Parsing and Sending Genesys Cloud Web Messaging Rich Cards with Node.js
- A Node.js service that validates rich card payloads against Genesys Cloud messaging constraints, constructs atomic POST requests, tracks parsing latency and render success rates, and exposes a programmatic card parser for automated Web Messaging management.
- This tutorial uses the Genesys Cloud Conversations API and Messaging API surface for rich card delivery.
- The implementation is written in modern JavaScript with
async/await,axios, andajvfor schema validation.
- OAuth2 Client Credentials flow configuration with
conversation:writeandconversation:readscopes - Genesys Cloud API version
v2 - Node.js 18 or higher
- External dependencies:
axios,ajv,ajv-formats,uuid - A valid Genesys Cloud environment ID (subdomain) and conversation ID for testing
Genesys Cloud uses OAuth2 Client Credentials for server-to-server API access. The token expires after one hour and requires a refresh cycle. You must cache the token and validate its expiration before each API call to avoid 401 Unauthorized errors.
import axios from 'axios';
export class GenesysAuthManager {
constructor(environment, clientId, clientSecret) {
this.environment = environment;
this.clientId = clientId;
this.token = null;
this.expiresAt = 0;
this.baseUrl = `https://${environment}.mypurecloud.com/api/v2`;
async getAccessToken() {
const now = Date.now();
if (this.token && now < this.expiresAt - 60000) {
return this.token;
console.log('Requesting new OAuth2 token...');
const response = await axios.post(`${this.baseUrl}/oauth/token`, {
client_id: this.clientId,
client_secret: this.clientSecret,
scope: 'conversation:write conversation:read'
this.token = response.data.access_token;
this.expiresAt = now + (response.data.expires_in * 1000);
console.log(`Token acquired. Expires in ${response.data.expires_in} seconds.`);
return this.token;
The request targets POST /api/v2/oauth/token. The response returns an access_token and expires_in. You must store the token in memory and subtract sixty seconds from the expiry window to prevent edge-case 401 errors during concurrent requests.
Step 1: JSON Schema Validation and Complexity Limits
Genesys Cloud enforces strict limits on rich card payloads to prevent rendering crashes and excessive bandwidth consumption. You must validate the card structure before transmission. The validation pipeline checks card definition references, layout component matrices, and rendering constraint directives.
import Ajv from 'ajv';
import addFormats from 'ajv-formats';
const ajv = new Ajv({ allErrors: true });
addFormats(ajv);
// Genesys Cloud rich card schema with complexity limits
const cardSchema = {
type: 'object',
required: ['cards'],
properties: {
cards: {
type: 'array',
maxItems: 10,
items: {
type: 'object',
required: ['cardType', 'header'],
properties: {
cardType: { type: 'string', enum: ['card', 'carousel', 'quickReply'] },
header: {
type: 'object',
properties: {
title: { type: 'string', maxLength: 100 },
subtitle: { type: 'string', maxLength: 150 },
imageUrl: { type: 'string', format: 'uri' }
body: {
type: 'object',
properties: {
text: { type: 'string', maxLength: 500 }
actions: {
type: 'array',
maxItems: 5,
items: {
type: 'object',
required: ['type', 'label'],
properties: {
type: { type: 'string', enum: ['button', 'link'] },
label: { type: 'string', maxLength: 30 },
uri: { type: 'string', format: 'uri' }
const validateCardPayload = ajv.compile(cardSchema);
export function validateCardStructure(payload) {
const valid = validateCardPayload(payload);
if (!valid) {
const errors = validateCardPayload.errors.map(e => `${e.instancePath}: ${e.message}`);
throw new Error(`Card validation failed: ${errors.join(', ')}`);
// Enforce total payload size limit (Genesys recommends < 100KB)
const payloadSize = Buffer.byteLength(JSON.stringify(payload), 'utf8');
if (payloadSize > 102400) {
throw new Error(`Payload exceeds 100KB limit. Current size: ${payloadSize} bytes.`);
return true;
The schema enforces a maximum of ten cards per message, five actions per card, and character limits that align with Genesys Cloud’s rendering engine constraints. The ajv library returns detailed error paths when validation fails, allowing you to pinpoint malformed layout matrices.
Step 2: Image Dimension Verification and Asset Caching Triggers
Rich cards often reference external image assets. Genesys Cloud caches these assets automatically, but you must verify dimensions to prevent UI stretching or layout shifts. This step implements a verification pipeline and an asset caching trigger.
const assetCache = new Map();
export async function verifyImageDimensions(imageUrl) {
if (!imageUrl) return true;
// Check cache trigger
if (assetCache.has(imageUrl)) {
console.log(`[Asset Cache] Hit for ${imageUrl}. Skipping verification.`);
return assetCache.get(imageUrl).valid;
const response = await axios.head(imageUrl, { timeout: 5000 });
const contentType = response.headers['content-type'];
if (!contentType || !contentType.startsWith('image/')) {
throw new Error(`Invalid content type for image: ${contentType}`);
// Genesys Cloud recommends max 1200x630 for web messaging cards
// In production, you would use a library like sharp to decode actual dimensions.
// Here we validate URL patterns and simulate dimension compliance.
const dimensionsValid = true; // Placeholder for sharp-based verification
assetCache.set(imageUrl, { valid: dimensionsValid, timestamp: Date.now() });
console.log(`[Asset Cache] Stored ${imageUrl}. Dimensions verified.`);
return dimensionsValid;
} catch (error) {
assetCache.set(imageUrl, { valid: false, timestamp: Date.now() });
console.error(`[Asset Cache] Verification failed for ${imageUrl}: ${error.message}`);
return false;
The function performs a HEAD request to verify content type and triggers an internal cache. You must replace the dimension placeholder with a sharp pipeline in production to decode actual pixel dimensions. The cache prevents redundant network calls during rapid parse iterations.
Step 3: Atomic POST Operations and Format Verification
You must construct the final payload and send it via an atomic POST request. The Genesys Cloud Conversations API expects a specific envelope structure. This step includes retry logic for 429 rate limits and format verification before transmission.
export async function sendRichCardPayload(authManager, conversationId, payload, retryCount = 3) {
const token = await authManager.getAccessToken();
const endpoint = `${authManager.baseUrl}/conversations/${conversationId}/messages`;
const headers = {
'Accept': 'application/json'
const messageBody = {
to: { id: 'web-messaging-endpoint' }, // Replace with actual user ID or endpoint
body: 'Rich card message',
cards: payload.cards
console.log('POST Request Cycle:');
console.log('Method: POST');
console.log(`Path: ${endpoint}`);
console.log('Headers:', JSON.stringify(headers, null, 2));
console.log('Body:', JSON.stringify(messageBody, null, 2));
const response = await axios.post(endpoint, messageBody, { headers });
console.log('Response Cycle:');
console.log(`Status: ${response.status}`);
console.log('Headers:', JSON.stringify(response.headers, null, 2));
console.log('Body:', JSON.stringify(response.data, null, 2));
return { success: true, messageId: response.data.id, status: response.status };
} catch (error) {
if (error.response?.status === 429 && retryCount > 0) {
const retryAfter = error.response.headers['retry-after'] || 1;
console.warn(`Rate limited. Retrying in ${retryAfter} seconds...`);
await new Promise(resolve => setTimeout(resolve, retryAfter * 1000));
return sendRichCardPayload(authManager, conversationId, payload, retryCount - 1);
throw error;
The request targets POST /api/v2/conversations/{conversationId}/messages. The conversation:write scope is required. The retry logic handles 429 Too Many Requests by reading the Retry-After header or defaulting to one second. You must preserve the retry count to prevent infinite loops.
Step 4: Metrics, Callbacks, and Audit Logging
Production card parsers require observability. This step tracks parsing latency, render success rates, synchronizes with external design systems via callbacks, and generates audit logs for governance.
export class CardParserMetrics {
constructor(callbackUrl, auditLogPath) {
this.callbackUrl = callbackUrl;
this.auditLogPath = auditLogPath;
this.metrics = { parsed: 0, successful: 0, failed: 0, totalLatency: 0 };
async recordParseEvent(event) {
const timestamp = new Date().toISOString();
this.metrics.parsed++;
if (event.success) this.metrics.successful++;
else this.metrics.failed++;
this.metrics.totalLatency += event.latency;
const auditEntry = {
timestamp,
conversationId: event.conversationId,
cardCount: event.cardCount,
success: event.success,
latencyMs: event.latency,
messageId: event.messageId,
error: event.error
// Write audit log (simplified to console for this tutorial)
console.log(`[AUDIT] ${JSON.stringify(auditEntry)}`);
// Synchronize with external design system via callback
if (this.callbackUrl) {
await axios.post(this.callbackUrl, {
type: 'CARD_PARSE_EVENT',
payload: auditEntry
}, { timeout: 3000 });
console.log('[Callback] Design system synchronized.');
} catch (cbError) {
console.error(`[Callback] Synchronization failed: ${cbError.message}`);
getRenderSuccessRate() {
if (this.metrics.parsed === 0) return 0;
return (this.metrics.successful / this.metrics.parsed) * 100;
getAverageLatency() {
return this.metrics.totalLatency / this.metrics.parsed;
The metrics class accumulates latency and success counts. It writes structured audit logs and posts to an external callback URL for design system alignment. You must implement file system writes or database inserts for auditLogPath in production.
The following module combines authentication, validation, asset verification, atomic posting, and metrics tracking into a single runnable class. Replace the placeholder credentials and conversation ID before execution.
// --- Authentication Manager ---
this.token = null;
this.expiresAt = 0;
if (this.token && now < this.expiresAt - 60000) return this.token;
}, { headers: { 'Content-Type': 'application/x-www-form-urlencoded' } });
return this.token;
// --- Validation Engine ---
addFormats(ajv);
type: 'object',
properties: {
cards: {
type: 'array',
maxItems: 10,
items: {
type: 'object',
properties: {
header: {
type: 'object',
properties: {
body: { type: 'object', properties: { text: { type: 'string', maxLength: 500 } } },
actions: {
type: 'array',
maxItems: 5,
items: {
type: 'object',
properties: {
// --- Asset Cache ---
if (assetCache.has(imageUrl)) return assetCache.get(imageUrl).valid;
assetCache.set(imageUrl, { valid: true, timestamp: Date.now() });
return true;
} catch {
return false;
// --- Main Parser Class ---
export class GenesysCardParser {
constructor(config) {
this.auth = new GenesysAuthManager(config.environment, config.clientId, config.clientSecret);
this.callbackUrl = config.callbackUrl || null;
async parseAndSend(conversationId, cardPayload) {
const startTime = Date.now();
// Step 1: Validate structure and complexity limits
const valid = validateCardPayload(cardPayload);
if (!valid) throw new Error(validateCardPayload.errors.map(e => e.message).join(', '));
const size = Buffer.byteLength(JSON.stringify(cardPayload), 'utf8');
if (size > 102400) throw new Error(`Payload exceeds 100KB limit: ${size} bytes`);
// Step 2: Verify image assets
for (const card of cardPayload.cards) {
const imageUrl = card.header?.imageUrl;
if (imageUrl && !(await verifyImageDimensions(imageUrl))) {
throw new Error(`Invalid image asset: ${imageUrl}`);
// Step 3: Atomic POST with retry
const token = await this.auth.getAccessToken();
const endpoint = `${this.auth.baseUrl}/conversations/${conversationId}/messages`;
cards: cardPayload.cards
headers: { 'Authorization': `Bearer ${token}`, 'Content-Type': 'application/json' }
const latency = Date.now() - startTime;
this.metrics.totalLatency += latency;
// Step 4: Callback and Audit
await this._emitEvent({ success: true, conversationId, cardCount: cardPayload.cards.length, latency, messageId: response.data.id });
return { success: true, messageId: response.data.id, latency };
} catch (error) {
await this._emitEvent({ success: false, conversationId, cardCount: cardPayload.cards?.length || 0, latency, error: error.message });
throw error;
async _emitEvent(event) {
console.log(`[AUDIT] ${JSON.stringify({ timestamp: new Date().toISOString(), ...event })}`);
await axios.post(this.callbackUrl, { type: 'CARD_PARSE_EVENT', payload: event }, { timeout: 3000 });
} catch (cbErr) {
console.error(`[Callback] Sync failed: ${cbErr.message}`);
getMetrics() {
totalParsed: this.metrics.parsed,
successRate: this.metrics.parsed ? (this.metrics.successful / this.metrics.parsed) * 100 : 0,
avgLatencyMs: this.metrics.parsed ? this.metrics.totalLatency / this.metrics.parsed : 0
// --- Execution Example ---
async function run() {
const parser = new GenesysCardParser({
environment: 'your-env',
clientId: 'your-client-id',
clientSecret: 'your-client-secret',
callbackUrl: 'https://your-design-system.internal/webhooks/cards'
const testPayload = {
cards: [{
cardType: 'card',
header: { title: 'Order Confirmation', subtitle: 'Thank you for your purchase', imageUrl: 'https://example.com/order-thumb.jpg' },
body: { text: 'Your order #8821 is confirmed and will ship within 24 hours.' },
actions: [{ type: 'button', label: 'Track Order', uri: 'https://example.com/track/8821' }]
const result = await parser.parseAndSend('your-conversation-id', testPayload);
console.log('Parse Result:', result);
console.log('Metrics:', parser.getMetrics());
} catch (err) {
console.error('Parse Failed:', err.message);
run();
- Cause: The OAuth token expired or the client credentials are invalid.
- Fix: Verify the
clientIdandclientSecret. Ensure the token refresh logic subtracts a buffer window before expiry. Check that the OAuth scope includesconversation:write. - Code Fix: The
GenesysAuthManagerclass handles refresh automatically. If you receive a 401 during the POST call, force a token refresh by callingthis.auth.getAccessToken()again before retrying.
Error: 403 Forbidden
- Cause: The OAuth client lacks the required scope, or the conversation ID belongs to a different environment.
- Fix: Confirm the token request includes
conversation:write. Verify theconversationIdmatches the environment subdomain. Check IAM policies if using role-based access. - Code Fix: Log the token scope by inspecting the OAuth response. Ensure the endpoint URL matches the environment exactly.
Error: 400 Bad Request
- Cause: The card payload violates Genesys Cloud schema constraints. Common triggers include exceeding
maxItemsfor actions, malformedcardTypevalues, or payload size exceeding 100KB. - Fix: Review the
ajvvalidation output. Reduce card complexity by splitting large carousels into multiple messages. Verify allurifields use valid HTTPS endpoints. - Code Fix: The
validateCardPayloadfunction catches these errors before transmission. InspectvalidateCardPayload.errorsto locate the exact field violation.
- Cause: You exceeded the Genesys Cloud rate limit for messaging endpoints.
- Fix: Implement exponential backoff. The provided
sendRichCardPayloadfunction includes linear retry logic based on theRetry-Afterheader. - Code Fix: The retry loop decrements
retryCountand pauses execution. If the limit persists, implement a queue-based dispatcher to throttle outgoing card assembly operations.
Error: 5xx Server Error
- Cause: Transient Genesys Cloud platform outage or internal parsing failure on the messaging engine.
- Fix: Implement circuit breaker logic. Do not retry immediately. Log the error for audit governance and queue the payload for later processing.
- Code Fix: Catch
error.response?.status >= 500and route to a dead-letter queue. The metrics class tracks these failures for render success rate calculations.
