OAuth token validation fails under load
How come this setting causes 401 errors on /api/v2/auth/oauth/token when JMeter hits 500 concurrent requests? The US1 environment drops connections after 10 seconds despite valid credentials.
Using SDK v2.8 with standard scope. Is there a hidden rate limit on the auth endpoint during load tests?
TL;DR: The 401s are not rate-limit errors; they are token caching collisions and thread-safety issues in the SDK’s default auth handler. You need to implement a singleton token manager with a background refresh loop, not per-request fetches.
The problem here is that the Genesys Cloud SDK’s default authentication module is not designed to handle 500 concurrent threads hammering the /oauth/token endpoint simultaneously. While the credentials are valid, the underlying HTTP client pool is likely exhausting connections or experiencing race conditions when multiple threads attempt to acquire a new token at the exact same millisecond. The 401 response often masks a deeper issue where the token refresh request fails due to connection timeouts or internal server throttling on the auth gateway, which then returns an expired or invalid token to the subsequent requests.
To fix this, you must decouple token acquisition from the request execution path. Do not let the SDK handle auth directly under high load. Instead, implement a centralized token manager. Here is a robust pattern using a background refresh loop with a lock to prevent double-fetching:
import threading
import requests
class GenesysTokenManager:
 def __init__(self, client_id, client_secret, region):
 self.client_id = client_id
 self.region = region
 self.token = None
 self.expiry = 0
 self.lock = threading.Lock()
 self.refresh_endpoint = f"https://{region}.genesyscloud.com/oauth/token"
 def get_token(self):
 # Check if token is valid and has > 60s buffer
 if self.token and time.time() < self.expiry - 60:
 return self.token
 with self.lock:
 # Double-check inside lock
 return self.token
 # Fetch new token
 payload = {
 'grant_type': 'client_credentials',
 'client_id': self.client_id,
 'client_secret': self.client_secret
 headers = {'Content-Type': 'application/x-www-form-urlencoded'}
 response = requests.post(self.refresh_endpoint, data=payload, headers=headers)
 response.raise_for_status()
 data = response.json()
 self.token = data['access_token']
 self.expiry = time.time() + data['expires_in']
 return self.token
 raise RuntimeError(f"Token refresh failed: {e}")
Use this manager to inject the Authorization: Bearer <token> header manually into your JMeter requests. This ensures that only one thread refreshes the token while others wait briefly or use the cached value. The SDK’s internal retry logic is insufficient for this scale. Additionally, verify that your JMeter thread group is not creating a new SDK instance per thread; that multiplies the connection overhead significantly. Switch to a single shared instance with the custom token provider.
If you check the docs, they mention that the default SDK behavior for authentication is not optimized for high-concurrency load testing scenarios like the 500 concurrent requests mentioned above. While the suggestion to implement a singleton token manager is correct, there is a more granular approach using the Authenticator interface directly to avoid thread contention. You should instantiate a single PureCloudAuthenticator and share it across all JMeter threads, rather than letting each thread instantiate its own client.
Here is the configuration logic you need to adjust in your JMeter Java Request or Scripting element:
// Initialize once in setUpThread or a static block
PureCloudClientBuilder builder = PureCloudClientBuilder.standard()
 .withClientId("your-client-id")
 .withClientSecret("your-client-secret")
 .withRegion(Region.US1);
// Create a shared authenticator instance
PureCloudAuthenticator authenticator = builder.build().getAuthenticator();
// In your sampler, reuse this authenticator
// Do NOT call builder.build() inside the loop or per-thread
ApiContext context = authenticator.getApiContext();
The 401 errors you are seeing are often a symptom of the SDK’s internal token refresh logic triggering simultaneously across multiple threads, causing a race condition where one thread invalidates the token while another is trying to use it. By centralizing the authenticator, you ensure that token refreshes are serialized. This is similar to how we handle SIP registration states across our 15 BYOC trunks; if multiple nodes try to re-register simultaneously during a failover event, the carrier can drop the call. The same principle applies here. The US1 environment has strict connection pooling limits, so reducing the number of distinct HTTP connections to the auth endpoint is critical. Ensure your JMeter HTTP Request Defaults are set to reuse connections, and verify that your keepAlive settings are enabled. This approach reduces the load on the auth server significantly and prevents the temporary state conflicts that trigger the 401 responses.
