Paging NICE CXone SCIM User Directories with Node.js Using Cursor Tokens and State Validation
This script enumerates all users in a NICE CXone SCIM directory using cursor-based pagination, validates each page against schema constraints, filters tombstone records, logs pagination metrics, and pushes synchronized state to an external webhook.
This implementation uses the NICE CXone SCIM 2.0 REST API.
This tutorial covers Node.js using native fetch and async/await patterns.
  • OAuth client type and required scopes: Client Credentials flow with the scim:read scope
  • SDK version or API version: NICE CXone SCIM 2.0 API (REST), Node.js 18+
  • Language/runtime requirements: Node.js 18 or later, environment variables for credentials
  • Any external dependencies: No external packages required. Native fetch, URLSearchParams, and crypto modules are used.
NICE CXone requires OAuth 2.0 client credentials to access SCIM endpoints. The following function exchanges your client ID and secret for an access token, caches it in memory, and handles expiration by tracking the issued-at timestamp.
const CXONE_SITE = process.env.CXONE_SITE; // Example: acme.cxone.com
const CXONE_CLIENT_ID = process.env.CXONE_CLIENT_ID;
const CXONE_CLIENT_SECRET = process.env.CXONE_CLIENT_SECRET;
const SCIM_BASE = `https://${CXONE_SITE}/scim/v2`;
const TOKEN_URL = `https://${CXONE_SITE}/oauth/token`;
let tokenCache = { accessToken: null, expiresAt: 0 };
async function getValidToken() {
  const now = Date.now();
  if (tokenCache.accessToken && tokenCache.expiresAt > now) {
    return tokenCache.accessToken;
  const response = await fetch(TOKEN_URL, {
    method: 'POST',
    body: new URLSearchParams({
      client_id: CXONE_CLIENT_ID,
      client_secret: CXONE_CLIENT_SECRET,
      scope: 'scim:read'
  if (!response.ok) {
    const errorBody = await response.text();
    throw new Error(`OAuth token acquisition failed (${response.status}): ${errorBody}`);
  const data = await response.json();
  tokenCache.accessToken = data.access_token;
  tokenCache.expiresAt = now + (data.expires_in * 1000) - 5000; // Refresh 5 seconds early
Step 1: Initialize the Directory Pager and Construct Page Payloads
The directory pager manages pagination state, validates page size matrices against CXone constraints, and applies sort order directives. CXone enforces a maximum page size of 100 records per request. The pager validates the requested size, normalizes sort parameters, and initializes the cursor token.
class CXoneDirectoryPager {
  constructor(options = {}) {
    this.pageSize = Math.min(Math.max(options.pageSize || 100, 1), 100);
    this.sortBy = options.sortBy || 'userName';
    this.sortOrder = options.sortOrder === 'descending' ? 'descending' : 'ascending';
    this.cursor = null;
    this.maxDepth = options.maxDepth || 1000; // Safety limit for pagination depth
    this.pageCount = 0;
    this.totalFetched = 0;
    this.auditLog = [];
    this.webhookUrl = options.webhookUrl || null;
  buildQueryString() {
    const params = new URLSearchParams({
      count: this.pageSize.toString(),
      sortBy: this.sortBy,
      sortOrder: this.sortOrder
    if (this.cursor) {
      params.append('cursor', this.cursor);
    return params.toString();
  recordAuditEvent(eventType, details) {
    const entry = {
      eventType,
      page: this.pageCount,
      cursor: this.cursor,
      ...details
    this.auditLog.push(entry);
    console.log(JSON.stringify(entry));
Step 2: Execute Atomic GET Operations with Format Verification and Cursor Refresh
Each page fetch is an atomic GET operation. The request includes the bearer token, pagination parameters, and accepts JSON. The response undergoes format verification to ensure it matches the SCIM 2.0 envelope. If a 429 status occurs, the pager implements exponential backoff retry logic. The cursor refresh trigger updates the internal cursor state from the response payload.
async function fetchPage(pager) {
  const url = `${SCIM_BASE}/Users?${pager.buildQueryString()}`;
  const token = await getValidToken();
  let attempts = 0;
  const maxRetries = 3;
  const baseDelay = 1000;
  while (attempts <= maxRetries) {
    const startTime = Date.now();
      const response = await fetch(url, {
        method: 'GET',
        headers: {
          'Accept': 'application/scim+json',
          'Content-Type': 'application/scim+json'
      const latency = Date.now() - startTime;
      if (response.status === 429 && attempts < maxRetries) {
        const retryAfter = response.headers.get('Retry-After') || Math.pow(2, attempts);
        console.warn(`Rate limited (429). Retrying in ${retryAfter}s...`);
        await new Promise(resolve => setTimeout(resolve, retryAfter * 1000));
        attempts++;
        continue;
      if (!response.ok) {
        const errorText = await response.text();
        throw new Error(`SCIM request failed (${response.status}): ${errorText}`);
      // Format verification: Ensure SCIM 2.0 envelope structure
      if (!data.schemas || !data.schemas.includes('urn:ietf:params:scim:api:messages:2.0:ListResponse')) {
        throw new Error('Invalid SCIM response schema. Missing ListResponse envelope.');
      // Cursor refresh trigger
      pager.cursor = data.nextCursor || null;
      pager.pageCount++;
        records: data.Resources || [],
        totalResults: data.totalResults,
        latency,
        success: true
    } catch (error) {
      if (attempts === maxRetries) throw error;
      attempts++;
      await new Promise(resolve => setTimeout(resolve, baseDelay * Math.pow(2, attempts)));
Step 3: Implement State Consistency, Tombstone Verification, and Webhook Synchronization
After fetching a page, the system validates state consistency by checking meta.lastModified timestamps against the previous page. Tombstone records (users marked as inactive or soft-deleted) are identified and filtered. The remaining valid records are synchronized to an external data warehouse via webhook callbacks. Duplicate prevention is enforced using a Set of processed id values.
function processPageData(pageResult, processedIds, previousMetaTimestamp) {
  const validRecords = [];
  const tombstones = [];
  const duplicates = 0;
  for (const record of pageResult.records) {
    if (!record.id || !record.schemas || !record.schemas.includes('urn:ietf:params:scim:schemas:core:2.0:User')) {
      continue;
    // Duplicate prevention during SCIM scaling
    if (processedIds.has(record.id)) {
      duplicates++;
      continue;
    // Tombstone record verification pipeline
    if (record.active === false || record.meta?.removed) {
      tombstones.push(record.id);
      continue;
    // State consistency checking
    const currentMeta = record.meta?.lastModified || '';
    if (previousMetaTimestamp && currentMeta < previousMetaTimestamp) {
      console.warn(`State inconsistency detected: Record ${record.id} has older timestamp than previous page.`);
    processedIds.add(record.id);
    validRecords.push(record);
  return { validRecords, tombstones, duplicates, latestMeta: pageResult.records[0]?.meta?.lastModified };
async function syncToWebhook(pager, payload) {
  if (!pager.webhookUrl) return;
    await fetch(pager.webhookUrl, {
      method: 'POST',
      body: JSON.stringify(payload)
  } catch (error) {
    console.error(`Webhook sync failed: ${error.message}`);
Step 4: Track Latency, Fetch Completion Rates, and Generate Audit Logs
The pagination loop aggregates latency metrics, calculates fetch completion rates, and writes structured audit logs for pagination governance. The loop terminates when the cursor is null, the maximum depth is reached, or an unrecoverable error occurs.
async function runDirectoryPager(pagerOptions) {
  const pager = new CXoneDirectoryPager(pagerOptions);
  const processedIds = new Set();
  let previousMetaTimestamp = null;
  let totalPagesProcessed = 0;
  let totalLatency = 0;
  let successPages = 0;
  pager.recordAuditEvent('PAGING_START', { pageSize: pager.pageSize, sortBy: pager.sortBy });
  while (pager.pageCount < pager.maxDepth) {
      const pageResult = await fetchPage(pager);
      totalPagesProcessed++;
      successPages++;
      totalLatency += pageResult.latency;
      const { validRecords, tombstones, duplicates, latestMeta } = processPageData(pageResult, processedIds, previousMetaTimestamp);
      previousMetaTimestamp = latestMeta;
      pager.recordAuditEvent('PAGE_COMPLETE', {
        recordsFetched: pageResult.records.length,
        validRecords: validRecords.length,
        tombstones: tombstones.length,
        duplicates: duplicates,
        latency: pageResult.latency
      // Synchronize paging events with external data warehouses
      await syncToWebhook(pager, {
        event: 'SCIM_PAGE_SYNC',
        page: pager.pageCount,
        validRecords: validRecords.map(r => ({ id: r.id, userName: r.userName, email: r.emails?.[0]?.value })),
        metrics: { latency: pageResult.latency, cursor: pager.cursor }
      if (!pager.cursor) break; // Pagination complete
    } catch (error) {
      pager.recordAuditEvent('PAGE_FAILURE', { error: error.message });
      throw error;
  const completionRate = totalPagesProcessed > 0 ? (successPages / totalPagesProcessed) * 100 : 0;
  const avgLatency = totalPagesProcessed > 0 ? totalLatency / totalPagesProcessed : 0;
  pager.recordAuditEvent('PAGING_COMPLETE', {
    totalPagesProcessed,
    totalRecords: processedIds.size,
    completionRate: `${completionRate.toFixed(2)}%`,
    averageLatency: `${avgLatency.toFixed(2)}ms`
  return { pager, processedIds, completionRate, avgLatency };
The following script combines all components into a single executable module. Set the environment variables before running.
const WEBHOOK_URL = process.env.WEBHOOK_URL || null;
    method: 'POST',
      scope: 'scim:read'
  if (!response.ok) {
    this.cursor = null;
    this.pageCount = 0;
    this.auditLog = [];
    if (this.cursor) {
    const entry = {
      eventType,
      ...details
  let attempts = 0;
        method: 'GET',
        headers: {
        attempts++;
        continue;
      if (!response.ok) {
      pager.pageCount++;
        latency,
        success: true
    } catch (error) {
      attempts++;
      await new Promise(resolve => setTimeout(resolve, 1000 * Math.pow(2, attempts)));
  let duplicates = 0;
      continue;
      duplicates++;
      continue;
      continue;
      method: 'POST',
  } catch (error) {
      successPages++;
    } catch (error) {
      throw error;
// Execution
(async () => {
    const result = await runDirectoryPager({
      pageSize: 100,
      sortBy: 'userName',
      sortOrder: 'ascending',
      maxDepth: 500,
      webhookUrl: WEBHOOK_URL
    console.log(`Directory paging completed. Processed ${result.processedIds.size} unique users.`);
  } catch (error) {
    console.error(`Fatal error during directory paging: ${error.message}`);
    process.exit(1);
  • What causes it: The OAuth token is expired, malformed, or missing the scim:read scope.
  • How to fix it: Verify the client credentials match a valid CXone integration. Ensure the token refresh logic runs before expiration. Check that the scope parameter in the token request exactly matches scim:read.
  • Code showing the fix: The getValidToken function automatically refreshes the token 5 seconds before expiration and throws a descriptive error if the initial exchange fails.
Error: 400 Bad Request
  • What causes it: Invalid cursor token, page size exceeding 100, or malformed sort parameters.
  • How to fix it: Clamp pageSize between 1 and 100 using the matrix validation in the pager constructor. Reset the cursor to null if it returns an invalid state. Ensure sortBy matches valid SCIM attributes like userName or emails.value.
  • Code showing the fix: this.pageSize = Math.min(Math.max(options.pageSize || 100, 1), 100); enforces the constraint before request construction.
  • What causes it: The CXone API rate limit is exceeded due to rapid sequential GET requests.
  • How to fix it: Implement exponential backoff retry logic. Parse the Retry-After header if present.
  • Code showing the fix: The fetchPage function includes a retry loop with Math.pow(2, attempts) delay and respects the Retry-After header.
Error: SCIM Schema Validation Failure
  • What causes it: The response envelope lacks urn:ietf:params:scim:api:messages:2.0:ListResponse or resource items lack urn:ietf:params:scim:schemas:core:2.0:User.
  • How to fix it: Validate the schemas array immediately after parsing the JSON. Skip malformed resources and log them to the audit pipeline.
  • Code showing the fix: The format verification block throws a controlled error if the envelope is missing, and processPageData skips records lacking the core user schema.
