Optimizing NICE CXone Outbound Predictive Dialer Rates with TypeScript
  • A TypeScript service that continuously monitors outbound campaign performance and adjusts the predictive dial ratio every 30 seconds to maximize agent utilization while keeping abandon rates below threshold.
  • The service uses the NICE CXone Campaign API to fetch real-time metrics, applies a heuristic algorithm to balance answer rates against agent availability, and updates campaign parameters via REST with built-in rate limit handling.
  • The implementation covers OAuth 2.0 token management, production-ready TypeScript code, and dynamic adjustment logic.
  • OAuth 2.0 Client Credentials grant with scopes: campaign:read, campaign:write, campaign:metrics:read
  • NICE CXone API version: v2
  • Node.js 18+ with TypeScript 5+
  • Dependencies: axios, dotenv, typescript, @types/node
  • Access to a live or sandbox CXone tenant with an active predictive outbound campaign
NICE CXone uses OAuth 2.0 for all API authentication. Server-to-server integrations require the Client Credentials grant. The token must be cached and refreshed before expiration to prevent unnecessary authentication round trips. The following class handles token acquisition, in-memory caching, and early refresh logic to avoid race conditions during active polling cycles.
import axios, { AxiosInstance, AxiosError } from 'axios';
export class CxoneAuth {
  private readonly client: AxiosInstance;
  private tokenCache: string | null = null;
  private tokenExpiry: number = 0;
  private readonly clientId: string;
  private readonly clientSecret: string;
  private readonly baseUrl: string;
  constructor(clientId: string, clientSecret: string, baseUrl: string) {
    this.clientId = clientId;
    this.baseUrl = baseUrl.replace(/\/$/, '');
    this.client = axios.create({ baseURL: this.baseUrl });
  async getAccessToken(): Promise<string> {
    if (this.tokenCache && Date.now() < this.tokenExpiry) {
      return this.tokenCache;
    const authResponse = await this.client.post('/oauth/token', new URLSearchParams({
      client_id: this.clientId,
      client_secret: this.clientSecret,
      scope: 'campaign:read campaign:write campaign:metrics:read'
    const data = authResponse.data;
    if (!data.access_token || !data.expires_in) {
      throw new Error('Invalid OAuth response structure');
    this.tokenCache = data.access_token;
    // Refresh 60 seconds before expiration to prevent mid-request token expiry
    this.tokenExpiry = Date.now() + (data.expires_in * 1000) - 60000;
The scope parameter explicitly requests campaign:metrics:read for polling performance data and campaign:write for modifying dial ratios. The early refresh offset prevents token invalidation during active optimization cycles.
Step 1: Fetch Real-Time Campaign Metrics
The predictive dialer requires current performance data to calculate adjustments. CXone exposes live campaign statistics through the real-time metrics endpoint. This endpoint returns a snapshot of answer rates, abandon rates, active agent counts, and the current dial ratio.
Required Scope: campaign:metrics:read
export interface CampaignMetrics {
  answerRate: number;
  abandonRate: number;
  activeAgents: number;
  dialRatio: number;
  callsDialed: number;
  callsAnswered: number;
export async function fetchRealtimeMetrics(
  auth: CxoneAuth,
  campaignId: string
): Promise<CampaignMetrics> {
  const token = await auth.getAccessToken();
  const response = await axios.get(`/api/v2/campaigns/${campaignId}/realtime-metrics`, {
    headers: { Authorization: `Bearer ${token}` },
    timeout: 10000,
    validateStatus: (status) => status < 500
  const data = response.data;
    answerRate: data.answerRate ?? 0,
    abandonRate: data.abandonRate ?? 0,
    activeAgents: data.activeAgents ?? 0,
    dialRatio: data.dialRatio ?? 1.5,
    callsDialed: data.callsDialed ?? 0,
    callsAnswered: data.callsAnswered ?? 0
HTTP Request Cycle:
GET /api/v2/campaigns/12345678-1234-1234-1234-123456789012/realtime-metrics HTTP/1.1
Host: api-us-01.nice.incontact.com
Authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9...
Accept: application/json
Expected Response:
  "answerRate": 0.78,
  "abandonRate": 0.02,
  "activeAgents": 14,
  "dialRatio": 2.5,
  "callsDialed": 1542,
  "callsAnswered": 1202
The endpoint returns a flat JSON object. If the campaign is paused or inactive, the metrics will reflect zero activity. The code handles missing fields using nullish coalescing to prevent runtime errors during transient API states.
Step 2: Calculate Optimal Dial Ratio with Heuristic Logic
Predictive dialing relies on balancing outbound call volume against available agent capacity. The heuristic algorithm evaluates three factors: current answer rate deviation from target, abandon rate threshold breaches, and active agent scaling. The algorithm adjusts the dial ratio within a safe operational window to prevent system overload or agent idle time.
export interface OptimizationResult {
  currentRatio: number;
  targetRatio: number;
  adjustmentReason: string;
export function calculateOptimalDialRatio(
  metrics: CampaignMetrics,
  minRatio: number = 1.5,
  maxRatio: number = 5.0
): OptimizationResult {
  const TARGET_ANSWER_RATE = 0.85;
  const MAX_ABANDON_RATE = 0.03;
  const AGENT_SCALING_FACTOR = 0.04;
  const ADJUSTMENT_STEP = 0.2;
  let newRatio = metrics.dialRatio;
  let reason = 'No adjustment required';
  // Priority 1: Enforce abandon rate compliance
  if (metrics.abandonRate > MAX_ABANDON_RATE) {
    const reduction = Math.min(0.5, MAX_ABANDON_RATE - metrics.abandonRate + 0.05);
    newRatio -= reduction;
    reason = 'Abandon rate exceeded threshold';
  // Priority 2: Align answer rate with target
  const answerDeviation = TARGET_ANSWER_RATE - metrics.answerRate;
  if (answerDeviation > 0.05) {
    newRatio += ADJUSTMENT_STEP;
    reason = 'Answer rate below target';
  } else if (answerDeviation < -0.05) {
    newRatio -= ADJUSTMENT_STEP;
    reason = 'Answer rate above target';
  // Priority 3: Scale with available agent capacity
  const agentAdjustment = metrics.activeAgents * AGENT_SCALING_FACTOR;
  newRatio += agentAdjustment;
  reason = metrics.activeAgents > 10 ? 'Agent capacity increased' : reason;
  // Clamp to safe operational bounds
  const clampedRatio = Math.min(Math.max(newRatio, minRatio), maxRatio);
    currentRatio: metrics.dialRatio,
    targetRatio: Math.round(clampedRatio * 10) / 10,
    adjustmentReason: reason
The algorithm prioritizes abandon rate compliance because regulatory compliance and customer experience take precedence over efficiency. It then evaluates answer rate deviation to maintain a steady flow of connected calls. Finally, it scales the ratio based on active agent count. The clamping operation prevents the dialer from exceeding hardware or carrier limits. The output is rounded to one decimal place to match CXone API precision requirements.
Step 3: Update Campaign Parameters with Rate Limiting
CXone enforces API rate limits to protect tenant stability. The platform returns HTTP 429 responses with a Retry-After header when limits are exceeded. The update function implements exponential backoff with header-based retry timing to ensure reliable parameter updates without triggering cascading failures.
Required Scope: campaign:write
export async function updateCampaignDialRatio(
  auth: CxoneAuth,
  campaignId: string,
  newRatio: number
): Promise<void> {
  const url = `/api/v2/campaigns/${campaignId}`;
  const payload = {
    dialRatio: newRatio
  let retries = 0;
  const maxRetries = 3;
  while (retries < maxRetries) {
      const response = await axios.put(url, payload, {
        headers: {
          Authorization: `Bearer ${token}`,
          'Content-Type': 'application/json'
        timeout: 15000,
      if (response.status === 200 || response.status === 204) {
        return;
      throw new Error(`Unexpected status: ${response.status}`);
    } catch (error) {
      if (axios.isAxiosError(error) && error.response?.status === 429) {
        const retryAfter = parseInt(error.response.headers['retry-after'] || '5', 10);
        console.log(`Rate limited on campaign update. Retrying in ${retryAfter}s (attempt ${retries + 1}/${maxRetries})`);
        await new Promise(resolve => setTimeout(resolve, retryAfter * 1000));
        retries++;
      } else if (axios.isAxiosError(error) && error.response?.status === 400) {
        throw new Error(`Invalid payload or dial ratio out of range: ${error.response.data}`);
      } else {
        throw error;
  throw new Error(`Failed to update campaign after ${maxRetries} rate limit retries`);
HTTP Request Cycle:
PUT /api/v2/campaigns/12345678-1234-1234-1234-123456789012 HTTP/1.1
  "dialRatio": 2.8
Expected Response:
HTTP/1.1 200 OK
The PUT request modifies only the dialRatio field. In production environments, you should fetch the full campaign configuration, mutate the ratio, and submit the complete object to prevent accidental overwrites of unrelated settings. The retry loop respects the Retry-After header value, which CXone calculates based on current tenant load.
Step 4: Dynamic Adjustment Loop
The optimization service runs continuously, polling metrics every 30 seconds and applying adjustments when the heuristic algorithm determines a change is necessary. The loop includes drift detection to avoid unnecessary API calls when the calculated ratio matches the current configuration within a tolerance threshold.
export async function runOptimizationLoop(
  auth: CxoneAuth,
  campaignId: string,
  intervalMs: number = 30000,
  tolerance: number = 0.1
): Promise<void> {
  console.log(`Starting predictive dialer optimizer for campaign ${campaignId}`);
  while (true) {
      const metrics = await fetchRealtimeMetrics(auth, campaignId);
      const optimization = calculateOptimalDialRatio(metrics);
      console.log(`[METRICS] Answer: ${metrics.answerRate.toFixed(2)} | Abandon: ${metrics.abandonRate.toFixed(2)} | Agents: ${metrics.activeAgents} | Ratio: ${metrics.dialRatio}`);
      const drift = Math.abs(optimization.targetRatio - optimization.currentRatio);
      if (drift > tolerance) {
        console.log(`[ADJUST] Applying new ratio: ${optimization.targetRatio} | Reason: ${optimization.adjustmentReason}`);
        await updateCampaignDialRatio(auth, campaignId, optimization.targetRatio);
      } else {
        console.log(`[STABLE] Ratio drift ${drift.toFixed(2)} within tolerance. No update sent.`);
    } catch (error) {
      console.error(`[ERROR] Optimization cycle failed:`, error instanceof Error ? error.message : error);
    await new Promise(resolve => setTimeout(resolve, intervalMs));
The tolerance check prevents API thrashing caused by minor metric fluctuations. The 30-second interval aligns with CXone metric refresh rates while providing responsive adjustment capability. The loop catches all exceptions to prevent process crashes during network partitions or temporary tenant outages.
The following TypeScript module combines all components into a single executable service. Replace the environment variables with your tenant credentials and run the script using ts-node or compile it with tsc and execute the output.
import * as dotenv from 'dotenv';
dotenv.config();
import { CxoneAuth } from './auth';
import { fetchRealtimeMetrics, CampaignMetrics } from './metrics';
import { calculateOptimalDialRatio, OptimizationResult } from './heuristic';
import { updateCampaignDialRatio } from './campaign';
async function main() {
  const clientId = process.env.CXONE_CLIENT_ID;
  const clientSecret = process.env.CXONE_CLIENT_SECRET;
  const baseUrl = process.env.CXONE_BASE_URL || 'https://api-us-01.nice.incontact.com';
  const campaignId = process.env.CXONE_CAMPAIGN_ID;
  const intervalMs = parseInt(process.env.OPTIMIZATION_INTERVAL || '30000', 10);
  if (!clientId || !clientSecret || !campaignId) {
    throw new Error('Missing required environment variables: CXONE_CLIENT_ID, CXONE_CLIENT_SECRET, CXONE_CAMPAIGN_ID');
  const auth = new CxoneAuth(clientId, clientSecret, baseUrl);
  // Initial token validation
    console.log('Authentication successful');
  } catch (error) {
    console.error('Authentication failed:', error);
    process.exit(1);
  const runLoop = async () => {
    while (true) {
        if (drift > 0.1) {
        } else {
      } catch (error) {
  // Graceful shutdown handling
  process.on('SIGINT', () => {
    console.log('\n[SHUTDOWN] Received SIGINT. Stopping optimizer...');
    process.exit(0);
  process.on('SIGTERM', () => {
    console.log('\n[SHUTDOWN] Received SIGTERM. Stopping optimizer...');
    process.exit(0);
  await runLoop();
main().catch((error) => {
  console.error('Fatal error:', error);
  process.exit(1);
The script validates environment variables before initialization, handles graceful process termination, and logs all optimization decisions for audit purposes. Deploy this module in a containerized environment or as a systemd service for continuous operation.
Error: HTTP 401 Unauthorized
  • Cause: OAuth token expired, invalid client credentials, or missing campaign:metrics:read scope.
  • Fix: Verify CXONE_CLIENT_ID and CXONE_CLIENT_SECRET in your environment. Ensure the OAuth client in CXone has the required scopes assigned. The token cache refreshes automatically, but initial failures indicate credential misconfiguration.
  • Debug Code: Add console.log('Token expires at:', new Date(auth.tokenExpiry).toISOString()) after authentication to verify cache timing.
Error: HTTP 403 Forbidden
  • Cause: The OAuth client lacks campaign:write permissions, or the campaign is owned by a different tenant context.
  • Fix: Navigate to the CXone Admin console, locate the OAuth client configuration, and add campaign:write to the allowed scopes. Verify the campaign ID belongs to the authenticated tenant.
  • Debug Code: Test the PUT endpoint manually with Postman using the same token to isolate scope versus payload issues.
  • Cause: Exceeded CXone API rate limits due to aggressive polling or concurrent tenant activity.
  • Fix: The implementation already handles 429 responses using the Retry-After header. If failures persist, increase the polling interval to 45 seconds or implement request batching across multiple campaigns.
  • Debug Code: Monitor Retry-After header values in logs. Values exceeding 30 seconds indicate sustained tenant-level throttling.
Error: HTTP 400 Bad Request
  • Cause: Invalid dialRatio value outside the 1.5 to 10.0 range, or missing required campaign fields during PUT.
  • Fix: Verify the heuristic algorithm clamps values correctly. In production, fetch the full campaign object, mutate dialRatio, and submit the complete payload to satisfy schema validation.
  • Debug Code: Log optimization.targetRatio before API calls to confirm clamping logic executes as expected.
