OAuth client secret rotation: 401 gap during secret swap
Trying to rotate the OAuth client secret for our production app without dropping any active connections. The docs say we can add a new secret, use it for new tokens, and then remove the old one. Sounds simple enough.
Here is the flow I am running:
  1. POST to /api/v2/oauth/clients/{id} to add secret2 to the list of secrets.
  2. Wait 5 minutes (just to be safe).
  3. Start requesting tokens using secret2.
  4. Remove secret1 from the client config.
The problem happens in step 3. For about 30 to 60 seconds after adding the new secret, requests using secret2 return a 401 Unauthorized. The error payload is just {"error": "invalid_client"}.
We have a high-volume webhook listener that needs to refresh tokens continuously. If we switch secrets and get a burst of 401s, we miss events. I assumed the API would validate against the new secret immediately upon saving the client config.
Is there a caching layer on the auth service that causes this delay? Or am I missing a step in the rotation process? I tried calling the endpoint directly with curl to rule out SDK issues, same result.
curl -X POST https://api.mypurecloud.com/api/v2/oauth/token
-H “Content-Type: application/x-www-form-urlencoded”
-d “grant_type=client_credentials&client_id=xyz&client_secret=new_secret_value”
Response:
HTTP/1.1 401 Unauthorized
{“error”:“invalid_client”}
After about a minute, the same curl command works fine. This window of failure is unacceptable for our uptime SLA. How do others handle this? Is there a way to force a cache invalidation on the auth side?
