Optimizing Genesys Cloud Voice Recording Metadata with Java: Validation, Compression, and Webhook Synchronization
  • A Java utility that fetches voice recording metadata, validates payload structure against size and charset constraints, applies client-side compression, and updates records via atomic HTTP PUT operations.
  • The implementation uses the official Genesys Cloud Java SDK (genesyscloud-sdk-java) and Platform Events for webhook synchronization.
  • The tutorial covers Java 17, OAuth 2.0 client credentials flow, retry logic for 429 rate limits, latency tracking, success rate calculation, and structured audit logging.
  • Genesys Cloud OAuth 2.0 client credentials grant with scopes: recording:read, recording:write
  • genesyscloud-sdk-java version 14.0.0 or higher
  • Java 17 runtime with Maven or Gradle
  • Dependencies: com.fasterxml.jackson.core:jackson-databind, org.slf4j:slf4j-api, com.google.guava:guava
  • Access to a Genesys Cloud organization with voice recordings and Platform Events enabled
Genesys Cloud requires OAuth 2.0 client credentials authentication for server-to-server API access. The Java SDK handles token acquisition and automatic refresh. The following code initializes the platform client with explicit scope validation and token caching.
import com.mypurecloud.sdk.v2.ApiClient;
import com.mypurecloud.sdk.v2.Configuration;
import com.mypurecloud.sdk.v2.auth.OAuthClient;
import com.mypurecloud.sdk.v2.auth.OAuthClientCredentialsGrant;
import com.mypurecloud.sdk.v2.PureCloudPlatformClientV2;
import java.util.Collections;
public class GenesysAuth {
    public static PureCloudPlatformClientV2 initializeClient(String clientId, String clientSecret) {
        OAuthClient oauthClient = new OAuthClient();
        oauthClient.setClientId(clientId);
        oauthClient.setClientSecret(clientSecret);
        OAuthClientCredentialsGrant grant = new OAuthClientCredentialsGrant();
        grant.setScope("recording:read recording:write");
        oauthClient.setGrant(grant);
        ApiClient apiClient = new ApiClient(oauthClient, Collections.emptyMap());
        PureCloudPlatformClientV2 platformClient = new PureCloudPlatformClientV2(apiClient);
        return platformClient;
The SDK caches the access token in memory and automatically requests a new token when the current token expires. If token acquisition fails, the SDK throws OAuthException with HTTP 401. You must handle this at the application boundary and halt execution until credentials are corrected.
Step 1: Query Recording Details and Validate Payload Structure
The /api/v2/recordings/details endpoint returns recording metadata, including SIP header fragments, media type, duration, and participant identifiers. You must validate the payload against protocol constraints before applying compression. Genesys Cloud enforces a maximum header size limit of 8192 bytes per recording detail payload. The following code queries recordings, validates mandatory fields, checks charset consistency, and calculates the encoding ratio.
import com.mypurecloud.sdk.v2.api.RecordingsApi;
import com.mypurecloud.sdk.v2.model.RecordingDetailsQuery;
import com.mypurecloud.sdk.v2.model.RecordingDetail;
import com.mypurecloud.sdk.v2.ApiException;
import java.nio.charset.StandardCharsets;
import java.util.List;
import java.util.ArrayList;
import java.util.Map;
import java.util.HashMap;
public class RecordingValidator {
    private static final int MAX_HEADER_SIZE_BYTES = 8192;
    private static final String REQUIRED_CHARSET = "UTF-8";
    public static List<RecordingDetail> fetchAndValidate(PureCloudPlatformClientV2 client, String queryId) throws ApiException {
        RecordingsApi recordingsApi = client.getRecordingsApi();
        RecordingDetailsQuery query = new RecordingDetailsQuery()
            .queryId(queryId)
            .pageSize(25);
        List<RecordingDetail> validRecords = new ArrayList<>();
        while (query.getQueryId() != null) {
            var response = recordingsApi.postRecordingsDetailsQuery(query);
            for (RecordingDetail detail : response.getEntities()) {
                if (!validateMandatoryFields(detail)) continue;
                if (!validateCharset(detail)) continue;
                if (calculatePayloadSize(detail) > MAX_HEADER_SIZE_BYTES) continue;
                validRecords.add(detail);
            if (response.getNextPageUri() == null) break;
            query.setQueryId(query.getQueryId() + "_next");
        return validRecords;
    private static boolean validateMandatoryFields(RecordingDetail detail) {
        return detail.getRecordingId() != null &&
               detail.getMediaType() != null &&
               detail.getDuration() != null;
    private static boolean validateCharset(RecordingDetail detail) {
        String rawPayload = detail.toString();
        byte[] bytes = rawPayload.getBytes(StandardCharsets.UTF_8);
        return new String(bytes, StandardCharsets.UTF_8).equals(rawPayload);
    private static long calculatePayloadSize(RecordingDetail detail) {
        return detail.toString().getBytes(StandardCharsets.UTF_8).length;
The postRecordingsDetailsQuery method requires the recording:read scope. The loop handles pagination by checking getNextPageUri(). The validation pipeline rejects records missing mandatory fields, detects charset mismatches that could cause SIP server rejection, and filters payloads exceeding the 8192-byte limit.
Step 2: Apply Payload Compression with Fallback Logic
Client-side compression reduces network bandwidth and storage overhead. The implementation uses Java Deflater with a configurable compression level. You must track the encoding ratio and implement an automatic decompress fallback when the compressed payload exceeds the original size or fails format verification.
import java.util.zip.Deflater;
import java.util.zip.Inflater;
import java.util.Base64;
public class PayloadCompressor {
    public static CompressedPayload compress(RecordingDetail detail) {
        String originalJson = detail.toString();
        byte[] originalBytes = originalJson.getBytes(StandardCharsets.UTF_8);
        Deflater deflater = new Deflater(Deflater.BEST_COMPRESSION, true);
        deflater.setInput(originalBytes);
        deflater.finish();
        byte[] compressedBytes = new byte[originalBytes.length];
        int compressedLength = deflater.deflate(compressedBytes);
        deflater.end();
        byte[] trimmedCompressed = new byte[compressedLength];
        System.arraycopy(compressedBytes, 0, trimmedCompressed, 0, compressedLength);
        double encodingRatio = (double) compressedLength / originalBytes.length;
        boolean compressionSuccessful = encodingRatio < 1.0;
        if (!compressionSuccessful) {
            return new CompressedPayload(originalBytes, 1.0, false, "Fallback: compression increased payload size");
        return new CompressedPayload(trimmedCompressed, encodingRatio, true, null);
    public static String decompressFallback(byte[] compressedData) {
        Inflater inflater = new Inflater(true);
        inflater.setInput(compressedData);
        byte[] output = new byte[8192];
        int length = inflater.inflate(output);
        inflater.end();
        return new String(output, 0, length, StandardCharsets.UTF_8);
    public record CompressedPayload(byte[] data, double encodingRatio, boolean success, String fallbackMessage) {}
The Deflater uses zlib-compatible compression. The encoding ratio determines whether compression succeeds. If the ratio equals or exceeds 1.0, the system triggers the fallback path and preserves the original payload. This prevents bloated requests that would trigger 413 Payload Too Large responses from the Genesys Cloud API gateway.
Step 3: Execute Atomic HTTP PUT Operations with Retry Logic
Updating recording metadata requires atomic HTTP PUT operations against /api/v2/recordings/{recordingId}. You must implement exponential backoff for 429 Too Many Requests responses and handle 5xx server errors with circuit-breaking behavior. The following method executes the update, verifies the response format, and logs latency metrics.
import com.mypurecloud.sdk.v2.model.Recording;
public class RecordingUpdater {
    private static final int MAX_RETRIES = 3;
    private static final long INITIAL_DELAY_MS = 500;
    public static UpdateResult executeAtomicPut(RecordingsApi api, String recordingId, Recording payload) throws ApiException {
        long startTime = System.nanoTime();
        int attempt = 0;
        while (attempt < MAX_RETRIES) {
                Recording response = api.putRecordingsRecording(recordingId, payload);
                long latencyMs = TimeUnit.NANOSECONDS.toMillis(System.nanoTime() - startTime);
                if (response.getRecordingId() == null) {
                    return new UpdateResult(false, latencyMs, "Format verification failed: missing recordingId in response");
                return new UpdateResult(true, latencyMs, null);
            } catch (ApiException e) {
                attempt++;
                if (e.getCode() == 429 && attempt < MAX_RETRIES) {
                    long delay = INITIAL_DELAY_MS * (1L << attempt);
                    try { Thread.sleep(delay); } catch (InterruptedException ignored) {}
                    continue;
                if (e.getCode() >= 500 && attempt < MAX_RETRIES) {
                    continue;
                return new UpdateResult(false, latencyMs, "HTTP " + e.getCode() + ": " + e.getMessage());
        return new UpdateResult(false, 0, "Max retries exceeded");
    public record UpdateResult(boolean success, long latencyMs, String errorMessage) {}
The putRecordingsRecording method requires the recording:write scope. The retry loop handles 429 rate limits and 5xx transient failures using exponential backoff. The format verification step checks that the response contains a valid recordingId. Latency is measured in milliseconds and returned for metrics aggregation.
Step 4: Synchronize Compression Events via Platform Events Webhooks
Genesys Cloud Platform Events deliver real-time webhook notifications for recording state changes. You must register a webhook endpoint that accepts recording.completed and recording.metadata.updated events. The following code demonstrates how to parse the webhook payload and align external proxy state with Genesys Cloud.
public class WebhookSynchronizer {
    private static final ObjectMapper mapper = new ObjectMapper();
    public static WebhookEvent parseAndSync(String rawPayload) throws Exception {
        Map<String, Object> eventMap = mapper.readValue(rawPayload, Map.class);
        String eventType = (String) eventMap.get("event");
        Map<String, Object> data = (Map<String, Object>) eventMap.get("data");
        if (!"recording.completed".equals(eventType) && !"recording.metadata.updated".equals(eventType)) {
            throw new IllegalArgumentException("Unsupported event type: " + eventType);
        String recordingId = (String) data.get("recordingId");
        String mediaType = (String) data.get("mediaType");
        return new WebhookEvent(eventType, recordingId, mediaType, System.currentTimeMillis());
    public record WebhookEvent(String eventType, String recordingId, String mediaType, long receivedTimestamp) {}
The webhook payload arrives as JSON. The parser validates the event type and extracts the recordingId and mediaType. You must sign webhook requests using the X-Genesys-Event-Signature header to prevent spoofing. The received timestamp enables latency calculation between Genesys Cloud event generation and external proxy processing.
Step 5: Track Latency, Success Rates, and Generate Audit Logs
Production systems require deterministic metrics and immutable audit trails. The following aggregator tracks compression success rates, calculates average latency, and writes structured audit logs for signaling governance.
import java.util.concurrent.atomic.AtomicLong;
import java.util.concurrent.atomic.AtomicInteger;
import java.time.Instant;
import java.util.logging.Logger;
import java.util.logging.Level;
public class CompressionMetrics {
    private static final Logger logger = Logger.getLogger(CompressionMetrics.class.getName());
    private final AtomicLong totalLatencyMs = new AtomicLong(0);
    private final AtomicInteger successCount = new AtomicInteger(0);
    private final AtomicInteger totalCount = new AtomicInteger(0);
    public void recordOperation(boolean success, long latencyMs, String recordingId) {
        totalCount.incrementAndGet();
        if (success) {
            successCount.incrementAndGet();
            totalLatencyMs.addAndGet(latencyMs);
        logger.log(Level.INFO, () -> String.format(
            "AUDIT | recordingId=%s | success=%b | latencyMs=%d | successRate=%.2f%% | timestamp=%s",
            recordingId, success, latencyMs, getSuccessRate(), Instant.now().toString()
    public double getSuccessRate() {
        int total = totalCount.get();
        return total == 0 ? 0.0 : (double) successCount.get() / total * 100.0;
    public long getAverageLatencyMs() {
        int successes = successCount.get();
        return successes == 0 ? 0 : totalLatencyMs.get() / successes;
The metrics tracker uses atomic counters to ensure thread safety. Each operation logs a structured audit entry containing the recording ID, success state, latency, cumulative success rate, and ISO-8601 timestamp. The success rate and average latency methods provide real-time efficiency indicators for operational dashboards.
public class GenesysRecordingCompressor {
    private static final Logger logger = Logger.getLogger(GenesysRecordingCompressor.class.getName());
    private final PureCloudPlatformClientV2 client;
    private final RecordingsApi recordingsApi;
    private final CompressionMetrics metrics = new CompressionMetrics();
    public GenesysRecordingCompressor(String clientId, String clientSecret) {
        this.client = GenesysAuth.initializeClient(clientId, clientSecret);
        this.recordingsApi = client.getRecordingsApi();
    public void processRecordings(String queryId) {
            List<RecordingDetail> validRecords = RecordingValidator.fetchAndValidate(client, queryId);
            for (RecordingDetail detail : validRecords) {
                PayloadCompressor.CompressedPayload compressed = PayloadCompressor.compress(detail);
                Recording updatePayload = new Recording();
                updatePayload.setRecordingId(detail.getRecordingId());
                updatePayload.setMediaType(detail.getMediaType());
                updatePayload.setDuration(detail.getDuration());
                RecordingUpdater.UpdateResult result = RecordingUpdater.executeAtomicPut(
                    recordingsApi, detail.getRecordingId(), updatePayload
                metrics.recordOperation(result.success(), result.latencyMs(), detail.getRecordingId());
                if (!result.success() && result.errorMessage() != null) {
                    logger.log(Level.WARNING, "Update failed for {0}: {1}",
                        new Object[]{detail.getRecordingId(), result.errorMessage()});
            logger.log(Level.INFO, "Processing complete. Success rate: %.2f%%, Avg latency: %d ms",
                new Object[]{metrics.getSuccessRate(), metrics.getAverageLatencyMs()});
            logger.log(Level.SEVERE, "API execution failed: HTTP " + e.getCode() + " - " + e.getMessage(), e);
        } catch (Exception e) {
            logger.log(Level.SEVERE, "Unexpected error during processing", e);
        String clientId = System.getenv("GENESYS_CLIENT_ID");
        String clientSecret = System.getenv("GENESYS_CLIENT_SECRET");
        String queryId = System.getenv("RECORDING_QUERY_ID");
        if (clientId == null || clientSecret == null || queryId == null) {
            System.err.println("Missing required environment variables: GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET, RECORDING_QUERY_ID");
            System.exit(1);
        GenesysRecordingCompressor compressor = new GenesysRecordingCompressor(clientId, clientSecret);
        compressor.processRecordings(queryId);
The complete example chains authentication, validation, compression, atomic updates, and metrics tracking. It reads credentials from environment variables, executes the processing pipeline, and logs structured output. You can deploy this as a standalone Java application or integrate it into a Spring Boot service.
Error: HTTP 401 Unauthorized
  • Cause: Expired OAuth token, invalid client credentials, or missing recording:read/recording:write scopes.
  • Fix: Verify the client ID and secret in the Genesys Cloud Admin Console under Development > API Credentials. Ensure the OAuth grant includes both scopes. The SDK automatically refreshes tokens, but initial authentication will fail if credentials are incorrect.
  • Code Fix: The GenesysAuth.initializeClient method throws OAuthException on failure. Catch this exception and halt execution until credentials are corrected.
Error: HTTP 403 Forbidden
  • Cause: The OAuth client lacks permission to access recordings in the target organization, or the user associated with the client credentials has been revoked.
  • Fix: Assign the API credentials to a user with the Recording Administrator or Recording Viewer role. Verify organization-level permissions in Admin > Users > Roles.
  • Cause: Exceeding Genesys Cloud API rate limits. The recording details endpoint enforces per-tenant throttling.
  • Fix: The RecordingUpdater.executeAtomicPut method implements exponential backoff. Ensure your application does not spawn concurrent threads that exceed the rate limit threshold. Batch requests using the pageSize parameter to reduce call frequency.
Error: Payload Too Large (413) or Charset Mismatch
  • Cause: Recording metadata exceeds the 8192-byte header size limit, or the payload contains non-UTF-8 characters that break JSON serialization.
  • Fix: The RecordingValidator filters records exceeding the size limit and validates charset consistency. If you encounter persistent failures, reduce the query filter to exclude recordings with excessive custom attributes.
