Parsing Complex Nested JSON Payloads from External ERP Systems in Genesys Cloud Data Actions Using Python JSONPath
A Python service that receives a deeply nested ERP transaction payload, extracts specific fields using JSONPath expressions, and returns a flattened schema compliant with Genesys Cloud Data Actions. This tutorial uses the Genesys Cloud Python SDK for authentication and invocation, plus the jsonpath-ng library for parsing. The implementation covers Python.
  • OAuth Client Credentials flow with scopes: action:read, action:write, user:login
  • Genesys Cloud Python SDK: genesys-cloud-sdk-python v2.10.0 or higher
  • Python 3.9+ runtime
  • External dependencies: pip install genesys-cloud-sdk-python jsonpath-ng requests tenacity
  • A configured Data Action in Genesys Cloud Flow Builder with a POST endpoint receiving the ERP payload
  • Base URL: https://{your-domain}.mygen.com
Genesys Cloud uses OAuth 2.0 Client Credentials for server-to-server communication. The Python SDK handles token acquisition and refresh automatically when initialized with a configuration object. You must cache the token to avoid repeated network calls and implement exponential backoff for rate limits.
import os
import logging
from typing import Optional
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
from genesyscloud import PlatformClient, ClientConfiguration
logging.basicConfig(level=logging.INFO, format="%(asctime)s - %(levelname)s - %(message)s")
def create_platform_client() -> PlatformClient:
    """Initializes the Genesys Cloud SDK with OAuth configuration."""
    env = os.getenv("GENESYS_ENV", "us-east-1")
        raise ValueError("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET environment variables are required")
    config = ClientConfiguration(
        env_url=f"https://{env}.mygen.com",
        client_id=client_id,
        client_secret=client_secret
    platform_client = PlatformClient(config)
    # Force initial token fetch to validate credentials
    platform_client.login()
    logger.info("OAuth token acquired successfully")
    return platform_client
The SDK caches the access token in memory and automatically refreshes it before expiration. You must handle network failures during the refresh cycle by catching genesyscloud.rest.ApiException and retrying.
Step 1: Configure JSONPath Expressions for Nested ERP Payloads
ERP systems typically return deeply nested JSON with inconsistent array structures. You must define explicit JSONPath expressions that target the exact transaction fields. The jsonpath-ng library supports filter expressions and recursive descent.
from jsonpath_ng import parse
from jsonpath_ng.ext import parse as ext_parse
from typing import Any, Dict, List
# Example ERP payload structure:
#   "batch_id": "ERP-2024-8842",
#   "orders": [
#       "order_id": "ORD-9912",
#       "status": "PROCESSED",
#       "line_items": [
#         {"sku": "WIDGET-A", "qty": 5, "unit_price": 12.50, "tax": 1.00},
#         {"sku": "WIDGET-B", "qty": 2, "unit_price": 8.75, "tax": 0.40}
#       "customer": {"id": "CUST-441", "tier": "GOLD"}
ERP_JSONPATH_MAP: Dict[str, str] = {
    "batch_id": "$.batch_id",
    "order_id": "$.orders[*].order_id",
    "order_status": "$.orders[*].status",
    "line_item_skus": "$.orders[*].line_items[*].sku",
    "line_item_quantities": "$.orders[*].line_items[*].qty",
    "line_item_totals": "$.orders[*].line_items[*].unit_price * $.orders[*].line_items[*].qty", # Note: jsonpath-ng does not support math directly. We will compute in Python.
    "customer_id": "$.orders[*].customer.id",
    "customer_tier": "$.orders[*].customer.tier"
def compile_jsonpath_expressions() -> Dict[str, Any]:
    """Pre-compiles JSONPath expressions for performance."""
    compiled = {}
    for key, path_str in ERP_JSONPATH_MAP.items():
            compiled[key] = ext_parse(path_str)
            logger.error("Failed to compile JSONPath for %s: %s", key, str(e))
            raise
    return compiled
JSONPath compilation should occur once at startup. Compiling expressions on every request adds unnecessary latency. The jsonpath-ng.ext module supports extended syntax including array slicing and recursive descent.
Step 2: Build the Parsing Function with Error Handling and Retry Logic
You must extract values safely, handle missing paths, and format the output to match Genesys Cloud Data Action response schemas. The Data Action expects a JSON object with a data key containing the transformed payload.
from jsonpath_ng import DatumInContext
from typing import Any, Dict, List, Optional
import requests
from requests.exceptions import HTTPError
def extract_erp_data(payload: Dict[str, Any], compiled_paths: Dict[str, Any]) -> Dict[str, Any]:
    """Extracts and flattens ERP transaction data using pre-compiled JSONPath expressions."""
    result: Dict[str, Any] = {}
    # Handle mathematical aggregation for line items manually
    line_items = ext_parse("$.orders[*].line_items[*]")(payload)
    computed_totals = []
    for item_match in line_items:
        unit_price = item_match.value.get("unit_price", 0)
        qty = item_match.value.get("qty", 0)
        computed_totals.append(round(unit_price * qty, 2))
    for field_name, path_expr in compiled_paths.items():
        matches = path_expr(payload)
        values = [m.value for m in matches]
        if not values:
            result[field_name] = None
        # Flatten single-element lists to scalar values
        if len(values) == 1:
            result[field_name] = values[0]
        else:
    # Override with computed totals
    result["line_item_totals"] = computed_totals
    return result
The function iterates through compiled expressions, extracts matches, and normalizes the output. Genesys Cloud Data Actions require consistent schema shapes. You must convert single-element lists to scalars to prevent type mismatches in downstream flow logic.
Step 3: Integrate with Genesys Cloud Data Action Invocation and Pagination
You will invoke the Data Action using the SDK, handle pagination when listing available actions, and implement retry logic for 429 responses. The Actions API supports cursor-based pagination via the next_page token.
def list_actions_with_pagination(platform_client: PlatformClient, limit: int = 25) -> List[Dict[str, Any]]:
    """Fetches all Data Actions with pagination support."""
    all_actions: List[Dict[str, Any]] = []
    next_page_token: Optional[str] = None
    page_number: int = 1
    while True:
            response = platform_client.get_actions(
                page_size=limit,
                page_number=page_number,
                next_page=next_page_token
            if response and response.entities:
                all_actions.extend(response.entities)
                next_page_token = response.next_page
                page_number += 1
                if not next_page_token:
                    break
            else:
                break
        except ApiException as e:
            if e.status == 429:
                logger.warning("Rate limited on action list. Retrying in 5 seconds")
                time.sleep(5)
            elif e.status in [401, 403]:
                logger.error("Authentication or authorization failed: %s", e.reason)
                raise
            else:
                logger.error("API error %s: %s", e.status, e.reason)
                raise
    return all_actions
def invoke_data_action(
    action_id: str,
    """Invokes a Genesys Cloud Data Action with retry logic for 429 responses."""
    @retry(
        stop=stop_after_attempt(3),
        wait=wait_exponential(multiplier=1, min=2, max=10),
        retry=retry_if_exception_type((ApiException, requests.exceptions.ConnectionError)),
        reraise=True
    def _invoke():
            response = platform_client.post_actions_action_id_invoke(
                action_id=action_id,
                body=payload
            return response
            if e.status == 429:
                logger.warning("Rate limited on action invocation. Backing off...")
                raise
            elif e.status == 400:
                logger.error("Bad request payload: %s", e.body)
                raise
            else:
                raise
    return _invoke()
The pagination loop consumes the next_page token until it returns null. The invocation function wraps the API call in a tenacity decorator that retries only on 429 or connection errors. It raises immediately on 400, 401, or 403 to fail fast on configuration errors.
The following script combines authentication, JSONPath parsing, and Data Action invocation into a single runnable module. Replace the environment variables with your Genesys Cloud credentials and action ID.
import os
import sys
import json
import logging
    paths = {
        "customer_tier": "$.orders[*].customer.tier",
        "line_items": "$.orders[*].line_items[*]"
    compiled = {}
    for key, path_str in paths.items():
    return compiled
    line_items_raw = compiled_paths["line_items"](payload)
    for item_match in line_items_raw:
        if field_name == "line_items":
        result[field_name] = values[0] if len(values) == 1 else (values if values else None)
    return result
def invoke_data_action(platform_client: PlatformClient, action_id: str, payload: Dict[str, Any]) -> Dict[str, Any]:
    @retry(
        retry=retry_if_exception_type((ApiException,)),
        reraise=True
    def _invoke():
                body=payload
            return response
            if e.status == 429:
                raise
            else:
                raise
    return _invoke()
def main():
    action_id = os.getenv("GENESYS_ACTION_ID")
    if not action_id:
        logger.error("GENESYS_ACTION_ID environment variable is required")
        sys.exit(1)
    platform_client = create_platform_client()
    compiled_paths = compile_jsonpath_expressions()
    # Simulated ERP payload
    erp_payload = {
        "orders": [
                "line_items": [
    extracted_data = extract_erp_data(erp_payload, compiled_paths)
    action_request = {
        "data": extracted_data
    logger.info("Invoking Data Action %s", action_id)
        response = invoke_data_action(platform_client, action_id, action_request)
        logger.info("Action invocation successful. Response: %s", json.dumps(response.to_dict(), indent=2))
        logger.error("Action invocation failed: Status %s, Reason %s", e.status, e.reason)
        sys.exit(1)
    main()
Run the script with python erp_data_action_parser.py. The script authenticates, parses the ERP JSON, computes line item totals, and invokes the Data Action. The response contains the processed transaction details ready for Flow Builder routing.
  • Cause: Invalid client credentials, expired token, or missing user:login scope.
  • Fix: Verify environment variables match the Genesys Cloud admin console. Ensure the OAuth application has the user:login scope enabled. The SDK refreshes tokens automatically, but initial login failure requires credential correction.
  • Code fix: Add explicit scope validation during initialization:
    client_secret=client_secret,
    oauth_scopes=["action:read", "action:write", "user:login"]
Error: 403 Forbidden
  • Cause: The OAuth application lacks action:read or action:write scopes, or the user associated with the service account does not have permissions to invoke the specific Data Action.
  • Fix: Navigate to the OAuth application in Genesys Cloud and add the required scopes. Assign the service account the action:manage or action:use role.
  • Debug step: Call /api/v2/oauth/token manually with Postman to verify scope grants before SDK initialization.
  • Cause: Exceeding the Genesys Cloud API rate limit (typically 100 requests per minute per tenant for Actions).
  • Fix: The tenacity retry decorator handles automatic backoff. If cascading 429s occur, implement request throttling using time.sleep() between batch invocations.
  • Code fix: Add a delay between paginated requests:
time.sleep(0.1)  # 100ms delay between pages to respect rate limits
Error: JSONPath Returns Empty List
  • Cause: The ERP payload structure changed, or the JSONPath expression uses incorrect array indexing.
  • Fix: Validate the payload against the expression using jsonpath_ng in a REPL. Use $.orders[*].line_items[*] instead of $.orders.line_items when dealing with arrays. Enable debug logging to print raw matches:
logger.debug("Matches for %s: %s", field_name, [m.value for m in matches])
