Optimizing NICE CXone Voice Recording Storage Tiers via Recording API with Python SDK
- You will build a Python service that migrates CXone voice recordings to optimized storage tiers based on retention policies, compression directives, and quota constraints.
- You will use the NICE CXone Recording API, Storage Bucket API, and Retention Policy API through the Python SDK and
httpx. - You will implement legal hold verification, audio quality validation, atomic PATCH operations, callback synchronization, and audit logging in a single production-ready script.
- OAuth 2.0 Client Credentials grant with scopes:
recording:read,recording:update,storage:read,storage:update,archive:read - CXone Python SDK version
>= 1.0.0(or direct API access viahttpx) - Python 3.9+ runtime
- External dependencies:
pip install httpx cxone-python pydantic python-dotenv
CXone uses OAuth 2.0 Client Credentials for server-to-server integrations. You must exchange your client ID and secret for an access token before invoking the Recording API. The token expires after 3600 seconds and requires caching or refresh logic.
import httpx
from typing import Optional
class CXoneAuthManager:
def __init__(self, client_id: str, client_secret: str, region: str = "api-us-1"):
self.client_id = client_id
self.auth_url = f"https://{region}.cxone.com/oauth/token"
def get_token(self) -> str:
if self.token and time.time() < self.token_expiry - 60:
return self.token
with httpx.Client() as client:
response = client.post(
self.auth_url,
data={"grant_type": "client_credentials", "scope": "recording:read recording:update storage:read storage:update archive:read"},
auth=(self.client_id, self.client_secret),
headers={"Content-Type": "application/x-www-form-urlencoded"}
response.raise_for_status()
payload = response.json()
self.token = payload["access_token"]
self.token_expiry = time.time() + payload["expires_in"]
return self.token
Step 1: Fetch Recordings and Build Retention Policy Matrix
You must retrieve recordings in paginated batches and map each recording to a target retention policy. The CXone Recording API returns a maximum of 100 records per request. You will construct a retention policy matrix that dictates which storage tier and compression format each recording should target.
import httpx
class RecordingFetcher:
def __init__(self, base_url: str, auth_manager: CXoneAuthManager):
self.base_url = base_url
self.auth = auth_manager
self.recording_url = f"{base_url}/api/v1/recording/recording"
def fetch_all_recordings(self, max_pages: int = 50) -> List[Dict[str, Any]]:
recordings: List[Dict[str, Any]] = []
page = 1
cursor: Optional[str] = None
while page <= max_pages:
headers = {"Authorization": f"Bearer {self.auth.get_token()}"}
params = {"pageSize": 100, "page": page}
if cursor:
params["cursor"] = cursor
response = client.get(self.recording_url, headers=headers, params=params)
data = response.json()
recordings.extend(data.get("entities", []))
page += 1
cursor = data.get("nextPageCursor")
if not cursor:
break
return recordings
def build_retention_matrix(self, recordings: List[Dict[str, Any]]) -> Dict[str, Dict[str, Any]]:
matrix: Dict[str, Dict[str, Any]] = {}
for rec in recordings:
rec_id = rec.get("id")
if not rec_id:
current_format = rec.get("format", "wav")
days_old = max(1, int((time.time() - rec.get("recordingDate", time.time())) / 86400))
if days_old <= 30:
target_format = "wav"
target_bucket = "hot-storage"
elif days_old <= 365:
target_format = "mp3"
target_bucket = "warm-storage"
else:
target_format = "aac"
target_bucket = "cold-archive"
matrix[rec_id] = {
"current_format": current_format,
"target_format": target_format,
"target_bucket": target_bucket,
"days_old": days_old
return matrix
Step 2: Validate Optimize Payloads Against Storage Engine Constraints
Before issuing PATCH operations, you must validate that the target storage bucket has sufficient quota and that the compression directive does not violate audio quality thresholds. CXone storage buckets expose quota limits via the Storage API. You will calculate expected size reduction based on format bitrate ratios and reject optimizations that exceed bucket capacity or degrade quality below acceptable limits.
import httpx
from typing import Dict, Any, Tuple
class StorageValidator:
self.bucket_url = f"{base_url}/api/v1/storage/bucket"
def check_bucket_quota(self, bucket_name: str) -> Tuple[bool, int]:
response = client.get(f"{self.bucket_url}/{bucket_name}", headers=headers)
if response.status_code == 404:
return False, 0
used = data.get("usedSpace", 0)
limit = data.get("quotaLimit", 0)
available = max(0, limit - used)
return available > 0, available
def validate_quality_degradation(self, current_format: str, target_format: str) -> bool:
quality_scores = {"wav": 1.0, "mp3": 0.75, "aac": 0.65}
current_score = quality_scores.get(current_format, 0.5)
target_score = quality_scores.get(target_format, 0.5)
if current_score >= 0.9 and target_score < 0.7:
return False
return True
def validate_optimize_batch(self, matrix: Dict[str, Dict[str, Any]], batch_size: int = 50) -> Dict[str, Dict[str, Any]]:
validated: Dict[str, Dict[str, Any]] = {}
for rec_id, meta in matrix.items():
bucket_ok, available_space = self.check_bucket_quota(meta["target_bucket"])
quality_ok = self.validate_quality_degradation(meta["current_format"], meta["target_format"])
if bucket_ok and quality_ok:
validated[rec_id] = meta
else:
print(f"Skipping {rec_id}: bucket quota exceeded or quality threshold violated")
return validated
Step 3: Execute Atomic PATCH Operations with Legal Hold Verification
CXone recordings support a legalHold boolean field. You must skip any recording flagged for legal hold to prevent compliance violations. You will issue atomic PATCH requests to /api/v1/recording/recording/{recordingId} with format verification and metadata indexing triggers. The payload includes format, storageBucketId, and tags to force automatic reindexing.
import httpx
class RecordingOptimizer:
def optimize_recordings(self, validated_matrix: Dict[str, Dict[str, Any]], legal_hold_flag: str = "legalHold") -> List[Dict[str, Any]]:
results: List[Dict[str, Any]] = []
headers = {"Authorization": f"Bearer {self.auth.get_token()}", "Content-Type": "application/json"}
for rec_id, meta in validated_matrix.items():
self._retry_operation(
self._patch_recording,
headers=headers,
rec_id=rec_id,
meta=meta,
max_retries=3
results.append({"recordingId": rec_id, "status": "optimized", "target_format": meta["target_format"]})
results.append({"recordingId": rec_id, "status": "failed", "error": str(e)})
return results
def _patch_recording(self, headers: Dict[str, str], rec_id: str, meta: Dict[str, Any]) -> httpx.Response:
payload = {
"format": meta["target_format"],
"storageBucketId": meta["target_bucket"],
"tags": [f"tier-optimized-{int(time.time())}"],
"indexed": True
response = client.patch(
f"{self.recording_url}/{rec_id}",
headers=headers,
json=payload
if response.status_code == 423:
raise RuntimeError(f"Recording {rec_id} is under legal hold or locked for processing")
return response
def _retry_operation(self, func, *args, max_retries: int = 3, **kwargs):
last_exception = None
return func(*args, **kwargs)
last_exception = e
if e.response.status_code == 429:
retry_after = int(e.response.headers.get("Retry-After", 2 ** attempt))
time.sleep(retry_after)
raise
raise last_exception
Step 4: Synchronize with External Storage Gateways and Track Metrics
You must align CXone tier migrations with external cloud storage gateways via callback handlers. You will track optimization latency, calculate storage cost savings based on format size ratios, and generate audit logs for data governance. The callback handler posts optimization events to an external endpoint with idempotency keys.
import httpx
import json
class OptimizationTracker:
def __init__(self, callback_url: str, auth_manager: CXoneAuthManager):
self.callback_url = callback_url
self.start_time = time.time()
self.format_size_ratios = {"wav": 1.0, "mp3": 0.35, "aac": 0.25}
def generate_audit_and_sync(self, results: List[Dict[str, Any]], original_sizes_mb: Dict[str, float]) -> Dict[str, Any]:
latency = time.time() - self.start_time
total_savings_mb = 0.0
audit_log = []
for rec in results:
rec_id = rec["recordingId"]
original_size = original_sizes_mb.get(rec_id, 0.0)
target_format = rec.get("target_format", "wav")
ratio = self.format_size_ratios.get(target_format, 1.0)
estimated_new_size = original_size * ratio
savings = max(0, original_size - estimated_new_size)
total_savings_mb += savings
audit_log.append({
"timestamp": int(time.time()),
"status": rec["status"],
"originalSizeMB": original_size,
"estimatedNewSizeMB": estimated_new_size,
"savingsMB": savings
summary = {
"totalRecordings": len(results),
"optimizedCount": sum(1 for r in results if r["status"] == "optimized"),
"failedCount": sum(1 for r in results if r["status"] == "failed"),
"latencySeconds": round(latency, 2),
"totalStorageSavingsMB": round(total_savings_mb, 2),
"auditLog": audit_log
self._post_callback(summary)
return summary
def _post_callback(self, payload: Dict[str, Any]):
response = client.post(self.callback_url, headers=headers, json=payload)
print(f"Callback synchronization failed: {e}")
The following script initializes authentication, fetches recordings, builds the retention matrix, validates storage constraints, executes atomic PATCH operations with legal hold verification, and synchronizes results with an external gateway. Replace placeholders with your CXone tenant credentials and callback endpoint.
import os
import sys
import httpx
# Import classes from previous sections
# (In production, place these in separate modules)
def main():
client_id = os.getenv("CXONE_CLIENT_ID")
client_secret = os.getenv("CXONE_CLIENT_SECRET")
region = os.getenv("CXONE_REGION", "api-us-1")
callback_url = os.getenv("STORAGE_CALLBACK_URL", "https://internal.gateway.example.com/recordings/sync")
base_url = f"https://{region}.cxone.com"
auth = CXoneAuthManager(client_id, client_secret, region)
fetcher = RecordingFetcher(base_url, auth)
validator = StorageValidator(base_url, auth)
optimizer = RecordingOptimizer(base_url, auth)
tracker = OptimizationTracker(callback_url, auth)
print("Fetching recordings...")
recordings = fetcher.fetch_all_recordings(max_pages=5)
print(f"Retrieved {len(recordings)} recordings")
print("Building retention matrix...")
matrix = fetcher.build_retention_matrix(recordings)
print("Validating against storage constraints...")
validated = validator.validate_optimize_batch(matrix)
print("Executing atomic PATCH operations...")
results = optimizer.optimize_recordings(validated)
print("Generating audit logs and synchronizing...")
mock_original_sizes = {rec["id"]: 15.0 for rec in recordings}
summary = tracker.generate_audit_and_sync(results, mock_original_sizes)
print("Optimization complete.")
print(f"Optimized: {summary['optimizedCount']}")
print(f"Failed: {summary['failedCount']}")
print(f"Latency: {summary['latencySeconds']}s")
print(f"Estimated Savings: {summary['totalStorageSavingsMB']} MB")
main()
- What causes it: The OAuth token expired or the client credentials are invalid.
- How to fix it: Verify
CXONE_CLIENT_IDandCXONE_CLIENT_SECRET. Ensure the token cache checks expiry before reuse. TheCXoneAuthManagerclass handles refresh automatically. - Code showing the fix: The
get_token()method checkstime.time() < self.token_expiry - 60and re-authenticates when necessary.
Error: 403 Forbidden
- What causes it: The OAuth token lacks required scopes or the tenant restricts storage tier modifications.
- How to fix it: Request
recording:read,recording:update,storage:read, andstorage:updatescopes during token exchange. Verify tenant permissions in the CXone admin console. - Code showing the fix: Update the
scopeparameter inCXoneAuthManager.__init__to include all required scopes.
- What causes it: Rate limiting triggers when PATCH operations exceed CXone throughput limits.
- How to fix it: Implement exponential backoff with
Retry-Afterheader parsing. The_retry_operationmethod handles 429 responses automatically. - Code showing the fix: See
RecordingOptimizer._retry_operationwhich sleeps forRetry-Afterseconds and retries up to three times.
Error: 400 Bad Request
- What causes it: Invalid format directive or malformed PATCH payload.
- How to fix it: Ensure
formatvalues match CXone supported encodings (wav,mp3,aac). Validate JSON structure before transmission. - Code showing the fix: The
validate_quality_degradationmethod restricts format transitions to acceptable quality thresholds.
Error: 423 Locked
- What causes it: The recording is under legal hold or currently being processed by the CXone engine.
- How to fix it: Skip locked recordings and log them for manual review. The optimizer checks for 423 status codes and raises a descriptive error.
_patch_recordingmethod explicitly catches 423 and raisesRuntimeErrorwith legal hold context.
