolates Received headers, validates the hop count against the 50-hop limit, and processes them in reverse chronological order. The parseSingleHop helper extracts IP and domain values using string indexing. This approach avoids regex overhead and maintains deterministic parsing.
Step 3: DKIM Alignment, Missing Relay Detection, and Spoof Evaluation
Provenance validation requires checking DKIM signatures, verifying relay continuity, and evaluating spoof indicators. You will scan Authentication-Results for DKIM status, check for IP gaps in the route-matrix, and compare envelope sender domains against the From header.
func EvaluateProvenance(headers []CXoneHeader, routeMatrix *ParseResult) *ParseResult {
if !routeMatrix.Valid {
return routeMatrix
var dkimStatus string
var fromDomain string
var envelopeSenderDomain string
switch strings.ToLower(h.Name) {
case "authentication-results":
if strings.Contains(strings.ToLower(h.Value), "dkim=pass") {
dkimStatus = "pass"
} else if strings.Contains(strings.ToLower(h.Value), "dkim=fail") {
dkimStatus = "fail"
case "from":
if idx := strings.Index(h.Value, "<"); idx != -1 {
end := strings.Index(h.Value[idx:], ">")
if end != -1 {
fromDomain = h.Value[idx+1 : idx+end]
case "return-path":
if end != -1 {
envelopeSenderDomain = h.Value[idx+1 : idx+end]
// DKIM Alignment Check
if dkimStatus == "fail" {
routeMatrix.Flags = append(routeMatrix.Flags, "DKIM_MISMATCH")
// Missing Relay Detection
for i := 1; i < len(routeMatrix.RouteMatrix); i++ {
prev := routeMatrix.RouteMatrix[i-1]
curr := routeMatrix.RouteMatrix[i]
// If current hop IP does not match previous hop via domain IP range, flag gap
if prev.FromIP != "" && curr.FromIP != "" && prev.FromIP != curr.FromIP {
// Simplified gap detection for tutorial scope
routeMatrix.Flags = append(routeMatrix.Flags, fmt.Sprintf("RELAY_GAP_HOP_%d", i))
break
// Spoof Detection Logic
if fromDomain != "" && envelopeSenderDomain != "" {
if !strings.HasSuffix(envelopeSenderDomain, fromDomain) && dkimStatus != "pass" {
routeMatrix.Flags = append(routeMatrix.Flags, "SPOOF_SUSPECT")
return routeMatrix
This pipeline extracts DKIM status, normalizes domain values, and applies deterministic checks. The missing relay detection compares consecutive hop IPs to identify routing discontinuities. The spoof evaluation compares envelope sender and display sender domains against DKIM results.
Step 4: Webhook Synchronization, Latency Tracking, and Audit Logging
You must synchronize parsing events with external security gateways, track execution latency, and generate structured audit logs. This step wraps the parsing logic, measures duration, posts flag payloads to a webhook, and writes governance logs.
type AuditLog struct {
Timestamp string `json:"timestamp"`
EmailID string `json:"email_id"`
HopCount int `json:"hop_count"`
LatencyMs int64 `json:"latency_ms"`
Flags []string `json:"flags"`
Status string `json:"status"`
func ParseAndSync(ctx context.Context, client *CXoneClient, emailID string, webhookURL string) (*AuditLog, error) {
start := time.Now()
slog.Info("starting email parse", "email_id", emailID)
headers, err := client.GetEmailHeaders(ctx, emailID)
if err != nil {
slog.Error("header fetch failed", "email_id", emailID, "error", err)
return nil, err
routeMatrix, err := BuildRouteMatrix(headers)
if err != nil {
slog.Error("route matrix build failed", "email_id", emailID, "error", err)
return nil, err
result := EvaluateProvenance(headers, routeMatrix)
latency := time.Since(start).Milliseconds()
auditLog := &AuditLog{
Timestamp: time.Now().UTC().Format(time.RFC3339),
EmailID: emailID,
HopCount: result.HopCount,
LatencyMs: latency,
Flags: result.Flags,
Status: "completed",
// Webhook synchronization for flagged emails
if len(result.Flags) > 0 {
if err := triggerWebhook(ctx, webhookURL, auditLog); err != nil {
slog.Warn("webhook sync failed", "error", err)
slog.Info("parse complete", "email_id", emailID, "latency_ms", latency, "flags", result.Flags)
return auditLog, nil
func triggerWebhook(ctx context.Context, url string, log *AuditLog) error {
payload, err := json.Marshal(log)
if err != nil {
return fmt.Errorf("webhook marshal failed: %w", err)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, url, bytes.NewBuffer(payload))
if err != nil {
return fmt.Errorf("webhook request creation failed: %w", err)
resp, err := client.Do(req)
if err != nil {
return fmt.Errorf("webhook request failed: %w", err)
if resp.StatusCode >= 400 {
return fmt.Errorf("webhook returned %d", resp.StatusCode)
return nil
The ParseAndSync function orchestrates the entire pipeline. It measures wall-clock latency, constructs a structured audit log, and posts to the security gateway webhook only when flags are present. The triggerWebhook helper enforces a short timeout to prevent blocking the main parsing thread.
The following module combines authentication, header fetching, route-matrix construction, provenance evaluation, webhook synchronization, and audit logging into a single executable package.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"log/slog"
"net/http"
"strings"
"time"
Region string
ClientID string
ClientSecret string
Token string
Sequence int
FromIP string
ViaDomain string
Timestamp string
Raw string
HopCount int
Valid bool
Flags []string
AuthConfig: cfg,
return nil
if err != nil {
if err != nil {
return nil
maxRetries := 3
if err != nil {
if err != nil {
time.Sleep(time.Duration(1<<uint(attempt)) * time.Second)
c.Token = ""
break
return headers, nil
const maxHops = 50
hop := RouteHop{Sequence: i + 1, Raw: receivedHeaders[i]}
if idx := strings.Index(receivedHeaders[i], "from ["); idx != -1 {
end := strings.Index(receivedHeaders[i][idx:], "]")
if end != -1 {
hop.FromIP = receivedHeaders[i][idx+6 : idx+end]
if idx := strings.Index(receivedHeaders[i], "via "); idx != -1 {
end := strings.Index(receivedHeaders[i][idx:], " ")
if end == -1 {
end = len(receivedHeaders[i]) - idx
hop.ViaDomain = receivedHeaders[i][idx+4 : idx+end]
return &ParseResult{RouteMatrix: matrix, HopCount: len(matrix), Valid: true, Flags: []string{}}, nil
return routeMatrix
dkimStatus = "pass"
dkimStatus = "fail"
case "from":
if end != -1 {
case "return-path":
if end != -1 {
break
return routeMatrix
if err != nil {
if err != nil {
if err != nil {
return nil
start := time.Now()
if err != nil {
return nil, err
if err != nil {
return nil, err
EmailID: emailID,
LatencyMs: latency,
func main() {
ctx := context.Background()
cfg := CXoneAuthConfig{
Region: "api-us-1",
ClientID: "YOUR_CLIENT_ID",
ClientSecret: "YOUR_CLIENT_SECRET",
client := NewCXoneClient(cfg)
log, err := ParseAndSync(ctx, client, "8a8b9c0d-1e2f-3a4b-5c6d-7e8f9a0b1c2d", "https://security-gateway.example.com/webhooks/cxone-headers")
if err != nil {
slog.Error("pipeline failed", "error", err)
return
fmt.Printf("Audit Log: %+v\n", log)
Error: HTTP 401 Unauthorized
- Cause: Expired OAuth token or invalid client credentials. The CXone API rejects requests when the bearer token expires.
- Fix: Ensure
EnsureTokenruns before every API call. Clear the cached token on 401 to force a refresh cycle. Verify that the client credentials haveemail.readandemail.headers.readscopes assigned in the CXone admin console. - Code: The retry loop in
GetEmailHeadersautomatically resetsc.Token = ""on 401, triggering a fresh token fetch on the next iteration.
Error: HTTP 403 Forbidden
- Cause: Missing OAuth scopes or insufficient tenant permissions. The CXone platform enforces granular scope validation.
- Fix: Request
email.readandemail.headers.readduring OAuth token generation. Confirm the API user has read access to the email module in CXone. - Code: Add scope validation during client initialization. Return a descriptive error if the token response lacks expected claims.
- Cause: Exceeding CXone rate limits. The Email API enforces per-minute request caps.
- Fix: Implement exponential backoff. The complete example includes a retry loop with
time.Sleep(time.Duration(1<<uint(attempt)) * time.Second). - Code: The retry logic in
GetEmailHeaderscatches 429, sleeps, and retries up to three times before failing.
Error: EXCEEDS_MAX_HOP_COUNT or MISSING_RECEIVED_HEADERS
- Cause: Malformed email routing or stripped headers by upstream gateways. Some security appliances strip
Receivedheaders to prevent header injection attacks. - Fix: Adjust the
maxHopsconstant if your infrastructure requires deeper tracing. Log the email ID for manual inspection when headers are missing. - Code: The
BuildRouteMatrixfunction returns aParseResultwith explicit flags. The audit log captures these flags for downstream investigation.
Error: Webhook Timeout or 5xx Response
- Cause: External security gateway is unreachable or overloaded. Blocking webhook calls degrade parsing throughput.
- Fix: Use a background goroutine for webhook delivery or implement a message queue. The example uses a short 5-second timeout to prevent thread starvation.
- Code: The
triggerWebhookfunction enforceshttp.Client{Timeout: 5 * time.Second}and logs warnings instead of failing the entire pipeline.
