Orchestrating post-call data enrichment by routing Genesys Cloud EventBridge conversation.end events to AWS Step Functions using Python Lambda triggers
  • When a Genesys Cloud conversation ends, this pipeline captures the event via Event Streams, processes it in a Python Lambda function, and triggers an AWS Step Functions workflow to enrich the call data with external CRM and transcript analysis results.
  • This tutorial uses the Genesys Cloud Event Streams API, the Conversations Analytics Query API, and the AWS SDK for Python (Boto3).
  • The implementation covers Python for Lambda and JSON for the Step Functions state machine definition.
  • Genesys Cloud OAuth 2.0 client credentials grant with scopes: eventstream:write, analytics:query, conversations:read
  • Genesys Cloud REST API v2
  • AWS Lambda runtime Python 3.10+
  • AWS Boto3 (version 1.28+)
  • AWS Step Functions standard or express workflow
  • External dependencies: requests==2.31.0, boto3==1.28.0, pydantic==2.5.0
Genesys Cloud uses OAuth 2.0 client credentials flow for server-to-server integrations. You must cache the access token and handle expiration gracefully. The following module handles token acquisition, TTL tracking, and automatic refresh before API calls.
import requests
import os
from typing import Dict, Optional
GENESYS_BASE_URL = "https://api.mypurecloud.com"
OAUTH_TOKEN_ENDPOINT = f"{GENESYS_BASE_URL}/oauth/token"
class GenesysAuthManager:
    def __init__(self, client_id: str, client_secret: str, region: str = "us-east-1"):
        self.client_id = client_id
        self.region = region
        self.session = requests.Session()
        self.session.headers.update({
            "Accept": "application/json"
    def _get_token(self) -> Dict[str, str]:
        payload = {
            "client_id": self.client_id,
        response = self.session.post(OAUTH_TOKEN_ENDPOINT, json=payload)
        response.raise_for_status()
        data = response.json()
        self.access_token = data["access_token"]
        self.token_expiry = time.time() + data["expires_in"] - 300  # Refresh 5 minutes early
        return data
    def get_valid_token(self) -> str:
        if not self.access_token or time.time() >= self.token_expiry:
            self._get_token()
        if not self.access_token:
            raise RuntimeError("Failed to retrieve Genesys Cloud access token")
        return self.access_token
    def get_authenticated_session(self) -> requests.Session:
        token = self.get_valid_token()
        return session
This pattern ensures every API request carries a valid bearer token. The session object reuses TCP connections, reducing latency during high-throughput EventBridge routing.
Step 1: Provision the Genesys Cloud Event Stream via API
You must configure Genesys Cloud to push conversation.end events to AWS EventBridge. The Event Streams API accepts a target configuration with the EventBridge ARN. This call requires the eventstream:write scope.
def create_event_stream(auth: GenesysAuthManager, stream_name: str, eventbridge_arn: str) -> Dict:
    url = f"{GENESYS_BASE_URL}/api/v2/eventstreams"
    payload = {
        "name": stream_name,
        "enabled": True,
        "filter": {
            "eventType": "conversation.end"
        "target": {
            "type": "EventBridge",
            "eventBridgeArn": eventbridge_arn,
            "region": "us-east-1"
    session = auth.get_authenticated_session()
    response = session.post(url, json=payload)
    if response.status_code == 409:
        print(f"Event stream {stream_name} already exists. Returning existing configuration.")
        return {"status": "exists"}
    return response.json()
The conversation.end event type fires after all media legs terminate and the conversation state transitions to ended. This guarantees that transcript, wrap-up codes, and participant metadata are fully populated before the EventBridge payload arrives.
Step 2: Build the Lambda handler to parse EventBridge payloads and query Genesys Cloud
The Lambda function receives an EventBridge event. You must extract the conversation ID, query Genesys Cloud for detailed analytics, and prepare the enrichment payload. This step requires the analytics:query scope. The analytics query endpoint supports pagination, which you must handle when processing bulk events or high-volume queues.
import json
import logging
from typing import Any, Dict, List
logger = logging.getLogger()
logger.setLevel(logging.INFO)
MAX_RETRIES = 3
RETRY_BACKOFF = 1.5
def query_conversation_details(auth: GenesysAuthManager, conversation_id: str) -> Dict[str, Any]:
    url = f"{GENESYS_BASE_URL}/api/v2/analytics/conversations/details/query"
    payload = {
        "dateFrom": "2023-01-01T00:00:00Z",
        "dateTo": "2099-12-31T23:59:59Z",
        "groupBy": ["conversationId"],
        "filter": [
            {"type": "conversationId", "value": conversation_id}
        "size": 100
    all_details: List[Dict] = []
    next_page_token = None
    attempt = 0
    while True:
        attempt += 1
            params = {}
            if next_page_token:
                params["pageToken"] = next_page_token
            response = session.post(url, json=payload, params=params, timeout=30)
                retry_after = float(response.headers.get("Retry-After", RETRY_BACKOFF ** attempt))
                logger.warning(f"Rate limited (429). Retrying in {retry_after}s")
                time.sleep(retry_after)
            all_details.extend(data.get("entities", []))
            next_page_token = data.get("nextPageToken")
            if not next_page_token:
                break
            logger.error(f"Request failed on attempt {attempt}: {e}")
            if attempt >= MAX_RETRIES:
                raise
            time.sleep(RETRY_BACKOFF ** attempt)
    return all_details[0] if all_details else {}
The retry logic explicitly handles HTTP 429 responses by parsing the Retry-After header or applying exponential backoff. Genesys Cloud enforces strict rate limits on analytics queries, and this pattern prevents cascade failures during peak call volumes. The pageToken parameter handles pagination when the response exceeds the size limit.
Step 3: Implement idempotent Step Functions execution triggers
After retrieving conversation details, the Lambda function must start a Step Functions execution. You must generate a unique execution name to guarantee idempotency, preventing duplicate enrichment runs if EventBridge delivers the same event twice.
import boto3
import uuid
def start_enrichment_workflow(
    step_functions_client: boto3.client,
    state_machine_arn: str,
    conversation_id: str,
    details: Dict[str, Any]
    execution_name = f"enrich_{conversation_id}_{datetime.now(timezone.utc).strftime('%Y%m%d%H%M%S')}_{uuid.uuid4().hex[:8]}"
    input_payload = {
        "conversationId": conversation_id,
        "callDetails": details,
        "enrichmentSteps": [
            "fetch_crm_contact",
            "analyze_sentiment",
            "update_ticket_system"
        response = step_functions_client.start_execution(
            stateMachineArn=state_machine_arn,
            name=execution_name,
            input=json.dumps(input_payload)
        logger.info(f"Step Functions execution started: {response['executionArn']}")
        return response
    except step_functions_client.exceptions.InvalidExecutionNameException:
        logger.warning(f"Execution name collision detected. Generating new name.")
        # Fallback with pure UUID to guarantee uniqueness
            name=f"enrich_{uuid.uuid4().hex}",
        return response
        logger.error(f"Failed to start Step Functions execution: {e}")
        raise
def lambda_handler(event: Dict[str, Any], context: Any) -> Dict[str, str]:
    auth = GenesysAuthManager(
        client_id=os.environ["GENESYS_CLIENT_ID"],
        client_secret=os.environ["GENESYS_CLIENT_SECRET"]
    step_functions = boto3.client("stepfunctions")
    state_machine_arn = os.environ["STEP_FUNCTIONS_ARN"]
    event_data = event.get("detail", {})
    conversation_id = event_data.get("conversationId")
    if not conversation_id:
        raise ValueError("Missing conversationId in EventBridge payload")
    details = query_conversation_details(auth, conversation_id)
    start_enrichment_workflow(step_functions, state_machine_arn, conversation_id, details)
        "statusCode": 200,
        "body": json.dumps({"status": "enrichment_triggered", "conversationId": conversation_id})
The execution name combines the conversation ID, timestamp, and UUID fragment. This structure allows you to trace workflows back to the original call while preventing collisions. The InvalidExecutionNameException handler provides a deterministic fallback. Step Functions requires the execution name to be unique per state machine, and this pattern satisfies that constraint without relying on external databases.
The following module combines authentication, API querying, retry logic, and Step Functions triggering into a single deployable Lambda handler. Replace the environment variables with your credentials before deployment.
import json
import logging
import os
import uuid
import requests
import boto3
from typing import Any, Dict, List, Optional
MAX_RETRIES = 3
RETRY_BACKOFF = 1.5
    def __init__(self, client_id: str, client_secret: str):
        self.session.headers.update({"Content-Type": "application/json", "Accept": "application/json"})
        payload = {"grant_type": "client_credentials", "client_id": self.client_id, "client_secret": self.client_secret}
        return data
            self._get_token()
        session.headers.update({"Authorization": f"Bearer {token}", "Content-Type": "application/json", "Accept": "application/json"})
        return session
    payload = {
        "filter": [{"type": "conversationId", "value": conversation_id}],
        "size": 100
    attempt = 0
    while True:
        attempt += 1
            params = {"pageToken": next_page_token} if next_page_token else {}
                break
                raise
    input_payload = {
        "enrichmentSteps": ["fetch_crm_contact", "analyze_sentiment", "update_ticket_system"]
        step_functions.start_execution(
        logger.error(f"Step Functions trigger failed: {e}")
        raise
    return {"statusCode": 200, "body": json.dumps({"status": "enrichment_triggered", "conversationId": conversation_id})}
Deploy this code to AWS Lambda with the environment variables GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET, and STEP_FUNCTIONS_ARN. Attach an IAM role with stepfunctions:StartExecution permissions and logs:CreateLogGroup, logs:CreateLogStream, logs:PutLogEvents.
  • What causes it: The OAuth token has expired, the client credentials are incorrect, or the region endpoint mismatch (api.mypurecloud.com vs api.eu.pure.cloud.com).
  • How to fix it: Verify the client_id and client_secret match a Genesys Cloud application configured for client credentials grant. Ensure the GenesysAuthManager refreshes the token before each request. Check the response body for error and error_description fields.
  • Code showing the fix: The get_valid_token() method enforces a 5-minute early refresh window. If you receive a 401, add explicit validation of the token_expiry timestamp and force a re-authentication cycle.
Error: 403 Forbidden
  • What causes it: The OAuth client lacks the required scope (analytics:query or conversations:read). Genesys Cloud enforces scope validation at the API gateway level.
  • How to fix it: Navigate to the Genesys Cloud admin console, edit the application, and add the missing scopes. Re-generate the client secret if the application was recently modified.
  • Code showing the fix: Inspect the response.json() payload. It will contain "error": "insufficient_scope". Update the environment variables and redeploy the Lambda function.
  • What causes it: The analytics query endpoint enforces per-client and per-tenant rate limits. High-volume call centers trigger this during wrap-up spikes.
  • How to fix it: Implement exponential backoff with jitter. Parse the Retry-After header when present. Reduce the query frequency by batching conversation IDs if possible.
  • Code showing the fix: The query_conversation_details function already implements a retry loop with Retry-After parsing. Increase MAX_RETRIES to 5 and add random.uniform(0, 0.5) to the backoff calculation to prevent thundering herd problems.
Error: InvalidExecutionNameException
  • What causes it: Step Functions rejects duplicate execution names within the same state machine. EventBridge redeliveries or Lambda retries can cause collisions.
  • How to fix it: Append a UUID fragment or use a hash of the payload plus timestamp. Catch the exception and fall back to a pure UUID execution name.
  • Code showing the fix: The start_enrichment_workflow function handles this by catching InvalidExecutionNameException and regenerating the name with uuid.uuid4().hex.
