Orchestrating NICE CXone Outbound Campaigns with AWS Lambda and TypeScript
- A scheduled AWS Lambda function that reads contact segment metadata from DynamoDB, constructs batched payloads, and creates or updates NICE CXone outbound campaigns via the Outbound Campaign REST API.
- The workflow implements an adaptive retry strategy for HTTP 429 throttling, aggregates execution metrics for CloudWatch Logs Insights, and executes compensating deletions when error rates exceed a configured threshold.
- This tutorial covers TypeScript with Node.js 18+, using
axiosfor HTTP requests and@aws-sdk/client-dynamodbfor data retrieval.
- NICE CXone OAuth Client Credentials with scopes:
outbound:campaign:write,outbound:campaign:read - AWS IAM role attached to the Lambda function with permissions:
dynamodb:Query,logs:CreateLogGroup,logs:PutLogEvents,logs:CreateLogStream - DynamoDB table named
cxone-campaign-segmentswith partition keysegmentId(String) and sort keyenvironment(String) - Node.js 18+ runtime, TypeScript 5+,
axios,@aws-sdk/client-dynamodb,@aws-sdk/util-dynamodb,@types/aws-lambda - NICE CXone environment URL (e.g.,
https://us-east-1.platform.niceincontact.com)
NICE CXone uses the OAuth 2.0 Client Credentials flow. The Lambda execution context persists across invocations, so token caching reduces authentication latency. The following class manages token acquisition, caching, and automatic refresh when the token expires.
import axios, { AxiosInstance } from 'axios';
interface CXoneTokenResponse {
access_token: string;
token_type: string;
expires_in: number;
scope: string;
export class CXoneAuthClient {
private client: AxiosInstance;
private token: string | null = null;
private tokenExpiry: number = 0;
constructor(
private envUrl: string,
private clientId: string,
private clientSecret: string
this.client = axios.create({
baseURL: `${envUrl}/oauth`,
private async refreshToken(): Promise<void> {
const payload = new URLSearchParams({
client_id: this.clientId,
client_secret: this.clientSecret,
scope: 'outbound:campaign:write outbound:campaign:read'
}).toString();
const response = await this.client.post<CXoneTokenResponse>('/token', payload);
this.token = response.data.access_token;
// Subtract 60 seconds for refresh buffer
this.tokenExpiry = Date.now() + (response.data.expires_in - 60) * 1000;
async getBearerToken(): Promise<string> {
if (!this.token || Date.now() >= this.tokenExpiry) {
await this.refreshToken();
return this.token!;
The /oauth/token endpoint returns a JWT valid for 3600 seconds by default. The buffer subtraction prevents edge-case expiration during long-running Lambda executions. Always store clientId and clientSecret in AWS Secrets Manager or Parameter Store. Never hardcode credentials.
Step 1: DynamoDB Segment Fetching & Batching
The Lambda function queries DynamoDB for campaign segment definitions. Each record contains the target CXone contactListId, campaign name, dialing method, and scheduling parameters. DynamoDB requires explicit pagination handling when results exceed 1 MB. The following function handles pagination and batches records into chunks of 25 to align with CXone API concurrency limits.
import { DynamoDBClient, QueryCommand } from '@aws-sdk/client-dynamodb';
import { marshall, unmarshall } from '@aws-sdk/util-dynamodb';
interface SegmentRecord {
segmentId: string;
environment: string;
campaignName: string;
contactListId: string;
dialingMethod: 'preview' | 'progressive' | 'predictive';
maxCallsPerDay: number;
const dynamoDb = new DynamoDBClient({ region: process.env.AWS_REGION || 'us-east-1' });
export async function fetchSegments(segmentId: string): Promise<SegmentRecord[]> {
const params = {
TableName: 'cxone-campaign-segments',
KeyConditionExpression: 'segmentId = :sid AND environment = :env',
ExpressionAttributeValues: marshall({
':sid': segmentId,
':env': process.env.CXONE_ENVIRONMENT || 'production'
Limit: 100
const records: SegmentRecord[] = [];
let exclusiveStartKey: any = undefined;
do {
const command = new QueryCommand({ ...params, ExclusiveStartKey: exclusiveStartKey });
const result = await dynamoDb.send(command);
if (result.Items) {
records.push(...result.Items.map(item => unmarshall(item) as SegmentRecord));
exclusiveStartKey = result.LastEvaluatedKey;
} while (exclusiveStartKey);
// Batch into chunks of 25 for API concurrency management
const batchSize = 25;
const batches: SegmentRecord[][] = [];
for (let i = 0; i < records.length; i += batchSize) {
batches.push(records.slice(i, i + batchSize));
return batches;
The QueryCommand returns items matching the composite key. The LastEvaluatedKey drives pagination until exhaustion. Batching prevents Lambda timeout and reduces CXone API surface contention.
Step 2: CXone Outbound API Client & Adaptive Retry
CXone enforces rate limits on outbound endpoints. HTTP 429 responses include a Retry-After header. The following client wraps axios with an adaptive retry mechanism that respects the header, applies exponential backoff with jitter, and caps retries at five attempts.
import axios, { AxiosResponse, InternalAxiosRequestConfig } from 'axios';
interface ApiError extends Error {
status: number;
data?: any;
export class CXoneCampaignClient {
constructor(private baseUrl: string, private auth: CXoneAuthClient) {
baseURL: baseUrl,
headers: { 'Content-Type': 'application/json' }
private async getHeaders(): Promise<Record<string, string>> {
const token = await this.auth.getBearerToken();
return { Authorization: `Bearer ${token}` };
async request<T>(method: string, path: string, data?: any): Promise<T> {
const maxRetries = 5;
let attempt = 0;
while (attempt < maxRetries) {
const response = await this.client.request<AxiosResponse<T>>({
method,
url: path,
data,
headers: await this.getHeaders()
return response.data;
} catch (error: any) {
const retryAfter = parseInt(error.response.headers['retry-after'] || '0', 10);
const delay = retryAfter > 0 ? retryAfter * 1000 : Math.pow(2, attempt) * 1000 + Math.random() * 1000;
console.log(`[429] Rate limited. Retrying in ${delay}ms (attempt ${attempt + 1}/${maxRetries})`);
await new Promise(res => setTimeout(res, delay));
attempt++;
continue;
if (error.response?.status === 401) {
// Force token refresh on next call
continue;
const apiError: ApiError = Object.assign(new Error(error.message), {
status: error.response?.status,
data: error.response?.data
throw apiError;
throw new Error(`Max retries exceeded for ${method} ${path}`);
The retry loop checks for Retry-After. If absent, it falls back to exponential backoff with 0-1000ms jitter. HTTP 401 triggers a silent token refresh. All other errors fail fast to preserve Lambda execution time.
Step 3: Campaign Creation/Update Logic & Rollback Thresholds
CXone campaigns are managed via POST /api/v2/outbound/campaigns for creation and PUT /api/v2/outbound/campaigns/{id} for updates. The following function processes batches, tracks successful operations, and calculates error rates. If the error rate exceeds the configured threshold, it triggers a compensating rollback by deleting newly created campaigns.
interface CampaignPayload {
dialingMethod: string;
status: 'active' | 'inactive';
export async function processCampaignBatch(
client: CXoneCampaignClient,
segments: SegmentRecord[],
rollbackThreshold: number = 0.2
): Promise<{ created: string[]; updated: string[]; errors: number }> {
const created: string[] = [];
const updated: string[] = [];
let errors = 0;
for (const segment of segments) {
const payload: CampaignPayload = {
contactListId: segment.contactListId,
dialingMethod: segment.dialingMethod,
maxCallsPerDay: segment.maxCallsPerDay,
status: 'active'
// Attempt update first (idempotency pattern)
const existing = await client.request<any>('GET', `/api/v2/outbound/campaigns/search?name=${encodeURIComponent(segment.campaignName)}`);
if (existing.entities?.length > 0) {
const campaignId = existing.entities[0].id;
await client.request('PUT', `/api/v2/outbound/campaigns/${campaignId}`, payload);
updated.push(campaignId);
continue;
} catch (e) {
// Campaign does not exist, proceed to create
const newCampaign = await client.request<any>('POST', '/api/v2/outbound/campaigns', payload);
created.push(newCampaign.id);
console.error(`[ERROR] Failed to process segment ${segment.segmentId}: ${error.status} - ${error.message}`);
errors++;
const total = segments.length;
const errorRate = total > 0 ? errors / total : 0;
if (errorRate > rollbackThreshold && created.length > 0) {
console.warn(`[ROLLBACK] Error rate ${errorRate.toFixed(2)} exceeds threshold ${rollbackThreshold}. Reversing ${created.length} new campaigns.`);
await rollbackCreatedCampaigns(client, created);
return { created, updated, errors };
async function rollbackCreatedCampaigns(client: CXoneCampaignClient, campaignIds: string[]): Promise<void> {
for (const id of campaignIds) {
await client.request('DELETE', `/api/v2/outbound/campaigns/${id}`);
console.log(`[ROLLBACK] Deleted campaign ${id}`);
} catch (err) {
console.error(`[ROLLBACK FAILED] Could not delete campaign ${id}: ${err}`);
The search endpoint /api/v2/outbound/campaigns/search requires the outbound:campaign:read scope. The payload omits optional fields like languageCode and timezone to keep the example focused. The rollback function uses DELETE to remove campaigns that were not previously present. This compensating transaction prevents orphaned campaigns when partial batch failures occur.
Step 4: CloudWatch Monitoring & Execution Orchestration
AWS Lambda automatically streams console.log output to CloudWatch Logs. Structured JSON logging enables CloudWatch Logs Insights queries for metric extraction. The following handler ties DynamoDB fetching, batch processing, and metric emission together.
import { ScheduledHandler } from 'aws-lambda';
import { CXoneAuthClient } from './auth';
import { CXoneCampaignClient } from './api';
import { fetchSegments } from './dynamodb';
const CXONE_ENV = process.env.CXONE_ENVIRONMENT || 'us-east-1.platform.niceincontact.com';
const CXONE_CLIENT_ID = process.env.CXONE_CLIENT_ID!;
const CXONE_CLIENT_SECRET = process.env.CXONE_CLIENT_SECRET!;
const SEGMENT_ID = process.env.SEGMENT_ID || 'default-batch-001';
export const handler: ScheduledHandler = async (event) => {
const startTime = Date.now();
const auth = new CXoneAuthClient(`https://${CXONE_ENV}`, CXONE_CLIENT_ID, CXONE_CLIENT_SECRET);
const apiClient = new CXoneCampaignClient(`https://${CXONE_ENV}`, auth);
console.log(JSON.stringify({ event: 'start', timestamp: new Date().toISOString(), segmentId: SEGMENT_ID }));
const batches = await fetchSegments(SEGMENT_ID);
let totalCreated = 0;
let totalUpdated = 0;
let totalErrors = 0;
for (const batch of batches) {
const result = await processCampaignBatch(apiClient, batch, parseFloat(process.env.ROLLBACK_THRESHOLD || '0.2'));
totalCreated += result.created.length;
totalUpdated += result.updated.length;
totalErrors += result.errors;
event: 'batch_complete',
created: result.created.length,
updated: result.updated.length,
errors: result.errors,
const duration = Date.now() - startTime;
event: 'execution_complete',
durationMs: duration,
totalCreated,
totalUpdated,
totalErrors,
if (totalErrors > 0) {
throw new Error(`Execution completed with ${totalErrors} errors. Review CloudWatch logs for details.`);
The handler emits JSON objects to CloudWatch. You can query execution metrics using CloudWatch Logs Insights:
fields @timestamp, @message
| filter @message like /execution_complete/
| parse @message '"totalCreated":*,' as created
| stats avg(created) by bin(5m)
The explicit error throw at the end triggers Lambda retry policies if configured, or allows EventBridge to route failure notifications to SNS.
The following file combines all modules into a single deployable Lambda entry point. Save as index.ts and compile with tsc.
import axios from 'axios';
// --- Types ---
interface CXoneTokenResponse { access_token: string; expires_in: number; scope: string; }
interface SegmentRecord { segmentId: string; environment: string; campaignName: string; contactListId: string; dialingMethod: string; maxCallsPerDay: number; }
interface ApiError extends Error { status: number; }
// --- Auth ---
constructor(private envUrl: string, private clientId: string, private clientSecret: string) {}
private async refreshToken() {
const payload = new URLSearchParams({ grant_type: 'client_credentials', client_id: this.clientId, client_secret: this.clientSecret, scope: 'outbound:campaign:write outbound:campaign:read' }).toString();
const res = await axios.post<CXoneTokenResponse>(`${this.envUrl}/oauth/token`, payload, { headers: { 'Content-Type': 'application/x-www-form-urlencoded' } });
this.token = res.data.access_token;
this.tokenExpiry = Date.now() + (res.data.expires_in - 60) * 1000;
async getToken() { if (!this.token || Date.now() >= this.tokenExpiry) await this.refreshToken(); return this.token!; }
// --- API Client ---
private baseUrl: string;
private auth: CXoneAuthClient;
constructor(baseUrl: string, auth: CXoneAuthClient) { this.baseUrl = baseUrl; this.auth = auth; }
async request(method: string, path: string, data?: any) {
for (let attempt = 0; attempt < maxRetries; attempt++) {
const token = await this.auth.getToken();
const res = await axios({ method, url: `${this.baseUrl}${path}`, data, headers: { Authorization: `Bearer ${token}`, 'Content-Type': 'application/json' } });
return res.data;
} catch (err: any) {
if (err.response?.status === 429) {
const retryAfter = parseInt(err.response.headers['retry-after'] || '0', 10);
await new Promise(r => setTimeout(r, retryAfter > 0 ? retryAfter * 1000 : Math.pow(2, attempt) * 1000 + Math.random() * 1000));
continue;
if (err.response?.status === 401) { await this.auth.getToken(); continue; }
throw Object.assign(new Error(err.message), { status: err.response?.status });
throw new Error('Max retries exceeded');
// --- DynamoDB ---
async function fetchSegments(segmentId: string): Promise<SegmentRecord[][]> {
do {
const res = await dynamoDb.send(new QueryCommand({
ExpressionAttributeValues: marshall({ ':sid': segmentId, ':env': process.env.CXONE_ENVIRONMENT || 'production' }),
ExclusiveStartKey: exclusiveStartKey,
Limit: 100
if (res.Items) records.push(...res.Items.map(i => unmarshall(i) as SegmentRecord));
exclusiveStartKey = res.LastEvaluatedKey;
return Array.from({ length: Math.ceil(records.length / 25) }, (_, i) => records.slice(i * 25, i * 25 + 25));
// --- Business Logic ---
async function processBatch(client: CXoneCampaignClient, segments: SegmentRecord[], threshold: number) {
let errors = 0;
for (const seg of segments) {
let campaignId: string | null = null;
const search = await client.request('GET', `/api/v2/outbound/campaigns/search?name=${encodeURIComponent(seg.campaignName)}`);
if (search.entities?.length > 0) {
campaignId = search.entities[0].id;
await client.request('PUT', `/api/v2/outbound/campaigns/${campaignId}`, { ...seg, status: 'active' });
} catch {}
if (!campaignId) {
const newCamp = await client.request('POST', '/api/v2/outbound/campaigns', { ...seg, status: 'active' });
created.push(newCamp.id);
} catch (e: any) { errors++; console.error(`[ERR] ${seg.segmentId}: ${e.status} ${e.message}`); }
const rate = segments.length > 0 ? errors / segments.length : 0;
if (rate > threshold && created.length > 0) {
console.warn(`[ROLLBACK] Rate ${rate.toFixed(2)} > ${threshold}. Deleting ${created.length} campaigns.`);
for (const id of created) {
try { await client.request('DELETE', `/api/v2/outbound/campaigns/${id}`); } catch (e) { console.error(`[ROLLBACK FAIL] ${id}`); }
return { created, errors };
// --- Handler ---
export const handler: ScheduledHandler = async () => {
const env = process.env.CXONE_ENVIRONMENT || 'us-east-1.platform.niceincontact.com';
const auth = new CXoneAuthClient(`https://${env}`, process.env.CXONE_CLIENT_ID!, process.env.CXONE_CLIENT_SECRET!);
const client = new CXoneCampaignClient(`https://${env}`, auth);
const batches = await fetchSegments(process.env.SEGMENT_ID || 'default-batch-001');
let totalCreated = 0, totalErrors = 0;
const res = await processBatch(client, batch, parseFloat(process.env.ROLLBACK_THRESHOLD || '0.2'));
totalCreated += res.created.length;
totalErrors += res.errors;
console.log(JSON.stringify({ event: 'complete', created: totalCreated, errors: totalErrors, ts: new Date().toISOString() }));
if (totalErrors > 0) throw new Error(`${totalErrors} errors occurred during execution.`);
Deploy with serverless or sam build. Set environment variables CXONE_ENVIRONMENT, CXONE_CLIENT_ID, CXONE_CLIENT_SECRET, SEGMENT_ID, and ROLLBACK_THRESHOLD. The function compiles to a single bundle under 10 MB.
Error: HTTP 401 Unauthorized
- Cause: OAuth token expired during execution, or client credentials are invalid.
- Fix: Ensure the
CXoneAuthClientrefreshes the token before every batch. Verify the OAuth client has theoutbound:campaign:writescope assigned in the CXone admin console. - Code Check: The retry loop catches 401 and calls
await this.auth.getToken()to force a refresh before the next attempt.
Error: HTTP 403 Forbidden
- Cause: The OAuth client lacks required scopes, or the campaign name violates CXone naming constraints.
- Fix: Add
outbound:campaign:readandoutbound:campaign:writeto the OAuth client scopes. ValidatecampaignNamedoes not exceed 100 characters and contains only alphanumeric characters, spaces, hyphens, and underscores. - Debug Step: Log the exact request payload before the API call. Compare it against the CXone Campaign API schema.
- Cause: CXone rate limiting triggered by concurrent batch requests or exceeding tenant-level quotas.
- Fix: The adaptive retry wrapper parses the
Retry-Afterheader. If missing, it applies exponential backoff. Reduce the batch size from 25 to 10 if throttling persists. - Code Check:
const delay = retryAfter > 0 ? retryAfter * 1000 : Math.pow(2, attempt) * 1000 + Math.random() * 1000;ensures compliant pacing.
Error: HTTP 500 Internal Server Error
- Cause: CXone backend failure or malformed JSON payload.
- Fix: Validate all numeric fields (
maxCallsPerDay) are integers. EnsuredialingMethodmatches one of the enum values:preview,progressive, orpredictive. Retry once with a 2-second delay. If the error persists, halt execution and alert via SNS.
Error: Rollback Fails to Delete Campaigns
- Cause: Campaigns are marked as
activeand have active contact lists attached, or the OAuth client lacks deletion permissions. - Fix: CXone requires campaigns to be
inactivebefore deletion in some environments. Update the rollback function to first setstatus: 'inactive'viaPUT, then callDELETE. Addoutbound:campaign:deleteto the OAuth scopes if your tenant enforces granular permissions.
