Optimizing NICE CXone Outbound Call Pacing with TypeScript
  • A serverless TypeScript function that dynamically adjusts outbound campaign dial rates based on real-time agent availability and answer rates.
  • Uses the NICE CXone Analytics, Outbound Campaign, and Agent REST APIs.
  • Implemented in modern TypeScript with native fetch, async/await, sliding window calculations, and Fibonacci backoff retry logic.
  • OAuth Client Credentials flow configured in NICE CXone with scopes: analytics:read, outbound:campaign:read, outbound:campaign:write, agent:read
  • Node.js 18+ (native fetch support)
  • TypeScript 5+
  • @types/node, dotenv
  • AWS Lambda, Vercel, or Cloudflare Workers runtime compatible with Node.js 18+
NICE CXone uses OAuth 2.0 Client Credentials flow. The token expires after one hour. The following client manages token caching and automatic refresh to prevent 401 errors during long-running serverless invocations.
import { createRequire } from "module";
const require = createRequire(import.meta.url);
const dotenv = require("dotenv");
dotenv.config();
interface OAuthToken {
  access_token: string;
  token_type: string;
  expires_in: number;
  scope: string;
interface TokenState {
  token: OAuthToken | null;
  expiresAt: number;
class CxoneAuthClient {
  private tokenState: TokenState = { token: null, expiresAt: 0 };
  private readonly site: string;
  private readonly clientId: string;
  private readonly clientSecret: string;
  constructor(site: string, clientId: string, clientSecret: string) {
    this.site = site.replace("https://", "").replace("http://", "");
    this.clientId = clientId;
  async getAccessToken(): Promise<string> {
    const now = Date.now();
    if (this.tokenState.token && now < this.tokenState.expiresAt - 60000) {
      return this.tokenState.token.access_token;
    const response = await fetch(`https://${this.site}/oauth/token`, {
      method: "POST",
      headers: { "Content-Type": "application/x-www-form-urlencoded" },
      body: new URLSearchParams({
        grant_type: "client_credentials",
        client_id: this.clientId,
        client_secret: this.clientSecret,
    if (!response.ok) {
      const errorText = await response.text();
      throw new Error(`OAuth token fetch failed (${response.status}): ${errorText}`);
    const data: OAuthToken = await response.json();
    this.tokenState = {
      token: data,
      expiresAt: now + data.expires_in * 1000,
    return data.access_token;
Step 1: Poll Campaign Metrics
The Analytics API returns real-time outbound campaign statistics. You must construct a query payload with select, where, and interval fields. The endpoint supports pagination via the page parameter.
OAuth Scope: analytics:read
HTTP Request Example:
POST /api/analytics/outbound/details/query HTTP/1.1
Host: {site}.cxone.com
Authorization: Bearer {access_token}
  "select": ["campaignId", "totalCallsDialed", "totalCallsAnswered", "answerRate"],
  "where": "campaignId = '{campaignId}'",
  "interval": "PT30S",
  "pageSize": 1,
  "page": 1
Expected Response:
  "response": [
      "campaignId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
      "totalCallsDialed": 145,
      "totalCallsAnswered": 112,
      "answerRate": 0.7724
  "pageSize": 1,
  "page": 1,
  "totalElements": 1
interface CampaignMetric {
  campaignId: string;
  totalCallsDialed: number;
  totalCallsAnswered: number;
  answerRate: number;
async function fetchCampaignMetrics(
  auth: CxoneAuthClient,
  campaignId: string
): Promise<CampaignMetric> {
  const token = await auth.getAccessToken();
  const site = auth.constructor.name === "CxoneAuthClient" ? "" : ""; // Extracted from env in full example
  // In production, pass site explicitly or extract from auth class
  const queryPayload = {
    select: ["campaignId", "totalCallsDialed", "totalCallsAnswered", "answerRate"],
    where: `campaignId = '${campaignId}'`,
    interval: "PT30S",
    pageSize: 1,
    page: 1
  const response = await fetch(`https://${process.env.CXONE_SITE}/api/analytics/outbound/details/query`, {
    method: "POST",
    headers: {
      "Authorization": `Bearer ${token}`,
      "Accept": "application/json"
    body: JSON.stringify(queryPayload)
  if (response.status === 429) {
    throw new Error("RATE_LIMIT_EXCEEDED");
  if (!response.ok) {
    const err = await response.text();
    throw new Error(`Analytics fetch failed (${response.status}): ${err}`);
  const data = await response.json();
  if (!data.response || data.response.length === 0) {
    throw new Error("No metrics returned for campaign");
  return data.response[0];
Step 2: Calculate Real-Time Agent Availability Using a Sliding Window
Agent availability fluctuates rapidly. A sliding window algorithm smooths out transient spikes by averaging availability over the last N polling intervals. This prevents dial rate whiplash.
OAuth Scope: agent:read
interface AvailabilityRecord {
  timestamp: number;
  availableAgents: number;
class AvailabilitySlidingWindow {
  private window: AvailabilityRecord[] = [];
  private readonly maxSize: number;
  constructor(maxSize: number = 6) {
    this.maxSize = maxSize; // 6 intervals * 30s = 3 minutes
  async update(site: string, auth: CxoneAuthClient): Promise<number> {
    const response = await fetch(`https://${site}/api/v2/agents?state=available`, {
      headers: { "Authorization": `Bearer ${token}` }
    if (response.status === 429) throw new Error("RATE_LIMIT_EXCEEDED");
    if (!response.ok) throw new Error(`Agent fetch failed: ${response.status}`);
    const agents = await response.json();
    const count = agents.length || 0;
    this.window.push({ timestamp: Date.now(), availableAgents: count });
    if (this.window.length > this.maxSize) {
      this.window.shift();
    const sum = this.window.reduce((acc, rec) => acc + rec.availableAgents, 0);
    return sum / this.window.length;
Step 3: Adjust Dial Rates Via the Campaign API with Delta Updates and Fibonacci Backoff
The Campaign API accepts partial updates via PATCH. You only send the dialRate field to minimize payload size and reduce merge conflicts. The retry wrapper implements a Fibonacci sequence for 429 responses.
OAuth Scope: outbound:campaign:write
PATCH /api/v2/outbound/campaigns/a1b2c3d4-e5f6-7890-abcd-ef1234567890 HTTP/1.1
If-Match: "*"
  "dialRate": 42
const FIBONACCI_SEQUENCE = [1, 1, 2, 3, 5, 8, 13, 21, 34, 55, 89];
async function retryWithFibonacci<T>(
  fn: () => Promise<T>,
  maxRetries: number = 5
): Promise<T> {
  let attempt = 0;
  while (true) {
      return await fn();
    } catch (error: any) {
      if (error.message !== "RATE_LIMIT_EXCEEDED" || attempt >= maxRetries) {
        throw error;
      const waitSeconds = FIBONACCI_SEQUENCE[attempt] || FIBONACCI_SEQUENCE[FIBONACCI_SEQUENCE.length - 1];
      console.log(`429 detected. Waiting ${waitSeconds}s before retry ${attempt + 1}/${maxRetries}`);
      await new Promise(res => setTimeout(res, waitSeconds * 1000));
      attempt++;
async function adjustDialRate(
  site: string,
  campaignId: string,
  newDialRate: number
): Promise<void> {
  await retryWithFibonacci(async () => {
    const response = await fetch(`https://${site}/api/v2/outbound/campaigns/${campaignId}`, {
      method: "PATCH",
      headers: {
        "If-Match": "*"
      body: JSON.stringify({ dialRate: newDialRate })
    if (!response.ok) {
      throw new Error(`Dial rate update failed (${response.status}): ${err}`);
Step 4: Track Answer Rate Deviations Against SLA Thresholds and Export to Data Warehouse
The pacing controller compares the current answerRate against a configured SLA threshold. Deviations beyond a tolerance margin trigger export records to an external data warehouse endpoint. This enables downstream BI tools to audit pacing decisions.
OAuth Scope: None required for external POST, but uses internal state.
interface PacingExportRecord {
  timestamp: string;
  campaignId: string;
  previousDialRate: number;
  newDialRate: number;
  currentAnswerRate: number;
  slaThreshold: number;
  deviation: number;
  agentAvailabilityAvg: number;
async function exportToDataWarehouse(
  dwEndpoint: string,
  record: PacingExportRecord
): Promise<void> {
  const response = await fetch(dwEndpoint, {
    method: "POST",
    headers: { "Content-Type": "application/json" },
    body: JSON.stringify(record)
  if (!response.ok) {
    console.error(`DW export failed (${response.status}): ${err}`);
The following module orchestrates the 30-second polling loop, integrates all components, and handles graceful shutdown.
dotenv.config();
// --- Reuse classes from previous steps ---
// (CxoneAuthClient, fetchCampaignMetrics, AvailabilitySlidingWindow,
//  retryWithFibonacci, adjustDialRate, exportToDataWarehouse, PacingExportRecord)
interface PacingConfig {
  campaignId: string;
  toleranceMargin: number;
  minDialRate: number;
  maxDialRate: number;
  dwEndpoint: string;
async function runPacingController(config: PacingConfig) {
  const auth = new CxoneAuthClient(
    process.env.CXONE_SITE!,
    process.env.CXONE_CLIENT_ID!,
    process.env.CXONE_CLIENT_SECRET!
  const window = new AvailabilitySlidingWindow(6);
  let currentDialRate = 0;
  const site = process.env.CXONE_SITE!;
  console.log("Starting outbound pacing controller...");
  while (true) {
      // 1. Poll metrics
      const metrics = await fetchCampaignMetrics(auth, config.campaignId);
      // 2. Calculate availability
      const avgAvailability = await window.update(site, auth);
      // 3. Calculate target dial rate based on availability and answer rate
      const targetRate = Math.floor(avgAvailability * 0.85); // 85% capacity utilization
      const clampedRate = Math.max(config.minDialRate, Math.min(config.maxDialRate, targetRate));
      // 4. Check SLA deviation
      const deviation = metrics.answerRate - config.slaThreshold;
      const shouldAdjust = Math.abs(deviation) > config.toleranceMargin || clampedRate !== currentDialRate;
      if (shouldAdjust) {
        const exportRecord: PacingExportRecord = {
          campaignId: config.campaignId,
          previousDialRate: currentDialRate,
          newDialRate: clampedRate,
          currentAnswerRate: metrics.answerRate,
          slaThreshold: config.slaThreshold,
          deviation: deviation,
          agentAvailabilityAvg: avgAvailability
        console.log(`Adjusting dial rate: ${currentDialRate} -> ${clampedRate} | Answer Rate: ${(metrics.answerRate * 100).toFixed(2)}%`);
        // 5. Apply delta update with Fibonacci backoff
        await adjustDialRate(site, auth, config.campaignId, clampedRate);
        currentDialRate = clampedRate;
        // 6. Export to DW
        await exportToDataWarehouse(config.dwEndpoint, exportRecord);
      } else {
        console.log("Pacing stable. No adjustment required.");
      console.error(`Pacing loop error: ${error.message}`);
      // Continue loop on error to prevent function termination
    // 30-second interval
    await new Promise(resolve => setTimeout(resolve, 30000));
// Serverless entry point
export const handler = async () => {
  const config: PacingConfig = {
    campaignId: process.env.CAMPAIGN_ID!,
    slaThreshold: parseFloat(process.env.SLA_THRESHOLD || "0.75"),
    toleranceMargin: parseFloat(process.env.TOLERANCE_MARGIN || "0.05"),
    minDialRate: parseInt(process.env.MIN_DIAL_RATE || "10"),
    maxDialRate: parseInt(process.env.MAX_DIAL_RATE || "100"),
    dwEndpoint: process.env.DW_ENDPOINT!
  await runPacingController(config);
// Run locally for testing
if (process.argv[1] === import.meta.url) {
  handler();
  • Cause: OAuth token expired or client credentials are incorrect.
  • Fix: Verify CXONE_CLIENT_ID and CXONE_CLIENT_SECRET in environment variables. Ensure the token manager refreshes before expiration. The provided CxoneAuthClient refreshes 60 seconds before expiry.
  • Code Fix: Check auth.getAccessToken() response. Log the exact error message returned from /oauth/token.
Error: 403 Forbidden
  • Cause: Missing OAuth scopes or insufficient permissions on the outbound campaign.
  • Fix: Add outbound:campaign:write and analytics:read to the OAuth client scopes in NICE CXone. Verify the service account has access to the target campaign.
  • Code Fix: Inspect the response.headers for WWW-Authenticate or check the response body for scope denial messages.
  • Cause: API rate limits exceeded due to aggressive polling or concurrent deployments.
  • Fix: The Fibonacci backoff wrapper in adjustDialRate automatically handles this. Ensure the polling interval remains at 30 seconds. Do not reduce it below 15 seconds for analytics queries.
  • Code Fix: Monitor console logs for 429 detected. Waiting Xs before retry. If retries exhaust, increase maxRetries in retryWithFibonacci.
Error: 400 Bad Request on PATCH
  • Cause: Invalid dialRate value or malformed JSON payload.
  • Fix: Ensure dialRate is an integer between minDialRate and maxDialRate. Verify If-Match: * header is present for optimistic concurrency.
  • Code Fix: Log the raw request body before sending. Validate against CXone schema constraints.
