Paginating Genesys Cloud Interaction Records with Go Using Cursor Navigation and Exponential Backoff
  • A Go package that retrieves, paginates, and streams Genesys Cloud interaction details using cursor tokens, applies rate-limit-aware exponential backoff, and batches records for external warehouse synchronization.
  • This tutorial uses the Genesys Cloud Interaction Data API (/api/v2/analytics/conversations/details/query).
  • The implementation is written in Go 1.21+ using standard library packages for HTTP, JSON streaming, metrics, and structured logging.
  • OAuth confidential client registered in Genesys Cloud with the analytics:conversation:view scope
  • Genesys Cloud API version v2
  • Go runtime version 1.21 or higher
  • Standard library dependencies: net/http, encoding/json, time, context, fmt, log/slog, sync/atomic, crypto/rand
Genesys Cloud uses OAuth 2.0 client credentials flow for server-to-server integration. The following code retrieves an access token, caches it, and implements automatic refresh before expiration.
package main
import (
	"context"
	"encoding/json"
	"fmt"
	"io"
	"log/slog"
	"net/http"
	"os"
	"time"
type OAuthToken struct {
	ExpiresIn   int    `json:"expires_in"`
	ExpiresAt   time.Time
func FetchOAuthToken(ctx context.Context, clientID, clientSecret, baseURL string) (*OAuthToken, error) {
	payload := fmt.Sprintf("grant_type=client_credentials&client_id=%s&client_secret=%s", clientID, clientSecret)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, fmt.Sprintf("%s/oauth/token", baseURL), nil)
	if err != nil {
		return nil, fmt.Errorf("failed to create oauth request: %w", err)
	req.SetBasicAuth(clientID, clientSecret)
	resp, err := client.Do(req)
	if err != nil {
		return nil, fmt.Errorf("oauth request failed: %w", err)
	defer resp.Body.Close()
		return nil, fmt.Errorf("oauth authentication failed with status %d: %s", resp.StatusCode, string(body))
	var tokenResp struct {
		return nil, fmt.Errorf("failed to decode oauth response: %w", err)
	return &OAuthToken{
		AccessToken: tokenResp.AccessToken,
		ExpiresIn:   tokenResp.ExpiresIn,
		ExpiresAt:   time.Now().Add(time.Duration(tokenResp.ExpiresIn) * time.Second),
	}, nil
The ExpiresAt field enables token caching. You should check time.Now().Before(token.ExpiresAt) before each API call and refresh if the token is older than ninety percent of its lifetime to prevent mid-pagination 401 errors.
Step 1: Paginator Structure and Query Payload Construction
The Interaction Data API uses cursor-based pagination via the nextPageToken field. You must construct a query payload that specifies date ranges, field selection, filters, and page size. The API enforces a maximum page size of 1000 records.
package main
import (
	"encoding/json"
	"fmt"
	"time"
type InteractionQuery struct {
	DateFrom      string       `json:"dateFrom"`
	DateTo        string       `json:"dateTo"`
	Size          int          `json:"size"`
	NextPageToken string       `json:"nextPageToken,omitempty"`
	Filter        []FilterItem `json:"filter,omitempty"`
	Select        []string     `json:"select"`
type FilterItem struct {
	Dimension string `json:"dimension"`
	Operator  string `json:"operator"`
	Value     string `json:"value"`
func BuildQuery(dateFrom, dateTo time.Time, pageToken string, retentionDays int) (*InteractionQuery, error) {
	if dateTo.Sub(dateFrom).Hours() > float64(retentionDays*24) {
		return nil, fmt.Errorf("date range exceeds retention window of %d days", retentionDays)
	return &InteractionQuery{
		DateFrom: dateFrom.UTC().Format(time.RFC3339Nano),
		DateTo:   dateTo.UTC().Format(time.RFC3339Nano),
		NextPageToken: pageToken,
		Filter: []FilterItem{
			{Dimension: "mediaType", Operator: "equals", Value: "voice"},
		Select: []string{
			"conversationId", "mediaType", "startTime", "endTime", "wrapUpCode", "duration",
	}, nil
The Select array reduces payload size by requesting only required fields. The retention validation prevents 400 errors caused by querying beyond the standard thirteen-month data window.
Step 2: HTTP Request with Exponential Backoff and Audit Logging
Genesys Cloud returns HTTP 429 when rate limits are exceeded. The paginator implements exponential backoff with jitter to handle throttling gracefully. Structured logging tracks query parameters, cursor tokens, and latency for data governance.
package main
import (
	"bytes"
	"context"
	"encoding/json"
	"fmt"
	"io"
	"log/slog"
	"math/rand"
	"net/http"
	"time"
type PaginatorMetrics struct {
	TotalRequests   int64
	TotalRecords    int64
	TotalLatencyMs  int64
	ThrottleCount   int64
func ExecuteQuery(ctx context.Context, client *http.Client, baseURL, token string, query *InteractionQuery, logger *slog.Logger, metrics *PaginatorMetrics) ([]byte, string, error) {
	payload, err := json.Marshal(query)
	if err != nil {
		return nil, "", fmt.Errorf("failed to marshal query payload: %w", err)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, fmt.Sprintf("%s/api/v2/analytics/conversations/details/query", baseURL), bytes.NewReader(payload))
	if err != nil {
		return nil, "", fmt.Errorf("failed to create request: %w", err)
	req.Header.Set("Authorization", fmt.Sprintf("Bearer %s", token))
	startTime := time.Now()
	logger.Info("initiating query",
		slog.String("dateFrom", query.DateFrom),
		slog.String("dateTo", query.DateTo),
		slog.String("nextPageToken", query.NextPageToken),
	var resp *http.Response
	for attempt := 0; attempt < 5; attempt++ {
		resp, err = client.Do(req)
		if err != nil {
			return nil, "", fmt.Errorf("http request failed: %w", err)
			metrics.ThrottleCount++
			backoff := calculateBackoff(attempt)
			logger.Warn("rate limit exceeded, applying exponential backoff",
				slog.Int("attempt", attempt),
				slog.Duration("backoff", backoff),
			time.Sleep(backoff)
			resp.Body.Close()
			return nil, "", fmt.Errorf("query failed with status %d: %s", resp.StatusCode, string(body))
		break
	body, err := io.ReadAll(resp.Body)
	if err != nil {
		return nil, "", fmt.Errorf("failed to read response body: %w", err)
	latency := time.Since(startTime).Milliseconds()
	metrics.TotalLatencyMs += latency
	metrics.TotalRequests++
	logger.Info("query completed",
		slog.Duration("latency", time.Duration(latency)*time.Millisecond),
		slog.Int("statusCode", resp.StatusCode),
	return body, extractNextToken(body), nil
func calculateBackoff(attempt int) time.Duration {
	base := time.Duration(1<<uint(attempt)) * time.Second
	jitter := time.Duration(rand.Intn(int(base/2)))
	return base + jitter
func extractNextToken(body []byte) string {
	var envelope struct {
		NextPageToken string `json:"nextPageToken"`
	if err := json.Unmarshal(body, &envelope); err == nil {
		return envelope.NextPageToken
	return ""
The backoff algorithm doubles the wait time per attempt and adds random jitter to prevent thundering herd effects when multiple workers resume simultaneously.
Step 3: Streaming JSON Parsing, Chunking, and Batch Synchronization
Processing high-volume interaction logs requires memory-efficient parsing. The paginator streams each page response, aggregates records into configurable chunks, and synchronizes batches to an external analytics warehouse. Throughput metrics are calculated per chunk.
package main
import (
	"context"
	"encoding/json"
	"fmt"
	"log/slog"
	"net/http"
	"sync/atomic"
	"time"
type InteractionRecord struct {
	ConversationID string  `json:"conversationId"`
	MediaType      string  `json:"mediaType"`
	StartTime      string  `json:"startTime"`
	EndTime        string  `json:"endTime"`
	WrapUpCode     string  `json:"wrapUpCode"`
	Duration       float64 `json:"duration"`
type WarehouseBatch struct {
	Records []InteractionRecord `json:"records"`
	BatchID string              `json:"batchId"`
type InteractionPaginator struct {
	Client      *http.Client
	BaseURL     string
	Token       string
	Logger      *slog.Logger
	Metrics     *PaginatorMetrics
	ChunkSize   int
	WarehouseURL string
func (p *InteractionPaginator) StreamAndSync(ctx context.Context, query *InteractionQuery) error {
	currentToken := ""
	chunk := make([]InteractionRecord, 0, p.ChunkSize)
	batchCounter := 0
	for {
		body, nextToken, err := ExecuteQuery(ctx, p.Client, p.BaseURL, p.Token, query, p.Logger, p.Metrics)
		if err != nil {
			return fmt.Errorf("query execution failed: %w", err)
		decoder := json.NewDecoder(bytes.NewReader(body))
			Items         json.RawMessage `json:"items"`
		if err := decoder.Decode(&envelope); err != nil {
			return fmt.Errorf("failed to parse response envelope: %w", err)
		var records []InteractionRecord
		if err := json.Unmarshal(envelope.Items, &records); err != nil {
			return fmt.Errorf("failed to unmarshal interaction records: %w", err)
		atomic.AddInt64(&p.Metrics.TotalRecords, int64(len(records)))
		chunk = append(chunk, records...)
		for len(chunk) >= p.ChunkSize {
			batchCounter++
			batch := chunk[:p.ChunkSize]
			chunk = chunk[p.ChunkSize:]
			if err := p.SyncBatchToWarehouse(ctx, batch, batchCounter); err != nil {
				return fmt.Errorf("warehouse synchronization failed: %w", err)
		if nextToken == "" {
			break
		query.NextPageToken = nextToken
	if len(chunk) > 0 {
		batchCounter++
		if err := p.SyncBatchToWarehouse(ctx, chunk, batchCounter); err != nil {
			return fmt.Errorf("final warehouse synchronization failed: %w", err)
	throughput := float64(atomic.LoadInt64(&p.Metrics.TotalRecords)) / (float64(atomic.LoadInt64(&p.Metrics.TotalLatencyMs)) / 1000.0)
	p.Logger.Info("pagination complete",
		slog.Int64("totalRecords", atomic.LoadInt64(&p.Metrics.TotalRecords)),
		slog.Float64("recordsPerSecond", throughput),
		slog.Int64("totalLatencyMs", atomic.LoadInt64(&p.Metrics.TotalLatencyMs)),
		slog.Int("batchesSynced", batchCounter),
	return nil
func (p *InteractionPaginator) SyncBatchToWarehouse(ctx context.Context, records []InteractionRecord, batchNum int) error {
	batch := WarehouseBatch{
		Records: records,
		BatchID: fmt.Sprintf("batch-%d-%d", batchNum, time.Now().UnixNano()),
	payload, err := json.Marshal(batch)
	if err != nil {
		return fmt.Errorf("failed to marshal warehouse batch: %w", err)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, p.WarehouseURL, bytes.NewReader(payload))
	if err != nil {
		return fmt.Errorf("failed to create warehouse request: %w", err)
	resp, err := p.Client.Do(req)
	if err != nil {
		return fmt.Errorf("warehouse request failed: %w", err)
	if resp.StatusCode < 200 || resp.StatusCode >= 300 {
		return fmt.Errorf("warehouse sync returned status %d", resp.StatusCode)
	p.Logger.Info("batch synchronized",
		slog.Int("batchNumber", batchNum),
		slog.Int("recordCount", len(records)),
	return nil
The streaming approach avoids loading the entire dataset into memory. Chunking ensures consistent batch sizes for warehouse ingestion, and atomic counters provide thread-safe metric aggregation.
The following script ties authentication, pagination, streaming, and synchronization into a single executable module. Replace the placeholder credentials and warehouse endpoint before execution.
package main
import (
	"context"
	"log/slog"
	"net/http"
	"os"
	"time"
func main() {
	ctx := context.Background()
	logger := slog.New(slog.NewJSONHandler(os.Stdout, &slog.HandlerOptions{Level: slog.LevelInfo}))
	clientID := os.Getenv("GENESYS_CLIENT_ID")
	clientSecret := os.Getenv("GENESYS_CLIENT_SECRET")
	baseURL := "https://api.mypurecloud.com"
	warehouseURL := os.Getenv("WAREHOUSE_API_URL")
	token, err := FetchOAuthToken(ctx, clientID, clientSecret, baseURL)
	if err != nil {
		logger.Error("oauth failed", slog.Any("error", err))
		os.Exit(1)
	dateFrom := time.Now().Add(-7 * 24 * time.Hour)
	dateTo := time.Now()
	retentionDays := 390
	query, err := BuildQuery(dateFrom, dateTo, "", retentionDays)
	if err != nil {
		logger.Error("query validation failed", slog.Any("error", err))
		os.Exit(1)
	paginator := &InteractionPaginator{
		Client:       &http.Client{Timeout: 30 * time.Second},
		BaseURL:      baseURL,
		Token:        token.AccessToken,
		Logger:       logger,
		Metrics:      &PaginatorMetrics{},
		ChunkSize:    500,
		WarehouseURL: warehouseURL,
	if err := paginator.StreamAndSync(ctx, query); err != nil {
		logger.Error("pagination pipeline failed", slog.Any("error", err))
		os.Exit(1)
	logger.Info("pipeline completed successfully")
Run the program with go run main.go. The output will stream structured JSON logs containing query initiation, backoff events, batch synchronization status, and final throughput metrics.
  • Cause: The OAuth token expired during long-running pagination or was issued without the analytics:conversation:view scope.
  • Fix: Implement token lifecycle management. Refresh the token when time.Now().Add(300 * time.Second).After(token.ExpiresAt). Verify the client credentials in the Genesys Cloud admin console under Platform Applications.
  • Code Fix: Add a token refresh wrapper around the paginator loop or use a middleware that intercepts 401 responses and retries with a new token.
Error: 403 Forbidden
  • Cause: The authenticated user lacks the analytics:conversation:view permission or the client credentials are restricted to a different organization.
  • Fix: Assign the required OAuth scope to the confidential client. Verify the user role associated with the client has Analytics permissions.
  • Code Fix: No code change required. Update the Genesys Cloud IAM configuration and regenerate credentials.
  • Cause: The request rate exceeds the Genesys Cloud API throttle limits (typically 10 requests per second per token).
  • Fix: The exponential backoff implementation handles this automatically. If throttling persists, increase the base delay or reduce concurrent workers.
  • Code Fix: Adjust calculateBackoff to start with a higher base duration or implement a token bucket rate limiter before ExecuteQuery.
Error: 400 Bad Request (Date Range Exceeds Retention)
  • Cause: The dateFrom and dateTo span exceeds the configured data retention window (standard is 13 months, extended is 24+ months).
  • Fix: Split the query into multiple non-overlapping windows that fit within the retention policy. Validate the range before sending the request.
  • Code Fix: The BuildQuery function already validates this. If you need historical data beyond retention, switch to the Export API (/api/v2/analytics/conversations/details/export) which supports longer windows but returns asynchronous job IDs.
Error: 502/503 Bad Gateway or Service Unavailable
  • Cause: Genesys Cloud backend transient failure or maintenance window.
  • Fix: Implement retry logic with a maximum attempt limit and circuit breaker pattern to prevent cascading failures.
  • Code Fix: Extend the retry loop in ExecuteQuery to catch http.StatusBadGateway and http.StatusServiceUnavailable alongside 429.
