Not Connected to SCS [GA]
Hello and thanks for the time you’ll take to read this,
So i installed and GA and configured everything, at least i think i did. ::slight_smile:
But i don’t have the status of the applications even if my SCS exists and has connections to the Msg Server and the ConfServer.
It’s really strange since i tried to install SCI and this interface can connect to the SCS without a problem and see the status of each app/host.
I was thinking about roles and rights in GA.
If anyone has an idea please let me know, and if you need any informations just ask me.
is it in your TNSNAMES.ORA file?
Did you configure the connection to the SCS on object used for GA?
The default app needs connection to SCS.
Problem solved :
Yes the tnsname.ora was correct, i double checked just in case
The problem is that i needed to add SCS to the default app,
Thx everyone.
(Ps: i don’t know how to mark this as solved)
