Optimizing NICE Cognigy.AI Entity Extraction with Python
This tutorial builds a Python pipeline that analyzes entity distribution, augments rare classes with rule-based techniques, retrains models using weighted loss functions, evaluates precision and recall against a held-out test set, and automates retraining on drift detection. It uses the NICE Cognigy.AI REST API for dataset management, training job submission, and model export. All code is written in Python 3.10+ using the requests library.
  • OAuth 2.0 Client Credentials grant configured in the Cognigy.AI tenant
  • Required scopes: model:read model:write dataset:read dataset:write entity:read
  • API version: v1
  • Runtime: Python 3.10+
  • External dependencies: requests, pandas, scikit-learn, numpy, tenacity
The Cognigy.AI API requires a bearer token obtained via the OAuth 2.0 Client Credentials flow. The following function fetches the token, caches it in memory, and implements a retry strategy for transient network errors.
import os
import requests
from typing import Optional
BASE_URL = os.getenv("COGNIGY_BASE_URL", "https://your-tenant.cognigy.ai")
CLIENT_ID = os.getenv("COGNIGY_CLIENT_ID")
CLIENT_SECRET = os.getenv("COGNIGY_CLIENT_SECRET")
TOKEN_CACHE: dict = {}
def fetch_oauth_token() -> str:
    """Fetches and caches an OAuth 2.0 bearer token."""
    current_time = time.time()
    if "token" in TOKEN_CACHE and "expires" in TOKEN_CACHE:
        if current_time < TOKEN_CACHE["expires"]:
            return TOKEN_CACHE["token"]
    payload = {
        "client_id": CLIENT_ID,
        "client_secret": CLIENT_SECRET,
        "scope": "model:read model:write dataset:read dataset:write entity:read"
    response = requests.post(
        f"{BASE_URL}/api/v1/auth/token",
        data=payload
    response.raise_for_status()
    token_data = response.json()
    TOKEN_CACHE["token"] = token_data["access_token"]
    TOKEN_CACHE["expires"] = current_time + (token_data["expires_in"] - 60)
def get_authenticated_headers() -> dict:
    """Returns headers with a valid bearer token."""
        "Authorization": f"Bearer {fetch_oauth_token()}",
Step 1: Analyze Training Data Distribution
The first step retrieves all utterances from a target dataset and calculates entity frequency. The Cognigy.AI dataset endpoint supports pagination via page and pageSize query parameters. The code below fetches all pages, parses entity annotations, and identifies classes falling below a specified threshold.
import pandas as pd
def fetch_dataset_utterances(dataset_id: str) -> pd.DataFrame:
    """Fetches all utterances from a dataset with pagination."""
    all_utterances: List[Dict[str, Any]] = []
    page = 1
    page_size = 100
    while True:
        response = requests.get(
            f"{BASE_URL}/api/v1/datasets/{dataset_id}/utterances",
            headers=get_authenticated_headers(),
            params={"page": page, "pageSize": page_size}
        items = data.get("items", [])
        all_utterances.extend(items)
        if len(items) < page_size:
            break
        page += 1
    return pd.json_normalize(all_utterances)
def analyze_entity_distribution(df: pd.DataFrame, imbalance_threshold: float = 0.05) -> Dict[str, int]:
    """Identifies imbalanced entities based on frequency ratio."""
    entity_counts: Dict[str, int] = {}
    for _, row in df.iterrows():
        annotations = row.get("annotations", [])
        for annotation in annotations:
            entity_type = annotation.get("entityType")
            if entity_type:
                entity_counts[entity_type] = entity_counts.get(entity_type, 0) + 1
    total_entities = sum(entity_counts.values())
    imbalanced_classes = {}
    for entity, count in entity_counts.items():
        ratio = count / total_entities if total_entities > 0 else 0
        if ratio < imbalance_threshold:
            imbalanced_classes[entity] = count
    return imbalanced_classes
Step 2: Generate Synthetic Utterances
Rule-based augmentation expands rare entity classes without altering model semantics. The following function applies synonym replacement, case variation, and regex-based slot masking to existing utterances. It outputs a list of new utterance objects compatible with the Cognigy.AI dataset API.
import re
import random
SYNONYM_MAP = {
    "book": ["reserve", "schedule", "arrange"],
    "flight": ["airfare", "plane ticket", "airline booking"],
    "hotel": ["lodge", "accommodation", "resort"]
def augment_utterance(text: str, entity_type: str, entity_value: str) -> List[str]:
    """Generates synthetic variations of a single utterance."""
    variations = [text]
    # Case variation
    variations.append(text.swapcase())
    variations.append(text.upper())
    # Synonym replacement
    for word, synonyms in SYNONYM_MAP.items():
        if word in text.lower():
            for syn in synonyms:
                variations.append(re.sub(word, syn, text, flags=re.IGNORECASE))
    # Slot masking with regex patterns
    variations.append(re.sub(entity_value, f"<{entity_type}>", text, flags=re.IGNORECASE))
    return variations
def generate_synthetic_utterances(
    dataset_id: str,
    target_entity: str,
    target_count: int
) -> List[Dict[str, Any]]:
    """Generates and uploads synthetic utterances for a rare entity."""
    df = fetch_dataset_utterances(dataset_id)
    source_utterances = []
        for ann in row.get("annotations", []):
            if ann.get("entityType") == target_entity:
                source_utterances.append({
                    "text": row["text"],
                    "entityType": target_entity,
                    "entityValue": ann.get("entityValue")
    synthetic_data: List[Dict[str, Any]] = []
    attempts = 0
    while len(synthetic_data) < target_count and attempts < 500:
        if not source_utterances:
            break
        source = random.choice(source_utterances)
        variations = augment_utterance(
            source["text"],
            source["entityType"],
            source["entityValue"]
        for var in variations:
            if len(synthetic_data) >= target_count:
                break
            synthetic_data.append({
                "text": var,
                "annotations": [
                    {"entityType": target_entity, "entityValue": source["entityValue"]}
        attempts += 1
    return synthetic_data
Step 3: Retrain Models with Weighted Loss Functions
The Cognigy.AI training API accepts a classWeights object in the training job payload. This parameter adjusts the loss function to penalize misclassification of rare entities more heavily. The code below submits a training job with computed weights and polls for completion.
from typing import Dict, Any
def compute_class_weights(entity_counts: Dict[str, int]) -> Dict[str, float]:
    """Calculates inverse frequency weights for rare classes."""
    total = sum(entity_counts.values())
    weights = {}
        weights[entity] = round((total / (len(entity_counts) * count)), 2)
    return weights
def trigger_model_retraining(model_id: str, dataset_id: str, class_weights: Dict[str, float]) -> str:
    """Submits a training job with weighted loss and returns job ID."""
    payload = {
        "datasetId": dataset_id,
        "options": {
            "classWeights": class_weights,
            "epochs": 50,
            "learningRate": 0.001
        f"{BASE_URL}/api/v1/models/{model_id}/training-jobs",
        json=payload
    job_data = response.json()
    job_id = job_data["id"]
    print(f"Training job {job_id} initiated.")
    # Poll until completion
    while True:
        status_response = requests.get(
            f"{BASE_URL}/api/v1/models/{model_id}/training-jobs/{job_id}",
        status_response.raise_for_status()
        status = status_response.json()["status"]
        if status in ["COMPLETED", "FAILED"]:
            break
        time.sleep(10)
    if status == "FAILED":
        raise RuntimeError(f"Training job {job_id} failed.")
    return job_id
Step 4: Evaluate Precision and Recall Metrics
After training, the pipeline runs a batch prediction against a held-out test set and calculates precision and recall using scikit-learn. This step validates that weighted loss improved rare entity extraction without degrading overall performance.
import numpy as np
from sklearn.metrics import precision_score, recall_score
def run_batch_prediction(model_id: str, test_utterances: List[str]) -> List[Dict[str, Any]]:
    """Sends test utterances to the model prediction endpoint."""
    payload = {"utterances": test_utterances}
        f"{BASE_URL}/api/v1/models/{model_id}/predict",
        json=payload
    return response.json()["results"]
def calculate_entity_metrics(
    actual_entities: List[str],
    predicted_entities: List[str]
    """Calculates precision and recall for entity extraction."""
    precision = precision_score(actual_entities, predicted_entities, average="weighted", zero_division=0)
    recall = recall_score(actual_entities, predicted_entities, average="weighted", zero_division=0)
    return {"precision": precision, "recall": recall}
Step 5: Automate Retraining on Data Drift Detection and Export
Data drift occurs when the distribution of incoming utterances diverges from the training baseline. The following function compares current entity frequencies against historical thresholds using the Kolmogorov-Smirnov test. If drift exceeds the threshold, the pipeline triggers retraining and exports the updated model via the Model API.
from scipy import stats
def detect_data_drift(
    baseline_counts: Dict[str, int],
    current_counts: Dict[str, int],
    drift_threshold: float = 0.05
) -> bool:
    """Detects statistical drift in entity distribution."""
    entities = sorted(set(baseline_counts.keys()) | set(current_counts.keys()))
    baseline_values = [baseline_counts.get(e, 0) for e in entities]
    current_values = [current_counts.get(e, 0) for e in entities]
    # Normalize to probability distributions
    baseline_sum = sum(baseline_values)
    current_sum = sum(current_values)
    if baseline_sum == 0 or current_sum == 0:
        return False
    baseline_dist = np.array(baseline_values) / baseline_sum
    current_dist = np.array(current_values) / current_sum
    # KS test for distribution shift
    ks_stat, p_value = stats.ks_2samp(baseline_dist, current_dist)
    return p_value < drift_threshold
def export_trained_model(model_id: str) -> str:
    """Exports the updated model and returns the download URL."""
        f"{BASE_URL}/api/v1/models/{model_id}/export",
        json={"format": "tar.gz"}
    export_data = response.json()
    download_url = export_data["downloadUrl"]
    print(f"Model exported successfully. Download URL: {download_url}")
    return download_url
The following script combines all components into a single executable pipeline. It requires environment variables for credentials and runs the full optimization cycle.
import os
import sys
import pandas as pd
import numpy as np
import requests
# [Paste fetch_oauth_token, get_authenticated_headers, fetch_dataset_utterances,
#  analyze_entity_distribution, augment_utterance, generate_synthetic_utterances,
#  compute_class_weights, trigger_model_retraining, run_batch_prediction,
#  calculate_entity_metrics, detect_data_drift, export_trained_model here]
def run_optimization_pipeline(
    dataset_id: str,
    model_id: str,
    test_utterances: List[str],
    ground_truth_entities: List[str],
) -> None:
    """Executes the full entity extraction optimization pipeline."""
    print("Step 1: Analyzing entity distribution...")
    imbalanced = analyze_entity_distribution(df, imbalance_threshold=0.05)
    if not imbalanced:
        print("No imbalanced entities detected. Skipping augmentation.")
        return
    target_entity = max(imbalanced, key=imbalanced.get)
    print(f"Targeting imbalanced entity: {target_entity} (count: {imbalanced[target_entity]})")
    print("Step 2: Generating synthetic utterances...")
    synthetic_utterances = generate_synthetic_utterances(dataset_id, target_entity, target_count=50)
    # Upload synthetic data to dataset
    for utt in synthetic_utterances:
        requests.post(
            json=utt
    print("Step 3: Computing weights and triggering retraining...")
    all_counts = {**imbalanced, **{e: 100 for e in set(df["text"])}}  # Simplified count merge
    weights = compute_class_weights(all_counts)
    trigger_model_retraining(model_id, dataset_id, weights)
    print("Step 4: Evaluating model performance...")
    predictions = run_batch_prediction(model_id, test_utterances)
    predicted_entities = [p.get("entities", [{}])[0].get("entityType", "O") for p in predictions]
    metrics = calculate_entity_metrics(ground_truth_entities, predicted_entities)
    print(f"Precision: {metrics['precision']:.4f}, Recall: {metrics['recall']:.4f}")
    print("Step 5: Checking drift and exporting model...")
    current_counts = analyze_entity_distribution(df)
    if detect_data_drift(baseline_counts, current_counts):
        print("Data drift detected. Exporting updated model.")
        export_trained_model(model_id)
    else:
        print("No significant drift. Model baseline remains stable.")
    DATASET_ID = os.getenv("COGNIGY_DATASET_ID")
    MODEL_ID = os.getenv("COGNIGY_MODEL_ID")
    # Placeholder test data for demonstration
    test_set = ["book a flight to paris", "reserve hotel in london", "schedule meeting for tomorrow"]
    ground_truth = ["intent_travel", "intent_travel", "intent_meeting"]
    baseline = {"intent_travel": 150, "intent_meeting": 45, "entity_city": 30}
    run_optimization_pipeline(DATASET_ID, MODEL_ID, test_set, ground_truth, baseline)
  • Cause: Expired OAuth token, incorrect client credentials, or missing required scope in the token request.
  • Fix: Verify CLIENT_ID and CLIENT_SECRET match the Cognigy.AI application configuration. Ensure the token request includes model:write and dataset:write scopes. Clear the TOKEN_CACHE dictionary and re-run the authentication function.
  • Code Fix: Add explicit scope validation in the payload and implement automatic cache invalidation on 401 responses.
  • Cause: Exceeding the Cognigy.AI API rate limit, typically triggered during bulk utterance uploads or rapid polling of training job status.
  • Fix: Implement exponential backoff. The tenacity library handles this automatically. Wrap API calls with a retry decorator that catches requests.exceptions.HTTPError and checks for status code 429.
  • Code Fix:
from tenacity import retry, wait_exponential, stop_after_attempt
@retry(wait=wait_exponential(multiplier=1, min=2, max=10), stop=stop_after_attempt(5))
def safe_api_call(url: str, method: str, **kwargs) -> requests.Response:
    response = requests.request(method, url, **kwargs)
        raise requests.exceptions.HTTPError("Rate limit exceeded")
    return response
Error: 400 Bad Request
  • Cause: Malformed JSON payload, missing required fields in the training job configuration, or invalid entity type names in annotations.
  • Fix: Validate the payload structure against the Cognigy.AI API schema. Ensure entityType values match exactly with the entity definitions registered in the tenant. Check that classWeights keys correspond to valid entity identifiers.
  • Code Fix: Parse the response.json() error body to identify the exact field causing validation failure. Log the payload before submission for comparison.
  • Cause: Backend training service failure, typically due to dataset corruption, unsupported augmentation patterns, or exceeding model size limits.
  • Fix: Verify dataset integrity by checking for null values or unsupported characters in utterance text. Reduce target_count for synthetic generation if memory limits are approached. Contact NICE support with the training job ID if the error persists after payload validation.
