ODS and Datamart DB Reset CCA 7.1
We have a problem where someone connected another version of CCA to our DEV environment and now the ETL is givining errors everywhere about unique constraints and missing tables.
I think two different ETLs were processing the DB at the same time. ???
Luckily its a dev environment so we will just flush all data and create the DS Layouts from scratch. We dont mind about the lost data.
My question is without having to re-install the whole CCA process is there a quick way to get DataSourcer to run from a fresh ? I had a look a the ODS and DataMart DB to see if i could delete some reference to the old data but not sure.
To be clear the ODS works fine and DataSourcer is collectioning stats ok.
So its just the ETL. So how do i get the ETL to ignore the checks and run as a fresh?
Just drop the Datamart and rerun the DB creation scripts and reconnect in ETL Assistant. An hour tops.
Yeah tks i did that in the end.
Was just trying to find a lazy way todo it :wink:
e.g change on table and it fools ETL into thinking its running for the first time.
Cheers anyway
