Not able to dial internal call from wde to dn
Hi Members,
I am not able to dial call from WDE to dn internally getting below error in logs. 483 too many hops. Please help.
— DestBusy —
+++ Post-event +++
Type EventDestinationBusy
Devices: <2000/2000> <1001/1001> <-/->
Calls: 16777356/006d02f58e6c208c/16777356.641cb50/c:1/r:0 0/none
Parties: D2000/2000.61c1fd0-641cb50:1/l:1/r:0/Failed,Active,Origination
D1001/1001.61c2220-641cb50:1/l:2/r:0/Blocked,DNull,Destination
none
Cause: Blocked/35, Info: 0
Flags: divert=0 hook=0 postCall=0 active=1 moveAll=1 callType=1 hideOtherPi=0 InternalOther=1
— Post-event —
11:58:57.064 — CIFace::Event —
11:58:57.064: check call postponed until end of operation
11:58:57.064 SIPCONN(1001): terminate dialog
11:58:57.064: SipDialog: set monitor 0000000000000000
11:58:57.064: SipDialog::Terminate(state=9,reason=0)
11:58:57.064 SIPCONN(1001): state e:4,p:6,s:6,c:8,rc:483,m:1
11:58:57.064 SIPCONN(2000): CheckUpdateTransferStatus: no original dialog
11:58:57.064 SIPPARTY(1001): 16777496 verify update of party-connection state F-F
11:58:57.064 SIPCONN(1001): SIPCONN(00000000061b8a40,UH9ITBFF4T0CP5OKV4PUFCV1KC00008O) -Tr(1044,SipTransactionConnectNewParty)
11:58:57.064: Tr(1044,SipTransactionConnectNewParty):failed
11:58:57.064: Sc(1039):step 4, Tr(1044,SipTransactionConnectNewParty) - failed
11:58:57.064: Tr(1039,SipScenario):failed
11:58:57.064: SIPCM: transaction Tr(1039,SipScenario) failed
11:58:57.064: PI-1: 00 S[IN]D[2000]C[*D[2000]]P[1001]
11:58:57.064: PI: 01 S[FN]D[1001]P[2000], busy scheduled
11:58:57.064: party cannot be recovered
11:58:57.064: CALLSTATE(a:2,d:0,i:0,e:0,r:0,o:0)
11:58:57.064: apply fast busy tone for device ‘1001’
11:58:57.064: ERROR: No treatment services are configured
11:58:57.064: ERROR: 1000001d, GetDeviceManager().ResolveServiceDevice(call, SIP_MEDIA_SERVICE_MUSIC, geoLocation.CStr(), false,result), SipMediaResourceManager.cpp,238
11:58:57.064: ERROR: 1000001d, CreateMusicDevice(context, call, party, endPoint, type, device), SipMediaResourceManager.cpp,252
11:58:57.064: ERROR: 1000001d, CreateMusicServiceInternal(context,call,party,type,endPoint,musicService), SipMediaResourceManager.cpp,271
11:58:57.064: cannot create music service 4
11:58:57.064: cannot attach busy tone. Please check configuration.
11:58:57.064: previous scenario Tr(1039,SipScenario) is not cleaned up
11:58:57.064: Sc(1039):step 0, Tr(1045,SipTransactionRejectCall) - begin
11:58:57.064 SIPCONN(2000): re-invite-called-initiated
11:58:57.064 SIPCONN(2000): SIPCONN(00000000061b9350,UH9ITBFF4T0CP5OKV4PUFCV1KC00008N) +Tr(1045,SipTransactionRejectCall)
11:58:57.064: Sending [0,UDP] 405 bytes to 192.168.32.130:5060 >>>>>
SIP/2.0 483 Too Many Hops
From: sip:2000@WIN-PAPK5L4GODV;tag=AA44B13C-9385-4F1D-87CA-EEF0EA3495B0-278
To: sip:1001@192.168.32.130:5060;tag=AA44B13C-9385-4F1D-87CA-EEF0EA3495B0-279
Call-ID: 01C376B5-E60A-4F82-B7D6-7C958D102EA5-139@192.168.32.130
CSeq: 1 INVITE
Via: SIP/2.0/UDP 192.168.32.130:5060;branch=z9hG4bK970EB101-40BB-4E4E-84ED-50DB51F31CA2-139;received=192.168.32.130
Content-Length: 0
It is necessary to post the log fragment before the EventDestinationBusy is fired. From current fragment root-cause cannot be found
11:58:57.064: SipDialog: event CALLING_RESREJECT, t=282, s=9, r=5, m=00000000061b8af8 port=5060
11:58:57.064: CID:CUUID>01C376B5-E60A-4F82-B7D6-7C958D102EA5-140@192.168.x.x:7D04KUA6UT0J7BLLFD2GLU8H3C00004C:
11:58:57.064 SIPCONN(1001): HandleSipDialogEvent(CALLING_RESREJECT)
11:58:57.064 SIPCONN(1001): ConvertResponse: 483
11:58:57.064 SIPCONN(1001): ConvertResponse: no conversion configured for 483
11:58:57.064 SIPCONN(1001): Failed to obtain Media Server ID
11:58:57.064 SIPCONN(1001): state e:4,p:0,s:6,c:8,rc:483,m:1
11:58:57.064 SIPPARTY(1001): 16777496 verify update of party-connection state N-F
11:58:57.064 SIPPARTY(1001): 16777496 update party-connection state N-F
11:58:57.064 +++ CIFace::Event +++
+++ Pre-event +++
Devices:
Parties: D2000/2000.61c1fd0-641cb50:1/l:1/r:0/Dialing,Active,Origination
D1001/1001.61c2220-641cb50:1/l:2/r:0/Null,DNull,Destination
none
— Pre-event —
+++ DestBusy +++
SetFailed: party 2000.61c1fd0-641cb50:1, cause Blocked
@11:58:57.0640 [0] 8.1.103.76 distribute_event: message EventDestinationBusy
AttributeEventSequenceNumber 0000000000000140
AttributeTimeinuSecs 64000
AttributeTimeinSecs 1583303337 (11:58:57)
AttributeExtensions [23] 00 01 01 00..
‘BusinessCall’ 0
AttributeOtherDNRole 2
AttributeOtherDN ‘1001’
AttributePartyUUID ‘1CRA9MNFD101F0PK58QCJF7PFS0000FC’
AttributeThisDNRole 1
AttributeThisDN ‘2000’
AttributeDNIS ‘1001’
AttributeTransferConnID 006d02f58e6c2047
AttributeCallUUID ‘7D04KUA6UT0J7BLLFD2GLU8H3C00004C’
AttributeConnID 006d02f58e6c208c
AttributeCallID 16777356
AttributePropagatedCallType 4
AttributeCallType 4
AttributeCallState 5
11:58:57.064 Int 04544 Interaction message “EventDestinationBusy” generated
You have a missing object and therefore there is no way you get a Busy treatment
Check SIP Server guide and GVP to provide treatments
That doesn’t look like his problem itself. Just a problem to reproduce the fast busy tone indicating that the call has failed.
483 Too Many Hops might indicate a Softswitch or SBC problem or even a loop on the signaling path.
Yes hsujdik,
Also there is no sbc in this case as it is an internal call from one dn to other dn via wde.
via logs i m not clear what configuration i am missing :-\
Clean your errors and try again. Start by the basic missing objects.
