Outbound - Saving Custom fields through GAD
We are customizing GAD for outbound with customized outbound fields. We have set the “send_attribute” and the respective fields are shown in GAD. Below is the code taken from a working GAD where it was customized to save the customized fields for outbound.
String CCU_CallStatus="asdadasdasdadsdasd";
com.genesyslab.ail.AilFactory factory = com.genesyslab.ail.AilLoader.getAilFactory();
String idInteraction=(String)request.getParameter( "idInteraction" ) ;
com.genesyslab.ail.Interaction interaction = factory.getInteraction( (String)request.getParameter( "idInteraction" ) );
com.genesyslab.ail.InteractionVoiceOutbound IVO = (com.genesyslab.ail.InteractionVoiceOutbound) factory.getInteraction( (String)request.getParameter( "idInteraction" ) );
com.genesyslab.ail.OutboundRecord outboundRecord ;
outboundRecord=IVO.getActiveRecord();
if (CCU_CallStatus != null) {
		interaction.setAttachedData("CCU_CallStatus",CCU_CallStatus);
        outboundRecord.setCustomField("CCU_CallStatus",CCU_CallStatus);
interaction.saveAttachedData();
But when i run this code i am getting “com.genesyslab.ail.core.InteractionVoiceImpl cannot be cast to com.genesyslab.ail.InteractionVoiceOutbound” error. I have been breaking my head camparing both the GAD and was not able to find anything.
Am I missing any jar file or missing any setting in OCS?
Seems like your call is not an outbound call. You could check that the call you are trying to get the record from is the actual outbound-call having all outbound data in it..
Or what is this request variable you take the ‘idInteraction’ from? Maybe it does not give you correct id, or that call has already marked done (and therefore not found from AIL at all)?
The call was from an outbound and also checked this code before disconnecting and clicking markdone. “idInteraction” is the interaction ID attached by GAD, for the respective outbound call. :cry:
I am missing something here. But this code actually works in another GAD, but when i replicate into another GAD it is not working. :cry:
If works on another GAD:
  1. compare GAD versions
  2. Be 100% sure that you are calling the script on the exact same event, 100% copy of the working one
