Orchestrating Automated Disaster Recovery Drills with Synthetic Transaction Pipelines
You will build a scheduled, API-driven synthetic transaction pipeline that validates telephony failover, IVR routing, and CRM integration handshakes during planned DR events. The end result is a self-contained orchestration job that injects controlled call volumes, measures latency and drop rates across primary and secondary regions, and generates structured audit logs for compliance reporting.
- Licensing Tiers: Genesys Cloud CX 3 or CX 4 (required for Architect Advanced, API rate limit headroom, and multi-region execution tracking). NICE CXone Advanced or Premium (required for Studio Advanced, Integration Framework, and global load balancer API access).
- Platform Permissions:
Telephony > Trunk > Edit,Architect > Flow > Edit,API > OAuth Client > Manage,Integration > Custom Application > Create,Administration > User > Edit - OAuth Scopes:
telephony:trunk:read,architect:flow:execute,integration:customapplication:read,analytics:callcenter:read,telephony:phone:region:read - External Dependencies: SIP trunk provider with explicit DR routing capability, CRM with REST webhook endpoints, middleware orchestrator (Azure Logic Apps, AWS Step Functions, or n8n), dedicated synthetic service account with programmatic authentication enabled.
1. Design the Synthetic Transaction Payload and Orchestration Trigger
Synthetic testing requires deterministic control over call injection, routing path selection, and termination points. You cannot rely on organic traffic patterns during a DR drill because variable caller IDs, DIDs, and queue depths introduce noise into your validation metrics. The pipeline must generate calls that follow a predictable path through your architecture so you can isolate failure domains.
We use the Architect flow execution endpoint to trigger synthetic transactions rather than raw SIP INVITE injection. Direct SIP injection bypasses platform routing tables, skips license consumption tracking, and often triggers fraud detection heuristics. The flow execution API routes the transaction through the exact same logic path as production traffic, including skills-based routing, language matching, and CRM lookup blocks.
Configure a dedicated OAuth client credentials flow for the synthetic orchestrator. Generate a separate service account with the architect:flow:execute and telephony:trunk:read scopes. Bind the service account to a custom application to isolate its token lifecycle from production integrations.
The orchestration job sends a POST request to the flow execution endpoint. The payload must include a synthetic caller identifier, a target DID, and execution parameters that force the flow into the test branch. We use a custom parameter to tag the transaction as synthetic. This prevents the transaction from writing to production analytics or triggering WFM capacity adjustments.
POST /api/v2/architect/flows/{flowId}/executions
Authorization: Bearer <synthetic_oauth_token>
"parameters": {
"CallerId": "+15550199000",
"TargetDID": "+15550199100",
"SyntheticTag": "DR_TEST_CYCLE_04",
"TestPayload": {
"ExpectedRegion": "us-east-1",
"ValidationTimeout": 45,
"CRMWebhookUrl": "https://dr-validation.internal/webhook/synthetic"
"executionType": "synchronous"
We set executionType to synchronous for initial routing validation. This returns the immediate routing decision, including the selected region, queue, and media server assignment. For end-to-end latency measurement, we switch to asynchronous execution and poll the execution status endpoint until completion.
The Trap: Triggering synthetic flows without isolating them from production routing tables causes false metrics and accidental customer contact. If your synthetic DID shares a routing profile with live traffic, the platform will apply production business hours, holiday schedules, and skill requirements. During a DR drill, business hours may be disabled or overridden, causing your synthetic calls to route to closed queues or trigger fallback logic that masks the actual failover path.
Architectural Reasoning: We isolate synthetic transactions by creating a dedicated routing profile and a separate IVR flow branch. The synthetic branch uses a parameter guard that checks for the SyntheticTag. If the tag exists, the flow bypasses production CRM lookups, skips queue placement, and routes directly to a test agent group or a recording block. This isolation ensures that DR drills never consume production license capacity, never impact WFM adherence scores, and never pollute speech analytics transcription queues. As detailed in the WFM Capacity Modeling guide, synthetic traffic must be excluded from shrinkage calculations to prevent forecast distortion.
2. Configure Region-Aware Failover Validation and Latency Thresholds
Disaster recovery validation is not a binary pass or fail event. It is a measured degradation curve. When a primary region fails, DNS propagation, SIP trunk registration, and platform routing table updates operate on different timers. Your synthetic pipeline must validate each layer independently before declaring the DR event successful.
The first validation layer checks DNS resolution and SIP trunk registration state. We query the telephony region endpoint to verify active routing tables. The response indicates which region handles media processing and which region handles signaling. During a planned DR drill, you must force a region switch or simulate a region outage using the platform administration API.
GET /api/v2/telephony/phone/regions
The response returns an array of region objects with status, routingState, and mediaServerStatus. We parse the routingState field to confirm whether the synthetic transaction targets the primary or secondary region. If the routingState returns DEGRADED or STANDBY, the pipeline records a latency penalty and continues to the next validation step.
The second validation layer measures IVR traversal time and CRM handshake latency. We inject a synthetic call that triggers a CRM lookup block. The CRM webhook returns a JSON response with customer attributes. We measure the time delta between the POST request and the 200 OK response. During DR failover, cross-region latency often increases by 80 to 150 milliseconds. Your pipeline must enforce a dynamic threshold that accounts for geographic distance between regions.
"validationMetrics": {
"dnsResolutionMs": 45,
"sipRegistrationMs": 120,
"ivrTraversalMs": 340,
"crmHandshakeMs": 210,
"totalEndToEndMs": 715,
"thresholdMs": 1000,
"status": "PASS"
We store these metrics in a structured audit log. The log includes the timestamp, synthetic tag, region state, and metric breakdown. Compliance frameworks require immutable audit trails for DR testing. We write the log to a write-once storage bucket with cryptographic hashing.
The Trap: Assuming DNS/SIP trunk failover matches platform region failover creates false confidence. Your SIP provider may route traffic to a secondary data center within 30 seconds, but the Genesys Cloud or CXone routing table may require 120 seconds to propagate the new media server assignment. During this window, calls connect to signaling servers but fail to establish RTP streams. The platform returns a 408 Request Timeout or 503 Service Unavailable, which appears as a telephony failure when the root cause is routing table propagation delay.
Architectural Reasoning: We implement a staggered validation window. The pipeline validates DNS resolution first, then SIP trunk registration, then platform routing table propagation. Each step has an independent timeout. If DNS resolves but SIP registration fails, the pipeline logs a trunk provider failure. If SIP registers but routing tables remain stale, the pipeline logs a platform propagation delay. This separation prevents you from attributing a carrier issue to a platform bug or vice versa. We also configure the synthetic flow to retry failed CRM handshakes with exponential backoff. This absorbs transient network congestion during region switchover without marking the entire drill as failed.
3. Implement Scheduled Execution, Rate Limit Management, and Compliance Logging
DR drills run on a fixed cadence. Monthly or quarterly execution requires a scheduler that handles token rotation, payload generation, and result aggregation. We use a middleware orchestrator to manage the cron schedule, OAuth token lifecycle, and API request batching.
The orchestrator generates a new OAuth token before each drill cycle. Token expiration causes mid-drill failures that corrupt metric collection. We implement a pre-flight token validation check that verifies the expires_in value. If the token expires within 300 seconds, the orchestrator refreshes it before sending the first synthetic transaction.
Rate limit management is critical. The platform enforces per-client and per-tenant API limits. During a DR drill, you may inject 50 to 200 synthetic transactions across multiple regions. Uncontrolled request bursts trigger 429 Too Many Requests responses, which halt the drill and require manual intervention.
We implement request batching and exponential backoff. The orchestrator groups synthetic transactions into batches of ten. After each batch, the orchestrator reads the Retry-After header from the platform response. If the header exists, the orchestrator pauses execution for the specified duration. If the header is absent, the orchestrator applies a base delay of 200 milliseconds between batches. This approach keeps request volume within safe thresholds while maintaining drill cadence.
GET /api/v2/architect/flows/{flowId}/executions/{executionId}
Accept: application/json
"id": "exec-syn-9f8a7b6c",
"flowId": "flow-dr-validation-01",
"status": "completed",
"startTime": "2024-05-15T14:00:00Z",
"endTime": "2024-05-15T14:00:07Z",
"result": {
"region": "us-west-2",
"routingState": "ACTIVE",
"metrics": {
"latencyMs": 380,
"dropRate": 0.0,
"crmResponseCode": 200
The orchestrator aggregates execution results into a single compliance report. The report includes drill start time, drill end time, total transactions injected, pass/fail counts, and metric averages. We store the report in a versioned archive with digital signatures. Compliance auditors require proof that DR testing occurred on schedule and that results were not modified post-execution.
The Trap: Running synthetic drills during peak business hours without capacity reservation causes license exhaustion and agent alert storms. If your synthetic transactions bypass isolation guards, they may route to production queues. Agents receive phantom calls, WFM adherence drops, and customer satisfaction scores degrade. The platform counts synthetic transactions toward your concurrent session limit. If you exceed your license tier during a drill, the platform blocks new inbound traffic until sessions drop below the threshold.
Architectural Reasoning: We schedule DR drills during off-peak maintenance windows and reserve a fixed percentage of concurrent sessions for synthetic testing. The platform administration console allows you to set session caps per region. We configure a hard cap that leaves 15 percent of total licenses available for emergency production traffic. We also implement a circuit breaker pattern in the orchestrator. If the platform returns a 429 or 503 response for three consecutive batches, the orchestrator halts the drill and alerts the operations team. This prevents cascade failures that could impact live customer traffic. The circuit breaker resets only after manual acknowledgment, ensuring that engineers review the failure state before resuming testing.
Edge Case 1: Synthetic Call Stuck in Queue During Region Failover
The Failure Condition: The synthetic transaction reaches the queue placement block but never transitions to agent assignment. The execution status remains IN_PROGRESS until the timeout threshold expires. The audit log records a false fail condition.
The Root Cause: Queue routing rules reference skills or language attributes that do not exist in the secondary region. During DR failover, the platform replicates routing tables but does not automatically replicate skill definitions or user assignments. If the synthetic flow applies a skill requirement that matches no active agents in the failover region, the call queues indefinitely.
The Solution: Configure the synthetic flow to use a dedicated test skill that is explicitly assigned to the DR validation service account. The service account must be set to Available status in both primary and secondary regions. Add a queue timeout block that forces call termination after 10 seconds if no agent answers. This ensures the synthetic transaction completes within the drill window and returns a deterministic result. Update the queue routing profile to prioritize the test skill over production skills during DR validation windows.
Edge Case 2: CRM Webhook Timeout Masking Telephony Success
The Failure Condition: The synthetic call connects successfully, IVR traversal completes, and the platform returns a 200 OK response. However, the CRM webhook times out after 5 seconds. The orchestrator marks the entire drill as failed because the end-to-end payload validation did not complete.
The Root Cause: Cross-region latency increases during failover. The CRM endpoint resides in a different geographic zone than the secondary media server. The HTTP request traverses multiple network hops, and the CRM load balancer applies a strict timeout policy. The platform telephony stack completes successfully, but the integration layer fails due to network constraints.
The Solution: Decouple telephony validation from integration validation. The synthetic flow should record the CRM webhook response code independently of the call status. If the webhook times out, the flow logs a CRM_TIMEOUT event but continues to mark the telephony transaction as PASS. The orchestrator aggregates these events separately. You can then analyze telephony performance and integration performance as independent metrics. Add a retry block to the CRM webhook with a maximum of two attempts and a 200 millisecond delay between retries. This absorbs transient network congestion without blocking the synthetic pipeline.
