Parsing NICE Cognigy Webhook Payloads with Node.js: Template Processing, Validation, and Audit Logging
- A production-grade Node.js webhook service that receives, validates, and transforms NICE Cognigy bot response payloads.
- Uses the Cognigy Webhook API schema with custom template interpolation, variable directive resolution, and strict schema validation.
- Implemented in Node.js with Express, Zod, sanitize-html, and structured audit logging.
- Cognigy Studio project with a Webhook integration configured to POST to your endpoint
- Cognigy API Key for webhook authentication (
X-Cognigy-API-Keyheader) - Node.js 18.0+ runtime with npm or pnpm
- External dependencies:
express,zod,sanitize-html,pino,uuid,crypto - Understanding of Cognigy’s inbound webhook payload structure and expected response format
Cognigy webhooks do not use OAuth 2.0. Instead, they authenticate via an API key passed in the X-Cognigy-API-Key header. The key is generated in Cognigy Studio under Project Settings > API Keys. Your endpoint must verify this header before processing any payload. The following middleware validates the key and rejects unauthorized requests with a 401 status.
import express from 'express';
import crypto from 'crypto';
const COGNIGY_API_KEY = process.env.COGNIGY_API_KEY || 'your-cognigy-api-key-here';
const authenticateCognigy = (req, res, next) => {
const providedKey = req.headers['x-cognigy-api-key'];
if (!providedKey) {
return res.status(401).json({
error: 'Unauthorized',
message: 'Missing X-Cognigy-API-Key header'
// Constant-time comparison to prevent timing attacks
const isValid = crypto.timingSafeEqual(
Buffer.from(providedKey),
Buffer.from(COGNIGY_API_KEY)
if (!isValid) {
return res.status(403).json({
error: 'Forbidden',
message: 'Invalid Cognigy API key'
req.authTimestamp = Date.now();
next();
export default authenticateCognigy;
The middleware performs a constant-time string comparison to mitigate timing attacks. It returns 401 for missing headers and 403 for invalid keys. Cognigy will retry failed webhooks with exponential backoff if your endpoint returns 5xx errors. You must return 2xx for successful parsing.
Step 1: Payload Reception and Schema Validation
Cognigy sends a JSON payload containing conversation metadata, user input, and a variable matrix. You must validate this payload against the webhook engine constraints before processing. The following Zod schema enforces required fields, type safety, and maximum string interpolation limits.
import { z } from 'zod';
const MAX_INTERPOLATION_LENGTH = 2048;
const MAX_TEMPLATE_DEPTH = 5;
const CognigyPayloadSchema = z.object({
conversationId: z.string().uuid('Invalid conversationId format'),
userId: z.string().min(1, 'userId is required'),
input: z.string().max(1000, 'Input exceeds maximum length'),
variables: z.record(z.string()).optional().default({}),
language: z.string().regex(/^[a-z]{2}-[A-Z]{2}$/, 'Invalid language format'),
platform: z.enum(['webchat', 'slack', 'teams', 'whatsapp', 'voice']),
sessionId: z.string().uuid('Invalid sessionId format'),
templateDirective: z.string().optional(),
responseId: z.string().optional()
}).refine((data) => {
if (data.templateDirective && data.templateDirective.length > MAX_INTERPOLATION_LENGTH) {
return false;
return true;
message: `Template directive exceeds maximum interpolation limit of ${MAX_INTERPOLATION_LENGTH} characters`
export default CognigyPayloadSchema;
The schema validates UUID formats for conversationId and sessionId, enforces platform enums, and checks the templateDirective against the maximum string interpolation limit. Cognigy expects your endpoint to fail fast on invalid schemas. You will catch validation errors and return a 400 response with the exact field that failed.
Step 2: Template Matrix and Variable Directive Processing
Cognigy passes a variable matrix in the variables object. Your parser must resolve placeholder references like {variableName} against this matrix. The following function implements placeholder resolution checking, escape sequence verification, and depth limiting to prevent infinite recursion or injection.
import { MAX_TEMPLATE_DEPTH } from './schema.js';
const ESCAPE_SEQUENCE_REGEX = /\\[{}$]/g;
const PLACEHOLDER_REGEX = /\{([a-zA-Z0-9_]+)\}/g;
export function resolveTemplateMatrix(template, variables, depth = 0) {
if (depth > MAX_TEMPLATE_DEPTH) {
throw new Error('Template interpolation depth limit exceeded');
if (typeof template !== 'string') {
return template;
// Restore escaped sequences after processing
const restored = template.replace(ESCAPE_SEQUENCE_REGEX, (match) => {
return match.slice(1);
let resolved = restored;
let hasPlaceholders = true;
while (hasPlaceholders && depth <= MAX_TEMPLATE_DEPTH) {
hasPlaceholders = false;
resolved = resolved.replace(PLACEHOLDER_REGEX, (match, key) => {
if (Object.prototype.hasOwnProperty.call(variables, key)) {
return variables[key];
return match;
depth++;
return resolved;
The function tracks interpolation depth to prevent stack overflow. It uses a regex pipeline to identify placeholders and replaces them with values from the variable matrix. Unresolved placeholders remain intact so the bot can display fallback text. The escape sequence verification pipeline ensures that literal braces or dollar signs are not misinterpreted during resolution.
Step 3: Markdown Sanitization and Injection Prevention
Bot responses often contain markdown formatting. You must sanitize all interpolated text to prevent HTML injection, XSS vulnerabilities, and malformed markdown during scaling. The following pipeline applies automatic markdown sanitization triggers and verifies escape sequences before rendering.
import sanitizeHtml from 'sanitize-html';
const ALLOWED_TAGS = ['p', 'br', 'strong', 'em', 'ul', 'ol', 'li', 'a', 'code', 'pre'];
const ALLOWED_ATTR = {
a: ['href', 'title', 'target'],
code: ['class'],
pre: ['class']
export function sanitizeBotResponse(text) {
if (typeof text !== 'string') return text;
const cleaned = sanitizeHtml(text, {
allowedTags: ALLOWED_TAGS,
allowedAttributes: ALLOWED_ATTR,
transformTags: {
a: (tagName, attribs) => {
if (attribs.href && !attribs.href.startsWith('http')) {
delete attribs.href;
return { tagName, attribs };
selfClosing: ['br', 'img']
return cleaned.trim();
The sanitization pipeline strips disallowed tags, blocks non-HTTP protocols in links, and preserves safe markdown structure. Cognigy’s rendering engine expects clean HTML or plain text. This function ensures that external data injected via the variable matrix cannot execute scripts or break the chat interface.
Step 4: Analytics Synchronization and Audit Logging
You must track parsing latency, generation success rates, and synchronization events for bot governance. The following logger captures structured audit logs and calculates metrics without blocking the response thread.
import pino from 'pino';
const logger = pino({
transport: {
target: 'pino-pretty',
options: { colorize: true }
export const metricsStore = {
totalRequests: 0,
successfulParses: 0,
failedParses: 0,
totalLatencyMs: 0,
lastAuditId: null
export function trackParseEvent(event) {
const auditId = uuidv4();
const timestamp = new Date().toISOString();
metricsStore.totalRequests++;
if (event.success) {
metricsStore.successfulParses++;
} else {
metricsStore.failedParses++;
metricsStore.totalLatencyMs += event.latencyMs;
metricsStore.lastAuditId = auditId;
logger.info({
auditId,
timestamp,
conversationId: event.conversationId,
sessionId: event.sessionId,
platform: event.platform,
latencyMs: event.latencyMs,
success: event.success,
error: event.error || null,
responseId: event.responseId || null,
governance: 'webhook-parse-audit',
analyticsSync: true
}, 'Cognigy Webhook Parse Event');
return auditId;
The metrics store accumulates request counts, success/failure ratios, and cumulative latency. The structured log includes governance and analyticsSync flags for downstream analytics loggers. You can forward these logs to Splunk, Datadog, or ELK via pino transport configuration.
Step 5: Exposing the Parser for Automated Management
Cognigy administrators require visibility into parser health. The following GET endpoint returns format-verified metrics and audit status for automated management dashboards.
const router = express.Router();
router.get('/api/parser/metrics', (req, res) => {
const total = metricsStore.totalRequests;
const successRate = total > 0 ? (metricsStore.successfulParses / total) * 100 : 0;
const avgLatency = total > 0 ? metricsStore.totalLatencyMs / total : 0;
res.json({
status: 'active',
metrics: {
totalRequests: total,
successfulParses: metricsStore.successfulParses,
failedParses: metricsStore.failedParses,
successRate: parseFloat(successRate.toFixed(2)),
averageLatencyMs: parseFloat(avgLatency.toFixed(2)),
lastAuditId: metricsStore.lastAuditId
constraints: {
maxInterpolationLength: 2048,
maxTemplateDepth: 5,
sanitizationEnabled: true
export default router;
The endpoint returns a deterministic JSON structure with success rates, latency averages, and constraint boundaries. External automation tools can poll this endpoint to verify parser health and trigger alerts when success rates drop below thresholds.
import authenticateCognigy from './auth.js';
import CognigyPayloadSchema from './schema.js';
import { resolveTemplateMatrix } from './template.js';
import { sanitizeBotResponse } from './sanitization.js';
import { trackParseEvent, metricsStore } from './analytics.js';
import metricsRouter from './metrics.js';
const app = express();
app.use(express.json({ limit: '1mb' }));
app.use('/api', metricsRouter);
app.post('/webhook/cognigy', authenticateCognigy, (req, res) => {
const startTime = Date.now();
const auditPayload = {
conversationId: req.body?.conversationId || 'unknown',
sessionId: req.body?.sessionId || 'unknown',
platform: req.body?.platform || 'unknown',
responseId: req.body?.responseId || null,
success: false,
latencyMs: 0,
error: null
const parsed = CognigyPayloadSchema.parse(req.body);
const template = parsed.templateDirective || 'Hello {userId}, your session is {sessionId}.';
const resolved = resolveTemplateMatrix(template, parsed.variables);
const sanitized = sanitizeBotResponse(resolved);
const cognigyResponse = {
responses: [
text: sanitized,
type: 'text',
responseId: parsed.responseId || `resp_${Date.now()}`
variables: {
...parsed.variables,
parsedTimestamp: new Date().toISOString(),
parserVersion: '1.0.0'
flow: 'continue'
auditPayload.success = true;
auditPayload.latencyMs = Date.now() - startTime;
auditPayload.responseId = cognigyResponse.responses[0].responseId;
trackParseEvent(auditPayload);
res.status(200).json(cognigyResponse);
} catch (error) {
auditPayload.error = error.message;
if (error.name === 'ZodError') {
return res.status(400).json({
error: 'ValidationFailed',
details: error.errors.map((e) => ({ field: e.path.join('.'), message: e.message }))
return res.status(500).json({
error: 'InternalProcessingError',
message: 'Failed to parse Cognigy webhook payload'
const PORT = process.env.PORT || 3000;
app.listen(PORT, () => {
console.log(`Cognigy Webhook Parser running on port ${PORT}`);
The complete example wires authentication, schema validation, template resolution, sanitization, and analytics tracking into a single Express application. It returns compliant Cognigy response objects with responses, variables, and flow control fields. The error handler distinguishes between validation failures (400) and processing errors (500).
Error: 400 ValidationFailed
- What causes it: The incoming payload violates Zod schema constraints. Common triggers include missing
conversationId, invalid UUID formats, or template directives exceeding the 2048 character limit. - How to fix it: Verify that Cognigy Studio sends the exact field names expected by the schema. Adjust the
templateDirectivelength or split large templates across multiple variable directives. - Code showing the fix: The error handler maps
ZodErrorto a structured 400 response with field-level details. Add logging to capture the raw payload before validation for debugging.
Error: 401 Unauthorized / 403 Forbidden
X-Cognigy-API-Keyheader is missing or does not match the configured key. - How to fix it: Rotate the API key in Cognigy Studio and update the environment variable. Ensure your load balancer or reverse proxy does not strip custom headers.
- Code showing the fix: The authentication middleware uses
crypto.timingSafeEqualfor secure comparison. Verify that the header name matches exactly, including case sensitivity.
Error: 500 InternalProcessingError
- What causes it: Template interpolation depth exceeded, sanitize-html threw an unexpected exception, or memory limits were breached during scaling.
- How to fix it: Reduce nested variable references in Cognigy Studio. Increase Node.js heap size with
--max-old-space-size. Add circuit breakers for external analytics loggers. - Code showing the fix: The
resolveTemplateMatrixfunction throws on depth limits. Wrap the template resolution in a try-catch block and fallback to a static message if processing fails.
- What causes it: Cognigy sends webhook bursts during peak traffic. Your endpoint hits rate limits or connection pools exhaust.
- How to fix it: Implement async queue processing for analytics logging. Use connection pooling for external databases. Return 202 Accepted with a delayed processing acknowledgment if Cognigy supports it.
- Code showing the fix: Offload
trackParseEventto a background worker usingsetImmediateor a message queue. Ensure the HTTP response returns before analytics synchronization completes.
