platformClient.api.notifications.api_v2.notification.post is failing to populate the eventBody field for flow.transfer events. It’s intermittent - about 20% of transfer events are missing all custom data passed via transfer.call.setUserData(). The eventType and topicName are correct.
We’ve verified the Architect flow - cust_transfer_reason is being set with transfer.call.setUserData({key: 'cust_transfer_reason', value: $transferReason}). platformClient.api.architect.flow.get confirms the variable is scoped correctly as ‘session’. It’s not a throttling issue - the rate is well below the documented limits. This started after the last release.
