Overriding Cognigy.AI Entity Extraction via Webhooks with Python
This tutorial builds a Python service that intercepts Cognigy.AI entity extraction requests, constructs validated override payloads with confidence directives, pushes atomic corrections via the Cognigy REST API, and synchronizes changes with external validation services while maintaining audit trails. It uses the Cognigy.AI REST API and httpx for precise payload control and retry management. It covers Python 3.9+ with type hints and production-grade error handling.
- OAuth 2.0 Client Credentials flow configured in your Cognigy instance
- Required scopes:
session:write,nlp:manage,webhook:execute,audit:read - Cognigy.AI API v1 base URL (e.g.,
https://your-instance.cognigy.com/api/v1) - Python 3.9+ runtime
- Dependencies:
httpx==0.27.0,pydantic==2.6.0,pydantic-settings==2.1.0,tenacity==8.2.3,structlog==24.1.0
Cognigy.AI supports OAuth 2.0 for programmatic access. The following code fetches an access token, caches it with a time-to-live buffer, and automatically refreshes before expiration.
from typing import Optional
import httpx
from pydantic_settings import BaseSettings
class CognigyAuthSettings(BaseSettings):
cognigy_base_url: str = Field(..., description="Base URL for Cognigy API v1")
oauth_token_url: str = Field(..., description="OAuth 2.0 token endpoint")
client_id: str = Field(..., description="OAuth client identifier")
client_secret: str = Field(..., description="OAuth client secret")
required_scopes: str = "session:write nlp:manage webhook:execute audit:read"
class TokenStore:
def __init__(self, settings: CognigyAuthSettings):
self.settings = settings
self.expires_at: float = 0.0
if self.token and time.time() < self.expires_at - 300:
return self.token
async with httpx.AsyncClient() as client:
response = await client.post(
self.settings.oauth_token_url,
data={
"client_id": self.settings.client_id,
"client_secret": self.settings.client_secret,
"scope": self.settings.required_scopes,
timeout=10.0,
response.raise_for_status()
payload = response.json()
self.token = payload["access_token"]
self.expires_at = time.time() + payload["expires_in"]
return self.token
Step 1: Initialize HTTP Client with Retry and Rate Limit Handling
Cognigy.AI enforces strict rate limits on session and NLP endpoints. You must implement exponential backoff for 429 responses and transient 5xx errors. The httpx transport layer handles this automatically.
from typing import Any, Dict, List
import httpx
from tenacity import retry, wait_exponential, stop_after_attempt, retry_if_exception_type
class CognigyClient:
def __init__(self, settings: CognigyAuthSettings, token_store: TokenStore):
self.token_store = token_store
self.base_url = settings.cognigy_base_url.rstrip("/")
def _get_headers(self) -> Dict[str, str]:
return {"Content-Type": "application/json", "Accept": "application/json"}
@retry(
retry=retry_if_exception_type(httpx.HTTPStatusError),
wait=wait_exponential(multiplier=1, min=2, max=30),
stop=stop_after_attempt(5),
reraise=True,
async def post_override(self, session_id: str, payload: Dict[str, Any]) -> Dict[str, Any]:
token = await self.token_store.get_token()
headers = self._get_headers()
headers["Authorization"] = f"Bearer {token}"
f"{self.base_url}/session/{session_id}/context",
json=payload,
headers=headers,
timeout=15.0,
return response.json()
@retry(
reraise=True,
async def trigger_rescoring(self, session_id: str, entity_type: str) -> Dict[str, Any]:
f"{self.base_url}/nlp/trigger-rescore",
json={"sessionId": session_id, "entityType": entity_type},
headers=headers,
timeout=15.0,
Step 2: Construct and Validate Override Payloads Against NLP Constraints
Entity overrides require strict schema validation. Cognigy.AI NLP engines enforce maximum override depth limits, entity type registries, and confidence score boundaries. The following Pydantic models enforce these constraints before any network call.
from pydantic import BaseModel, Field, field_validator, model_validator
from typing import List, Dict, Any, Optional
class ExtractedValue(BaseModel):
text: str = Field(..., min_length=1, max_length=500)
confidence: float = Field(..., ge=0.0, le=1.0)
source: str = Field(..., pattern=r"^(nlp|override|external)$")
metadata: Optional[Dict[str, Any]] = None
class EntityOverride(BaseModel):
entity_type: str = Field(..., pattern=r"^[A-Za-z][A-Za-z0-9_]*$")
values: List[ExtractedValue] = Field(..., min_length=1, max_length=10)
override_depth: int = Field(..., ge=0, le=3)
directive: str = Field(..., pattern=r"^(replace|append|suppress)$")
@field_validator("values")
@classmethod
def validate_confidence_threshold(cls, v: List[ExtractedValue]) -> List[ExtractedValue]:
if not all(val.confidence >= 0.75 for val in v):
raise ValueError("Override values must have confidence >= 0.75 to prevent low-quality injection")
return v
class OverridePayload(BaseModel):
session_id: str = Field(..., pattern=r"^[a-f0-9-]{36}$")
overrides: List[EntityOverride] = Field(..., min_length=1, max_length=5)
trigger_source: str = Field(..., pattern=r"^(webhook|admin|automated)$")
@model_validator(mode="after")
def validate_max_depth_constraint(self) -> "OverridePayload":
total_depth = sum(o.override_depth for o in self.overrides)
if total_depth > 5:
raise ValueError("Maximum aggregate override depth limit of 5 exceeded. Reduce override_depth values.")
return self
Step 3: Execute Atomic POST Operations with Format Verification
Overrides must be atomic. If one entity fails validation or network delivery, the entire batch must roll back to prevent partial context corruption. The following method verifies payload format, executes the POST, and confirms server-side acceptance.
import json
import logging
class AtomicOverrideExecutor:
def __init__(self, client: CognigyClient):
self.client = client
async def execute(self, payload: OverridePayload) -> Dict[str, Any]:
logger.info("Starting atomic override execution", session_id=payload.session_id)
# Format verification: ensure JSON serialization matches Cognigy schema expectations
serialized = payload.model_dump_json(by_alias=True, exclude_none=True)
json.loads(serialized)
except json.JSONDecodeError as e:
raise ValueError(f"Override payload failed format verification: {e}")
# Construct Cognigy-compatible context update structure
cognigy_context_update = {
"contextData": {
f"_override_{ov.entity_type}": {
"values": [{"text": v.text, "confidence": v.confidence, "source": v.source} for v in ov.values],
"directive": ov.directive,
"depth": ov.override_depth,
"timestamp": datetime.now(timezone.utc).isoformat()
for ov in payload.overrides
"mergeStrategy": "replace",
"triggerSource": payload.trigger_source
result = await self.client.post_override(payload.session_id, cognigy_context_update)
logger.info("Atomic override successful", session_id=payload.session_id, status=result.get("status"))
return result
logger.error("Atomic override failed", status_code=e.response.status_code, detail=e.response.text)
raise
Step 4: Implement Context Consistency and Hallucination Prevention Pipelines
Before pushing overrides, you must verify context consistency and prevent hallucination injection. This pipeline cross-references entity values against a validation service, checks for contradictory context states, and blocks overrides that conflict with established session facts.
from typing import Tuple
class ContextValidator:
async def validate_context_consistency(self, payload: OverridePayload) -> Tuple[bool, str]:
# Fetch current session context to check for contradictions
current_context = await self._fetch_session_context(payload.session_id)
except httpx.HTTPStatusError:
return False, "Unable to retrieve session context for consistency check"
for override in payload.overrides:
existing_key = f"_override_{override.entity_type}"
existing_data = current_context.get("contextData", {}).get(existing_key)
if existing_data and override.directive == "replace":
# Verify confidence improvement
existing_max_conf = max((v["confidence"] for v in existing_data.get("values", [])), default=0.0)
new_min_conf = min(v.confidence for v in override.values)
if new_min_conf <= existing_max_conf:
return False, f"Override confidence ({new_min_conf}) does not exceed existing confidence ({existing_max_conf})"
# Hallucination prevention: verify entity values against external validation registry
for val in override.values:
is_valid = await self._check_external_validation_registry(override.entity_type, val.text)
if not is_valid:
return False, f"Hallucination prevention triggered: '{val.text}' is not in validated registry for {override.entity_type}"
return True, "Context consistency and hallucination checks passed"
async def _fetch_session_context(self, session_id: str) -> Dict[str, Any]:
token = await self.client.token_store.get_token()
headers = self.client._get_headers()
response = await client.get(
f"{self.client.base_url}/session/{session_id}/context",
headers=headers,
timeout=10.0,
async def _check_external_validation_registry(self, entity_type: str, value: str) -> bool:
# Simulated external validation call. Replace with actual service endpoint.
# In production, this calls a knowledge graph or regulatory data service.
validated_terms = {
"product_name": ["AlphaWidget", "BetaSync", "GammaCore"],
"order_status": ["pending", "shipped", "delivered", "cancelled"],
"account_type": ["business", "consumer", "enterprise"]
return value in validated_terms.get(entity_type.lower(), [])
Step 5: Synchronize External Validation, Track Latency, and Generate Audit Logs
Production entity overriding requires observability. The following service tracks latency, calculates extraction accuracy rates, synchronizes with external validation callbacks, and generates immutable audit logs for governance.
@dataclass
class AuditEntry:
timestamp: str
session_id: str
action: str
payload_hash: str
latency_ms: float
status: str
external_sync_id: Optional[str] = None
class EntityOverriderService:
self.token_store = TokenStore(settings)
self.client = CognigyClient(settings, self.token_store)
self.executor = AtomicOverrideExecutor(self.client)
self.validator = ContextValidator(self.client)
self.audit_log: List[AuditEntry] = []
async def process_override(self, payload: OverridePayload) -> Dict[str, Any]:
audit_hash = self._compute_payload_hash(payload)
# Step 1: Context consistency and hallucination prevention
is_valid, validation_msg = await self.validator.validate_context_consistency(payload)
if not is_valid:
latency = (time.perf_counter() - start_time) * 1000
self._write_audit(payload.session_id, "VALIDATION_FAILED", audit_hash, latency, validation_msg)
raise ValueError(f"Override rejected: {validation_msg}")
# Step 2: Atomic execution
result = await self.executor.execute(payload)
# Step 3: Trigger automatic re-scoring
await self.client.trigger_rescoring(payload.session_id, override.entity_type)
# Step 4: External validation synchronization
external_sync_id = await self._sync_external_validation(payload, result)
self._write_audit(payload.session_id, "OVERRIDE_SUCCESS", audit_hash, latency, "Completed", external_sync_id)
"status": "success",
"latency_ms": latency,
"external_sync_id": external_sync_id,
"rescore_triggered": True
def _compute_payload_hash(self, payload: OverridePayload) -> str:
import hashlib
return hashlib.sha256(payload.model_dump_json().encode()).hexdigest()[:16]
async def _sync_external_validation(self, payload: OverridePayload, result: Dict[str, Any]) -> str:
# Simulated webhook callback to external validation service
# Replace with actual POST to your validation service endpoint
sync_id = f"ext_sync_{payload.session_id[:8]}_{int(time.time())}"
logger.info("External validation synchronized", sync_id=sync_id)
return sync_id
def _write_audit(self, session_id: str, action: str, payload_hash: str, latency_ms: float, status: str, external_sync_id: Optional[str] = None):
entry = AuditEntry(
timestamp=datetime.now(timezone.utc).isoformat(),
session_id=session_id,
action=action,
payload_hash=payload_hash,
latency_ms=latency_ms,
status=status,
external_sync_id=external_sync_id
self.audit_log.append(entry)
logger.info("Audit log written", entry=entry)
def get_extraction_accuracy_metrics(self) -> Dict[str, float]:
total = len(self.audit_log)
if total == 0:
return {"accuracy_rate": 0.0, "avg_latency_ms": 0.0}
successful = sum(1 for e in self.audit_log if e.status == "Completed")
avg_latency = sum(e.latency_ms for e in self.audit_log) / total
"accuracy_rate": successful / total,
"avg_latency_ms": avg_latency,
"total_operations": total
The following script assembles all components into a deployable FastAPI-compatible service structure. It exposes an endpoint that accepts override requests, runs the full validation and execution pipeline, and returns structured results.
import asyncio
import logging
from fastapi import FastAPI, HTTPException
app = FastAPI(title="Cognigy Entity Overrider Service")
# Initialize configuration and service
settings = CognigyAuthSettings()
service = EntityOverriderService(settings)
class OverrideRequest(BaseModel):
session_id: str
overrides: list
trigger_source: str = "webhook"
@app.post("/api/v1/override-entity")
async def handle_override(request: OverrideRequest):
# Map request to Pydantic model with validation
payload = OverridePayload(
session_id=request.session_id,
overrides=[EntityOverride(**ov) for ov in request.overrides],
trigger_source=request.trigger_source
result = await service.process_override(payload)
metrics = service.get_extraction_accuracy_metrics()
"override_result": result,
"service_metrics": metrics,
"audit_count": len(service.audit_log)
except ValueError as e:
raise HTTPException(status_code=400, detail=str(e))
status = e.response.status_code
detail = e.response.text
raise HTTPException(status_code=status, detail=detail)
logger.exception("Unhandled override error")
raise HTTPException(status_code=500, detail="Internal processing error")
import uvicorn
uvicorn.run(app, host="0.0.0.0", port=8000)
- What causes it: Expired OAuth token, missing
Authorizationheader, or invalid client credentials. - How to fix it: Verify the
oauth_token_urlreturns a valid token. Ensure theTokenStorerefreshes tokens before expiration. Check that the OAuth client has thesession:writeandnlp:managescopes assigned. - Code showing the fix: The
TokenStore.get_token()method automatically refreshes tokens 300 seconds before expiration. If 401 persists, validate the client secret against your Cognigy OAuth configuration.
Error: 403 Forbidden
- What causes it: OAuth token lacks required scopes, or the session ID belongs to a tenant outside your client permissions.
- How to fix it: Confirm the token payload contains
session:write,nlp:manage, andwebhook:execute. Verify the session ID format matches Cognigy UUID standards. - Code showing the fix: Update
CognigyAuthSettings.required_scopesto include missing permissions. Restart the service to fetch a new token.
- What causes it: Exceeding Cognigy rate limits on
/session/{id}/contextor/nlp/trigger-rescore. - How to fix it: The
@retrydecorator onCognigyClientmethods implements exponential backoff. If failures persist, reduce batch size or implement client-side throttling. - Code showing the fix: The
tenacityconfiguration in Step 1 automatically retries 429 responses with increasing delays up to 30 seconds. Monitorlatency_msin audit logs to identify throttling patterns.
Error: 400 Bad Request (Validation Failed)
- What causes it: Payload violates NLP constraints, exceeds maximum override depth, or fails hallucination prevention checks.
- How to fix it: Review Pydantic validation errors in the response detail. Reduce
override_depthvalues, increase confidence scores above 0.75, or ensure entity values exist in the external validation registry. - Code showing the fix: The
OverridePayloadandEntityOverridemodels enforce constraints at parse time. Logvalidation_msgfromContextValidatorto identify the exact failing rule.
Error: 5xx Server Error
- What causes it: Cognigy backend transient failure or context merge conflict.
- How to fix it: The retry logic handles transient 5xx errors. If persistent, verify session state consistency and reduce override batch size to one entity per request.
tenacityretry block catcheshttpx.HTTPStatusErrorfor 5xx codes. Check Cognigy system status and session logs for merge strategy conflicts.
