We are running an outbound calling list however for any records that have been answered, the call result within ocm is updating as dropped. Answer machine detected, no answer, busy are updated correctly within the calling list. I think this may related to the Genesys desktop (GAD) showing the following message when I click mark done:
The Interaction has not been marked as processed: record already processed
The default call result in the open record is Answer so am assuming from this message that it is not writing the result into the calling list and by default it remains dropped?
I have tried the solution search site however the only meaningful page stated the agent must be in a not ready or aftercallwork state to process the record - which they are as we have set the wrap up time in the persons record to 60.
log files for ocs show the answer call result so seemingly in the background all is correct.
We are using:
SIP 8
GVP 8.1
GAD 7.6
ocs 8.0
ocm 7.6
CPD 7.6
There is a bunch of new configuration items in OCS 8. Have a look at the migration guide page 276, possibly one of the default options is causing this behaviour.
I have added the record_processed setting to true in the OCServer section of the ocs application but hasnt worked, still receive the same message and call is marked as dropped within the calling list.
Was this the right location to the add the option?
This was caused by the route point containing an option called default_dn, value of true, when removed enabled the agents to update the calling list with the call result selecting in GAD.
